View Full Version : Forced Induction
- ls1 magnacharger to fit l99
- FrozenBoost??
- Ebay Turbo Kits???
- increase power but not boost?
- Lq4 +F1r
- 6spd FI guys and no lift shifting (lingenfelter lnc-003)
- HS turbo kit with alternator relocation???
- Merry christmas fi people
- Anybody have procharger pullies?
- Boosted 5.3
- Head/Intake question w/boost
- no intercooler
- 69 Firebird LS2 Twin Turbo HELP!!
- Which is better turbo build, LQ4 or 5.3. Need pros and cons.
- Guys I need some help
- Perfect gears for turbo M6 setup
- Who Is Running a GT91?
- Crank Question
- NYC Tri State area
- turbo sizing definition!!
- Pro Flo XT...install help needed.
- Need help identifying a turbo kit???
- stock truck cam?
- Second cable attached to throttle?
- Looking for wrapped truck manifold pics
- Opinion on "refresh" of a stock 5.3
- 11.5 compression and boost-why not!
- Help! Will my current cam work with a supercharger?
- s475 on untouch ls1, what to expect with 9psi
- STS turbo build soon!!
- STS Kit Build????
- TT + 390ci..........which turbos....Modular Turbo CBR F2....
- Procharged LSX mustang
- Turbo cooling question.
- Wishing You a Supercharged Holiday Season
- Boost and rwhp
- Crazy turbo setup idea need help
- 02 Ws6 trans am with a junkyard diesel turbo? sure why not
- My new sleeper!
- Undersizing or Oversizing Your Turbo: An "Honest" Discussion.
- tech question
- is it to big
- FI guys at or near the 1000rwhp mark, what flexplate are you using?
- 400+ ci LS9 blower speed?
- Twin Turbo cam
- The power (Literally) of ignition timing
- Worth the build?
- crankcase vent for cam /D1sc
- 5.3 twin turbo
- LS1 243 heads and pro charger build?
- keep blowing headgaskets/ cam too small ?
- 67 Nova SS. Pro Touring. LS + Twin 72's. 1000rwhp plz.
- how much boost are you pushing your stock bottom end iron block?
- discussion about overlap in a turbo cam
- T56 Rearmount GTO Cam
- Anyone run a big cam with turbo?
- need help with ls1 turbo combo!
- Heintz Racing resets IRS GTO Record @ 8.74! Plus a few other great runs.
- NXS Spring Loaded Manual Boost Controller Question
- Need some opinions
- V2
- AES Announces Our First Year End Sale!!!!
- 02 Turbo Camaro Exhaust Question
- Wanted: Twin intercooler and Procharger
- How many still have A/C?
- Does unequal exhaust pipes matter?
- Catch can with return style BOV Question.
- Procharged G8
- Thinking about completely changing the direction of my car, advise?
- 370 BW s480 e85 non intercooled build
- How much boost and hp will a stock bock, forged internals LS2 handle?
- Boosted 5.3 guys drop in.
- making LSX happen everywhere
- TC78 + 390ci..........will it make 900 RWHP....?
- New best 78 Turbo Trans Am, cam only 5.3 rear mount Turbo 10.22@140.98
- good idea or bad- twin turbo oiling
- TC78 BMW build
- ebay hot parts kit
- I did some LSA head testing!
- Where can you find official rules on the stock shortblock record?
- Changes for 2013
- How much HP can a stock ls2 handle?
- Where to place wideband sensor on twin turbo
- do I need to run a thermostat?
- What size intercooler on 71 chevelle Single t76 turbo??
- Head studs ?
- 68 camaro 5.3 single turbo swap, what manifolds?
- 408, S488 turbo build feedback
- 69 Camaro twin turbo build - Loads of pics
- T78 + 4L80e + e85 + stock cooling system and AC round 2 **dyno vid pg 3**
- Road Racing twin turbo 5.3 cam and turbo selection...
- New Project... need advice, opinions and help
- Flipped C6 Manifold for Driver Side???
- Huron Speed *Special Edition* Truck Manifold Turbo Kit end of 2012 Special!
- bv57 and ysi settings
- building turbo headers /log
- Using meth to compensate for more boost on current tune?
- First Gen Manifolds
- New BAD ASS Turbo kmember ( DKT/BMR )
- LT1 Turbo Tuner in / near NC ???
- best short block?
- 408, GT55-94, E85, Glide, Truck manifold build thread -- UPDATE 06-29
- burkhart chassis-Thanks
- LS9 cam ?s
- LS6 intake how much boost
- First turbo build
- Edelbrock Vic Jr VS. Edelbrock Pro Flo XT
- Boost creep issues please help!!
- AMS-1000 Boost Controller
- 626hp 800+Tq!!
- AES 390 users, how do you like it?
- Twin turbo LS1 heads question
- Oil for fi
- flywheel choice
- What fans for procharger?
- need help to make my part list
- S475 Billet wheel
- Will it make 1000 RWHP??
- GN TB0348 Turbos?
- Check out my sweet new turbo merge
- FREE Installation & Tuning of Prochargers
- VNT turbos?
- Help!!!Info needed...TURBO LS1 CHEVELLE BUILD
- Sell me your turbo Camaro or Trans Am
- Something went wrong, ticking and smoke...
- what size turbo /injectors/tb/regulator
- Homemade Turbo Build fuel problem :( (video up)
- Any 4th Gen Maggies still out there?
- APS parts?
- LSX 427...is this power a little low?
- quick question: procharger pulley jack screw
- Lifters for stock turbo?
- Stock 4.8 & t76 What cam???
- FAST 78mm Throttle Body Question
- Arp head stud question
- Going to a new setup! 408, and 91mm
- ~Procharged ls1 f-body 1/4 mile times~
- stock 6.0L 8.81@161
- stainless turbo tubing and bends etc.
- Turbonetics 6665 Twin Turbo build, Fab process started Post #71! finally!
- MSD Timing Twister users. Please come in!
- MS1 and Micro2 tune, downloads.
- Need help on some steel cable ties please.
- Help on used motor?
- need your advices please
- What muffler(s) maintains TURBINE whistle?
- Quick help! ATI SuperDamper removal.
- 5th gen twin turbo build
- Head selection advice
- Recommended gear ratio? (FI related)
- TC78 9.05 at 150
- what size turbo?
- Dyno numbers stock bottom end, D1 procharger
- Truck manifold hot side
- stock manifold pictures?
- Procharger pulley for 6-8 lbs of boost?
- Howards Turbo cams?
- inlet pipe size?
- EMSpro testing for EFI source (even more MS stuff)
- big boost with wiseco pistons
- Christmas special on Whipple Superchargers
- Made it into new GMHTP
- Procharger Rebuild
- Our Shop Car 427/88mm setup
- On 3 Performance Introduction, New Turbo System Details, And Photos
- Turbo Support/Braces
- 91 S-10 Front Mount 5.3 L33/GT45/TH350/ Holley HP EFI update 3/10/13
- 5.3L Big Single vs. Twin 76mm
- spraying a boosted lt1
- Wastegate dump into exhaust or air
- Bearings for Turbo 383 Motor
- anyone running power steering with a front motor plate
- First Turbo LS
- turbo question
- Guys with transbrake's and lingenfelter 2 step got some ???
- My car on dragzine!!
- Who makes the part?
- 4.8+ GT45 on notchback
- BW s366 oil feed
- How bad will the tourqer v 3 be with a turbo?
- have the casting issues been fixed on the rectangle port hi rams?
- ~Procharger budget build~
- GT45 vs 6CTAA
- Critique my Turbo Setup
- Slipage, belt wrap vs tension???
- Gauging Interest: Custom Build per Order Kits
- can i boost an lq motor with 11:1 compression
- Attention all KY-Turbo Customers, Supporters, and Friends:
- Twin turbo system supports 1200 hp
- Proper BOV spring?
- ?? water intercooler pump switch ??
- Lets see some s/c pics
- Holley Intake question
- Procharger questions
- 85 c10 5.3 turbo build
- new to FI
- c6 manifold turbo set up
- T70 (on3) questions
- finally hit the dyno
- 12an fitting on timing cover
- How do you build boost off the line with an m6?
- stock 5.3 goes 8.89 @ 157
- 383 S488 Build
- Input needed for torque converter
- 65 Mustang build thread- 404,Twins,Caged,Tubbed,ETC. UPDATE 10/9
- C6 manifold turbo build pics
- Whats the difference between the 76gts and the 76/75?
- Hot side options shorter length vs equal length?
- Name that Turbo
- quickest/fastest stock 6.0L?
- Twin Turbo 92 C10 ????
- just a thought
- Need info for Turbo build
- Need cam suggestions!!
- Would these manifolds work flipped up?
- best cam ratio for supercharger
- stock 5.3 twin turbo build
- which valvetrain for turbo motor??
- Which cam should I use for turbo?(dyno # update)
- Decided how to blow my money. Forged 347 w/ AFR heads, D1SC
- 5.3 Twin build
- Twin turbo street 67 camaro,60-1's?
- Camaro 68 jy5.3 guestions
- Looking for a compressor map
- Help with cam spec's
- lq4 turbo build
- PLEASE HELP!!! looking for a low mount passenger side alternator bracket
- Anyone run one of these elbows?
- 243 vs 241 heads, does it make a difference with a MP112?
- G body 5.3 turbo single turbo, which manifolds
- any manifold out there that will clear the a/c compressor on the passenger side?
- what intake/tb setup for a l92 404?
- Need advice on a GT-45 LQ4 setup
- Crossover flex joint
- EFI Live injector tuning with turbo question.
- stock 5.3 turbo...how much boost?
- eBay gt45, stock 4.8, goes 9.18@146
- Cam for Nos
- What's the fastest stock bottom end LSx?
- Marcella Intake for boost!!!
- Found a cheap bracket for forward manifolds
- whipple 4.0 Camaro ZL1 teaser
- ring end gap discussion
- All Out Bonneville Junkyard Effort
- turbo kit parts ?s
- camshaft opinions please
- 5.3 turbo
- 1998 Camaro LSx Real Street Build Thread
- Chevelle turbo sizing
- Ls6 vs fast intake
