View Full Version : Conversions & Swaps
- Valve covers with coils inside
- Carb Conversion MAP sensor
- Hot Rod Rule Change
- I'm confused about oil pan, fuel and steering clearence with certain mounts - 68 bird
- LQ9 in a 1957 Bel Air
- Radiator & Air Bleed question
- ls1 4l60e swap in 76 c3 stingray shifter linkage help ?
- Anyone package ECM flash with new cam?
- Odd pcm behavior in conversion
- Corvette LS1 mounting bracket\ear
- FAST EFI setup for sale (perfect for an ls1 swap)
- cts pan in an "A" body
- 2003 ZR2 issues
- First start video.
- Need help with alternator wires
- Newb ?
- Swaping an Ls1 into a 94 5spd. rs camaro???Anyone know how???
- LS-1 in a 1977 vette
- did your hooker LS1 headers come with O2 bungs?
- Some pics and blower questions.
- No Spark please help!!!
- Top covers not working out.
- Few pics of my 240sx
- Conversion twin turbo setup....
- 5.3L with a 4l60E S10 V8 swap.
- sticking a 02 vortec 6.0 in a 84 bagged and body dropped 4 door dually
- Another "Painting the Fuel Rail Covers" Question
- conversion help
- where to get a balancer installer
- injector question motor ID
- What about ls1 swapped skyline r32 ??
- LQ9 to TH400
- Where can I find a good deal on a 6.0L
- help with a plug
- 1968 Firebird LS1/BOP TH400 will it work?
- 0-60mph=7.67sec. should i be happy? jeep wrangler conversion
- ls1 headers for g-body
- hooker headers in an "A" body(chevelle)
- mustang ls conv. headers and exhaust
- Tri-five Fuel Milage with LSx motor?
- LS1 swap in suburban???anyone done it?
- LS1 in place of a LT1. In a Jeep. kinda.
- BRP Kit + LQ4/4L60E + '72 A-Body = ?
- LS1 Oil Pan on LQ9
- Doing Some Research!!!!!
- LS1 race car wiring with batt/alt disconnect
- LS1+third gen
- 98 alt. wiring
- Exhaust Manifold for 5.3 in a 1947 Chevy car
- How 2 Mustang LS1 Conversion?
- exhaust manifold flange help
- man, i am about to give up
- effort to get 1st gen LS1 headers into 2nd gen?
- LS1 into a Reg. Cab Silverado?
- Anyone done a Mercedes 90's SL LS1 swap?
- Anyone ever used Entropy radiators?
- 2003 5.3 Yukon Wiring
- need help to emissions obd II
- who makes the least expensive t56 master moutn bracket?
- Aftermarket Throttle Cable?
- how did you clean your ls1 before the swap?
- where is the cheapest place to get a start up tune? 99 ls1
- 1st gen f-body quarter or eight mile times?
- Am I crazy to sell my F-body and convert a G-body?
- "massaging" the trans tunnel on a fox.
- Doing LS1 swap in Washington State -- what are State Requirements
- 66 Nova 6.0l Alt Wiring Problem
- 6.0L swap???????
- Looking for 2007 ecm pinout with DOD and knowledge of DOD
- Vortec Lq9 With Low Profile Intake (???)
- Stock 5.3 manifold fit...
- 04 GTO Throttle control module-Bypass?
- 98+ LS1 S10 Guys - Pics?
- Exhaust for LS1 68 cutlass GM A body
- ls1 into WRX...... can it be done???
- Multi-swap & s10 Front suspension rebuild
- PCM issue w/convertion
- Swap a 6.2L into a 2007 4.8L Silverado
- Megasquirting your LS engine??
- What would my setup run if i transplanted it into a FD rx7?
- 69 camaro disc brake conversion HELP!?!
- 1997 240sx with LS1
- Need a FWD manual transmission for an LSx
- Running on a stand...
- s&p headers in an a body w/4l80e
- over heating LS1 in 35 chevy sedan
- Help!!!
- LSx into a '99 BMW 540 E39
- Which Sensors Do I need?
- VSS to Speedo????
- Any RX7 1st gen conversions?
- 1964 Chevy II Exhaust Manifolds or Headers
- 96+ S10 LS1 guys - passing the OBD2 Inspections?
- Going Carb'd on my Third Gen LS1
- Newbie here.. please help with wiring question
- How many think we should have a "Conversion Parts Only" for sale area???
- Guages...
- 911 LS1 convesion
- factory gauges and ls2
- 5.3L into a 1995 Silverado
- which is the VSS connector?
- Gto Ls1 Oil Pan Gasket Part Number?
- lt1 to ls1 guys... i have a part you really want :)
- t-5 transmission
- harness power question.
- Diagnostic plug??
- LS1 help and your opinion on wiring the harness
- LS1 alternator hook up
- odb1 to odb11 plug changeover
- Problem with 240sx / ls1 swap fuel issues I belive
- Hey I need help finding
- S13, LS1. Pic's!
- ls1/t56 swap. which gauges?
- lq4 and bellhousing bolt holes
- what is the best way to ship a complete engine?
- lq9 into 98 z28
- How much should one pay for a engine and trans?
- Driving impressions of my LS1 powered Seven...
- early 70's pickup conversions
- Distributor Question
- Another newb with another different vehicle
- which stall for my LS1 Silverado
- LX + 408 + thumper (pix)
- question guys ls1 to 6.0 conversion in a camaro
- Looking for ways to build a quiet exhaust?
- Advantage of running a Ford style TB
- 1970-73 camaro swap
- 99 pcm with 05 harness---NOT
- ls1 into 68 camaro
- 66 Nova SS/ LS/ Procharger - intercooled
- 1967 nova ss LS1 swap help....
- Wieghing 86 Nissan 300 ZX - LS1 project
- Few pics of the LS1 going into my 95 Z
- LS1 swap running like S**t
- will the stock 69 console with with a T56?
- ls1 in 94 z28
- corvette engine covers w/4 barrel intake
- First post - Installing a Gen III/IV in a 1991 caprice
- Ecu???
- Identifying a LQ9......hopefully not a LQ4.
- 5.3 What is this sensor and can I lose it?
- Vortec swap help
- 6.0 w/carb, Need Help
- Q's about walbro 255's
- Good GM online supplier ??
- v6 ac bypass belt
- need some help, please, long...
- Need to find out if my new steering rack is indeed a LS1 rack
- L92?
- Power steering on right side ?
- Anyone have a carb'd third gen?
- BMW E36 LS1 Swap Video
- Help planning fuel system on first Gen
- LS14 catback?
- HEI & Carbed LS Motor
- Can I Swap?
- Does Traction Control cause computer issues in a swap?
- A couple vids- 81z28 LQ4 swap.
- I have a S&P vette regulator set up that i do not need.
- Looking For LQ4 super charger
- progress LSX stang swap build
- 1998 V6>LS1 Camaro build (with pics)
- All post '98 T-56 the same?
- I need help with an old starting issue problem
- Sorry for the dumb question.
- LS1 > V6 fbody shifter boot
- corvette accs. drive in an A body
- Mil Q:
- First long haul.
- 99 truck alt and 98 f body harness????
- S&P Collector flange question
- Engine/Transmission adapter plate?
- LS1 & T56 in 69 Camaro mock up question
- LS1/T56 swap Mustang track time and dyno
- Compression Tests
- Clutch master cylinder size?
- ls1 into an 85 4x4 pickup questions
- what are the best mounts for ls1-t56 in 79z
- aje mustang swap ?
- Need Some Help
- LSx into a G-Body in NC
- Selling my front mount turbo setup - LSx in 72 Chevelle
- Swap oil pan, swap windage tray too?
- 4th gen dash in 2nd gen
- Different oil pan?
- 67 Camaro Vert- LS2/4L60E
- E36 BMW LS2 Swap - Oficially Finished
- Mulling Over Third Gen Swap
- need torq specs
- knock sensor harness part number
- You want GM cruise control on your cable driven TB
- lq4 with l92's in mustang
- ls1 in a 93z , or 99 v6?
- name this connector!
- LS1 in 96 camaro, how to use fuel lines and bypass return?
- recomendation for elec. fuel pump carbed LSx
- pcv system with a carb
- I need your Advise Plz
- 4l80e -> 4L60e wiring
- Bolt size for LS1 adaptor to 69 Camaro mounts
- ECM location, GM A body '68 cutlass
- My LQ4 powered 81z - new rims.
- 1st Gen s10-5.3/th350
- GEN III/GEN IV Engine Bolts/Hardware
- LS1 exaust manifold question
- 87 RX-7 future swap
- Speartech LS2/6L80E swap
- hyd clutch mounting bracket-suppliers?
- 58 Apache 5.3 4L60e on the road
- more bad news
- Alternator mounting problems
- power steering in a 240sx.
- LS1 in 2003 s-15 power steering question
- conversion wiring ?
- AC hook up Question...
- LSX engine hardware chart
- Check Engine Light Wire????
- LS1 into E36 KIT
- lsx engine mounting question
- best acces. drive for A body
- Could this be a first for a LS1 swap !? Hmmm...
- Drive by wire pedals
- upper rad. hose
- started truck...have concerns..LONG!
- DBW part numbers
- ls2 in a 98 firebird?
- 5 speed ?
- ls1 block dimensions
- Ever been done?
- 24/58 relucter
- Where to Find An Inexpensive Air Intake Reducer??
- Conversion shop in Dallas
- LS1 technical drawing anyone?
- One Day It Will Run, The Next It Won't???
- LT5 vs LS1
- what is the amp draw on F body fans?
- Ls2 Gen IV in 86 Caballero
- What header gaskets
- alt. help
- 2 Mustangs $3000firm Dfw
- LS1 mustang track times
- F-car cooling fan high to low sequence of operation
- 72 Firebird swap complete
- Ls 94> s10 air intake setups
- TCC Wire
- New LS6 Mustang setup with pics
- LT1 6sp work w/a LS1?
- Swapped GenIII will fire but not start
- 6.0 mustang
- cyl head freezeplugs
