View Full Version : LT1-LT4 Modifications
- GOOD LT1 Tuner in the southeast, where are they?
- Idle Issue
- oil pump gear
- help whats my car worth? (pix inside)
- Fuel gauge, float? what did you guys do?
- rear end noise
- OutlawZ is alive finally
- Oil Pump Drive Problems
- Custom Guage pod, paddle shift setup
- MAP sensor ??s
- 388?s
- re torquing head bolts
- Cam options
- Advice on Rocker Arms
- why i love magnaflow!!
- head gaskets
- Missfire at idle only....Opti??
- About to invest In these mods for my 94 lt1
- Few pics of the Z with C5 brakes..
- reworked the existing AC brkt for the alternator
- What are you guys using for fuel pumps??
- LT-1 SL Mercedes
- Cats?
- Starting problems when motor is cold
- Loudmouth I or II
- what is the biggest cam you can put into an lt1?
- UMI Drive Shaft Loop
- got cam questions
- 355 questions that need answers to them
- 3.42 rear end in auto
- Cam Install question
- Putting her on the bottle
- quick cam question....
- Parts needed for meziere and opti
- So who really makes those Summit TB's??
- need help finding a wierd part....
- heads?exhaust?questions.....stripped plug!
- which throttle body????
- oil pump question
- lean idle problem
- sbc in trans am
- Gear Lube?
- Flashing some codes...any ideas?
- Ownage to the Acura NSX
- LT4 hot cam injector sizing?
- PS 3" ORY too close to fuel lines?
- Where to put cut outs
- o2 sensor or my opti ?
- bolt on or pin on cowl hood? where can i get one?
- Starter nose cone plug?
- Are AFR's Eliminator heads as good as LSx heads??
- I Need Lots Of Help Lol
- Scoggin Dickey Camshaft
- Dyno tune
- Well...I was rather impressed.
- Stock Bottom End Dyno#s For LT1 N/A 93 Octane and on E85
- What does this wire go to? Connector.....
- What Are These? *10 points for ever correct anser:P*
- HELP! Can't separate engine from transmission!
- Car Dilema?!!!
- New Cam Soon
- WOT fuel issue?
- LT1 engine pull question
- Alternator bracket question
- Oil Pressure issue
- dealer license
- what is this?
- lingenfelter valve springs
- Running Like Crap
- Wiring issue with installing pacesetter long tubes
- 97 z28 wont start
- Changing alot of stuff. OPTI related
- True LT1 Guys, NEED YOUR HELP OIL LEAK.
- Stroker Oil Pressure Issue. Plz Help !
- Oil Temp Gauge Install
- Converter question
- Loose oil
- Another opti question!
- opti ?
- Y pipe install question
- quick injector question
- Removing Oil pan
- need advice on inspecting coil/opti
- student on a budget build (could use tips)
- Lt1 huge problem when warmed up
- Emissions Delete / Head bolts Question
- What's the gayest LS1 cam name?
- LT1 into a v6?
- 355 vs 383 vs 396
- Injector Question
- Vid of my E-cut out.
- should i buy?
- Help Please... Big power problem
- How difficult is it to put in a BMR k-member and A-arms?
- Oil Plugs
- Ticking Valvetrain?
- Need emission legal - are mid tubes worth it
- Would I win?
- Gauges
- solid roller vs hydraulic
- 9 inch rear
- whats wrong with my car?
- Where is the cheapest place to buy Jet hot or Hooker ORY?
- Check Twice, Cut Once
- LTX , So who is ready to go???
- Will an LS1 Hooker Y-pipe fit on LT1 Jet Hot Long Tubes?
- LT1 cooling problems
- What ORY fits on Jet Hot Long tubes?
- What cam to use?
- 96 misfire partially fixed...not all the way tho...depressing....
- LT1 Miss fire
- Valve Spring Compressor
- Band clamps
- Ignition Break-up at High Rpms
- SAW THIS ON CRAIGLIST "Ford 302 Mexican Block - $350 "
- Ported heads and intake, plus cam.
- o2 sensors are frustratin
- Lt-1 Wth Omg
- o2 extension's, home made
- Where the hell can i rent or buy a Rear main seal installer tool????
- e brake
- 02 extensions
- Spohn Sway Bars
- Headers: Coated or Painted
- Stalling. HELP!!!
- PCM - MADZ28 (Madtuner) or PCMforless?
- need exhaust advice, please chime in
- Comp cams XFI 467 / Converter question?
- Finally Got Some New Parts!!
- new motor dyno cc503
- NEED HELP!!! My z wont shift
- What convinced you to buy your car?
- lost brakes
- '93-97 Camaro Wide "Sunoco Style
- MAF code
- Long Tube Headers vs Spark Plug Wires
- Exhaust Options
- Finally I Have An Exhaust Video!!!!
- Throttle Body Q
- DTC 24 (Vehicle Speed Sensor)
- A/C not cold, fans won't turn on. Same problem?
- What is FUSE #2 Actuators for?
- Whats wrong with my car???
- TUNE/nn THROTTLE BODY
- 2 bolt blocks
- FINALLY got on a dyno....
- Cost and Info on LT1 A4 To M6 Swap?
- Looking for plug wire ideas.
- where can i order some reducers......
- True Duals?
- Timing Chain Questions
- LT1 what's it worth
- 383 question!
- Started plumbing up the motor
- Corvette wheels?
- No codes any ideas??
- SBC balancer/pulley work on LT1??
- cylinders 5 and 6 misfire
- Blowing Off Tb Elbow.....fixed
- Shot in the dark
- proper way to port intake for monoblade?(pics)
- Cutout Question
- Upper tower strut bar PROBLEMS!!
- Cam or headers?
- hot start "click"
- Still looking for answers. V6 rear into V8
- Where to buy new IAC Controller?
- rear o2 sensor type?
- Hot cam
- Starting to look like an engine
- NEVER underestimate your own work!
- Piston to valve clearance
- Lets See Them True Dual Pics
- o2 sensor
- OTVC Wires
- Racer in need of a Vic Jr. Converted for LT1 - Carbed.
- Electric Water Pump
- Time for a change??
- Selecting proper springs
- SRP vs JE for YSI vortech?
- my turbo lt1 vs stroker supra
- Stock Fbody LT1 combustion chamber size
- Pacesetter to good to be true?
- Help me I'm confused!!! Plug wires/Smog Question
- not sure what to do
- I got my Z28!
- for the guys who dont frequent cz28.com
- Oil Temperature Gauge
- 96 motor in a 94
- PCM Bad?
- Nos vs Supercharger
- bad rings. what should I do?
- Need a part number! Help!
- random misfire because of front o2 sensors?
- Speed limiter????
- Cam to work with LE2 heads?
- Is the 2 otl exhaust 3"??
- Removed the air cond compressor, ps, and bracket
- Problem with fan turning on
- Gotta sick 'bird...?'s
- What next?
- Tranny Temp gage
- OBDII tuning info needed
- who would win
- need some help
- egr delete question!!
- 1.6 rockers/springs
- What sponsor for o2 extentions and AC sensors?
- Spark Plugs Black and Smelling like Fuel? Pic Inside
- misfire because of a p0100 code?
- Help me get my car to pass inspection!
- Timing Chain Cover Help!!!
- does hooker make a mid length headers?
- my waterpump weep hole mod
- how do i connect a 2.5" exhaust to a 3" collector?
- im stumped
- Are new bearings required w/ cam install?
- starting problems and more
- will 11in wheels fit without any modifications?
- Best oil for supercharged lt1? Royal Purple?
- My Life.
- What color is my new car!?
- Headers
- lt4 falling on its face above 5000rpm
- New LT1
- Sputtering and popping.
- A.I.R. stands for
- Chossing coil pack
- NGK Platinum or Autolite Platinum.
- how soon should MAF be upgraded
- Is there a best CAI?
- Piston to head clearance
- Coated or un-coated PS LTs ?
- What's an Ultra-z hood sell for? Pics please.
- changing control arms
- Ses light goes off again
- Question about heads!
- feul filters
- WTB: LT1 in Texas, Arkansas, or Oklahoma.
- Stock GM timing chain
- Exhaust Help
- LS7 Lifters in an LTx motor
- Where is that two tone red & black t/a at??
- How much boost can speed density handle?
- Those in the extreme street class come inside!
- Need A Lt1 Tuner After I Get My Cam Installed
- I Live In Chicago And Looking For A Cam Installer For My Lt1
- lt1 t56
- Gasket Kit?
