View Full Version : Forced Induction
- valve cover breather mods
- Manual boost contrller
- Need an intercooler, where to buy?
- Anyone ever use a Tial Blow off valve for a Procharger?
- o2's
- Cam/Spray or FI?
- Which forced induction option.
- What turbo for my 390ci (T6 Flange)
- Victor JR setup??
- Lsx 6-71
- Turbonetics 7675
- TFS 245s or PRC 237s ? Kinda new to FI
- 5.65@124 - stock 317's, AC, pump gas, s480 towing a trailer ;)
- front vs rear mount turbos ?
- D1SC 347 forged - which Compression ?
- Mesh filter for procharger....
- Free BOV with turbo purchase!!!!! good until the end of JAN2013
- My ls1 Foxbody t76
- Piston/ Rod Suggestions for Boosted Applications
- Looking for some imput/direction
- practical downpipe limit???
- Procharger 5psi mph gain?
- Ring gap for turbo motor
- MP112 cam?
- Pontiac G8/Maggie 1900/AI ported L76 heads/Tick Custom cam
- Opening up the combustion chamber on ls3 style head??
- magnum xt80 or s475/83 both in T4... which will flow more?
- Another turbo selection thread...
- LQ4 alternator relocation bracket
- TTI 4th gen twin kit 777rwhp @10lb's
- help with turbo kit for lq4
- New motor fallinf on face
- cts-v manifolds ?
- Turbo help!
- Fuel Promblems, Turbo Camaro *NEED HELP*
- MD-104 BOV pic/vid/narlz
- Need help with wiring zr1 map
- Motor swap TT build - Intake manifold measurement Questions
- turbo 4.8/5.3 setups, what RPM stall are you running?
- My Project for tx2k13.....
- My LS1 S2000 76mm On3 turbo build
- d1 procharger bracket
- Twin 58 mm vs twin 62mm turbo.
- Need help sounds like a 2step at 3500rpm
- gm price increase on l92/ls3 heads
- 835whp new comp ct5 88mm
- Camaro Twin Turbo Kit
- twin turbo vette scavenge setup
- I'm bout to buy.......... Turbo K-member... BMR or who????
- LSA Heads / Components Questions - please help!
- Under boost piston quetion.
- What vendor for built bottom end short block ?
- Tell me why I should not fill my ls3 block?
- Huron Speed - Turbosmart Dealer!
- Would you rather?? Electric or boost activated cutout.
- e85 vs meth? or both
- truck manifolds non egr?
- Twin turbo LS7 Z06 guru help please!
- Just another 5.3L S480 Build Thread (with prices for parts)
- Cam choice Turbo LQ9
- Need help with 98 Mustang LS/turbos swap
- 3 bar map
- What stall to use?
- twin 6165 vs. twin 6162
- Poor man's dual stage boost controller(GM boost solenoid)
- Project s10
- turbo 4.8 ?'s
- Oil pans for turbo setup
- putting together longblock for boost, need help
- street driving with turbos mounted in grill
- Old school blower setups on an ls1
- Cam for 6.0 TT in a Jeep?
- Need help choosing a turbo for 370ci
- Iron versus Aluminum when you do have a problem?
- vortech rebuild
- Turbo Cartridge question
- s10 sudo ls6 turbo m6 build thread
- Injector size??
- Injector sizing E85
- Sources for stainless & aluminum tubing?
- ~GUESS HOW MUCH BOOST I'LL MAKE THREAD~ (procharger 4.50 pulley)
- How much power left on the table...?
- F-body Procharger w/Iron Block 6.0L - ????????
- Help me build a monster street cruizer
- If I was to ditch my HX60..
- Bolt on Power Steering line setup for Turbos?
- Fbody procharger rebuild possibility question
- FMIC piping fab guys.
- Making sheet metal fan shroud for procharger?
- cam doctor! please help! Houston area..
- Opinons on wastegate placement.
- air to water intercooler
- 6-71 blower questions
- D1 G8 630hp
- Cast turbo manifolds
- What's 1 7/8 headers worth over 1 3/4 on a procharged car making 15psi?
- boost & nitrous timing?
- Smartfire injectors
- Header/log manifold build
- Best spot for the O2 sensors in my crossover?
- Turbo LS engine builders in the Southeast?
- Ls1 with aviaid 3 stage pump lower left
- Slow Ride's twin turbo vette build
- Which turbo would be better for my 390?
- high hp stock short block guys... question
- Trans Am 88mm Turbo Build
- Motor mounts
- 39x ish with twin turbos
- My Procharged truck made it in Truckin' Magazine this month
- Need help picking a motor for my TVS1900
- Pros and cons on TT vs ST?
- Truck manifold gaskets
- Need help with Cam selection
- the Mighty LS6 cam.post your combos
- 2012 ProCharger Rebate 3 Days Left
- plugs after 2000 miles tell me what you think.
- Fuel feed line size
- Paint, powdercoat or anodize my IC
- Anyone run the K1 Billet Rods?
- 2k turbo project
- 1025rwhp f1r tbss!!!
- 5.3l turbo build
- WG not hooked to boost reference?
- 1118 RWHP Twin Turbo CTS-V
- Who makes baller drag spoilers?
- Best block for forced induction ?
- Ebay Turbo build?????
- How many of you guys run your oil feed off the oil pressure sender?
- project 1951 chevy fleetline ls1 (aka BOOSTLINE)
- Need some rear mount help.
- Turbo cam gurus please answer
- Sleeper......or Custom?
- Who all is running a carb setup?
- Heard the vic jr does not like rectangle ports....?
- Maggie Cog Drive Video
- Keeping A/C in new turbo build.
- What size Ebay intercooler and piping to get???
- DIRT CHEAP: LQ4 Turbo carb yadda yadda Need advice!!!!
- ls1 magnacharger to fit l99
- FrozenBoost??
- Ebay Turbo Kits???
- increase power but not boost?
- Lq4 +F1r
- 6spd FI guys and no lift shifting (lingenfelter lnc-003)
- HS turbo kit with alternator relocation???
- Merry christmas fi people
- Anybody have procharger pullies?
- Boosted 5.3
- Head/Intake question w/boost
- no intercooler
- 69 Firebird LS2 Twin Turbo HELP!!
- Which is better turbo build, LQ4 or 5.3. Need pros and cons.
- Guys I need some help
- Perfect gears for turbo M6 setup
- Who Is Running a GT91?
- Crank Question
- NYC Tri State area
- turbo sizing definition!!
- Pro Flo XT...install help needed.
- Need help identifying a turbo kit???
- stock truck cam?
- Second cable attached to throttle?
- Looking for wrapped truck manifold pics
- Opinion on "refresh" of a stock 5.3
- 11.5 compression and boost-why not!
- Help! Will my current cam work with a supercharger?
- s475 on untouch ls1, what to expect with 9psi
- STS turbo build soon!!
- STS Kit Build????
- TT + 390ci..........which turbos....Modular Turbo CBR F2....
- Procharged LSX mustang
- Turbo cooling question.
- Wishing You a Supercharged Holiday Season
- Boost and rwhp
- Crazy turbo setup idea need help
- 02 Ws6 trans am with a junkyard diesel turbo? sure why not
- My new sleeper!
- Undersizing or Oversizing Your Turbo: An "Honest" Discussion.
- tech question
- is it to big
- FI guys at or near the 1000rwhp mark, what flexplate are you using?
- 400+ ci LS9 blower speed?
- Twin Turbo cam
- The power (Literally) of ignition timing
- Worth the build?
- crankcase vent for cam /D1sc
- 5.3 twin turbo
- LS1 243 heads and pro charger build?
- keep blowing headgaskets/ cam too small ?
- 67 Nova SS. Pro Touring. LS + Twin 72's. 1000rwhp plz.
- how much boost are you pushing your stock bottom end iron block?
- discussion about overlap in a turbo cam
- T56 Rearmount GTO Cam
- Anyone run a big cam with turbo?
- need help with ls1 turbo combo!
- Heintz Racing resets IRS GTO Record @ 8.74! Plus a few other great runs.
- NXS Spring Loaded Manual Boost Controller Question
- Need some opinions
- V2
- AES Announces Our First Year End Sale!!!!
- 02 Turbo Camaro Exhaust Question
- Wanted: Twin intercooler and Procharger
- How many still have A/C?
- Does unequal exhaust pipes matter?
- Catch can with return style BOV Question.
- Procharged G8
- Thinking about completely changing the direction of my car, advise?
- 370 BW s480 e85 non intercooled build
- How much boost and hp will a stock bock, forged internals LS2 handle?
- Boosted 5.3 guys drop in.
- making LSX happen everywhere
- TC78 + 390ci..........will it make 900 RWHP....?
- New best 78 Turbo Trans Am, cam only 5.3 rear mount Turbo 10.22@140.98
- good idea or bad- twin turbo oiling
- TC78 BMW build
- ebay hot parts kit
- I did some LSA head testing!
- Where can you find official rules on the stock shortblock record?
- Changes for 2013
- How much HP can a stock ls2 handle?
- Where to place wideband sensor on twin turbo
- do I need to run a thermostat?
- What size intercooler on 71 chevelle Single t76 turbo??
- Head studs ?
- 68 camaro 5.3 single turbo swap, what manifolds?
- 408, S488 turbo build feedback
- 69 Camaro twin turbo build - Loads of pics
- T78 + 4L80e + e85 + stock cooling system and AC round 2 **dyno vid pg 3**
- Road Racing twin turbo 5.3 cam and turbo selection...
- New Project... need advice, opinions and help
- Flipped C6 Manifold for Driver Side???
- Huron Speed *Special Edition* Truck Manifold Turbo Kit end of 2012 Special!
- bv57 and ysi settings
- building turbo headers /log
- Using meth to compensate for more boost on current tune?
- First Gen Manifolds
- New BAD ASS Turbo kmember ( DKT/BMR )
- LT1 Turbo Tuner in / near NC ???
- best short block?
- 408, GT55-94, E85, Glide, Truck manifold build thread -- UPDATE 06-29
- burkhart chassis-Thanks
- LS9 cam ?s
- LS6 intake how much boost
- First turbo build
- Edelbrock Vic Jr VS. Edelbrock Pro Flo XT
- Boost creep issues please help!!
- AMS-1000 Boost Controller
- 626hp 800+Tq!!
- AES 390 users, how do you like it?
- Twin turbo LS1 heads question
