PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 [213] 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. dyno, should i be disaponited? pics
  2. 94 TA - when the car warms up, and you jump on it, it runs great. But try it again, and it falters.
  3. Stock Fuel lines. How much power they good for? *fueling issues*
  4. Suspension.. snap crackel and pops... can i get rid of it?
  5. Budget Build Questions
  6. Are my lifters bad? pics inside...
  7. which plugs???
  8. Will JB Weld work for this?
  9. What times are you 383 guys gettin
  10. Killed at wot
  11. HP gains from hotcam and bolt-ons????
  12. horsepower gain
  13. optispark dowel upside down??
  14. lt4 knock sensor for 95 TA?
  15. 1.5's or 1.6's Rockers?
  16. Main stud tourqe
  17. ABS light and some times engine light but it gos away
  18. What do you guys think of LT1 Edit
  19. Curiosity....
  20. Changing Gears (2.73 To 3.42)
  21. Black Ignition Box?? Underhood??
  22. lookin for a hood
  23. p1807 for a 97 lt1a4
  24. tci super street fighter
  25. Stock Block Rev Limit?
  26. HELP!!!!! Accel DFI Gen 7/ LT1
  27. Finally a 93-97 to 98-2002 front-end conversion tutoral
  28. Tranny question, but mated to a 396 LT4...
  29. code 16
  30. LT1 engine build up at Exotic Performance Plus
  31. best heads for LT1
  32. Cailfornia Smog Laws
  33. Can I use this True Dual setup?!COME IN!
  34. which stall converter??
  35. dont know where to connect this hose
  36. so what brans do u guys have for air foils?
  37. LT4 Hot Cam Kit vs. Crane 210/224 w/springs & rockers
  38. LT4 Hot Cam with 1.7 RR's. Valve Spring?
  39. Cc305
  40. abs light with ss led light???????
  41. Looking for forged crank advice.
  42. what hardware do i need?
  43. Best 1/4 Mile times w/Full Exhaust & Spray??
  44. Stage 8 bolt sizes HELP?
  45. HELP! High RPM ignition missfire/breaking up issue
  46. Big Solid Roller, and my heads??
  47. Wierd high rmp issue
  48. 95TA vs. 97TA
  49. Scattershield?
  50. Engine Cleaning?
  51. Abs Inop
  52. 355 buildup....?
  53. will trade.
  54. good choice?
  55. HPs #, out all motor 396?
  56. Crane 210/224 Or Lloyd Elliot 2 Cam?
  57. FUEL PRESS Gage HELP
  58. lifters...
  59. how many qurts does the lt1 take???
  60. coil conversion nightmare please help
  61. O2 Sensor and Cutout Help
  62. Lt1 elbow
  63. Where To Find Motor?
  64. Lt1 Timing Chain
  65. help or suggestions please
  66. lt1 starter issues
  67. Best Cam To Run In A 383 Stroker?
  68. im noob
  69. New pics of the WS6, finally set the ride height :)
  70. what website is this car off of?
  71. ? Gm 847CAM where to buy and how is it ????
  72. Black smoke form exhaust......
  73. Dynatech Headers
  74. Help needed with drive shaft bearing/center support!!!!
  75. BBK Vs Holley
  76. Need Help Fast!!
  77. North Charleston shops?
  78. predict times with cam and spray
  79. S&W 8 point roll bar
  80. How fast are STI's?
  81. Ok, need some help
  82. To resistor or not to resistor...I'm new
  83. Air pump for engine important/affect performance?!!?
  84. Cams / Crank etc
  85. Pic's of my new heads...
  86. is this a good deal for a 396?
  87. Fastest bolt on times,
  88. Electric Water + Opti Spark = ??QUESTIONS?? have you done one. . .?
  89. CC306 Idle Video
  90. Wider tires slower times?
  91. lt4 intake direct port fogger 4 sale
  92. Typical Oil Pressure
  93. Help w/ my LT1 CSR waterpump!!!
  94. 323Gears MAX SPEED
  95. 93 to 94 gauges
  96. Which Cam and Tune?
  97. help help
  98. Slp dual cat shortys help!!!
  99. Does this sound like a bad torque converter?
  100. Idle problems
  101. 97+ gauge cluster swap
  102. "Cadillac Cam"?
  103. Minimum cam dowel pin length?
  104. Mcleod Clutch
  105. Adjustable Master
  106. nitrous question?
  107. Ported TB or MAF???
  108. 355 or 383
  109. HELP oil lines
  110. me vs eclipse
  111. if your car wont start, start here
  112. Fans will not kick on at any temp, need help to diagnose?
  113. LT1 Exhaust
  114. Stock internal 96k+ mile LT1 goes 11.67
  115. real quick question....how much is stock fuel pressure?
  116. Help HOT
  117. Will this spring hold cc306 lift??
  118. doing rebuild! 355, 383, 396?
  119. looking for a guide for headers install
  120. looking for a guide for headers install
  121. BBK mid headers? Anyone?
  122. Which cam?? for 3.73 and 3000 stall?
  123. Help 383 Carbed In 97 Ws6
  124. 383 build questions
  125. Ignition wiring question, need help
  126. Couple install price ?'s
  127. Give me an idea of the power for these mods?
  128. 95 corvette exhaust
  129. Car will not start after rain, Opti?
  130. what times with 230/236 cc
  131. Gas Mileage improvement?
  132. Hotcam/CC305 owners, what times are you running?
  133. Thoughts on Mac cat-back
  134. How difficult to replace the "Optispark" on a 95?
  135. wanting to upgrade from lt4 intake to carb intake help
  136. LT1 to LS1 swap ??????
  137. cheap horsepower
  138. 306 cam And check these valvertrain????
  139. What Mod Next?
  140. Valve Spring/ Retainers
  141. lt1 oil pump & head gasket????
  142. Hp Estimate
  143. HPE 383 Shortblock
  144. Noisy Valvetrain
  145. Taste Test...
  146. What cam should I run
  147. Anyone running a CC503 on a 114LSA?
  148. 1990 corvette
  149. GM847 vs. cc305 for a daily driver
  150. Pacesetter Header Questions
  151. Catalytic Converters
  152. ____3000 stall how is it with 306 & 3.73??___
  153. 355 6 Speed goes 10.49 @ 130.4 NA
  154. finally got the bottle in the car and got a few pics for ya guys on my 93 LT
  155. throttle body airfoil
  156. smog pump lines were do they go
  157. LT1 with no spark at coil
  158. What is the RPM rang for CC306?
  159. starter issues
  160. Any tips/guides for cleaning the MAF?
  161. How the hell do i tell?
  162. Header/Y-Pipe Combination Question for '97
  163. Header/Y-Pipe Combination Question
  164. Cooling a high HP 383 LT1
  165. Max lift on 986-16 valve springs
  166. Muffler...
  167. 30# Ford SVO red tops
  168. lt header question?
  169. Which cam for Ported LT1 heads??
  170. what couldi get
  171. Will a clogged cat prevent a car from starting?
  172. Someone lend a hand
  173. Any HPE guys in here???? Rick???
  174. lt1 block interneals = sbc internals? yes no?
  175. Vibration from exhaust. Any help?
  176. How hard to get 400rwhp from LT4?
  177. coil wire
  178. tunning
  179. what should i expect?
  180. Recommendatons on Y-pipe
  181. header and exaust install parts?
  182. what kind of numbers should i see with this cam?
  183. Post pics of your longtubes and y-pipes please!
  184. so i raced an 05 GT...
  185. Help Needed LT4 Valves
  186. Compression
  187. Cam Question
  188. CAI Adds How Much Power?
  189. Some updated pics of my project
  190. ??recommended valve springs
  191. Mod Update
  192. almost finished my LT1 rebuild...
  193. 355" LT1 goes 9's!
  194. flow numbers on a stock lt1 head??????????
  195. Looking for 383 396 LT1 Stroker Info
  196. rough idle backfiring after motor work
  197. 1994 formula six speed for sale,$2000 firm
  198. under hood pics
  199. Best heads and cam
  200. Best heads and cam setup
  201. LT1 headers problem
  202. Carbed 383
  203. LCA's worth it?
  204. Dynaspark no longer available at DTE
  205. underdrive pulleys
  206. noise when launching
  207. zz9 cam
  208. optispark
  209. Pacesetter Mid-Tubes Question
  210. Long Tubes or Converter ???
  211. Post Cam/Valvetrain Specs
  212. LTs for a 96-97 on a 94?
  213. Weight of LT1 Motor
  214. Hotcam F/s
  215. Short or mid or long tube headers?
  216. bog issue
  217. How is the sound for Flowtech muffler????
  218. Biggest cam for daily driver??????????
  219. Shortys or Mid length headers - '97 LT1 Ram Air
  220. Anyone with the cc305
  221. lt1 questions
  222. car surging
  223. Tsp duals on LT1s
  224. Catted Y- Pipe
  225. Work in progress 56K users beware!
  226. SLP LT headers buy it or don't buy it?
  227. strokin it
  228. Recalls?
  229. Pics of the HPC coated Y-pipe
  230. What do I need for 12's?
  231. Need Help Tuning! 94 Procharged Z-28
  232. supra vs TA
  233. cam question
  234. Plans and questions
  235. 1500 - 1800 rpm Stumble
  236. Hooker Aerochamber? Or Full Hooker Catback?
  237. Pacesetter Midtubes fit with stock y-pipe?
  238. how much horse power can i expect
  239. question involving intake removal
  240. I need an Estimate from you guys
  241. Neeeeeeeeed Your Heeeeeeeeeeelp!!!!
  242. 10s on stock bottom end?
  243. LT1 ss
  244. Best Mod?
  245. LE3 LE3 <-- its the rage right?
  246. radiator overflow lines?
  247. quick: intake inlet elbow & airfoil
  248. is there a forumula for LT1s hitting 350 whp
  249. Custom Grind Cams For LT1?
  250. lt4 hot cam kit
