- Project Lightning...almost done!
- POR-15 the STS turbo housing???
- STS turbo kit
- Brain fart
- Sponsors who are Precision dealers???
- sooo close, twin turbo buildup
- how much psi can I run on stock bottom
- Pretty head repair
- gains witrh racegas?
- Maggie cam and differential gear ratio
- Latest Incon Dyno - 644/701
- Wastegate ????
- Please Discuss here: Does Oringing the Block/heads make an engine stronger?
- STC/Hi-Flo Street Force TT Vette - 692rwhp/660rwtq STOCK SHORTBLOCK!
- It runs
- anyone run f3 or f4 procharger..?
- What wastegate are you high hp guys using?
- Which Turbo?
- turbo cars at the track?
- need help guesstimating rwhp
- Holy Pressure ratio bat man... BW turbo maps
- What Kind of Exhaust are you running with Procharger/Turbo???
- Stock MAF with Procharger or Aftermarket...
- Look out HUGE breakthrough in turbo design..
- Hurst knob -- high boost switch for turbo
- Where is a good place to buy turbos.
- Will my 2 1/2" Exhuast Handel FI POWER?
- What size belt for 02 Powerdyne kit?????
- Attention W2W engine build customers
- Procharger install how-to?
- Blower belts?? 52" 8 rib?
- Predictions for HP on new setup...
- NEED Powerdynesupercharger Impeller
- Progress Pictures...
- Solid Roller Turbo Dyno sheets
- Gauges Needed with FI...
- Weld Ells vs U-bends
- Magnuson Mystery Part !!
- where to find reasonable 4 into 1 collectors
- anyone running a LT1 PTS turbo kit
- mild steel down pipe?
- "Roofer Dave's" engine lives!!
- Hi Flo website down for a few days for construction
- SIN 14 featuring Hi Flows TT vette
- Yeah, Another STS post.
- Folks with FI and Vacuum modulated trannies inside, please
- which makes more power?
- '05 C6 coming in today to begin installation of an ATI ProCharger
- Almost done with my 408 turbo truck!
- supercharged 402 or 408...
- ASP pulley has more slip than Vortech Pulley - Why?
- AFR with Turbos....
- Can I run a supercharger on a h/c/e ls1?
- NGK 3 and 4 Stage Colder Plugs...Good for FI?
- supercharger people, a little help if you would...
- LS6 intake manifold restriction?
- Finished up my truck manifold turbo set up..
- twin turbo 427
- Water cooled turbo here, need coolant feed/return (did search)
- Spark Plugs and Wires for FI...
- Zex spark plugs
- LS1 motor/ATI procharger/1970 Camaro
- Another Ohio Car, first pic release!
- Tial Wg?
- TR 227/224 114 good turbo cam?
- turbo kit do i want the ground zero log style
- Fuel Pump Question...
- Yet Another Turbo Ta Buildup
- Some updated pics
- Stenod White Formula...Motor, Turbo kit and fuel system for Sale!!
- Best plug for magnacharged 383 with meth
- best stock fuel rail setup?
- Turbo oil drain line size?
- New Edelbrock Intake
- STS system
- Turbo/component selection 347...
- 908rwhp 908rwtq Speed Inc. GT76 single turbo
- Cost to upgrade a P1 to a D1?
- What to do??????
- 1143rwhp, 1119rwtq Custom PTK set-up
- whats a quiet muffler for turbo app?
- PTK Turbo Kit set-ups, please check in!
- Guestimated RWHP???
- Turbo Exhaust Setup
- what am i missing?
- ATI aluminum damper with SC?
- Project Lightning...Big A$$ Intercooler pics!
- Finally got the engine running right but now.......
- What are the bolts sizes for the bolts that hold procharger to J bracket
- More questions for you STS experts
- ATI Super Damper with supercharger?
- first tuning session of new setup
- Truck manifold setup's
- Finally got to the dyno part 2
- sts exhaust
- AFR 225's, Stock Bore and Turbos?
- Best Meth kit
- Oil in down pipe
- Best material for tubular turbo headers
- Turbo Carnage (pics)
- STENOD Build-up Pt 4
- Any research on T3/T4 Hybrid vs T4 turbo flanges?
- Thinking ahead, need opinions. Which blower?
- looking for a Good daily-driver turbo setup
- Powerdyne missing Parts?????!?!!!
- SDCE guys in here
- How much BOOST with stock heads?????
- Our phone lines and a snow plow...
- Newbies with boost...
- Status on PTK install.
- how do u get oil to turbo?
- Clutch for FI guys?
- Comp 206/212 for turbo truck...
- E85 boosted setup
- My 05 GTO twin turbo kit arrived
- vacuum operated cutout for turbo setups?
- Turbo Cam for STS
- Incon car blowing smoke(oil) through exhaust, need help
- How well would u think this Motor would work with FI?
- STS guys
- 6.0 Manifolds
- turbo repeat
- Almost finished!
- what belt for 3.5 pulley
- getting ready to drill oil pan
- turbo quad question
- LS6 & 225cc or Carb & 205cc
- 150 passes + 14psi + graphite head gaskets + stock heads =
- Octane Question
- W2W Tecstar Rotrex?
- Building 408 for my D1 Procharger Setup...opinions!
- Chevy turbo kits
- need a mounting bracket for my supercharger
- tang or on center
- Bored of the 408 F2r.. What next?
- Problem with autometer A Pillar
- Waistegate Atmospheric Dump
- 222-216 reverse split cam with a supercharger?
- 2 step explanation?
- STS owners?
- ffhp's single turbo for corvette
- The new setup!
- Might be picking up a 98 Z28 w/ turbo and blown tranny...need tranny advice (A4)
- IAT sensor mounting...
- waste gates and blow off valves
- ati twin intercoolers on an sts kit??
- turbo or pro charger
- help me decide on setup
- Hi Flo Twin Turbo
- jethot 2000 for turbo manifolds?
- LS2 Compression ratio for a blower?
- gage pod and boost controller pics
- Would you build a 408ci TT or purchase a Viper and TT it?
- 98 ss with powerdyne. having problems
- 224/224 and procharger
- STS leaking oil on exuaust pipe
- Anyone have any HI FLO TURBO DYNO # YET????
- FI Question
- STS turbo for $3500 (new) a good deal?
- First trip to track w/ new ATI setup
- check this out!! twin whipple
- Vaccume pumps and dry sump oiling...
- So i had a fun sunday did everyone else?
- Tell me why the turbo guys don't use shorty headers?
- Best electronic boost control
- Do I need a vacum pump?
- OMG!! Not another "what turbo" thread...
- Best Oil Catch Can/tank?????
- F.I. SCR issue (request advice)
- Compression ratio too low?
- STS SoCal
- i have a question about heads. help
- O2 placement for STS turbo answer
- Anyone running PRC Dual Springs with Boost?
- Performance Racing Industry 2005 Photos!
- Professionally Installed
- 363 versus 383 cid with a T-76GTS
- best compression for whipple charged 408?
- PTK mock-up
- Where does your combo make peak torque?
- question about turbo lag
- Vortech TA & C5
- T3 with .84 a/r or T4 w .81 ar
- not ls1 but double your hp at 8psi?
- Sts T60 A/r???
- H/C D1 Question
- Turbo kits For BBC
- Time to lose the tubular turbo manifolds..
- I got the SDCE setup, but i have a question.
- anybody boosting 402+ with stock heads and built bottom?
- My Powerdyne Is Broken...help!
- Reverse Casting Turbos?
- help with my heads.
- nice turbo vette
- Ordered my Novi 2000 today, Need help with fabing mounting brackets
- 2005 SSR Automatic "Radix" Dyno Sheet
- how much is safe
- air to air converted into water to air ?
- Few temp vs boost numbers and other math fun..
- Long or short primaries on headers?
- Anyone use a TV8101 or simular
- Magnuson on bone stock LS1/A4
- Please help me get to 600 rwhp with Mag on Vette
- STS with long tube headers?
- Advice on Gauges
- how many turbo lt1 cars and setups on here?
- 408 poll, help me decide
- Ordering a quiet Procharger
- mp t70 what kinda power
- ARP bolts or studs?
- Pro Turbo Kits Pics
- Those w/ MMS Crank Pulley
- tr227 reverse split cam with blower
- Fel-Pro head gaskets for FI?
- New Turbo Kit??
- Which size should i go with?
- I got oil ,vortech
- Turbo on the SLP motor
- New project help! 402 or forged 346 w/ FI? Goal=500whp
- Yet another head gasket issue
- Rear mounted turbo ...
- My Stenod Performance Project Update (*PICS*)
- Porsche's new turbo technology for the 911
- Forced induction head gaskets
- Procharger FMU for 99 LS1???
- Fast 78 or 90 intake?????
- fuel system ?'s
- New motor?
- Please comment on proposed advanced set-up
- Turbo with hotcam??
- Manifolds and Welding
- How much boost can this engine handle
- Vortech/Procharger?
- Procharger - Reverse rotation ???
- Wastegates and PSI rating-
- Venting To Atmosphere Cons
- Cam for turbo ??
- 10.3:1 CR too high for a blower?
- Rear-Mount Single turbo goes 9.33 at 149
- How soon can boost come in (rpm)?
- mechanical vacuum/boost gauge guys step inside
- Track times for my turbo setup...
- LS1 5.7 - Turbo
- Help
- Question about cost..
- Turbosmart ProGate Question
- super charger info
- Newbie questions
- Special order (quiet procharger)?
- FINALLY finished...
