PDA
View Full Version : LT1-LT4 Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 [21] 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235
  1. Removing PCV Valve Made Car Die??????
  2. Best performance for the money
  3. How to register in VA and make it legal enough
  4. LT1 Intake Manifold PN
  5. Best fitting headers?
  6. 514HP/506TQ NA LTx. What will it do with boost?
  7. slicks
  8. Kooks stepped 1 7/8's or 1 3/4
  9. New Eagle rods
  10. Suspension?
  11. Porting LT1 heads Advise
  12. 1996 lt1 data logging
  13. Bigger injector needed for mild cam change?
  14. help me guide him correctly
  15. LT1 Cam Swap Tear Down
  16. Moroso 20185 Pan & Pickup For sale
  17. Power steering pump help
  18. caprice motor on firebird who has done it?
  19. high speed vibration
  20. Front framerail area, what is this....
  21. Need Advice on Transmission
  22. My other baby came home finally.
  23. Milling LT1 Heads
  24. What's the difference between caprice lt1 and firebird lt1
  25. Is my opti dying??
  26. camshaft??
  27. Starting LT1 without WP or Drive belt.
  28. Opinions on this LE custom grind for a stock head ltx
  29. Rear end question for a '96 Trans Am
  30. Which converter for my CC503
  31. LS1 Engine Harness to LT1 Body Harness, anyone still do it?
  32. 3.73, 3.90, or 4.10
  33. LTCC/6speed/2step/N20 Wiring
  34. Water pump was leaking, anything to check for on the opti?
  35. Torsen Rearend Whining?
  36. How much hp will Headers+Catback+CAI+3.73s+Tune??
  37. Convert to vented Opti?
  38. LT1 Acceleration problems
  39. Info.. What is my SC worth?
  40. Best years for tuning and mild mods. 93-97 LT motor and 98-02 LS
  41. Spark Plugs.
  42. 4l60 redlines when i use nitrous
  43. misfire or lugging or..?
  44. Optispark seal wont go in
  45. LT1 Build
  46. What's this lt1 worth?
  47. MLS head gasket questions
  48. Lt1 odd behavior
  49. MSD Ignition Upgrade
  50. Hard start after sitting 2days?
  51. Kooks Longtube Headers?
  52. LT1 with Coil Pack conversion
  53. LT4 Camshaft??
  54. BP Automotive Thanksgiving Season Sale! 15% Off Every Online Order! Free Shipping!
  55. Selling my 383"
  56. Ati 4400 stall. Streetability???
  57. 1/4 Time with LE1 Heads?
  58. Need some urgent help fellows...need inspection!
  59. LT1 w/ LS PCM - P0106 and P1336
  60. Need help with injectors
  61. '95 Caprice 9C1, LT1, new opti, water pump & MAF still won't run
  62. Louisiana LT1 Engine (including tuning) & Transmission Work
  63. Whats wrong with my car?
  64. nitrous jetting
  65. Engine idiot needing some help.
  66. Looky what I just dragged out the field !!
  67. Anyone install a Walbro E85 430/450lph pump?
  68. loss of power
  69. vacuum line help??
  70. MAF Malfunction on a '96 Trans Am
  71. LT1 OBD2 Tuning Software
  72. Leaky seals
  73. Oil in Alderaan places.
  74. 95 TA won't start...Help Please
  75. Muffler comparisons.
  76. starting issues with lt1 after rear main seal replacement
  77. Need TEA head flow numbers
  78. LT1 ticking.
  79. no power
  80. Do I have the fastest N/A cc306 car 11.35 @ 121 mph
  81. P0400 code, EGR pressure sensor?
  82. Burning Oil of a Trans Am
  83. corvette acc bracket work in camaro?
  84. Need info asap pleaseeeee someone..
  85. lt1 porting
  86. Which head gasket do I need to lower compression
  87. Traction Control Module Removal LT1
  88. New to the site
  89. No start issue please advise
  90. I'm in the wrong section!
  91. High HP LT1 T56 clutch
  92. high idle
  93. Needles on dash not keeping up with speed tach
  94. throttle body upgrade
  95. HELP PLEASE 1994 z28 lt1automatic no injector pulse
  96. High idle
  97. Seals are STUCK!!!
  98. Lunati cam choice for my LT1
  99. timing at wot
  100. New water pump drive seal
  101. OptiSpark - Adding Vent Lines with Vented Cap
  102. where to get ford 36lb blue top injectors
  103. just replaced clutch. now no pedal?? help!
  104. Bought a 96 LT1 about a month ago take a look
  105. Lunati Bootlegger
  106. nitrous 60 foot questin
  107. 96 Camaro Z28
  108. Trying to remember the name of a company...
  109. Optispark help!
  110. Headliner dropping?
  111. Dashcommand APP for 96-97 LT1
  112. LT Intake gurus....casting # list
  113. Top Speed of a Firebird Trans Am
  114. who would win?
  115. u-joints
  116. To Cam or Cam not?
  117. Fouling plugs constantly.
  118. LT1 Build Updates
  119. Small Leak?
  120. Stock LT1 Long block quench height
  121. Firebird Trans Am vs Challenger SRT-8
  122. Quick question...O2 sensor...I think?
  123. Piston head volume on stock 95 lt1 f-body.?
  124. lt1 burning oil!
  125. Still having fun with my LT1
  126. Reviving a 94 formula
  127. 93 Z28 dies and then starts back up
  128. How much HP should i have with these mods
  129. need help on high compression lt1 build
  130. plug sizes
  131. Couple questions for the supercharged peeps
  132. Coolant Temp Sensor Problem
  133. lt1 parts
  134. HELP ME my brakes squeal when I turn
  135. Stop Replacing Opti's!!!!
  136. wrong radiator?
  137. Frostbite is being reborn again
  138. PCMForless Tune Questions
  139. Heater core replaced in 3hrs
  140. More Horsepower for a '96 Trans Am
  141. Need Optispark/Ignition advice
  142. Stalling Issue
  143. Engine stalls after closing throttle fast
  144. 1995 comaro z28
  145. Dropping in the New 383
  146. Draining antifreeze with shop vac
  147. Power Steering Leak for a '96 Trans Am
  148. Nitrous 398 lt1 pb
  149. Best coils for 24x conversion
  150. Cc503 cam
  151. MagnaTronX Install and Field Testing
  152. I need a part #
  153. Winter storage issue
  154. Very Confused RPO Codes
  155. BMR guys with relocated TA mount
  156. Guide plates
  157. Heater hose mod with bilsteins
  158. Wishful thinking?
  159. Fuel Rail..quick question.
  160. LT4 Knock Module
  161. 94-95 LT1 Mid Tube Header question
  162. Fitting mis-matched lug pattern
  163. lt1 exhaust question
  164. Readings from Denso O2s sensors
  165. injector question and tuning
  166. injector question and tuning
  167. new best cc306 track times.
  168. Long tube install
  169. 93 Trans Am times
  170. True dual fabrication
  171. LT4 intake on older 4bolt main 350
  172. 94 Car with 95(?) Transmission
  173. Some opti troubles any help appreciated
  174. eBay headers, what y-pipe?
  175. 94 camaro lt1 no start
  176. 355 cfm ported and polished LT1 intake/TB
  177. Physical location of aldl port
  178. Lt1 data logging
  179. Any LT1 turbo guys out there? Have a question...
  180. LT1 to LSX 376 swap
  181. Lt1 starting issue
  182. idles too fast randomly
  183. 95 Z/28 no crank no start(Solved)
  184. 95 z28 spit and sputter problem
  185. Project: shut my car up and fix the crappy merge
  186. 24x fuel question
  187. Starting Problem (With Video)
  188. NOS + Turbo
  189. plz help need anwser quickly
  190. did 95 formula come with 7.5 or 7.625 axle.?
  191. My new 96 z28
  192. Rebuild
  193. Lt1 sputter at 3k
  194. rear housing
  195. IAT reset 95 formula/auto
  196. bigger injectors
  197. Outlaw Vid from 2014 LTX Shootout
  198. Bad Alternator?
  199. spark plug wire quesitons
  200. LT1 Harness
  201. WS6 Ram Air box issue
  202. ported heads and le cam opinions
  203. 94 camaro igntion related problem?
  204. LS1 steering rack and shaft on LT1
  205. Low coolant light sensor
  206. Strongest gears for stock rearend? ??
  207. Ideas on a LT1 crate motor?
  208. Question: LT1 MAP sensor 1, 2 or 3 bar?
  209. need help on the newer 97 lt1 mods
  210. 1995 B4C Camaro Build
  211. help car not turining on!!!!!
  212. need help with vats
  213. Unhooking battery effect tune?
  214. strange noise all of sudden
  215. Cracked windsheild!!!
  216. no injector pulse with a noid light
  217. Need members expertise!
  218. 96 lt1 crank hub
  219. Help identifying SS hood
  220. lt1 fuel injection to carb
  221. wtb camaro parts
  222. LT1 wiring harness question help needed
  223. Lt1 383 air intake
  224. knocking noise with video and data
  225. Whistle Noise
  226. High knock count on startup
  227. 95 lt1 timing cover for sale.
  228. 97 LT1 WS6 quick power additions
  229. Stock coolant overflow tank????
  230. engine noise
  231. What gauges would you install
  232. Headers? Yes or No?
  233. PCV and valve cover breather questions
  234. iac reset 95 formula
  235. 1997 LT1 - Troubleshooting
  236. Plug Wires
  237. LT1 Harness
  238. Header flange bolt holes?
  239. 396ci Forged LT1
  240. Should I do the 24x conversion? What setup should I go with?
  241. 95 lt1 build up
  242. how much?
  243. Need Honest Opinions on What My Car Is Worth
  244. zero reliability - then I found this in the PCM...
  245. Need Motivation..
  246. Need a datamaster log read & diagnosis help
  247. 1995 formula idle problems
  248. Aeromotive 13106 install question- fuel return line connection
  249. lt1 idling problem. Need help!
  250. Need new 95 lt1 timing chain cover
