View Full Version : Forced Induction
- Which cam for a 402 with at 16psi
- who uses a launch controller?
- What to do about tuning?
- Have a inspection Comming and need cats to pass
- anyone run a BW S475? pics? dyno?results?
- SC gearing compared to Turbo gearing
- Oil leak from D1SC Procharger?
- Mustang Dyno Results
- How to secure turbo blanket?
- Fans for Griffen Radiator and Twin Turbo
- What magnacharger tune looks like?
- kentucky turbo build pics
- are there any advantages to polishing?
- Pros/Cons of T56 VS Th400 in a turbo car aka, why T56 turbo cars suck.
- replacing my lifters what to get?
- Boost question
- Rear Twin turbo Z06
- Supercharged guys-Cutout question
- Twin Turbo ZO6 by Speed Inc.
- where to get the steel procharger bracket?
- Plug gap ?
- Oil in downpipe....Heerrreee weee gooo..
- A2A or A2W on FI set up?
- F1C procharger impeller speed
- Procharger pinning kit with Eagle crank??
- well is this true about procharger?
- 500-550hp lq4 truck manifold setup
- procharger causing oil leak?
- NGK TR8 vs. gasketed plug
- STS Turbo system Intake question
- need more boost
- Prosport Gauges.Anyone running these?
- Auto turbocharged vs. Manual turbocharged
- New BS3/turbo setup won't start
- 3" Blow off valve Piping. W(here)TB?
- Underhood heat
- all verticle radiators come in!!!!!
- LT1 boost questions......
- My setup
- How much rwhp should I expect with my setup?
- Got it fired! Now a fuel pressure issue...
- adjustable alt. bracket for a truck manifold set-up
- new edelbrock cam good for a turbo setup?
- Another one bites the dust!!
- twin or single
- what size wastegate?
- Fi 94x Billet Build-up
- SBC turbo motor got one?
- Turbo freaks come in for feedback....
- p600b procharger help.
- Short video of my Magnacharged Trans Am
- Does a 10lb spring on a 60 trim equal 10lbs on a T67?
- Advanced look at BLOWER SPEED
- Lets see some front mounts!!
- FMIC On dumdumdumdumdum
- i got a FI Comp Cam and have a quick question
- How much boost are you guys running on stock short block w/6.0 heads?
- Best Fluids for Forced Induction
- APS BOV's removed
- APS PCV system... problems?
- Plug & Play harness for ATI Procharger fans
- Wanna see a 300+ft Long Wheel Stand
- thinking of trying race gas over E85
- My buddies whippled cobra*VID*
- intercooler?
- Yet another PCV thread
- Procharger Diaphram
- What brand intercooler is the best?
- Paging Turbo Gurus
- procharger 6 rib falls off
- Blow off Valve Flange
- I gotta pull tranny on my APS Camaro
- tial wastegates on ebay?
- single front mount
- Velocity stack with a screen ???
- Turbo Rebuilds
- Are exhaust cutouts worth it on a turbo car?
- Burkhart now carries Chiseled Performance Intercoolers
- Drove car for 1st time since removing turbo
- LS9 Build Video
- Any feedback
- Precision PT8047 turbos on sale
- intercooler
- Ontariovette's 427 F1R build up: UPDATE!!!!!!!
- EPP ProCharger Prices
- ATI Procharger D-1SC Kit
- How far are you supercharged going on the maching of the block??
- Please can you read this map for me?
- I need a CHECK VALVE, which one?????
- 365" or 403" LS2 with T-Trim?
- blowby with sts...poss pcv issue?
- 106 turbo questions
- Max boost with Stage 1 Incon kit??
- looking for detailed frnt mount intercooler pics
- MAF or SD tune? which is right for me?
- Wiring help.......adding 9 inch spal to procharger shroud
- dumb turbo question distance vs spool time
- Turbo setup nearing completion
- LMR Custom Twin 67mm Initial Start Up Vid!!
- Anyone w/ Maggie or KB running Meth?
- Uh, so..which charger..which cam?
- friend wants turbo
- So many ways to go...
- Not the best way to start the day.....
- it's coming....
- APS kit: Spark Plug Gap and detonation/gas mileage
- 95 turbo TA inj. pulse disapears at 4,800 once warm
- building my own sts kit??
- Holy crap - check out this video
- YSI 383 combo pully size and ect?
- Anyone using total seal rings w/ chromoly top ring?
- New Hardcore Parts are Ready!!!!!!!
- Need a Recommendation for Spark Plugs
- Which spark plugs for boosted e-85 car.
- APS TT 92/92, Vic JR or GM performance
- whats the biggest bore on LSX block with FI
- 408/PT98/Six Speed Build
- Are TR6 plugs available in Platinums ?
- gt47-88 with .69 a/r???
- just wondering???? sts exhaust pics
- My 408 iron block, GT47-88 build.
- Is There A Whipple Dealer In The House?
- what rearend/tranny combo are you running on turbo cars??
- PART NEEDED Silicone Reducer, 90° bend - 4.0" to 3.0"
- Procharger Fan Setup
- magnacharger + methanol + Nos
- aps turbo project underway
- Since its hot and my car dont run that well..
- Masterpower 2008 catalog link!!!!
- Anyone with the Ebay kit have a problem with the wastegate bolting up?
- Custom PT88-402LQ9 build pics!
- Forced induction timing and air fuel?
- Most Power From LSX TT setup
- Cam on stock LS1??
- MAF delete hose for APS kit
- What ever happened to the HPS Formula?
- Doweled Main Caps
- Tires size and spool
- Plenum Box Exploded! (Procharger Race Bypass info needed)
- Possibly stupid question about a 2 step...
- 2 bar MAP
- new d1sc build
- OFI kit and aftermarket k-members?
- Its a STS kit? good luck making any sort of decent power
- Need 2.5" Merge to T4 flange, build or buy?
- Forged LS1 build?
- STS turbo Methonol kit info
- Dyno #'s for my STS set up
- need advice on turbo
- Belt length with SDCE tensioner??
- 6 to 8 rib coversion
- blow off valves?
- ignition cut out...on turbo car?
- 2000hp LSX Twin Turbo/STOCK CRANK
- Widebody Twin Turbo Corvette C6 (Turkey)
- Anyone running a Proparts boost controller?
- EvoByDawin's eBay build-up
- Interesting pics over on another forum....
- Stock motor + turbo + 93 octane..
- Head studs on LQ9 block...
- Redid APS inlet pipes
- D1SC Filter Problem.
- FI98X Initial Startup movie
- garret a/r 1.39 hot side - go or no go?
- Possible twin build - Turbocharger's physical size
- Exhaust diameter size?
- Rear mount guys. Has anyone thought of this
- my car falls on its face in 4th gear..Help
- For those that have asked about Turbosmarts new 50mm Gate....inside
- Cam for a S/C stock LS1
- torquer 2 cam and a procharger?
- motor and parts all came in!!!
- supercharged map sensor question?
- vortech T.Trim
- pics needed: turbo bracing
- Mild steel pipes
- supercharger swap
- Stupid Question: weight???
- VIDEO of Superchargered F-Body by MTI Racing
- Gen TTr Install Pics on 04 GTO
- Anti-Surge system?????
- What should I do about the Oil Return?
- Who else ordered the new tc78?
- Upgrade crank pulley to SFI Procharger /w GTO blower pulley, who makes one?
- Turbo Build
- Compression Ratio?
- will a MPT-70 .96a/r t4 fit the stock t4 sts kit
- MTI Racing F- Body Supercharger Kit
- High HP Guys Not Using BS3 - Knock Sensor Question
- building a 1300-1500hp turbo LSx ?'s
- STS tuning suggestions
- Quick question about OBX
- SI007 Cam for Boost
- Fitting a 106mm turbo...
- LSX, F2 in another mustang
- How do you STS guys feel about your kits piping?
- belt tensioner question
- Any Sponsors make a Radiator Relocation Kit?
- D1SC-more boost-custom crank pulley
- Carrie LIVES!!
- Procharger Clamp Question
- Radiator and Turbo Set Up!?!?!
- comp 918's gonna be enough?
- Cam for STS TT
- I finally did it..Thank you OFI.
- STS & Wideband O2 Sensor Placement
- Vacuum Source
- Gas Ported Forged pistons with boost?
- Which headgaskets are the best
- limit on Stock 5.3 bottom end? should i go more??
- Motor loses RPM at top of track
- need some help guys
- TSP 231 237 cam on turbo 6.0
- What fuel setup for MPT-70 kit?
- how runs 10psi with stock LS6?
- round 2 of my turbo build
- off road y pipe
- Has anyone used this product to quiet procharger?
- STS kit on a C5
- belt question..
- SDCE w/ Stock Damper Question
- Opinions on my set-up please
- Fel-Pro 6-layer MLS gaskets-where to get them?
- H/C Change pics
- Blower Header Delimma-Educated Input Requested
- Whipple kit
- My Turbo Project Has Started
- Eboost 2 reading low
- in trouble
- Factory feed line 'T' return size? Pic inside
- Procharged GTO -- Oil Leak?
- Got the car running and driving
- V8 RX7 Sigle turbo build
- bolt hole size T76
- I need help
- 06 GTO with an 402/ATI ProCharger F-1C being built at EPP
- Warm start up issue.
- wastegate reference issue
- ISO - HP Tuners bin for my car
- Who eliminated the STS PCV system and used a catch can?
- Turbo Question not for a ls1 though
- Twin turbo car making high pitch sound...need some help
- which block for big turbo power.
- Aps Dyno On Stock Bottom End, Trans, Clutch Etc...
- supercharge candidate
- sts guys come in!!
- What Bypass Valve?
- Vacuum sources
- Turbo Advice?
- Twin T-70s
