View Full Version : LT1-LT4 Modifications
- Clutch problem...
- Streetability??? Nitrous, Turbo, Blower???
- High Impedance Injectors
- Have a slight Ticking!!
- 36lb Injectors
- cold fusion
- What size injectors?
- Anybody Have Carbon Fiber Driveshaft?
- Do Cams Make Car Harder To Start?
- Help please
- Which's better? lt4 hotcam or cc305?
- Wiring tach to HEI
- 700r4 Swap
- headers for LT1s?
- Where To Get SS Long Tubes?
- Stock LT1 crank limits
- 396 cubic inch lt1 with t76
- lowering kits
- 93 camaro speedo
- cam question
- Muffler choices?
- Headers Or Nitrious
- problem with OBD2 connection wires
- MAF Sensor Question!
- No ignition
- does anyone make an Aluminum oil cap for LT1's?
- Problems, Problems, Problems....
- help on adjusting roller rockers...
- NX or TNT
- Exhaust Question Something New I Think
- Borla Y-Pipe
- LS1 intake for b-body?
- d ports...
- tune
- PaceSetter Longtubes and Loud Mouth Combo ???
- Pushrod Length - '96 LT1 B-Body
- Question about true dual exhaust???
- Need copy of Diacom Plus Software
- LT1 to LT4!
- To coat or not to coat...
- throttle cable
- Spark knock
- New headers
- What kind of gains could I expect to see from this cam on my LT1?
- Probably Old News... but...
- how to polish fuel rails and MAF ends
- What do you guys think of these??
- My first question
- Where can I purchase new Pacesetter?
- Morso or Homemade
- 99 SS 6sp stock alum D.S. into 95Z28?
- will stock lt1 injectors fit a 98 v6
- Any Turbo Kits Other Than STS???
- O2 problems
- Gen 6 Dfi
- best starting mods?
- cats
- Need Nitrous Kit for LT1 Carburetor
- Need suitable Crank
- anyone know the problem here?
- How Do You Bypass The Throttle Body??
- Anybody Running 1.7 RR or Higher???
- Shift cable
- 93 IAC Valve
- opti again??!
- 95 auto vert T/A?? worth modding??
- Putting heads and Intake on?
- cam help
- Need Help identifying something
- LT1 ScanMaster.
- cheap stroker question
- will 03-04 cobra injectors fit my lt1??
- Help me run 12's!!!
- backfires
- LT1 catback exhaust question 3in vs.4in
- Problems at WOT.
- quick LT1 gearing ?
- Headers
- LT4 bare casting
- These Vavle covers
- Replace opti when doing an Electric WP?
- 3 valve heads for LT1
- Getting rid of Opti?
- Why Kooks are the BEST headers - EVER! Let me tell ya why!
- cc-306 and nitrous
- Anybody running this exhaust setup???
- Edelbrock and trickflow lt1 heads?
- 4.10's MPGs
- EGR and AIR, A/C removal
- need to modify injector wire lengths?
- nitrous timing question
- Hotckis or Eibach springs for LT1?
- Pulled Code P0372
- need casting number
- CC-306 Cam Questions.
- Removing Electronic Smog Pump
- Stepped header question
- will any 4 bolt splayed cap for 350 fit LT1s?
- Thunders Ported LT1 TB ?
- Headers
- need a part number
- Which headers to go with?
- will 94-95 headers fit 93
- Engine oil cooler question
- 1993 LT1s; What makes them different...
- Where should I look for new Stroker Kits?
- Think I should Get a TB
- Need fuel specs for LT1
- weight reduction for LT1!!??
- LT1 Rotating Assembly
- LT1 Exploded View
- Are these good times???
- Rant about my LT1
- Need headers?
- x-pipe good or bad...?
- flashing the ecm
- Need help getting catback mated to shorties
- 383 shortblock and LE2 package for sale
- le1 head cam package
- most power from blower LT1?
- A.I.R Diverter Tubes / EGR removal?
- Lloyd Elliots Le1 and Le2 cam and head packages
- Hypertech
- EGR plates... do I NEED them??
- LT4 rev limit?
- After Exhaust and Intake What Next???
- 2.02 1.60 head question
- ULTRA-Z Hood & Airbox
- LE2 Sound Clips
- Looking to make a forged bottom end...
- where to get a good custom grind cam
- DynaSpark
- LS1 lid on LT1?
- lt1 -ls1 coil per cylinder conversion
- dual exhaust question
- new 383 pictures inside
- Weird start-up problems.
- Knock Module
- Induction hum...
- Procharger +503 Cam
- aftermarket elbows?
- weight reduction
- WTF is up with my TB?
- new best this weekend at hub city in miss.
- fastest times on hotcam
- OBD1 Conversion
- coil convert vs. old style distributor
- Pulled the AIR system....
- A little Upgrade
- Lloyd Elliots LE3 on 350 w/ stock bottom end?
- lt1 problem
- Looking for catted y-pipe pictures
- Need Help With my LT1 Wont RUN!!!!
- Finally Ran full 1/4!! (hotcam, ported heads)
- heads and cam lt1, 420rwhp??
- Connecting rods?
- 95 z28 4500$?
- few lt1 mod questions
- Electronic Cutout
- Major Change In Build!!!
- Nitrous question
- GM847 cam?
- Why OBD I??
- SBC EFI style intake on LT1?
- Rebuilding Non-vented OptiSpark
- Calculating Compression Ratio
- Oversized Valve Benefits?
- Ignition box?
- Best exhaust, You tell me!
- 93/94 vs other years' LT1s?
- Engine noise
- All motor LT1/LT4 dyno numbers?
- '96 Formula
- what to do first?
- Stock Rear with Girdle???
- Going With TH-400
- the LT1 block is no longer being made?
- Best Supercharger Kit
- I need a bin file
- 383 Stroker
- Crap
- Mac mids vs JBA shorties & tune question
- which tuner do i use
- repair sleeve
- Lt1 bottom-end
- Edelbrock Heads
- NOS 5176 tips/trick/pics
- air leak somewhere...
- Would this Intake work?
- YOUR LT1 Nitrous install pics?
- hooker cat back exhaust clips
- Need Help ASAP
- Valeo, Exedy, or Ram clutch?
- Nitrous
- LT4 Knock Module
- Raising the engine?
- Small problem with TB
- ram hdx clutch for LT1
- good handheld tool for LT1's
- The best heads
- How Much Horsepower Should I See???
- Cutting out water trap in Ram-Air hood. Is it safe to run a straight through ram air?
- going carbed
- Surge + Check engine light
- Contemplating Selling My 94 Formula Because Of 10 Bolt...
- What belt with ASP underdrive and overdrive?
- Sts Kit Need Tune And Cam
- GMMG Exhaust
- Cam question
- Need an Opti
- Is it worth it to ditch SLPs for longtubes?
- You F-body guys get to be jealous. Well for the time being.
- Lt4 Cam Or What?
- Dual Cat Y-pipe for LTs
- 383 or 396?
- Idle question
- Bye Bye 6-spd
- where to get parts?
- horsepower
- Banjo bolts
- Looking for LT's with good ground clearence.
- Stumbling problem
- gears & trans?
- Exhaust That Sounds Like Muscle Car???
- 3.42s to 4.10s
- What should I do to my Mac headers once i get them?
- Best tuner around?
- 3500 Stall on an OBD1
- universal plug wires set?
- Pics of true duals
- Heads and Cam, Need Help!
- which rockers are best
- Valve opinions
- What Should I Do??
- LTs, KM, & False Knock?
- I need a new clutch durable enuf for 450 ft lbs?
- Turbo cam for LT1
- Shops that build 383 short blocks
- 383 and 396 numbers
- hotter or colder plug?
- Engine sensor fuse???
- help with spark arc
- vavle cover breather
- Why is the Lingenfelter SuperTube so cheap?
- gauge installation?
- Cam Question....
- Pacesetter Headers on LT1
- SLP Y-Pipe
- speedometer question?
- Who has the best bang for the buck headers
