View Full Version : LT1-LT4 Modifications
- How To Clean the LTx engine bay
- HP and 1/4 predictions
- Ahhh remembering killagt
- Steam Pipe A/C Seals
- the beginning of my build
- New Wires/Opti...wont rev past 3k.
- pcm dead? fuse blows
- 97 t/a opti installed wrong " will it run!!!!"
- cometic headgaskets fit?
- Need diagnosis ASAP
- 1993 LT1 intake on a 96 LT1
- O2 Sensors, Fans, SES HELP!!!
- 95 Z28 Dumb question of the day
- Weird Knocking? Need Advise
- Installing LS1 (bosch III style) injectors
- over heating issues.....?????????
- heads and cam with 383
- Dumb AC compressor lines question
- Is the 98 & 97 wiper assembly the same?
- ARP Rod Bolts Without Resizing Rods
- Starter shims
- Strange LT1 start up problem, low idle?
- All you diy tuners out there!!
- lsmeng.com for Custom Camshafts!!!!!!
- tuner pro not mating with my car
- Puck's SR 383 build: Results for PTV and PR length
- Tunercat 4l60 tuners help please
- missing after 5000 rpms!!!
- Opinions on Texas Speed Rumbler cat back.
- question about opti's
- lt1 oil filter sandwich
- Tuner Pro
- MAC Headers
- 4l60e th400 conversion .question
- pulling my hair out car keeps dying
- fuel question
- Took the car to the track tonight
- Want to convert your lt1 to carb style intake ?
- Start up / Idle Problem
- Suspension Q's
- Weird oil leak??
- a pillar trim
- My Coolant fans will not come on!!
- IAT trick to pull timing? stock lt1 100 shot wet.
- At a crossroads....
- opti sensor
- few noob questions
- 96 Z28 (LT1) Overheating
- Video of me going WOT on an on-ramp and pegging the speedo today
- Incase anyone else didn't know, Jegs elbow not a perfect fit
- corrosion: harness n opti
- Best set of rings to use on a SC LT1?
- a/c bolts
- carb conversion question
- red97WS6 turn key battery related things go on then silence wont start
- Questions & Opinions needed on what do with car now.
- Tired of feeling body roll everytime I turn a corner at high speeds..
- Idle Clip of new set up
- Need ZR1 wheels special lug nut socket???
- Quick silly question respond asap!
- Exhaust Advice
- bumper emblem
- Rocker arms hitting valve cover? (not stock VC)
- 10 inch rear with 3.73 gears
- Need advice( i have this is the suspension part too)
- Summit Racing seats
- I think I spun a Bearing?
- Fastest true lt1
- Few questions before servicing my lt1
- Alternator Issues.
- Pulling tune from PCM
- CSR waterpump failure
- Cog Setup for Lt1
- T56 swap, crank shaft pilot bearing
- More Issues, Come on in!
- lt4 EFI or carb?
- 95 z-28 PCM and wiring swap to 96 anybody have ideas?
- Going carbureted....
- Front end problems
- For those of you that have been following........i hope its fixed...
- 383 shortblock questions
- My New Racing Group!!
- Starter Too Close To Flywheel - Already Shimmed
- F@#& E-bay headers!
- shutter/shake issues<<<<<<Help>>>>>
- Sound deadening removal...
- Ltx ram air formula intake system
- water leak
- AC Compressor / Wiring Harness HELP!!!
- Lost motor mount bolts? help!
- Starting problem
- Good forged bottom end for boost?
- how to make 93 lt1 work in a 95 camaro
- lt1 ready for boost?
- Too good to pass up!!
- Who has the fastest LT1 record for a full weight car?
- P400 code egr?
- OE Wheels fitment
- Incomplete Dyno Numbers!
- Anyone do a IAT sensor relocation? Looking for pictures
- New Mod?? Need help on converter!!
- 94 LT1 IN 96 V6 wiring issue
- LT1 experts -- have a miss.. local shop cannot figure out
- how the F@3k do i get the plastic off from the wiper trim?
- lt1 intake
- Ebay Header Guys
- 95 LT1 no power to starter
- Picked up the engine today from the machine shop
- heads!!
- summit opti???
- 95 z-28 with a 96 vette motor wiring compatability
- 95 z-28 true dual exaust qestions for CA emissons
- New wheels on my white 95 z28
- Exhaust is too loud inside the car after H/C/383
- 95 and 97 LT1 question
- So what mods to do (budget)
- torque arm bolt stuck
- Taylor cut to fit wires
- New build under way.
- Are painted headers a bad choice?
- Name this noise for me
- Check this LT1 out
- another lt1 back to life!
- Question on balacers
- need LT1 Tune
- Is my exhaust leak hurting anything?
- Wiring problems
- Little Lt1 Muscle
- I has lid now
- Brake Light problem. Help!!
- another budget 355 build
- New mod!!!
- another clutch wont shift
- Wiring EWP and How to mount tranny cooler
- LS1 brake swap questions
- Greeting from the UK. Got a few questions
- 95 harness on 96
- starting my rear mount turbo build
- Harmonic Balancer Help
- And it starts
- 60# or a lt1?
- Extending IAT sensor?
- LE cam
- Looking for review of my LT1 383 Build
- small base cam+1.7 shaftmounts+tall valves=...
- Random top end miss, barely present now, not good enough!!!
- What grommet for IAT sensor in Trick Flow aluminum intake elbow?
- what gears and stall?
- Question about some sending units
- As it gets hotter outside...What does the engine do to adapt?
- no injector pulse on LT1 please help!
- Where did all the PP Throttle Bodies go?
- Help!!! Oil pressure problems!
- dumb question about tires
- LT1 Oil Pump
- Two things, When replacing a tstat...
- MAF code questions???
- Balance issue
- It started!!!!!!
- LT1 Isky cams
- do you guys think this is asking too much?
- Hot Cam Dyno....
- build thread...good news
- RF/EMI Effects on a computer.......cool stuff check this out
- LT1 Goes under the knife...again
- hyd roller vs flat hyd lift numbers?
- Helpful mods
- Overheating Issue
- Ignition System....Gauging Interest....Opinions Please
- 1996 Formula revived.
- Timing Issue With New Stroker Build
- Can i use this steering wheel?
- LT1 Starter wiring probems
- Fun Twist on Throttle Body Plates
- LOOKin FoR a New Opti
- My LT1, bye bye.
- Help my car has a weird squeak!
- Wiring Question
- Oil pan help
- Shortys vs. Long Tubes
- suspension and frame set up
- Scanner not responding
- Probe dish pistons vs Flat tops
- 383 who can tune it?
- Split BLMs with closed throttle
- Cam selection question: Is this cam that I'm looking at fit my goals?
- Ghaaaa Optispark!!!
- which suspension mods??
- fog lights
- LT1 Carb Setup
- 2002 slp loudmouth and y pipe
- URGENT: Chamber size, CC's for 1995 LT1 heads
- LT1 Head Gasket Replacement Parts list
- 94 Z28, Is it a sin to modify (see photo)
- It's alive!
- Please tell me I've figured this out....
- For the love of God, Please help with misfire, stumble problem
- Aligning k member when reinstalling
- Confused, tiny gasket leak maybe?
- LPP y-pipe doesn't fit right
- Bullets or XR1
- Smallest Mini Starter for Shorty Headers
- compadibility of pcm's?
- Bare minimal to hear the car run??
- Local LT1 Stock Eliminator Car
- 11' camaro wheels on my lt1?
- Ac prof. charged still nothing???
- TPS in need of adjustment?
- What size serpentine belt?
- Low Profile Oil filter and why brand of Oil
- lt1 to ls2
- Best place to buy an assembled ahort block?
- reving up and down????
- Water Pump Noise? Video Inside. Help.
- A little over heating problem!!
- LT1 ram air box with non-ram air hood?
- factory tach calibration?
- New 255 walbaro fuel pump
- Just arrived to Cocoa Beach FL, Patrick AFB, Need Alignment and tune FAST!!!!!!!!!!
- HELP! BRAKE light stuck on, not the switch!!
- What Cam will get me into the 11's? if I can with my mods..
- Has any used the Be Cool Radiator on an LT1?
- Why is this Happening?
- Almost ready to start...few ?'s
- Need help finding Cat Look-a-likes
- 1997 Z28 wouldn't start temporarily
- Leak Down Testing
- did I trash my pcm?
- What vendor sells NGK TR6
- qestions on Rear mount turbo LT1
- forged or not
- Canton Valve Covers, PCV fresh air tube????
- Where Is The Coil Pack and How Do I Replace It??
- First time at the track
- This Tstat, yay or nay? Crap or gold? Good or scam
- 550 hp lt1??
- Cnc-motorsports.com
- 95 LT1 ignition issue
- Got EGR delete question.
- ac compressor
- what are the symtoms of a leak in the header gasket?
- E-85 qestion
- How high should I go with my Compression Ratio?
- ECM reading 1350 F. on Cats
- Removing and reinstalling a starter
- 94 lt1 going into 96 V6 car
- Little Help? A/C Q's
- '95 LT1 breaking up at all RPMs
- DIY head porting question
- new twin turbo project
