View Full Version : Forced Induction
- Turbo cars with aluminum vs. steel flywheel
- OFI.... do you have a tracking # for me??
- MAF question on forced ind. setups
- BOV spring sellection
- Slight piston problem....pics
- Another turbo vid
- KP's TA on the cover of FSC and inside feature
- ST80 vs 76GTS some tad bit of info....more will be coming
- Synergy Twin Turbo Truck kit....
- boost takes out another lucky #7
- general timing question
- Last Hi-flo turbo finally finished!
- baseline STS kit on stock motor, What cam? and fuel pump. power numbers and boost?
- 2 step
- Turbo Guy's! I Need Your Help!!!!!!!
- 383 high compression turbo??
- Journal Bearing vs. Ball Bearing Turbos
- project turbo_z
- APS GTO Twin-Turbo Installed (photos)
- APS boosted 402 dyno results (7psi)
- Opinions on 427 iron block
- Lets talk about A/R's on bigger turbos...
- Twin Turbo 3.4L Camaro?
- 246/221/237
- NEED good turbo camfor my InconTT
- inconTT manifolds manufatures name ?
- very slow driving for extended time
- 4'' stroke guys with prochargers
- Stock LS6 exhaust manifolds with blown 427 LSx...
- cam and injectors for turbo
- Vortech 7" Crank pulley
- need your advice
- AEM boost gauge/controller....
- Detonation Need Help
- Ninetres 1st day track videos
- Vortech Supercharger - Anybody running one? Thoughts????
- sts wiring
- 96 T/A tuning help needed. (Detroit area)
- catch can with magnacharger
- Short vid of my car
- help please, still have oil in my intake
- looking for a supercharger/twin turbo for LS2 block
- No boost + lifters
- HELP! guys with procharger going mid 9s...
- 2 precision 76 gts for sale..
- INTAKE pipe TOO Big???
- S80+370 full spool by???
- Procharged Firehawk Build **PICS**
- Turbo Filter
- Boost issue
- Another D1 in the 10s
- Got my car on the road! finally.....
- want 600HP, which block to chose?
- Turbo Tech >>> GM 4L60e
- Turbo ? possible problem
- what does everyone run for crank ref deg on bigstuff3?
- Anyone done any real life testing or gear ratio diff with turbos?
- APS Twin Turbo Kit For T/a
- New Set-up..Procharger guys inside please!
- no good news, but cool pic
- Is this cam ok for a Magnacharger?
- Deleted Post on LS1 Tech
- F.A.S.T. O2 sensors for FI
- D1-SC with Torquer v2?
- proper oil pump for 427 boosted?
- Harlan 2 step?
- STS or P-1SC
- Best FI set up to keep A/C
- Is anyone doing COMPOUND turbos?
- 6.0 truck headers
- Pics Of My New Twin Turbo Setup
- **********summer Mod Marker**********
- Choose a supercharger for LS1?
- Traction control and MAF on a supercharged LT1
- Anyone got a video of an F-1 supercharger on an F-body?
- Gaskets yes or no
- poll: biuld or boost
- OFI update after some miles on the kit
- boost gauge mech or electric?
- Update to my "no/low boost" problem
- uh-oh fbody d1sc bracket and tension pulley
- Gen-TT Truck Twin Turbo Kit
- A little help choosing a fuel system
- a new catch can option from...home depot?
- 1996 Vortech ignition recomendations.
- Porting help all stock
- How would this cam work for FI in a 408
- What Intercooler? SS or Non SS Piping?
- Methanol Injection
- Can we discuss air filters?
- Over spinning a D1?
- got the 6 point roll bar installed. just need tires
- what do you think it will make on HP
- 1999-2002 F-Body Big Stuff 3 Integration Harness (Plug and Play)
- Clutch ?
- Acceleronics Versafueler w/ 96# Injectors question?
- STS boost!!!!
- Threaded LS1 IAT sensor part #?
- ST80 vs T76gts ***PICS***
- intercooler integrated with intake manifold?
- help with my STS oil problem
- Backpressure Sensor ??
- belt length for a p1sc 3.5 pulley
- anyone makes a truck manifold pipe kit?
- Boosted 6.0 Intake Manifold
- Twin Turbo Recommendations
- I hope that i have better luck here...A/W IC gurus... need input
- exhaust wrap for sts turbo
- Thumbs Up To Bob@epp!!!!!!!!
- Can someone guide me..
- guesstamate on what rwhp i should be able to make
- New here, How bad is this cam going to hurt me.
- need advise
- STS Turbos On Sale / Installation
- good read on supercharging...
- Kenne Bell/D1SC cam difference (For C5)
- sdce owners chime in please
- My Lucky Day, I Won The $500 A&A Corvette Online Givaway!!!!!!
- Timeslip with 6.0L Turbo GN
- L92 heads with a 122HH Maggie?
- Debrits & STS (pics)
- Best Cam for STS turbo setup?
- Ohio Boost System
- Injectors for the STS?
- DIY PT88 kit
- Whats the highest hp you've seen on stock cubes and 93 octane?
- LS1 TT for 67 Nova
- Anyone running Patriot 6.0L heads??
- Question
- Just bought a 6.0 block, 370 or 408
- EPP doing an APS twin turbo installation on an '07 C6.
- 03 Silverado SS 76mm build
- Lysholm instead of root type...
- STS turbo w/ g5x3 cam
- Turbo Tuning Q's
- New Pics of my 348ci/ GT47-88 Setup
- Overspinning Your Centrifugal Blower??
- Manual Boost controller hookup
- Still cant make boost
- 347, 15 psi, pump gas only, mild cam, what SCR
- V6 Turbo
- Silicone Coupler for A2W intercooler help...
- Another update on my build...installed the A2W intercooler
- Procharger leaking oil?
- ls2 going TT kit what heads?
- Magnacharger pics and dyno
- where can i get a F1,F1A,F1R?
- How much power will stock internals hold?
- durability of a stock boosted 5.3 at 600rwhp
- Boost Problem on launch
- Help - what's this
- LT1 hotside
- Smaller pulley = higher boost at low RPM?
- What thickness Head gaskets do I need?
- Vortec? naw. Magnuson? Naw. 8-71? PFFF
- Anyone running 418 cid with boost?
- SX88 Compressor wheel
- Danm!
- Lookin' for Procharger pics
- Magnacharger Boost ??
- got my blown car to run cool... finally!
- Anyone have pics of there Vortech YSI Setup?
- Intake Elbow
- BEST Turbo help me out guys.
- Good on almost stock?
- Have you ever seen this much room for a turbo?
- blown/boosted 454 LSx, worth the coin, worth the effort?
- Gen-TT Twin turbo install today :)
- Low compression, Incon kit & rear gearing.
- which tt setup , aps, ls1turbo, or custom?
- OFI 4" DP Install Pics
- 408 with rear mount 76 GTS dyno
- missing boss on lq4
- STS 04 GTO... 649rwhp/625lb ft
- the beef is finally here....
- heat wrapping
- car having trouble starting
- Anyone using a TRT FMIC...
- LS7 with KB / Lysholm / Autorotor or dual Rotrex
- AIT...too hot?
- Help with MBC, cant add more boost
- turbo+M6= what rear gears
- Cammed LS2 GTO adding ATI D1SC...do I have the right parts...?
- air to water intercooler questions...
- 87 Buick GN, LS1 turbo video
- New dyno #'s for my TT v6 firebird
- E85 + 93???
- Which is the best supercharger? 4.5 & 6 PSI. And the best price for the LT1?
- P/N for 3 bar map sensor OEM Z06 manny
- Fan question?
- Putting together my first FI car,have some ???
- MS3 ok for boost?
- vortech v9(non-sq) kit videos?
- car stalls
- T4 GT66 for 346?!?
- Anyone know where I can get 4" v-band clamps
- Is it ture?
- Who's running Methanol?
- Is anyone running nitrous with there turbo setup?
- Stock LT1 Camaro with STS Setup
- Realistic gains going to an F1A from a D1SC?
- Twin turbo v6 firebird pb vids
- Custom Cam
- Heads lifting under boost: avoid?
- help! need a little info about a paxton supercharger, way to low boost,
- LSX High HP
- eBay flanges vs. StainlessWorks flanges
- Good Deal or Not?
- FMIC Kits
- Still planning FMIC or 4.5's ?
- Thinkin about a Procharger
- Pic of my car on a dry lakebed at sunset
- ForcedInductions.com ??
- Turbo Guys...what do you do for tuning?
- F1R vs F2
- Thinking of Turbo setup, please comment !
- Update for my car
- two totally unrelated turbo questions
- plumbing a boost gauge
- T66 big enough for 370ci?
- turbo gurus ? for ya
- Supercharger Cam
- Need a lil Help...Rear turbo want more power any suggestions?
- What brand?
- hell fire rings??
- Turbo, intercooler and fueling questions
- best turbo setup
- ZO6 comparison: TTI - APS - PROCHARGER
- Just a curious question about out D1SC....
- Needed good tuner in Maryland
- How much boost???
- who wants trouble...
- INCON Help.
- Pro Products Throttle Body
- cme and sts turbo
- Forced induction parts for sale
- installing turbo in my car
- Question - TT and Heat
- Tuning/Drivetrain question
- procharged car with high miles??
- steel wastegate flange
- Need help bad!!! PTS and other boss alt guys please come in
- ATI Pin on crank snapped
- eBay SBC Turbo Set-up
- oil in turbo- hot and cold side
- mustang d1 headunit
- Best manifold for procharged sbc?
- a few wiring questions for you turbo guys- fans- map- etcc
- Spark plug gap
- Your opinions on a custom spec'ed turbo cam
