View Full Version : Forced Induction
- Help!! Please
- Spraying e85 through a meth injection kit
- Using E85 and Methanol Injection?
- LS6 vs. GT2-3 or similar custom grind on D1SC 347 w/ heads
- Couple pics of Turbo Car!
- Need intercooler tubing or header tubing? We can mandrel bend you whatever you need.
- Twin GT42 LSX T/A
- help with overheating
- 2007 C6 Vert
- Going FI
- S91 408 T/A....dyno on low boost and pump gas
- What belt length with PTK turbo kit?
- where would I get compression clamps for exhaust?
- pics of ATI race valve installed
- First drive D1sc Video
- Is this a gt47-88???
- what size motor for f1r
- APS twin turbo what size of engine to get?
- Ignition system for Procharged ls1
- Building a block for FI
- What would happen ?
- 10's on stock heads/cam/intake/tb
- Wanted advice on potential vortech buy *Pic*
- Nitrous intercooler spray
- what size is a t3 turbo?
- Does running E85 affect turbo sizing?
- Stock block + 13psi + 7250rpm = (pics)
- whose main studdin?? and TB flange..
- Cam and Pulley ideas
- APS TT GTO vs Modded GSXR 1000
- Congrats MIGHTYMOUSE!
- Home made meth kit
- Procharger F1 Head unit?
- Wastegate for a T88
- Thick Cometic head gaskets for SC FI
- Going from Juice to Boost......help
- Good Cam For Turbo'd 408
- Semi Results
- I just bought a Procharger!!!!
- Going Fast...
- Paging EPP f1a install help
- ECS Paxton Novi 2000 Stock Bottom end 9.8 @ 139 Mph
- -10 to 3/8 good enough for return?
- My F1A/402 Setup
- remote turbo...wastegate feed
- new LPE 2 step
- Lifted the heads on the Dyno
- another aps tt
- BOV going bad?
- i represented for the FI LS1 crew
- SDCE ProFlosurge valve
- 408 + stock 317's
- FI stuff for sale
- 434" Buildup
- What would my car be worth?
- Turbocharged question!!!!!!
- Cheapest place to buy tial products??
- Which cam for a vortech blower?
- STS guys, get in hurrr.
- Procharger?
- Help with an F-1
- turbo drain ?
- any turbo guys had any problems with exaust lifters?
- P1SC pulley sizing and boost?
- Tial 44mm Wategate Q
- Pinning balancer
- best heads for boost
- Procharger Help.....
- Stock heads VS Ported heads
- Truck Manifold Twin Turbo New #'s
- Flipped GTO manifolds on an F-body
- CAM Recommendations for D1SC Procharger
- New motor setup for STS car
- Will these turbos work for me
- Custom rear mount turbo?
- Little compressor mapping script
- Big single turbo + 481ci
- whipple model for mid 90s vortec trucks?
- 618/643 aps tt @ 10 psi
- Pinning balancer
- Need Help With Sts Info
- ported victor jr. intakes ?'s
- What todo with a slow LT1?
- Stepping Up to a 3 Inch Exhaust On my Fi setup
- LS4 Turbo, Valve spring & misfire question
- the merge into a T4 flange (truck manifold setup)
- New to the ls1 world, s/c questions
- Best intake manifold for turbo kit?
- another "what do you think"???
- Have you seen this turbo question
- pro flow bypass valve
- Garrett Turbo and a Forged 346ci
- What is everyone running w/ a D1SC
- Future GM Engineer here.
- APS f-body it with th400?
- Anybody know if the new turbo BMR k member will work with the Fbody APS TT kit?
- Help me make up my mind...
- Got Fr1 Now Need Motor
- Well, did a little tuning
- What would YOU like to see in a Vortech big blower setup?
- What car to buy to super or turbo? which way?
- Garrett GT28R versus T3 60 trim
- No one can diag my turbo issue,please help!!!
- Shake down passes - D1SC 3.8 V6 Firebird (street driven).
- 370 vs. 408 stroker????
- LPE MAF? - What are the limits HP/Boost that you know of... ?
- paging Bob @EPP
- Bypass valve over BOV?
- lined up a sts first question
- C5 Single Front Mount 91mm Turbo Kit Done [PICS]
- How necessary are dual valve springs on 12 psi ls6 heads
- APS G8 Pontiac twin turbo system - First pics
- 826 RWHP from the 346 cube APS twin turbo
- LS1 block?
- APS kit with 4l60E
- Look what came today :) Gen TT
- can I get 800rwhp with my d1 and a 408?
- ls2, l92, ls7, lq9 head lifting???
- Which 3 disc Vig are people having the most luck with?
- Pair of TT Pontiac G8s
- how much boost can stock lq4 pistons take
- FI valve/spring question
- SEMA Photos (all fi)
- Oil in downpipe/intake
- Starquest Update
- What should I go with?
- P1SC + 385 ci LT4 Question
- Turbocharged LS1 Questions
- i need help ?
- This is what happens when you go for 9s on a stock 4l60e and stock block!
- ohio turbo kit
- Yep, another cam ?. Z06 vs. 224's
- speed inc tt 6 speed car goes 9.2@156.35
- New PB With STS..10.74@126
- GM 5-layer MLS thickness?
- Going for a twin T off road car, engine Q's
- D-1 car finally done (mostly)
- turbo selection ?
- where to buy 6.0 truck manifold exhaust flanges?
- Waste gate on a Centrifugal Supercharger with adjustible boost...
- need beger turbos
- Who do you use for U-bends/Elbows
- Not LS1 but cool Hellion Twin kit with Eaton
- BPV/BOV over the stock Procharger
- d1sc Procharger oil?
- Pt71GTSHP?
- TTi LSX holiday Pricing
- Should I expect anything going from my 4L60E to TH400?
- Which BOV/BPV for procharger
- Going to make one more try for the 8s tomorrow with the old 346, wish me luck
- Coolant Source
- Comp is 10:75 to 1 pro & cons of turbo vs nit
- Giving up on turbos, new and improved setup
- New Weiand LSX Intake Manifold
- Some videos from the track, one showing my spool time.
- EPP's blower cam with 1.75 rocker arms?
- Got my turbo back from Turbonetics
- D-1 kit to F-1 on LT4 motor???
- Best Oil return pump?
- 98 C5 with F-2 PICS......(56k good luck)
- What have you gained going to a larger A/R housing?
- 7.84@179 on 275's
- Crank Bolt came out
- magnacharged TA running to hot?
- What will I have to change
- Where does the BOV go?
- LT1 Forced Induction Gasket?
- STS Turbo Installation Guide?
- More News at KYTP.
- 408 turbo build - need advice
- HP Predictions
- Best Forced Induction Cam...?
- Turbo Choices.....
- slp Y with sts
- how much boost?
- Boost #s with D1SC 7.6/3.4 Pulleys? SDCE Help?
- LT1 TWIN TURBO-custom or homemade please post up!
- stock ls1 boosted
- Paging Ed at Late Model Speed....
- Maggie dyno video
- map sensor
- P0300 Code when car is stopped.
- Any F-2 Procharger kits for the LS1?
- LT1/ 89 GTA turbo kits?
- Jake brake sound
- Procharger SES light?
- Boost setup ?s
- alt 6 rib to 8 rib info (clutch pulley)
- Target Static compession on E85?
- Ready To Give Up My Money Lol
- Attn Ohio boys: O-ring question
- LSx misfire issue, come inside
- BW S388 turbo?
- Which Forged Engine for Boost???
- APS kit K member
- 60 lbs injectors
- GM Kenne Bell 6.0L supercharger
- Little vid of the TT Chevelle from Yesterday
- Trans Am Build.....
- FMIC for 01' TA
- Has anyone run LS6 heads milled to 62cc and ran up to 15 lbs of boost?
- wheres the best deal to get a Precision T88 turbo?
- Windshield Washer Fluid
- gm mls gasket purchase
- Wiring up 2step
- Oil on impeller side
- What to do with my turbo 5.3 powered stang?
- Most Bad Ass 76mm Turbo
- So how much did it cost?
- Muffler shop damaged my turbo, need help in fixing
- What Garrett turbo is this.
- Procharger 4.11's
- Turbo Setup in G-Bodies?
- Going boosted need help please!
- Tune and Boost
- Is anyone runnin KY turbo system or Ohio forced
- I took the leap!
- Some technical supercharger questions
- anyone got any info on this turbo
- The Turbo Project has Begun......
- 2008 ProCharger calendar, we have a C5 in there!
- HX60 on a LS1?
- custom turbo set-up for 71 Camaro who should I use
- What gears with Procharger?
- quarter mile magnacharger time
- similar ET but nice new MPH best today!
- last pass of the year, new best by a bunch!
- Can we hear turbo people's exhaust sounds
- gathering parts for a tubro build...critique away!
- is a D1sc enough blower for a 408ci?
- Couple more pics of my new Performance Auto Fabrication GT-47 turbo system
- New best, 10.67@131.71.
- Instant Tube Fittings
- Just installed Wideband need Tuner DFW for a Touch-up Tune
- BOV question
- corvette alt pulley removal
- Who sells excellent off the shelf F/I piston close to -3cc dish?
- BOV vs BPV flange question
- Rearmount setup new best. 10.139 @132.74
- Pump Gas Turbo
- Has anyone ran LS6 heads milled to 59 cc with up to 14 lbs of boost?
- will electric water pump work with pro-charger or magna charger
- Springs
- Boost control w/ Eboost 2
- New turbo setup?
- this is EGR correct? (truck manifold)
- Need Info For Best Cam
- boost engines
- Turbo support bar pics
- fastest log set up
