View Full Version : Conversions & Swaps
- 5.3 liter into a YJ.. need LOTS of help!
- ls1 swap in s-10
- s10 owners
- ls1 into a lt1
- LY6 in a '98 Jeep Wrangler
- LSx Identification
- New Project Same 72 2wd blazer
- transmission help
- ls1 fj cruiser
- W body exhaust manifolds
- Just Finishing off AC hoses - Compressor Question
- 5.3 liter for swap
- Twin turbo ls1 in 72 Cutlass
- Just another LS1 Procharged Mustang
- Cruise Control for LS2 DBW
- Which headers and cat back for fox ls1????
- I Need HELP!!! Just a couple quick questions.
- ls Mini-van
- Custom Aluminum gas tank info
- My LS1 Swap into a Porsche 944
- header choices for 68 Nova or 67-69 camaro
- LS2 69 Camaro running (vid)
- Is there really a huge benefit to getting an 01-02?
- Where did you get your LS1 pullout? (again)
- shorten corvette torque tube?
- Colorado SS
- Output shaft and extension housing lenght options 6L80
- GMCOPO Oil pan For LS1???
- vats box question?
- My 6.0L S-10
- Exhaust manifold
- Computer and Wiring
- LT1 into a Fox body, anyone done it?
- What harness is needed to put the ls1 in a fox body?
- Ram Air system for ls1 Abody car swap
- Brake heat soak problems after swap.
- the walbro 255 inline fuel pump
- do i need???
- Transmission help! silverado conversion.
- 1963 Chevy II Ls1 and T56 PICS!!!
- A/C Fitment: '68 Camaro LS1 Conversion
- Cut Supreme
- About to be another option for LS2/3/7 harness & pcm...
- whole c5 chassis under truck
- LQ4 Datsun 280Z Fuel system
- Another 4th Gen V6 to LS1 conversion...questions..
- OK heres the real problem
- A body ls1 egr & smog rmv & eng mount ?
- Oil Temp / Pressure adaptor
- alternator hook up question
- 2JZ lexus ls1 swap
- Where is the return fuel line on an LS1?
- LS1 PCM programming - what did I miss?
- Gauge pod wiring
- BMW e36 (LSX) project starting point
- LS1 into Fox Mustang parts and price list
- 1967 427 LSX Camaro
- My '95 240sx 347cc V8 Project
- another ones alive!!!!!!
- feeler-88 BMW M3 no motor trans perfect LSX swap candidate
- 87 ls1 gn
- Two Tone Turbocharged Chevy Oldie
- Drop out or Build up
- The horror...the horror.....
- fuel pump-carb to f/i conversion
- ..looking at v6-ls1 converted car
- Vid of red jet's ls1 notch
- 1967 Chevelle motor mount brackets
- LT1 Radiator and Fans fit first gen?
- fox ls1 + 4L60E or TH350?????????????????????
- what are you doing for a fuel pump.
- LS1 in LX in stock k member...............
- Ls1 into a 74 TR6
- Yup, another Mustang with an LS2, drag car.
- ls1 in a 57 pickup
- RX7 Project
- Can a V6 instrument cluster be used in a V8
- Gtols14
- Help with LS1
- Mustang II power rack fitting question
- Hmm this would be a cool but blasphemous swap
- heater hose question
- Another LS1 240SX Conversion begins....
- ls1 in mitsubishi starion?
- C3 speedo & tach converter
- 57 Chevy Black Widow Upgraded... FOR FREE
- LS2 PCM decision...(long)
- Easiest way to convert to drive by wire?
- Quick OBD port wiring question
- LS1 240 guys: What are you using for clutch master cylinders?
- LS1 head/351W block???
- DAMMIT. (Caveat emptor...)
- 6.0/T400 in a Toyota FJ40
- LSx Miata
- is my pcm bad? no serial communication 95 lt1 to 98ls1
- V6 F body to LS1
- what happened to the lsx into a first gen?
- 240 SX swap questions.
- New engine in a 62 Caddy
- LS7 3rd Gen Camaro
- Wiring 2000 LS1 into 95 Z28
- Rinkys
- 4L80E coolant lines
- 78 t/a shaker options?
- Quick exhaust question
- What Wiring Harness do you have?
- Pics of my friend's '82 LS10
- GMLAN hi\lo into OBD2 connector
- AC compressor question
- HELP!! 98 ls1 engine in a 99 chassis HELP!!
- And I thought the LS1/Mini was crazy
- alt problems
- my LS2 Firebird on Nurburgring
- Where is the best place for a hidden kill switch ??
- ECU and fuseblock plug disassembly
- "Code" light?
- ls1 into nissan
- will this x-pipe work? i drew a picture lol
- Lt1 2 Ls1!
- Wrangler LS1
- 96 Sonoma i need a rear end and shifter
- Fuel side of swap
- How much does a iron block LSx motor weigh as compared to a aluminum headed LT1???
- 64 Chevelle rear frame notch/narrow ?
- can you bypass the vats?
- '68 LS1 Camaro Suspension Q's
- LS1 Grand am
- S+P modified LS-1 oil pan
- tow capacity of sbc in 92 s-10
- LS4 harness
- Pulley system help
- Fuel Pressure Issue
- LSX Swap FAQ and Hall of Fame Threads
- LS1 into A 62 Chevy II
- not a LS1 but a hybrid
- V6 to ls1
- QPress do the headers fit?
- truck to car intake
- GTO AC compressor - swap to SS or TA AC compressor
- L76 into Cobra. E38 Mil light etc
- harness w vats and fuel pump switch won't come on
- wires pulled out of cps connector-??
- Carb guys: MSD 6ls2 Ignition controller
- ECM question
- Bracket question
- LSX oil pans
- LS1 Harnes..... Have a question.......
- A few pics of the 86 Silverado
- Starting Hummer H3 Swap-LQ4 vs. LS2 engine questions
- Mast Motorsports LS3 427 Dyno Numbers and Product Release
- 04 chevy 5.3 motor to 90 chevy
- coil cover question
- Engine Swap
- Newbie needs advice
- A/C compressor location on truck engine?
- Can F-body be converted to AWD?
- New GTO guages in old GTO
- Super t10 behind an Gen4?
- 73 Camaro swap
- My article in HPP
- Which headers for LS in 93 F-body
- LS1/T56 Mustang track results
- What am I doing wrong? (LS2 into 67 Firebird)
- Flexplate
- Another LS1 foxbody thread
- LS2 Powered 2004 NISSAN 350Z (soon to be 454 LSX)
- Quick Temp sensor question
- Cleaning up the aluminum parts question.
- LS1 swapped RX-7 vid, idle and 1/4mile pass
- Anyone need a turn signal switch...
- A-Body Trans Tunnel ?
- Alternator light will not turn off
- my 1991 rx-7 ls1 build vid
- Por -15
- Help me find a GTO cluster swap video!!!!
- Info needed.72 bbc Camaro changing to ls1.
- f-body edelbrock drag headers in g-body??
- do i even need to use the c105 plug?
- poll: how many think we should stop talking about the damn for sale section
- coolant expansion tank question
- lt1 to ls1 battery hookup questions
- Air cleaner- 4 barrel carb to ls1 question
- for AC help...
- Factory service manual?
- bbc in a 99 camaro
- 240sx LS1 ECM programing help needed
- Ignition switch wiring help (with pinout diagrams)
- New product: Painless Perfect ECU
- shortest water pump ?
- Gauge panel install questions
- I can't get my my tachs to function.. help!
- Is this a good idea?
- A-Body Centerlink clearance
- v12 ls1
- Starquest update
- Finally Found it! Exhaust Manifold Seal PN!
- Headers into offroad chassis..
- Some pics of my project
- LS1 into Tahoe
- Manifold length, diameters
- 85-5.7L into LS1 yes no?
- C3 Guys - Headers solution?
- weird temp sensor problem
- 91 Rx 7
- LS1 truck conversion mpg?
- v6 to lt1 question
- part # for corvette fuel filter/regulator
- carb vs. efi swap cost?
- questions about 92 z28 with swap
- f body alternator with a carb setup
- Cooling Problem
- new edelbrock A body LS conversion package coming out in 08
- 5.3 runs but trouble
- 95 Vette LT1 rough idle
- LS190 - Mercedes 190e LS1 swap
- LS2 GTO Question, water pump and
- LS1 1985 Pontiac Fiero build... have ?'s.
- C3 LS1 w/carb...times and Vids
- lt1 t56 to ls1..... come inside
- Calling all A bodies LS1 newbie swap
- ls1 in a gremiln??
- Touchscreen digital dashboard.
- Ls1 in fox. factory 4.6 kmember is a no go
- Retrofitting late model donor speedometers
- LS verses LS1 alternators and p.s. pumps
- 240sx questions
- 02 Vette Wiring Harness & ECM Questions...
- cam and fuel
- 6 Liter exhaust note and gas question
- pinouts for gauge cluster?
- Alternator Issues
- Fox Stangs w/ LS1/T56s..how did you do your clutch master...
- 04 5.3 in a 72 Chevy truck wiring help???
- Want to know the right k member for ls1 engine in Fox???
- Looking for some swap stuff...have a bike to trade for it...
- PorVette endurance road race car update...
- 67 Chevy II Exhaust
- LS 1 intake manifold gasket query?
- Which Motor mounts, headers, oil pan for a (LS2) 1970 Chevelle?
- Cutting Frame for AC Compressor, Who has done it?
- 6 Liter Accesories HELP
- my 69 with hooker headers & mounts. GOOD OIL PAN INFO.
- Restored my headlight stuff today
- anybody running turbo on 1st gen camaro conversion
- QSPress WINS !!!!!
- Is This A Realistic Time Frame
- 70 Chevelle LS2 Serpentine Setup
- ls1 ecu help
- hooker mounts in a 1st gen, did you notch the oil pan?
- ls1 in a 1st gen, what power steering hose? 3rd gen box
