View Full Version : LT1-LT4 Modifications
- Need help with Opti/code problem
- lt1 setup for 500 rwhp?
- WTF, no power
- Please help with a miss!!
- Header Maintenance?
- problem with headers?
- Kooks Or Pacesetter
- Removing the air pump question??
- Pacesetter LTs
- why isn't there an LSx-style head available for LT1s?
- b-body ecm for my obd1 conversion?
- Guide to Header Install?
- Lt1 Whipple Supercharger?
- ??cam for a 94 z?? anybody chime in on their knowledge any appreciated !!!
- 355ci Rebuild?
- What is gained going to electric waterpump on LT1?
- Need Help!
- Egr removal on stock cam
- Volant CAI
- difference loudmoulth, loudmoulth2
- Upper rpm help
- lt1 mileage?
- True Duals H-pipe, muffler
- just ordered heads
- Cam?
- BMR T56 Torque arm relocation mount pics!
- Lt1 Pulley Choice?
- Next Step? LT1 Mods?
- OptiSpark Install Question
- Making an old 12-bolt fit on my lt1
- Cam question
- Nitrous - would it be safe to run a 75 or 100 shot?
- LT1 broken pushrods
- what size injectors for heads/cam setup?
- Getting Headers. Cat-back question
- Suddenly car not running right but not throwing any codes
- Roller Rocker 1.6?
- 2 fuel pumps better than 1?
- What are full bolt ons
- LT1 exhaust is too loud, suggestions?
- cams
- Importance of Dyno Tuning?
- bad mileage: Datamaster file
- cost to swap out an LT1 motor? what else to check on car that hasn't been running?
- Harmonic balancer marking and adjusting valves
- car not running right
- 3.4 to Lt1 conversion in a 94
- what's so special about the hotcam?
- little hesitation
- Converter and Gears affect Tranny?
- PLUGS n WIRES
- broken lid. can I just buy the top part? will an ls1 lid fit an lt1?
- what is blowin apart my optisparks, and what snapped my wp drive shaft?
- pcm reprogramming
- ed wright computer?
- Intake elbow cleaning?
- Here Comes the BRUTL TA
- What Size Injectors?
- blower or stroker
- 383 Injectors?
- fastest LT1 Records?
- speed governor on 94 formula
- pulling my a.i.r.
- How are you running your optis with an adjustable timing chain?!
- The inside of a 150,000 Mile Opti :)
- taking out the LT1
- Stock timing chain with a CC306?
- A couple of pics of the WS6 motor
- where to by xe503
- i need a good cam & heads package
- Where to buy MAC Mid length headers?
- What is the best method for setting roller rockers?
- LT4 Intake question
- Headers
- Help me figure this dyno sheet out please
- LT4 KMs
- can a motor with a cam this big be tuned using a gm pcm? (Ed Wright?)
- hotcam kit
- 01 Camaro SS test drive (comparison to LT1)
- oil pressure problem!
- modding questions
- Elbow Sensor
- Running lean in closed loop
- LT Header confusion
- BLOCK machine?!
- Has Anyone Converted LT1 Gas Tank to an LS1 Plastic Gas Tank?
- another how much hp thread, dont come in and say you dont like these threads
- Old School heads on a LT1
- Speedometer does not respond to any ratio changes in editor. PLEASE HELP ME!
- LS1-LT1.com Sucks
- LE2 Package... where does it like to shift?
- MAF Tuner
- how much nitrous?
- Removed A/C condensor, looking for shortened radiator shroud.
- possible buying S/C lt1
- LT1 throwing 3 codes please help
- Aftermarket Radiator Cover?
- fel pro head gasket??
- spark plugs to use with supercharger?
- Dropped motor out the bottom...
- removing engine need help quick
- thinking of calling loyd elliott
- TSP Rumbler X on an LT1
- how much gain with LT4 conversion kit??
- K&N Filter Kit advice?
- Blew Head Gasket
- hp, 1/4mi est.
- Where can I get cheap suspension parts.
- Hotcam vs CC305 vs XE503 vs gm846
- Can I use 5.7" Connecting Rods on a 383?
- stripped head bolt
- Random SES light?
- LT1 problems
- Plug wires question
- would LT1 starter fit on an iroc-z? and what is best cam for LT1 with stock heads?
- LT4 hotcam kit
- LT4 Km necessary?
- jet stage 2 module
- emission legal headers?
- ported or lt4 heads?
- european exhaust...
- Exhuast Install?
- F/s
- Pistons
- Wanting to put a solid cam in my lt-1...
- help pick my heads!!!
- What Pistons To Use
- Need k-member help
- Bad Fuel Injectors??
- 4.10s on the A4 LT1...
- TPS Volts
- What is the best way to launch with a 6 speed
- good converter for the street?
- Pacesetter Coating Questions
- 4.10 VS 4.11 Whats the deal here???
- Am I screwed?
- instructions on egr/air delete??
- Looking for a good electric cutout.
- stroked LT1 with hotcam, computer question
- Coated or uncoated?
- 306CC,30 # SVO injectors,BBK/Edelbrock TB
- where can i get an lt4 knock module?
- exhaust video
- Valvesprings/Revs
- Nitrous Nitrous Nitrous
- Please help me choose a converter...
- What you guys think of this?
- steam pipe question
- Can anyone tell me what this sound is...?
- major hesitation at part throttle
- Backfire?!?!
- GMMG exhaust
- does msd box replace optispark??
- LT1 engine sound library
- Should I be concerned?
- Spec clutch problems?; also running lean and having misfires
- cam bolt on Qs
- Valve Springs Only install
- beginning mods... what areas to target??
- Tuning Software?
- Time for a new fuel pump
- side exhuast
- More Oil cooler questions
- First post! Critique my LT1 build plans
- Hotcammed LT1 smokes my TR230 cammed 02 TA!
- Who keeps ported LT1 heads in stock?
- Stupid 1LE elbow and airfoil! Please help!
- High RPM breakup
- Need to verify pigtail PN
- MSD Question
- how hard to install progressive nitrous controller
- GM LT4 HotCam
- hows the lt1 on gas??
- Ok, need some header advice & info....
- Should I get these?
- Need help with swap issues
- HELP Lt1 Fast Idling
- just bought a 30th anniversary 97 Z!!
- '93 LT Headers w/Emmisions.
- 383 stroker
- Recommended Mods?
- Looking for Stock engine info.
- 195cc AFR Heads
- StreeT Heads
- What main and rod bearings do you like for rebuilds?
- LT1 Engine torque procedure?
- my car is kinda spitting flames
- hypertech power programmer-lt1
- BBK throttle body
- Question for Guys/Gals Running 396s?
- Solid motor mounts
- Need help car running bad and rich
- Hypertech Thermostat
- Ory?
- Check out our '95 Formula project car.
- shooting for 10.90s
- Dowel pin removal from camshaft.
- Are after market cams interchangeable in OBD1 and OBD2
- Cam Install
- How do you remove LT1 Balancer Hub???
- Are these mid length?
- headers
- Dyno results from my LT1/T56 RX-7
- How much gained?
- $4 grand to spend... hmm
- waterpump drive leak???
- Dropping an LT1
- le2
- good mods, less power??
- my car is stumbling during part throttle conditions
- My dyno sheet
- Fan Switch Mod
- MAf installed backward cause problems?
- LT1's happy with 89 octane gas?
- lt1 i need help
- I Need Tuning advice please
- Cam pin switch 94 to 97 Z28
- lt1 to lt4 conversion
- What headers should I get?
- my project is choking, and i dyno friday. HELP!
- first day at the track this friday
- Help timming loss!
- back from kuwait ignition problems still an issue
- planning on modding...
- Header Question
- Help, Need Opti-spark!
- Complete Engine Wiring Harness
- Turbo Headers?
- Drilling hole for shifter cable, what size?
- Injector size?
- I need bleeder screws!
- how much power?
- O2 sensor help
- LT1 newbie a few q's
- Headers on a LT1
- need vids and pics of just lt-1
- anyone build a set of headers for a 95 camaro!!!
- LT engine cover.
- AIR and EGR block offs?
- Joe O. cam, what kind of springs?
- Anyone have pics of true duels on LT1's
- What are some good LT1 based websites and good LT1 product companies websites?
- What determines 4l60 lockup mph
- Buy or not buy?
- Stock Exhaust
- tranny problem
- Correcting speedo after gear change
- Need help finding a special bolt, Help me out everyone
- Hooking up a scan master on an OBD II connector.
- what to do
