View Full Version : LT1-LT4 Modifications
- running hot
- Removal and installation of LT1 Harmonic Dampner, and crank hub
- Entirely too loud Magnaflow, What to do.
- ls1 v. lt1
- roller rocker
- what would it run?and how much hp?
- broke water pump to heater core hose! Photos
- help on trans set up m6 or th -350
- coil? vacumm Leak? computer? Help?
- lifters
- exhuast
- Bored on Easter....GMMG Videos and Pics
- Tuning DFCO on the LT1?
- nitrous on a stock motor
- t-top Help
- LT1 Edit vs. Tuner Cat??
- rear main seal
- intake converrsion with accufab t body????s
- Rear Brake Caliper Adjustment
- I'm dropping the engine/subframe from underneath the car...
- help
- Apparently, it's possible to go 9's with an N/A LT1 and 450 horse!
- Need Advice- Motor ticking on throttle
- bad weekend broke 2 bolts taking off exh manifold!
- HELP ME! two things
- fans will not run!!
- headlights
- header
- car stumbling
- hooker vs. Pacesetter (LT's ONLY!!)
- Wtf!!!
- how do u purchase Llyoid elliot stuff
- valve covers that fit AFR 227 heads??????
- headlight covers
- running straight TB question
- Tb Run Need Help Soon
- Y-pipe Question
- Bored...spring media UPDATE
- 94-97 LT1 in a 93 Z28
- Need some help, want to dro pthe tnak but cant find to much info
- My 95 z28 is knocking, having trouble tracing it
- valve springs.....
- Pacesetter LT owners - your thoughts?
- These will work for on an LT1, correct?
- need some help with some problems
- underdrive pulley ?
- LT1 tech info
- need help determining gear ratio
- LT1 rod knock?
- After Tune?
- What will I dyno and run?
- 95 opti on a 94?
- Screw up or Coincidence????
- More "Project 8 sec LT1" pics not dialup friendly
- no spark after header install
- got the LT1 back together
- Light Weight Flywheel??
- Rick Hendrick Edition?
- 383 Lt1 What Hp ##???????
- spark plug wires
- Tell me if these are the right injectors.
- lt4 heads- lt1 intake
- All the the guys with 396s, come in here! Some questions
- Crazy AC
- ExHaust shooting out black stuff
- whats should i be running est.
- 11 sec LT1 TA auction ending Easter Sunday
- another fuel pump question
- Brodix heads on my LT1
- Cometic head gaskets - Help quick!!!
- lower and upper ball joint replacment
- Finally out of the garage!
- Jsut got my Mr Gasket copperseals, couple Qs.
- An interesting comparison from a local shop...
- Powerdyne SC owners????
- 95 LT1. What wire is the tach lead?
- Comp Cams XFI 242/248
- header question!
- LT1 engine rebuild kits?
- Going to need new radiator hoses.....
- How big!
- How big?
- Has anyone heard of this modification?
- help with picking porting and cam combo
- Headers
- header install price
- What all is included in "plugs and wires"?
- Custom cam
- lt1 dropping oil (still)
- LT1 starter wiring
- Is the OPTI SARK the problem?
- valve cover breather
- **helP My car cuts on then cuts right back off**
- Looking for Hood
- Tuning
- Need some LT1 help here!
- 97 LT1 starting issues
- What rims are these?
- replacing the o2 sensors
- gears in my ta
- Intake Air Box
- !EGR and !AIR???
- What should oil pressure be?
- Please Help Me!
- Brakes, Engine Shops, and heads and cam
- Where to get scorpion 1:7:1 rockers?
- Cams, cams and more cams
- LT1 cam write up
- Valves
- anyone have a blower for sale?????
- Roller rockers
- LT1 Cam help (unusual application)
- Considering purchase of 95 Formula with LT1
- what can i take off
- would small exhaust leaks make the Knock S. pull timing?
- Delteq users. Anyone use a shift light with it?
- fastest lt1
- is there such a thing????
- a3/th-350 swap
- LT1 bellows
- Shorty Headers
- Need Help Power= Not There
- hvac delete question
- having a brain fart......
- Msd?
- Fans wont come on at 220+..very wierd..read
- fuel rail covers, polishing, ??????
- Loss of torque with shorties
- 383 Shortblock
- Fuel pump?
- Beehive Selection 918's vs big block 120's
- should i port my heads?????
- Oil Pressure Problem???
- Do LT1's have the 4L60E?
- any horsepower numbers on 383 with stock heads?
- what cam
- LT1 Granatelli 85 MAF
- anybody got this
- progress
- overheating question
- Mostly stock LT1's, TNT f1 Nitrous kit *inside*
- I need help!!!!!
- TDC issues
- still misfiring
- cc305
- Comp cam to small or to big?
- should i get the Ram AIr Hood
- LT1 Missing up top
- How to..create a manual fan switch!
- Went to the Track Last night.....
- Mallory 685 came in jsut now... couple questions...
- 94Z vs import
- What would you do?
- Gremlin Keeps Opening My Hatch!
- Relays gone bad already??
- Stock tach
- Anyone ever hear of Allen Motorsports in TX?
- Where to buy LT1 edit
- OBD 1 vs. OBD 2
- sooo happy
- Motor Mounts
- Will a 98 ram air hood fit on a 96?
- my prayers may have been answered!
- what numbers are you runing with Hot Cam?
- newbe with a big ??????
- Car died on me
- Idle RPM
- lt1 codes????
- 93 Z28 Header Options with S/C
- how to tell what year?
- Roll cage pics......what do you guys think?
- New LT1 Exhaust Audio File
- Fuel Pump
- weird knock / shake in new motor
- Looking for a used/working opti spark for a 95-96LT1.
- What to do, what to do?
- borla wide open
- Should I Buy 1996 6 Speed Formula?
- Connecting aftermarket tach....
- Joe O cam on the way!!!!!!
- Horsepower gain with small cam
- alternator?
- Light Shut Off
- Car not running right, need help!
- hotcam install misfire codes
- Some thoughts on what mycombo might make
- Morel lifter adjustment?
- Maf Q
- Heads & Cam installed
- Changing Gaskets: Best way to clean head surface on block
- Stock bottom end
- LT1 true duals
- max hp on stock crank and rods
- Got my MegaSquirt ..Now a Few Questions.
- 383 power
- fuel rail schrader valve
- new 1995 z28 F1
- Lt1 Swap into LT1 car
- VE tables
- runs better when cold
- Just bought a 94 Z, need your thoughts on something
- LT4 vs. LT1
- balancer hub ??
- is high mileage a problem?
- New cam
- need help plz.. alt. relocation bracket
- What Am I Gonna Do?
- finally got the gears in!
- Smog legal shorties with ORY...
- Lets see your LT1 intake!!!
- grrrr...low rpm mis and rough idle in warm weather
- 00 Trans am WS6?
- T-56 M6 Conversion
- pics
- need seriuos help
- Post header install probs.
- 97' camaro needs some muscle
- 93 injector issue maybe?
- Overheatinga at idle, please help
- Blown Head Gasket or cracked Head
- 383 coming along... few questions...
- Borla plates
- Reflash Back To Stock
- ohlt1 gods
- what to buy next
- When is it time to get a bigger TB
- getting new ecu
- LT4 High RPM Miss - Help!
- Anyone using Pacesetter Mid-Lengths?
- shakin shifter knob
- crazy high idle, WTF?
- I'm stumped
- who tunes lt1's?????
- New dyno numbers smoggable setup
- shorty headers sound clips please!!!
- looking for headers
- 94 T/A questions
- cutouts
- Did a little turbo fabbing last night...
- opti problem "i know your tired of these questions"
- "Tipical" times of...
- Are heads necessary with a cam swap?
- Help with estimating my hp
- finally some dyno numbers!
- Forum Guidelines - Read Before Posting
- Anyone running JOE O. cams?
- turbo heads
- Aluminum Flywheel- pros and cons
- rocker question
- Cheapest place to get an Opti-spark?
