View Full Version : Forced Induction
- installing turbo in my car
- Question - TT and Heat
- Tuning/Drivetrain question
- procharged car with high miles??
- steel wastegate flange
- Need help bad!!! PTS and other boss alt guys please come in
- ATI Pin on crank snapped
- eBay SBC Turbo Set-up
- oil in turbo- hot and cold side
- mustang d1 headunit
- Best manifold for procharged sbc?
- a few wiring questions for you turbo guys- fans- map- etcc
- Spark plug gap
- Your opinions on a custom spec'ed turbo cam
- Short video of ST74 on 3.8L
- who's running F/I on a stock auto tranny?
- wastegate distance
- High power turbo guys- what timing?
- Back from the Dyno today, TTi Race kit
- need a good fuel pump controller
- best f bod twin kit
- gt-47 air filter
- Huge thanks to eb0z06 and SLED28!!!!
- Stewart Warner Boost Gauge Install
- PIcs of my 408 F1R, Becool setup
- Which centri head units can handle a 454?
- Tial 38mm Wastegate and 50mm BOV sufficient?
- a little FI predicament!
- What exhaust housing for a 402 w/76mm?
- Catch can eliminator!!
- help, oil out sts turbo exhaust
- Turbo car overheating
- S88 on a 408 with stock pcm possible??
- 6.0 truck turbo Q's
- Upping the boost, couple questions.
- Twin Turbo LQ4
- Wrapping hot parts with header wrap *pics*
- 6-71 intake prices
- which is better...procharger or vortech
- thinking about turbo
- questions on converter that does well w/sts
- Twin Turbo car in FS section
- supercharger+turbo?
- ok I am going crazy....
- Trickflow 220/224 cam for turbo?
- How Many Of You FI Guys Are Running An A/C
- Intake manifold for FI
- Realistically how bad will my cam hurt me?
- whipple dragon
- PVC Catch can system.... Final conclusive answer
- Looked high and low for 1" NPT/Barb fittings
- Polished cold parts...
- automatic trans...blowoff valve?
- What Boost Pump ????
- is this to good to be true..
- Planning my FI build
- EBoost 2 ??
- Should I do this or not?
- What boost to run?
- Pics Custom Truck Manifold kit
- Turbo guys: BOV, wastegate, and BC
- The ultimate turbo street setup!!!
- Any of you FI guys need a good fuel set up?
- 1,000+rwhp & 6-speed
- Mustang P1SC on an ls1?
- Help me pick pistons/rings/rods
- Procharger oil resivoir under pressure
- ma
- Question. Dont get mad.
- Turbo selection RWD Grand prix drag car
- oil dip stick relocation
- Advise On Car Build
- Help!!!
- Made alot of progress on my GT47 setup...pics within
- Welp...
- IAT sensor in air intake for meth injection
- Dr Turbo and JZ...BCI-18 and UHP questions.
- guys with sdce setup chime in please, anyone having any problems?
- procharged now
- S/C and gas mileage on an h/c car?
- Turbo Help
- pics of altenator relocation brackets?
- First Track Result's With New Setup!!!
- Turbo Kit Prices???
- Just test drove new build for first time!!!
- yes another 2 step thread....finally found 1
- Some vids of twin turbo v6 firebird
- Fired up the 'ol stock LT1
- Stall question...need to get this right
- procharging a 94 t/a
- Heads or Headers for an otherwise stock LS2 supercharged
- New Sponsor: KY Turbo & Perfomance
- Turbo system for $2225 ?!!?!
- Boost
- Procharger guys what exhaust do you have?
- not building boost on a 2-step?
- Is .601 lift on a 214 duration too much on a FI car?
- Turbo Questions (PCM and Crankshaft)
- STS Low Oil Press Warning
- Advantages to fast 90 w/ FI?
- looking for good internal advise
- painted FMIC
- Cutting front bumper on Camaro for FMIC....
- Anyone know cheapest place to get 4" & 5" mandrel u bends for downpipe?
- How much oil pressure do I want at the turbo's?
- OLSD vs CLSD
- where to put BOV on incon kit for good airflow
- Procharger ???
- Turbonetics GT-K 500 and 550 questions??
- Ok how bad really are 3.73 going to be in my twin turbo 408 or 427 m6.
- Advice on STS on H/C/i car please
- forged internals?
- what stall do you turbo people run?
- Something U wouldn't expect !!!
- Which Shortblock??
- procharger question
- Big Thumbs Up To Bob@EPP And Procharger!!!!!!!
- Best turbo to match 950rwhp with fastest spool on 408...
- looking for a superchager kit
- Which heads ?
- Weak factory internals
- aps order form
- started my turbo setup---
- Twin or single for the street?
- corvette twin turbo
- Oil feed restrictor poll
- 1'' to 2'' silicone?
- Newbe here; who has the TR Blower cam, what is your impression
- Turbo feed and drain flanges
- What are people running for 2 steps??
- turbo w/ transbrake??
- Who's cut their bumper for a FMIC...and what IC fit for you? And who's car is this?
- Twin GT35r's or PT67's for a 408
- What to do next to help 60'?
- 3k Turbo
- FI Lifters and Rockers
- ATTN. people with magnacharge kit from LM
- Power Tour '07 Pics
- A2W intercoolers?
- Custom Twin Turbo Setups
- what is your ECT and IAT at the end of a pass?
- How far would you push it?
- What year truck manifolds do I have?
- intercooler hanging low?
- GReddy Profec-B Spec II
- triple pod and guages
- New 1/4 mile best today barely
- AEM TRU Boost or E-Boost2?
- People with 850+hp which clutch?
- twin t61 turbos for sale on ebay
- STS, full throttle car falls on face.
- mondo bypass users in side!!
- Paging DrTurbo
- Oil out breather on PCV switch on STS?
- turbonetics warranty
- They got my motor out in a day...
- Best Pricing D1SC procharger
- rear mount w/ oil cooler
- OOOO i am excited, forced induction project finished next week!
- guy at vortech says 2.75 pulley eqauls 15-16 pounds of boost?
- Pics and dyno gragh of my fmic D1-SC set-up
- Procharger Head Unit to "J" Bracket Mount Bolt Ratchets
- ive got belt slip, should I go sdce?
- Got the first of my OFI parts!!
- What brand octane booster you using?
- LS2 oil feed
- Downpipe Length
- Drove my Procharged car for the first time tonight-Problems
- my 84 camaro project
- LT1, turbo or supercharge?
- Home built D1-SC set up part 3 (final dyno numbers)
- AFR225 head gasket question.....
- Hypothetical Turbo Scenario to Educate..
- Turbo's Ain't Worth Much,why?
- Overheating from FI
- Vortech supercharger question.
- 44mm tial wastegate
- Top guys opinion on high compression, high boost, low timing.
- Crank support systems for centrifigal superchargers?
- where to get an IAT gauge??
- What kit options are there for an S88??
- Should i shave heads for more compression?
- Any aftermarket pick up tubes available?
- To what hp is maf ok?
- Turbo choking it?
- Can I run a blower cam until I can afford a blower?
- Wish me luck fellow FI guys
- Tried search need Magnaflow Ipipe part# for STS kit
- how to quiet down an sts system
- 2 Step
- Solid or hydraulic cam
- vortech owners help please
- C6 - Procharger intercooler reversal
- Opinions please
- New set up, any ideas what kind of power to expect?
- vortech g trim on camaro ss?
- Will the first LT1 in the 8's also be the first to the 7's???
- Bellows with Procharger
- 700whp - Which clutch?
- Checking Belt alignment (supercharged setup)
- Some badge idea's for you turbo guys...
- O ringing block...yes or no
- 1/4 et question Stock every thing with ptk t76
- What are your thoughts on Boost regulated cut outs?
- How much timing in boost do y'all consider safe?
- Adjustable non tranny mount torque arm
- Dyno'd car this sound right
- 408 supercharged LQ4 help
- Tighten D-1sc Procharger belt
- Car is almost finishe!!!
- 8-Rib Procharger guys-Belt part numbers?
- dyno tune
- Smoking at idle
- Vortech repairs ?
- TT 07 Zo6...insane.
- AEM O2 WIDEBAND wiring
- What should my build be?
- Best stick/carb FI set-up??
- best stick/carb FI set-up??
- STS and Puddles
- Bypass valve hookup D1SC
- How do you tell if your BOV is adjusted correctly??
- calculation for figuring overlap??
- Turbo heat shield
- make that a mid 9 second daily driver
- before and after track times with cam swap
- What elbows are you running?
- New Best with the Supercharger
- turbo cam selection (search is down)
- ???'s about start-up tune
- what is wrong with my car?
- sts guys
- Some dyno results m6/10bolt to pg 9"
- Procharger Question (Nitrous Related)
- 1st track trip w/ Hi-Flo Turbo car
- Fuel pump of choice?
- vertical radiator people
- ofi kit at the track last night
- 9 Second guys... Wheelie Bars?
- A/C and Turbocharging?
- spark plugs
- truck coils
- couple mor pics of my diy rear mount!
- aem uego wideband users inside please
- Finally dyno'd with the D1
- hey
- FI Build sheets
- Please share you Turbo info with me
- people with multiple nozzles on their methonal setups
- cam effects on turbo spool?
