View Full Version : LT1-LT4 Modifications
- 95 z28 died while driving
- Fans question
- Cam question
- LT4 measurements, anyone know?
- To buy or not to buy: what would you do about this car?
- what is all of this stuff
- misfire question
- Going to look at a 97 TA today.....
- Code for Knock sensor, AIR after coolant flush
- T56 Trade
- Oil gauge
- help me pick rockers set up
- Help!! Oil Cooler
- Blow this car up!!! I have had it...
- Procharger question
- padding to wedge between y pipe and frame
- Need help finding a 1LE interior part..
- Well got my dyno #s
- Help With droping my LT1 in to my 63 Belair
- obdII to obdI conversion issues
- Single plane intakes
- New guys saying hi
- Lets see your oil breather catch can set ups!
- cam only lt1
- Can you throw off optispark timing
- Is there anything I can wrap around my wires so the headers dont melt them
- PCM fuel cut-off and supercharger - lean risk?
- Car is randomly shutting off PLEASE HELP!!!!
- Oil drain issue - quik95lt1 chime in please
- Absolute cheapest deal on LT1 pacesetter headers anywhere
- NEED HELP with some problems
- Need a cam gear compatible with the lt4 hot cam
- Code P1361 - Please help.
- what kind and length 02 extensions
- lt1 painless wiring harness
- Anybody have luck with aftermarket coil's
- what's next
- Vac ports/ plugs and pcv plugs
- AS&M Headers - where to buy dual cat Ypipe?
- im lost
- Switched to EV6 Bosch
- this %*$#* car is going to put me in the crazyhouse
- 3.4 to lt1 swap, swap dash harness?
- Bog/Misfire in closed loop
- Regular opti shoppers
- my 383 cranking compression
- need advise on buying a z28
- Ground circuit 97 trans am
- At what point is a vacuum pump needed???
- A little advice on a Vortech SC
- what will my hp be on my LT1
- What upgrade next
- Lt1 Software
- getting headers in place
- Clutch fork issue.
- Lt1 problem
- Le2 for a 383?
- T top guys need pix please
- egr air hoses
- LG motorsports coilovers
- Nothing to do with LT1 but need help
- Battery relocation engine ground location
- manfiold removal issue
- looking for a different cam
- Lt1 help!!!
- Any south Carolina guys??
- My new lt1 383 eighth mile times
- LT-1 Corvette & Caprice SS HELP
- 97 Firebird LT1 - Looking For EVAP Diagram
- 96 lt1 to ls1 swap
- Car cuts up and feels low on power
- no start
- checking bearing clearances rod/mains
- Fuel System
- lt1 question for a new mwmber
- -92 vette lt1 vs -94 trans am lt1?
- i hate parts classifieds
- obdI-obdII ?
- New engine - runs 200 degrees, higher temps at speed or in traffic
- Blow of valve VS MAF sensor
- 350 cc306 AFR PCM tuning thread
- How much damage do you guys think this is?
- Someone has got to have their air pump fittings still
- 94 z28 turning off
- stock 94 LT1 OBD1
- Induction discussion :)
- LT Custom Grind Camshafts from COMP Cams
- Lt1 M6 Safe Idle range?
- LS1 lid conversion, couple quick questions
- Procharger install manual
- Intermittent Starting Issues
- No Start After Walbro Pump Install... HELP!!!
- 96 z28 and i'm freakin stumped! help!
- Anyone know where OBX headers can be found?
- LT1 extended crank to start after a few hours of sitting, ECT?
- HELP!!! oil pump went out
- Exhaust leak or rocker noise?
- 95 z28 temperature gague does not work
- Time for heads....on a budget
- Name that sound...
- Posi is dying, what to do
- 93 T/A excessive cranking
- anyone running a ls1 4l60e
- What Next?
- Fuel Smell
- almost there woo
- Heart Attack moment
- Shops in South Carolina
- URGENT NEED HELP! Intake Manifold
- Canton 242T + Stock Dipstick
- 6LE front bumper inside PICS
- Alternator question
- Squeak at low rpms not the belt
- LS1 tranny on a LT1
- oil coolers
- Need to relocate my brake/fuel lines
- How to tune 94 PCM on 95 car/cable
- LT4 H/I or not?
- I'm fed up with this!
- LS MAF on LT1?
- how to learn how to blue print a engine?
- What All Is Needed For ABS Delete?
- corvette lt1 into 95 firebird formula
- Low Mount Power Steering???
- LT1 Parts for sale
- Hiss when I open gas cap.
- ATI super damper LT1 install ?'s
- I'm trying to make it to the shootout... (2013, lol!)
- Code 16 help
- Code 63
- where can I buy GM timing chain set???
- how many miles
- School me on two things:
- New best 60' and raceweight...lol
- New Stall, not happy, need answers
- Cooling issues, need help
- Temp guage only gets past first line.
- Anyone with 1st Gen LE Ported Trick Flow 195's???
- 96 LT1 newly installed cc503
- Whats it worth!!!!
- What head gaskets for a 383 motor?
- port heads and intake manifold
- New clutch time!
- Broke a u-joint, now RPM related vibration?
- Best 4.10 gears to buy?
- Unknown Connector, Radiator Mount Thing, Broken Hood Latch Bracket w Pics
- Few pics and Idle vids of the new build!
- Stock exhaust / catback question..
- Which is louder, loudmouth bullet or magnaflow bullet?
- M6 Idle questions
- Starter Bolts?
- Could this be my problem?? help
- over heating
- Dont know what to do with my lt1! stuck by options
- Th400 stall
- This Cam Seem Good On Stock ShortBlock?
- lt1 tune help
- where can i find the vss??
- OptiSpark Overhaul…. Help, PLEASE!!!
- LT1 randomly dies not sure what the issue is...
- Brake Line Routing
- Is the coolant pipe on back of heads necessary
- issues or am i paranoid
- what to set the lash on a solid lifter engine?
- Running Rough
- o2 sims
- ABS delete?
- what length stage 8 header bolts are you using?
- finally getting my camaro tuned and dynoed tomorrow
- OBDII Dataport Communication
- Which competition clutch is best for me?
- T400 guys here
- What timing chain set???
- Any tips to reduce drone with TDs
- advice for buying a lt1 camaro
- Did a search, but didn't get a clear answer.
- 383 is running!!!!
- Sprucing up a 150k mile LT1
- 95 impala no start
- LT1 383 valvetrain problems FIXXED THANKS EVERYONE THAT HELPED
- GM MLS header gaskets
- After rebuild startup problems??
- Exhaust Manifold Questions
- Bought a few new parts before the Shootout
- Corvette goes up in flames
- Anyone use lt1 tuning .com
- After 4 years she runs again! vid
- drag radials
- Michigan people!!!!
- LT1 Custom intake help
- Manual Pedal Assembly Question
- over the radiator intake
- HELP!! Z28 stalls
- Need advice on goodies!
- car smoking
- 96 Trans Am Restoration
- NEED help on pcm communication 96 TA lt1
- car has a slight shake at high speeds
- Trim on doors
- Spark issue on whole passenger side.
- Exhaust gasket fail
- What to do with stock LT1 cam?
- New stall, question.
- quiet exhaust system
- Injector sizes
- So whats quieter than an SLP Loudmouth?
- Tuning software for LT1
- Pulled for "Loud exhuast" in my other car.
- Stripped Head Bolt!
- 93-96 Dash Pad
- lt1 to 400 rwhp for 5k?
- magnaflow tail pipes??
- New Paint on the TA...whats your fav?
- Can you mix plugs of the same brand?
- new 94 z28
- what does your 9.5"converter slip?
- car starts but sputters
- ICM, opti or coil problems
- Bolt on/150 shot track results
- I just had to post this here, insane price for a bone stock high mileage Camaro....
- 95 lt1 firebird exhaust manifold question
- I want roller rockers on my LT1
- 6 speed locked in 1st
- Feed back on eBay low mount alternator brackets, please.
- LT1 cam swap lacks power?
- More Power
- LT4 knock module questions
- Did I miss anything? (mods)
- The head of one of my spark plugs is cracked?
- Braided power steering lines
- LT1 396 Turbo Build?
- WS6 Lower Control Arm Help
- Best nitrous piston 300+
- 88 Iroc swap no start
- HELP, car wont start
- I think i have a misfire? Please help details in thread.
- Who can give me part numbers for lt1 bearings
- Lt1 with gen1 cam questions??
- Mecum Auction
- le2 or le1
- le2 or le1
- Dead cylinder
- broken exhaust bolt AND extractor
- Turbo stalled guys. WHat size stall?
- 700r4 shifter cable adjustment?
- plug on heads (noob question)
- LT1 WISEMEN -in here plz
- LT1 swap .. advice?
- Installing X pipes over the axle
- 96 lt1 misfire. please help
