PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. Lt1 Revving On Its Own....
  2. y pipe question
  3. whats the best approach?
  4. Quick question about intake porting
  5. What kinda of hp u guys think??
  6. Born to go fast
  7. small problem
  8. Oil on Optispark
  9. Low Coolant light after high rpm
  10. Intake Manifold??
  11. Let Me Introduce Myself
  12. BRE Cam
  13. cam install & degree
  14. power + clutch = $$$$
  15. Question about TCS and the SJM Hurst Style ABS Delete w/ Line Lock
  16. 93 opti replacement?
  17. is this suspension ok for daily driver
  18. Help changing timing cover gaskets!
  19. 24lb injectors
  20. spark plugs? advise please.
  21. 375hp? +/-
  22. Fuel Pressure Regulator Vacuum?
  23. Torqued studs down on heads. A few studs show more threads, should I.......
  24. Gaskets
  25. Gen 1 SBC guys inside
  26. Any one used or heard of this stall ???
  27. Gears installed Dallas Tx area???
  28. Horrible vibration
  29. camaro z28 fans
  30. Convertor size for a Stock LT1 with a 373
  31. lt1pcmtuning.com
  32. Coolant in oil...
  33. Isky adjustable pushrod guide plates
  34. Which Cloyes timing set for LT1
  35. 1.7 rockers on stock cam lift?
  36. k-member???
  37. Golen Heads
  38. Keep My Magnaflow Tips (And Polish Them) or Get Corsa Clones?
  39. Gears, Cam, & Stall???
  40. Idle vid just because!
  41. hooker super comps
  42. tune and steering wheels
  43. winter mods
  44. code p0141 and code p0300 thrown together what does it mean??
  45. modifying a injector rail for 900hp
  46. water pump Question on instalation
  47. Replacing Foglight
  48. Trick Flow LT1 Heads for sale
  49. part number for scorpion 1.6 7/16 stud rockers
  50. Aftermarket Pulley and Damper?
  51. Removing ABS system
  52. PCM Question
  53. LT1 Tuner in Orange County, CA
  54. Stock LS lifters vs LT1 lifters
  55. datalog with a/f readings
  56. Jegs Crank Hub #555-51607 replacement?
  57. Lt1 not running correctly
  58. fuel pump questions
  59. Code p0227 throttle pedal position sensor, help!!
  60. block drain plugs
  61. looking for this LT1 intake,anyone got one?
  62. Stock LT1 Times
  63. Lawhead's 355 Build
  64. Procomp H-beams?
  65. Cold start, won't hold steady idle, stalls at stops.
  66. Hotcam has mild surge when taking off, how to fix it??
  67. Roadmaster w/ LT1 having ignition issues
  68. I ordered my tune!!!!
  69. opti-spark for 93 or 94
  70. Noob Question - Removing PCM
  71. Cheap opti?
  72. Rear end gears
  73. Hooker headers question
  74. Whole new exhaust set up question
  75. What sensor is this??? pics inside
  76. cat question
  77. Skeptical about water pump? help!!!!!
  78. lt4 heads
  79. where are the ls1's?
  80. P0443, P1657, possible bad PCM
  81. opti/throttle body advice
  82. Popping/back firing
  83. Give me a goal for my build. What ET to shoot for?
  84. NEED 2 CATS in any condition!
  85. Opti problems
  86. ABS Light Flashing
  87. STARTING ALL OVER WITH A LT1 BLOCK.. WHAT 1st?
  88. header gasket
  89. Are Lt1 head bolts Tty
  90. Removing LT1 with Tranny attached
  91. Major help needed, greatly appreciated
  92. 52mm Throttle Body Help....
  93. Post your LS1 lid swap!
  94. Optispark keeps going out
  95. oil pump gasket??
  96. good mufflers
  97. Which 1.6 Roller rockers do you guys recommend?
  98. RPMs with stock short block
  99. LT1 timing control question
  100. Anyone got a used Cam for lt1?
  101. Draks 94z camaro build thread
  102. LT1 Setup help...
  103. Running rough? Opti? maybe?
  104. A fluff and buff gone wild.
  105. What is a safe Rev Limiter Setting 4 me?
  106. all boltons need cam help.
  107. Those with Stage 8 locking header bolts and LT's
  108. If i were to cutt out the screen inside my maf sensor?
  109. No thermostat, no problem???
  110. MIG or TIG guide plates
  111. Oil and trans temp gauge
  112. how far have you pushed the stock suspension?
  113. Going from cam only to H/C/I and have questions
  114. Clunking sound when I lightly push the brakes in
  115. How do you adjust e-brake
  116. Walbro pump failing? Or pressure regulator?
  117. Murdered out Formula... MAKING THE CHANGE!!! Part 2
  118. Clutch problems
  119. longtubes and slp powerflo
  120. Fuel gauge fluxuates
  121. Quick question
  122. BMR LT1 K-Member help??
  123. Bad Misfire. Help please.
  124. Losing Lots of Coolant
  125. PCM problems
  126. identifying injectors
  127. Critique this setup for me
  128. Engine removal and cam question.
  129. 3 inch under the axle TD build thread
  130. Tuner cats vs Tunerpro
  131. LT1 swap/gbody
  132. So I can stop an argument me and pops are having
  133. MSD 6AL Digital?
  134. post pictures of your rims please i cant find good pix on google
  135. Need help looking for temperature switch connector
  136. Coolant crossover tube/steam pipe
  137. Valve Job options
  138. Dynatech header installation help!
  139. cam recommendations??
  140. Procharger on stock LT-1 bottom end?
  141. Brake booster removal help....
  142. Gm heater hose part number?
  143. Odd 93 PCM issue. Help appreciated.
  144. 100 Shot '93 z28
  145. Wanting to move at Idle?
  146. lt1 issues
  147. possible to use the crab cap dist?
  148. A3 Guys Come on in!
  149. What does this ground go to?
  150. no start, cranking w spark and fuel
  151. suspension mod best bang for the buck.
  152. Engine Oil Cooler Removal?
  153. pass power window broken?!
  154. custom intakes?
  155. problems after header install please help
  156. Finding a Y pipe to go with my headers and catback
  157. Steam Pipe
  158. Pushrods
  159. can removal of air system cause car to run horrible
  160. Compression for pump gas
  161. cc306 vs Lingenfelter 219/219 with ported heads/stock shortblock
  162. Best Mail Order LT1 Tune
  163. soft glow
  164. Whats the best way to adjust my shift points?
  165. Question on mph with different gears.
  166. Would it be okay to tow with LT1's?
  167. Quicktime blow proof GP!
  168. Porting header flanges?
  169. Who has or had an LT4 Hotcam?
  170. Is anyone using the vortech g-trim?
  171. lt1headers
  172. Tuner Cat and ECU Questions
  173. Anyone use these headers ?
  174. title issues
  175. 2nd time to the track, still disappointed, still knocking
  176. Blipped 7k on the tach
  177. Picked up a used short block, what to look for before assembling?
  178. Tranny fork problems,help please?
  179. Pacesetter LT + ORYP + Borla catback
  180. What causes this?
  181. 4l60e to 350 turbo
  182. Msd 6420 on 1997 TA
  183. need help
  184. T56 wont shift
  185. Lt1 Issue
  186. Well its officially gone...
  187. ***Blackbird Lighting Solutions (BLS) 93-97 Firebird Proj. Headlight Retro GP 2011***
  188. Clutch Bolt Issues
  189. BMR K member & Pacesetter = WTF?
  190. Look!!!!!!!!!!!!
  191. debating a switch
  192. Torque spec for engine mount through bolts?
  193. ebay headers.
  194. Will the panhard bar off a 2002 fit a 1993 TA
  195. lt1 performance
  196. 10 Pt. Roll Cage people in here please.....
  197. 2 in 1: Tune Question, & Temperature Question??
  198. Street/Strip suspension
  199. intake porting< what do i do
  200. New engne build. Let me know what you think...
  201. water pump died, gota few questions
  202. HVAC/Heater box
  203. Still having oil pressure problems
  204. Question about driveability?
  205. Question?
  206. After Intake Gasket car won't start
  207. 97 30th aniv. z28 gears
  208. who wants to help me figure this car out.
  209. lt1 overheating
  210. Installation of Crank Hub
  211. intake and heads years mismatch?
  212. How important is suspension!!!!!
  213. ?are 9.50s realistic thru lt4 heads an intake..
  214. looking to sell/pricing
  215. Obd2 crank sensor location
  216. Best front brake upgrade for road racing
  217. dyno
  218. Is the VATS chip in a GM key universal?
  219. Disappointed With Car's Performance
  220. 60 Foot times (Full bolt on/ Full suspension)
  221. Front Bumper Cover
  222. 1997 Camaro Fuel Pump
  223. ACs single digit build thread!
  224. WS6 airbox/MAF question
  225. poly lock part# help?
  226. Retained Accessory Power
  227. Went through my first tank of gas.....the fawk?!
  228. Facts or opinions about SA Rockers and guide plates
  229. Idles high for 15 second every time i put it in neutral. help?
  230. cc306 on stock bottom end?
  231. CERBERUS; A Daily Driven 97 SS Rescue Project
  232. 94z almost road worthy
  233. Question!!!!!
  234. Starter cracked?!
  235. New Opti, Car Dies P0372??
  236. how to change power steering pump
  237. Possibly a bad opti spark or igniton?
  238. obd1 question
  239. header gasket question???
  240. idle problem
  241. D body cam vs. Fbody cam
  242. LT1 Stall Question
  243. Dear Ed Wright
  244. High idle and rough startup.
  245. Umm broke something is it important?
  246. Question!
  247. Bore stock throttle body
  248. I just got it
  249. Need help with next mod!
  250. adjusting pinion angle
