View Full Version : Forced Induction
- Ring gap for boosted 5.3
- how much boost can the LS3 handle?
- F body LS1 front intercooler kit fit LT1 car?
- boosted lt1 question
- Turbo Ls powered '87 GN-Project
- 403 streetcar w/twins
- Can Banging and Popping when it starts to build boost
- Congrats to Mark Carlyle: 7.10@210 on 10.5's and still IRS
- 5.3 turbo build stall size
- My 7 second passes
- AES 390 precision lf88 will it work?
- Cam and valve spring question
- Forced Induction Iron V.S. Alloy
- what do you think? comp suggested 5.3 cam
- Single T76 setup questions
- Hp88 to small for a street driven 404???
- Turbo lq4, machining, stock or aftermarket
- My Final Turbo Build Setup.
- E-force LS3
- Opinions on EPS spec'd turbo cam
- HELP NINETRES!! Car randomly dies when boost hits.
- 9to1 cr ms3 cam and boost?
- In Need Of Procharger Pulley Help ASAP
- what boost should i expect
- bought cam from for sale forum=wrong cam
- My Twin Turbo 1968 Chevelle Build Start To Finish- Lots of Pics!
- Lets talk block for FI befor i buy...
- good budget twin turbo intercooler
- ls1, 317s, 228r, tc78, ebay, t56 build DYNO NUMBERS PAGE 2
- Twin turbo GT45s....416ci or 427+ci???
- New Build, Need Suggestions
- Any Ideas?
- Newb with a Procharger
- Turbo Tech f-body twins
- Odd noise and compression
- 1K whp Build - 10 bolt rear FTW
- Would a Compressed Air Intercooler be Feasible?
- What is the Cost Difference between Twins and Single Turbo
- Turbo Sizing for a HEAVY T56 Truck?
- Garrett turbo rebuild
- LS9 heads compared to aftermarket for boost
- Any turbo guys see a lean spike when going WOT from a roll?
- UPP tt kit
- Need some advise for turbo set up.
- A stock crank can handle how much rpms
- Which Pistons, Cast 402.
- 6.0 317 heads on a gen 3 5.3... quick questions
- F-1A Procharger build ** Updated 6/13/13 ** Pics, Videos, Results inside....
- Turbo/Auto guys, come on in!
- crank case vent and valve covers for blown cars
- Meth injection system
- 99 procharged formula with 5th gen air filter
- garrett turbo fs craigslist...
- Huron Speed - Comp Turbo Dealer
- Modular Turbo vids
- What Hp i can expected from my Front Mount
- Turbo LSx Fox Mustang Build
- BOV & Wastegate Sizing
- keep 706 heads or put on Dart 205cc
- TWIN sizing 9s to 8s ADVICE!!!!!!
- 6.0 Turbo questions
- P1SC without meth, how much boost?
- Found metal shavings in P1SC-1
- Angry Bird 2 (The Angrier Bird) GT91 build
- Procharger intercoolers!?
- PA Racing Turbo Style K-member GROUP PURCHASE!
- L98\L76 PCV on FI
- Borg Warner s300sx3-66 for 5.3?
- eBay cx racing turbo kit
- KUP engine + Speed Inc TT Street kit + 21psi...
- Oneoverwrx turbo 4.8L 240sx track results
- Ninetres Twins on the Dyno *VIDEO*
- my twins too small for 6.2 setup?
- Need help selecting a turbo set up.
- Procharger guys, what is your set up and what are you making?
- 4.0L WHIPPLE- <-Official thread.
- Do these dyno numbers sound right for my setup?
- 317 heads aftermarket valves?
- Quick question about GT35's
- 5.3 Twin On3 70mm's
- blower cam?
- Damnit!! Help me pick turbo #3.. M6 orrr 4L80e LQ4.. High HP
- Turbo mount
- What if (rear mount)
- Ported 799's for a Turbo 5.3L?
- Lifters and Pushrods for 1,000 RWHP turbo build......???????
- twin turbo oiling?
- Holley EFI boost Control!?! Where is it?
- Standing up the radiator, have a few questions.
- Custom made 6 rib procharger crank pulley?
- Ls1 turbo
- Good Blower Cam, Input?
- Need pics of Turbo Braces.
- Teaser Pics!
- Low Compression F1R combo-975 rwhp
- Picked up a used meth injection kit - Have a few questions
- Turbos?
- how much boost can a stock ls1 handle
- APS Twins, LG Upgrades too much oil...
- ls1turbo help pleasee
- ls1 gto truck manifolds
- What oxygen censors on a boosted car?*LOG POSTED*
- TUNERS: discussion of ignition timing and spool time
- F-2 Procharger on a 390 LQ9?
- Need help with turbo!
- Looking for info on my procharger build
- Motor let go - Plans for a 5.3
- Install a TC-78 turbo
- Huron Speed "Hotside" Turbo Kits Available!
- SIMPLE question: what is your intake air temp?
- Exhaust note with single turbo + NA cam
- Thanks to the thread by SpeedInc(Jim) on "Observations.."...
- Water pushing out the radiator!!
- Oil Cooler
- Apexi AVCR: anyone use it?
- JGS 40 can't control a pt76gts?
- innovation in v banding:
- on3 76mm feed/drain
- why not car manifolds ?
- Few questions for turbo owners of LS cars:
- No More Drag Radials
- LASTLS1 getting ready for Bradenton, Motor done, Dyno numbers
- P1SC What hp expected?
- F1A Transplant kit, P/S issue.
- no power when turbo is on a real heavy load....?
- Mayhem Motorsports C6 goes 7's on an IRS and 275's!!!!
- Thanks to Bob@Brute Speed!
- Help with a F.I. fuel setup
- 800-900rwhp Turbo build - List your setups here.
- T brake, drag radial guys.how so you do it?
- Runaway throttle....hellllllp
- Why is a 5.3l w/317 a slug?
- Unleashed Performance
- GSS340 pump for e85?
- 10.1@137,370,comp 80mm.
- 80lb injectors for 6-700whp(e85?)
- Back pressure T4 to T6 flange (maybe)
- Precision turbo rebuild??
- t56 and 2 step spool time with pt7675
- (In)sanity check
- F1A ,402, ls3 heads, intake, 4l80e ((( whats your boost/rwhp)))
- procharger pulley size/boost/rpm formula????????
- F1-a 408 4l80e converter and injector size
- Boost leak from fuel injectors, any solutions?
- re-tune required after gutting cats?
- What manifold on high HP 400+ci LS3 headed build
- Hydraulic lines for turbo feed and return
- Car won't build any boost; turbo failure main cause?
- who runs a pt 98 with a t6 and a 1.oo ar????
- Couple of Magnuson Questions....
- Audi S4 getting american blood... *some pics*
- What RPM do you make full boost?
- EGT sensors in stock cast manifolds
- P1 Procharger on a 5.3
- LS1 SLP whipple supercharger discussion
- Anyone ever use this turbo kit?
- LS2 GTO front mount single low budget turbo, keeping A/C
- Head Choice Vs. Blower Questions
- Another LS Stang Is Loose
- CTS-V SC'ed Cadillac head gaskets work on a LQ9 iron block?????
- advise on turbo size
- off season project
- Ls7 427 supercharged stuffed into lt1 camaro front clip.
- Boost cam recommendations for my setup?
- Ran my junk
- V6 singles = TT for my LS1?
- Injector Advice needed
- Figuring compression........HOW.......is there a calculator?
- Project "Because Streetcar"
- in need of a 76mm turbo
- Finally did it!
- Simple Front mount advice needed.
- aps twin turbo and Eboost2
- Cam rpm range?
- Breaking in a 402 with a F1R
- how many 5.3 turbo guys with 706 heads?
- high reving engine in boosted aplication
- Simple combo-big power-347+D1SC=800+rwhp
- Warhawk heads 72 or 64 cc heads on a 6.0 boosted
- whos running a boosted 408?
- The BIGGEST BADDEST air intake for turbos!
- WS6 LS3 Whipple
- FI and Motor Gurus step in please
- Typical turnaround on turbo purchase from Speedinc.com?
- dart 205 heads on turbo 4.8
- Need Custom Supercharger Bracket for LS2, Pic Attached.
- 347 vs 370
- race valve work on turbo
- what is next???
- IAT placement
- Piston/Rod recommendations
- Build thread with a 5.3L turbo
- LS2 block...385ci......will it hold 1,000 RWHP reliably......
- **LMR's Drag Radial Car Dyno**
- ****Late Model Racecraft 2013 ZR1 Performance VIDEO****
- can my cats melt?
- Is it possible to get lower boost in 1st gear on auto?
- It's alive!!! 94 Camaro 5.3/T56 Turbo
- gt88 spool
- Shake down passes with new YSI Set up from Jannetty Performance.
- I don't know what this is
- lq4 s10 + twin 70's
- What did you do to your lq4 ?
- Good exhaust gaskets?
- Need opinions/input on twin or single build w/ Stainless Works foward headers**Pics**
- What wastegate should I use?
- Newbie here
- What's the best wideband for boosted application ?
- LQ9 GT4780 turbo in a 240sx
- High Compression + Boost?
- Fuel pump/injector problem
- f1A back feeding help!!
- 5.3 turbo
- Who is running an oil cooler/filter inline pre-turbo?
- Eboost 2 problems. driving me crazy
- New To Forum... Need help deciding on a procharger
- Major oil in intake piping.
- Borg Warner turbo's
- F1 procharged guys
- Looking to maggie my lq4,need advice.
- aps intercooler
- boost controller
- Is this cam good for my goals? tt/408
- recommend me a cam?
- Internal debate on pistons and compression
- Precision 74 GTQ, SP Cover, .96 A/R?
- cam gurus, opinions needed please 404ci single 88 build
- LQ9 Block Limit
- Recommended Texas tuner....???
- Huron speed with maf question
- Which way to go? LQ4 heads for turbos.
- 6.0 turbo build needin help
- Oil clearance
- F1A LS2 waterpump-timing cover issue. Need help
- Some hot side pics needed for my GT50-88 build.
- Procharged 347 question
- Has anyone heard news on how KYTP is doing?
- FI guys with ac in hot climates come in
- Aftermarket Parts Installer Directory
- New turbo build questons.
- garrett tv7512 76mm turbo
- High Hp Pat G tuned ....?
- Unusual wear on a 50 mile old turbo motor. What is going on?
- Would I need a "ported" TB or it wouldnt matter for FI??
- Need a dowel for pinning my crank!
- looking pt7675 .96 exhaust housing, anyone got one?
- turbo's-please advise which ones
- 2 questions about compression...........
- Whos running a Huron Speed kit?
- vortech v1 help
