View Full Version : Suspension & Brakes
- Urethane bushings?
- Bent spindle?
- Wheel Hop
- PICTUREs of Hotchkis or Sams springs
- Help with a braking problem
- Problems with UMI TA and S60.
- Help with UMI products!
- What is the lowest I can go with my LTs?
- what causes fishtailing
- help.. least spring drop around 1 inch?
- settings for launch
- Bose suspension setup?
- Shocks????
- What brakes don't squeak???
- Lowering Help Needed ASAP!!
- Cheapest shock to use with a Pro-Kit?
- Am I missing anything on suspension?
- strut tower brace
- FYI: Koni pricing going up a bit 3/1/2007
- Strano springs are on *PICS*
- Duralast/Hawk HPS squeak
- help with suspension
- rear disc brakes
- [Pics] Can you ID these springs?
- Where to find non-adjustable 90/10's and 50/50's???
- I think my 68 conv. sits too high
- how difficult would it be.
- lca qusetion
- New Vibration
- Prothane vs. Energy Suspension
- 93-97camaro Calipers For Draglites ?
- how can i find this?
- Car shifts / wiggles side to side when I shift......why?
- Tubular K-member? Worth it?
- A-arm questions?
- BMR bolt in relocation brackets fit 12 bolt
- So I built some subframe connectors this weekend
- SJM ABS delete and TC delete
- How do you know when to replace rotors?
- Eibach Sportline Springs..'94 T/A
- Bilstein shocks - part number question
- ****QA1 spring choice****
- Whats The Purpose Of A Panhard Bar?
- Slight full steering problem when cold
- best shocks/struts for eibach springs
- front swaybar help
- how much PSI for cheatr bag?
- panhard relocation
- Spohn subframe connectors (anyone use them?)
- Relocation Bracket, stock height,which hole ?
- Did the heater hose mod - car is still at stock ride height, wtf?
- e-brake
- subframe connectors
- 1le sway bars?? are they worth it???????
- has anyone ever had problems with this vendor??
- does a T/A help with brake dive?
- brake question
- Duralast brake pads suck!!!
- Using an adjustable panhard...
- you guys know where I can find these?
- Which shocks??????
- Which would help traction more???
- Same thing?
- One fast question HELP
- Tq arm for dana s60?
- hotckis vs. eibach
- About to install C5 brakes...will my wheels fit.
- konis
- Help with some shock info please!
- Labor for LS1 brake conversion?
- Time to do suspension mods!!!
- installed lca's, and now the car seems to shift from right to left at higher speeds,
- Drop spindles or lowering springs
- alignment issues. rack and pinion problems?
- Any sponsors have a UMI K-member in stock?
- clearance level
- New Shocks/Springs???
- Tq Arm Adj or non-Adj
- Best Lowerings Springs for Hard Launching??
- DMS springs+Kook headers+18's=Ground Clearance?
- Popping from the rearend...
- strut mount bolt change?
- how to remove torx bolts?
- why is my car leaning to one side in rear???
- VERY annoying sound
- lt1 lowering springs fit on ls1
- c5 conversion question
- Rear suspension
- how much brake fluid do i need?
- suspension help
- need raplacement for decarbons.
- qa1 coilovers
- Disc brakes?
- relocation brackets mandatory???
- LCA clunk?
- Can you hook on the street?
- Which Shocks!~!~!~????
- QA1 front coil spring rates.
- Camaro Cup Cars!!!!!!!
- steering wanders
- C6 Z51 front brake upgrade verus C5 front brake
- when will i need LCAs and Torque Arm?
- Which drop spring most comfortable?
- new bushings for lower control arms
- What grease to use?
- A cheaper alternative to Expensive Coilovers
- SFC's going in
- Torque specs for k-member bolts?
- Drag launch springs question
- 12 way adjustable QA1's
- spring/shocks combo
- Cadillac V series
- caliper bracket torque specs
- Rear spring spacers
- How much should it cost to install subframe connectors?
- Front suspension popping/clunking when backing out.
- Which lowering kit should I buy?
- pics of camaros with sportlines/prokit please
- Caliper Bolt
- Setting pinion angle
- greasing susp. parts..
- Dragstrip traction?
- help me out here torque arm install
- Does this sound like a good list so far?
- All I can say is wow!!!
- what are some good coilovers???
- groaning noise in the rear!
- LCA relocation brackets help
- LCA Relocation brackets worth having?
- C5-brake-conv. with 17"-Z06-Replicas
- Lowering my Camaro
- Clunking in the front
- LT1 rear brake lines,parking brake cable pics
- she's lowered !!!
- Installed 1LE Springs - Help
- Switching to Redline Synthetic PS fluid
- Eibach prokit vs. Edelbrock prokit
- eibach sportline springs???
- Pro-Kit Question
- shocks and springs?
- My ASR turns on and off after head cam install?!?
- UMI LCA/PHB Chatter
- Powerslot install... Something is going wrong!
- Does anyone have this set up or know much about it
- foating rotors / hats??
- ground control: where to buy??
- Are these good brakes
- Looking for comfy springs for Sportlines!
- which shocks with eibach prokit springs?
- Post-LCA install issue
- Question About Painting Your Calipers With Duplicolor Caliper Paint
- what shocks with hotchkiss springs
- sfc's & lca's gonna kill my ride?
- Some spring/shock questions
- New brakes.... 17K miles on old ones and they're mint?? WTF?
- torque arm not ligning up!!!!!!
- Handle better than C6, yet still grab rubber?
- Where's the cheapest place to get bolt in lower control arm relocation brackets?
- Traction/Handling Questions
- Looking for aftermarket power steering pulley.
- stock torque arm
- What torque arm for TSP True Duals dumped???
- Bad SFC install cause dimples??
- Do I need an alignment??
- Is there a K member that you can have solid motor mounts with?
- Tunnel Mounted T/A, TD Exhaust on 98Z28?
- lowering car with wide tires
- 1LE 32mm
- Want a MUCH nicer ride... How?
- Help with 1LE Springs - Quick
- b&g vs pro kit springs?
- Getting power to the ground - what mods
- prokit and 1/4 mile
- powerstop or baer
- OK - stupid shock question, please don't flame me
- In a bit of a bind, need advice... (umi?)
- Line Lock
- Well tried to lower my Z today :(
- ANy one used R1concepts Brakes
- For those of you with V6 springs in the rear:
- Front Tires RUbbing Please Help
- Who has the UMI C5 brake kit?
- best shocks for every-day driving/best ride quality
- What Is The Difference In The Supsension Of A Stock T/a Vs Ws6
- Lower Shock Mount
- zinc washed rotors??
- shocks
- G2 super springs...before and after:
- torque arm and LCA brackets
- Those of you with tubular k-members...
- mounting line lock switch?????
- bilstein BTS-7501
- Shocks and springs.
- LT1 Owners With D/S Rotors
- Would '02 WS6 swaybars be an upgrade for an LT1?
- What Are The Best Rotors Out There
- Centric Rotors?
- Rear Airbag Need install insturctions
- Rack and Pinion differences.
- Painting Calipers/Hubs
- Edelbrock strut tower brace on a '94 Trans Am
- line lock sticking
- Help me decide on rotors.
- Gravity bleed with ABS and TCS
- UMI Control Arms.. single ad. or double adj.??????
- what is the first mod to go with on suspension
- WS-6 store rotors?
- Lca's?
- Shock question
- Brake ?
- Line Lock pics
- Pro kit lt1 springs on a ls1?
- Anyone try these Ebay Rotors??
- front strut replacement
- Anyone have those rotors off WS-6 store?
- Springs: DMS vs. Hotchkis vs. Strano
- Question for Foxxtron
- rusty rotors?
- Suspension Help!
- Convertible traction VS Coupe
- Suspension busgings and ends?
- UMI Adjustable TA Problem, anyone else?
- Help with DD suspension setup
- UMI TA questions
- Upper padhard brace removal? For duals
- New Sticky Recommendation
- Strano springs or keep my factory hawk suspension
- Stoptechs fit behind 02 WS6 wheels?
- which struts for cut springs
- Baer Brakes
- Can someone post a pic of the stock TA bracket?
- ABS Delete idea for no ABS light
- broke my tq arm, which one now? pics
- Characteristics of QA1 275#/in vs. 300#/in front springs
- Lowering A C5
- Can Anyone Tell Me What Size???
- 1LE Sway or just get Stranos?
- a-arm install help.
- Please help!
- strut question
- UMI 3 point subframes
- torque arm that can clear exhaust
- Steering column What did I screw up?
- Big Brake Upgrade
- What shock to use for front only drop?
- BMR boxed SFC modification
- Prothane Bushings for Rear Swaybar?
- Is a BMR Tork arm(non adustable) right for my set up?
- Can I get these Eradispeed rotors from anyone other than Baer? (Vendors welcome)
