- borg warner s400 75mm turbo w/t6 hot side
- Sway me - F1a
- best header gasket for a turbular turbo header?
- fast 90/90 on stock ls1 with boost?
- PT76gtsh Results (very pleased)
- LQ4 Build
- STS to Trick swap
- Need opinions!
- ModularTurbo needs help!!!!!!!!!!!!!!
- Anybody running a LM7 with stock 5.3 heads?
- what happened to OFI?
- Rear mounts chime in!! intake in the rain...
- Flex pipe
- stock block hp limit???
- Procharger upgrade help
- lm7,lq4 or lq9?
- How determine hot side size of turbo?
- vortech supercharger ?
- Need larger turbo?
- Twin Garrett 3271
- Max boost - min compression?
- 421ci SBC High Boost E85 Project
- best 3 bar map sensor
- Shops around Chicago IL??
- Hot Wire Installation question
- Any pics of twin turbo setups using truck manifolds?
- Single or twins with lsx 427
- turbo build question
- Borg Warner ST80 1.25a/r
- Intercooler Selection Fact and Fiction
- do i need a fuel pressure regulator???
- F1c$$$$
- 1000+ RWHP With Ls9 Head Gaskets
- Oil pump help.
- procharged mustang guys...
- Which intake for FI LS2 or LS6?
- Who has made their own double Walbro in-tank kits?
- single turbo with MAF tunning?
- Will this be the ideal PCV/catch can setup for my TT setup?
- Breather Tank - What should I do with the ports on TB/Intake
- JBA Truck Headers?
- ETP 6 bolt heads
- Results from Dyno Tune
- Powerdyne BD11A problems
- Vortech ?
- maf location
- Twin Turbo Choice...
- Best clutch set up for T76 5.3
- need to pick Turbos and cam for a TT forged 408
- Does this turbo kit look familiar?
- Rear Mount GT-4788 Z06!!
- APS F-body With GT35 option
- Your boost gauge?
- Issues with my setup
- t4 flange with y-pipe
- What gears for a roots blown Trans Am?
- 441 LSX,TFS 235,Nasty Sheetmetal Intake,Twin TC70's Turbo kit by KYTP 6spd street car
- Lifted Head with ARP Studs Question
- can i see how you trimmed your bumper for intercooler
- ebay kit
- ? about going with e85
- Procharger questions!
- Made a vortech airlid
- PT88 Rebuild
- my attempt at a complete vac/pcv diagram
- I need Fuel Advice for Procharger..
- Help with bov, iat sensor and Methanol nozzle placement
- Waste gate dumping, examples if possible
- turbo air filter
- Fuel pressure drops when Electric Cut-outs are open???
- Cometic Phuzion Gaskets
- What size oil feed line for my mid mounted turbo?
- Turbobygarrett.com sticky?
- How much horsepower can you make with a TC76?
- Iron 408, twin turbo choice?
- 87 Iroc-Z 6.0L Turbo Build
- looking for anodising services
- Pcv & fi?
- Where can I find a valveseat for JGS wg?
- maggie and water /meth spray location
- Syclone IAT, connector different on LS2?
- how big of a bore can you get a ls9 head gasket in
- Fell into race class, want street class. I have a restictive cat/muff Tune question
- going STS Turbo, need some advice on the set up please.
- TT Z06 Build Thread
- turbo suggestions please
- Valve Float - High RPM breakup
- turbo and 317 head's?
- Anyone build X-over pipes?
- turbo exhaust
- Junkyard LQ9 runs 9.92@141, 4000lb race weight!
- WHIPPLE SUPERCHARGER KIT UNDER STOCK HOODS for LS1/LS6/LS2/LS3/LS7
- thread?
- How much HP should I be making?
- tapping compressor housing master power 76
- what size wastegate spring
- LT1 TIMING Quse ?
- okay school me on wastegates for my turbo setup
- Higher elevation = moore boost?
- 2010 Fastest FI List
- Where did the Fast FI list go????
- Turbo kits for transplanted LS1s
- What turbo?
- GT 2-3 cam for a 370?
- Granatelli Version of 2010 Camaro Twin Turbo
- need cam help with 5.3
- Can flow direction on Mocal oil return pump be changed?
- Valve Spring Issue on D1SC 347
- What is a good size turbo for 6.0 swap? (plus more questions needing answers)
- Extra Bolts in Procharger J-Bracket
- Need advice if you don't mind
- Kytp Tubular header/radiator hose?
- Turbo Big Dogs Need Your Help
- Quick Radiator Question.... pics added
- GTO Procharger Bracket Question...
- Notching Radiator support
- belt size for speed inc relocation and slp underdrive
- Does an exhaust crossover matter under boost?
- Spool Up? 96 Impala SS TTLSX
- What dos everyonr think?
- does anyone have any info on innovative turbo systems
- PCV system on 15psi - help.
- TR224 112 and turbo
- Helion 2010 Camaro twin turbo kit makes 580rwhp
- New Vette Updates
- ls3 in 98 camaro f1 or d1
- fmic d1sc help!
- LS2Formula goes 7.95 @ 177.5 on E85 and DR's
- 10.01 @ 137 stock 6.0 76mm
- Deck thickness Q. 317s vs TFS/ETP/AFR aftermarkets.
- My 2010 Build... lotsa pics... almost done!
- No boost with my procharger setup?
- boost/vacuum reference help please
- ATI balancer or SLP?
- Powerdyne Questions
- MasterPower & Rob @Modular are the man
- maf
- Precision Pt6765sp Billet turbo questions
- Custom exhaust for turbo setup.
- Nitrous and boost
- Should I Do It Now Or Wait?
- Thinking about going FI... Any tips?
- C6Z makes 1050rwhp through Auto!
- ALL stock block FI guys come in!
- Threaded MAP Sensor
- First time with the th400
- Has anyone tried a 928 motorsports impeller?
- out of idea's(oil issue)
- Turbocharging a 355 Chevelle
- want to supercharge stock z28
- APS TT not reaching set boost.....??
- 1000 rwhp build which head unit
- Crank pulley for a boost motor?
- 2 bar map part # for you
- ATI Crank Pin Kit
- question for engine builders dealing with boost
- New Product of interest
- Boost controller with dual wastegates
- too much boost???
- Help for a friend.
- timing vs EGT vs IAT
- Will a 4" DP fit?
- people that moved their radiator verticle...
- Anyone using a turned crank?
- compression how much boost
- no intercooler on big turbos
- How good/bad is my WG position
- 44mm Tail wg inlet?
- JGS blow off valve hook up question
- F1A on stock LS3 and stock fuel?
- let's see those procharger dyno sheets!
- PCV System Diagram Based Largely on MM's
- Alky kit where to put nozzles for best result
- turbos and cam
- oval tubing calculation
- Help needed with timing
- puller for vertical griffin
- Best timing chain for FI
- couple short street vids
- Blew a head gasket today
- Went to the track yesterday...
- Any wastegates, like the ZR1, on supercharger setups?
- new to prochargers, what pulley is this?
- Will I need a scavenge pump?
- Downpipe under K-member..
- Project: Bumblebee
- How much hp can a maggie 112 make?
- Ebay turbo
- What dish wiseco pistons to have 8.5 CR on 241 heads
- Finally got some new track results with the new piping setup
- Eboost2 "boost only" hookup ???
- rear mount in a Chevelle
- Dyno Video of my car.
- is a vortech v9 big enough for me?
- Need some ideals for tt hotside for a fbody
- Best choice for a stock motor?
- Spark plugs for boost.
- Head gaskets for procharged LS3?
- Whose making the most power with Factory GM casting heads?
- LQ4, TSP MS4 and Blower?
- Can you use a larger comp housing and comp wheel on a PT88?
- Anyone One Making An Underhood Single Turbo Kit?
- Timing pointer
- TREX cam with a turbo?
- 5.3 Turbo Questions
- Question for APS TT guys!!
- Cam for procharged LS3?
- Procharger rebuild costs?
- speed inc alternator relocation bracket
- how much boost can 6.0 stock handle?
- what do i need to do to a lq9 to prepare it for boost
- Bypass Valve, how to save cash?
- 11 to 1 compression + forced induction.. need help
- Question about a turbo ls1 on ebay
- What will happen if I run without the MAF?
- 22x19x3 rad. car running hot...
- Thanks LSX TV and Dragzine!
- I was just on speed tv Pass time ...in zombiess car
- Buy your Procharger kit
- Pulse welding crossover
- Is it time for SD?
- single 14 or dual 12 fans?
- Throwing drive belt......which Tensioner ?
- How much HP would it take to notice a difference?
- Flow Matched High Flow LSx Injectors
- Precision pt88 turbo TO SMALL for a 408ci??
- 235cc intake runners on a 370ci
- Silicone couplers??
- EPP's phone number
- Who built your FI motor? Would you recommend them?
- 6 bolt ls2
- new to FI
- wastegate reference?
- t78 full boost rpm?
- Jegs Push Loc Hose Suitable for Scavenge pump lines?
- lt1 procharged
- Thread Size of Elbow above the oil filter.
- cam ?
- so I came back from work and ....
- What CI is preferred for a D1sc
- thermo-tec turbo insulation 15003
- When to pin crank?
- procharger Guys need your help..
- all you turbo and super charged dudes
- Turbo cam Question
- Turbo Single Turbo 08 Silverado
- anybody wanna see a dirt cheap turbo regal
- Is there a way to stretch a new belt before putting it on?
- meth injection
- buy a used kit?
