View Full Version : Suspension & Brakes
- Need help - Issue with rear sway bar / watts link fitment
- See inside for 2017 Holiday Discount Deals
- Severe vibration at 65+
- front end clunk after lowering
- OEM C6Z wheels fit easy. No spacers needed.
- CTSV 6piston calipers w/ Street Lites
- Forgestar wheels, $200 (18")-$300 (19") off full sets ... 11/20->11/30
- MWC Long or Short arm ? Need advice
- TCS C1255 Code Need Help
- Factory Ride Height Spec?
- Wheel hub options with ABS delete
- lca bushings
- Height or length adjustable RLCA
- Power Steering Pump Rebuilds
- Weld in LCA relocation bracket inputs
- How to tell what " Inch " springs I have
- Driveshaft question
- DOT 4 vs DOT 5.1
- Needing some advice on rear brake lines
- Recommendations for Stainless Brake Hoses, Routing for Moser 9"
- Correct Sway bar end link and bracket bushings
- Koni SRT review
- C5 vs T/A Ground Clearance
- Drag bar recommendations
- Scraping/rubbing sound when driving
- Rear end bearing, replacement a weekend job?
- Lowered cars with crossmembers, how much ground clearance do you have?
- Any Wilwood Superlite big brake kit users on here?
- Rear spring recommendations...
- rear end noise??? 1998 f-body
- BMR torque arm relocation bad fitment
- Unstable handling
- New suspension, need alignment, have q
- 4th gen CTS-V conversion write-up & video
- Fays2 Watts Link With Dual Exhaust
- Drag rear sway bar
- SP4000 Hub Adapter kits ready to go, available with and without hubs
- Low 1.2x and high 1.1x 60 foot tips! Rear lca angles? Tq arm angles?
- Replacing rear shocks, not sure what is going on...
- Brake pad advice
- Bump Steer
- How I bleed abs brakes
- SCCA Club Trials in the Z06 (Camaro still in process)
- Steering rack part number for WS6 2001
- Spohn rack and pinion
- Suspension overhaul Viking, UMI, MWC, Spohn, BMR. New pics!!
- Banjo Bolt Camaro LS1/V6
- Getting ready to finish the year
- Quick Review: Strano Master Cylinder Brace
- LONG Torque Arm and 4l80e
- Sway bar hitting Moser 12 bolt
- drive shaft twisting
- Afcos won’t fit Moser mounts!
- Rear leaning on one side
- Another upper control arm bushing thread...
- Help with QA1 parts
- Lca relocation mount.. top or bottom hole?
- 2000 camaro lower ball joint is loose in the control arm
- BMR TA013 Torque Arm Kit
- suggested spring compressor for hotchkis
- Brake Calipers
- Reminders, updates, etc.
- Shock or Coilover options for 2nd Gen F-body
- Help me make a decision - Bilsteins or STR.T
- Suspension Question
- What Is Your Ride Height (Strano Springs and Bilstein Shocks)?
- Rear coil overs... QA1 vs Spohn vs Viking vs UMI
- Bolt on SFC question
- Bilsteins to Koni yellows
- Burned brake line! Where to buy replacement?
- Fbody Wheel Hop Issue
- Coil over shocks...
- need a 2 button steering wheel
- Help me identify this Manual Rack? BMR?
- Nose Dive Durring Hard Braking
- Stripped/seized brake fitting
- wolfe racecraft anti roll bar on 02 fbody
- Replacing EBC yellows for the fronts...
- Rusted Lower Spring Mount
- UMI K Member
- Upper control arm brackets
- Rotots dont seem right
- *** WARNING - StopTech/Centric Stainless Steel Brake Hoses *** Read first
- Banjo Bolt Torque Specs - CENTRIC stainless brake hoses (950.62001)
- REVIEW: Torque Arm Relocation Bracket and Full Length Adjustable Torque Arm
- G8 GT brembos instead of CTS-V?
- What brake options for WS6 wheels?
- Does it matter if my panhard bar relocation isn't perfectly vertical?
- Koni STR.T Shocks
- Adjustable LCAs?
- Watts link with rear end back brace on 9inch rear?
- Replacing Brake Booster Drum.........How hard is it?
- Who sells Offset rear LCAs with the most extra clearance......?
- Easier ABS Delete?
- Abnormal brake pedal feel
- Suspension Packages
- Jegs wheels and ctsv brakes?
- Power steering after LT1 swap out
- Getting a 4th Gen to Hook Nails!
- 2nd Gen F Body Coilover Kit
- Disconnecting sway bar for drag strip do u zip tie it
- Coil spring perch for de Carbons?
- How to ensure no wheel hop at drag strip???
- Silverado brake bleeding issue
- steel braided brake lines
- Afco Install
- Lowered 30mm my f-body, need arm relocation brackets?
- Differences in stock springs?
- ABS bypass
- Seized Front Caliper Bleeders
- Koni SA Rears - So Awesome!
- Coil-over thought
- Rebuilding front end+back to stock height=29.75" WTF?
- UMI Labor Day Savings- Until Monday 09-04-17
- Tech answer for non tech question?
- Drivers side rear caliper binding
- LS1 Rear Brake Offset
- Odd Steering Problem
- rear brakes for ls1 camaro
- Brake hard lines with narrowed rear ends
- Pinion Angle: The great debate ends here
- mystery vibration starting at 65 mph and up.
- SCCA Solo Nationals time. Strano Performance Parts information
- Ford 9 inch
- Please help, something is making my tires choppy & feathered after 6k miles.
- Used prothane cobra rear isolators instead of heater hose mod
- Stoptech Stainless brake line won't stop leaking!!
- Ur opinion on my abs woes, really dont wanna delete
- Suspension upgrades
- Braking Problem and Recommendations!
- Suspension over hall. How many hours to install all of it?
- ABS sensor removal from front hub?
- C5/c10
- V8 ls1 vrs V6 3600 front struts
- How to Replace Your Brake Lines Gen 5 Camaro
- upgrade to UMI control arms??
- Review - Strano springs / koni srt.t combo kit - UMI suspension
- Installed stock springs on koni lower perch and somehow car is higher?
- Where to purchase wheel spacer?
- spinning t56 without drive shaft to diagnose vibration?
- Light in front end
- Truck steering wont go back on center anymore
- Strano part # 8327
- Rear caliper bracket bolt fell out
- Combining 2 Subframe Connectors? Anyone Done It?
- Vibration on highway?
- Poly or Rubber
- F Body tunnel mount hardware size?
- Suspension Wise What Else Is Left To Do?
- Questions Concerning Bilsteins, Stranos and Endlinks
- Steven Thomas, are you here?
- CTS-V brakes to 02 Trans am question
- bad vibration after new u joints
- Are there 2-Piece REAR Rotors for '99 Firebird?
- Brake parts for 18" Front 19" Rear Rims
- does the vibration go away eventually on energy trans mount
- A few abs module questions
- kenny brown weld in sfc
- Koni STR.T/Strano Spring
- Fbody 8.8 rear sway/ anti roll bar options for street/drag
- Lowered, need new front end links-what length?
- Shock help please!
- Firebird Upper Control Arm Mount Bracket Bushing
- Power steering rack mounts
- Strano sways review
- Suggestions on rear street srip shock
- QA1 trans mounted torque arm and S60 ?
- *RESOLVED* steering wheel vibration...not what you think
- Strano Performance Parts announcing Koni Shocks "Retro Rebate"
- thinking about SLP 70002, opinions?
- Anybody did CTS-V brake upgrade with C5 DD rims
- Using Dirty Dingo alt/ PS brackets for 6.0L truck engine swap in 1st gen Camaro
- Anybody else ever break a factory spring
- ABS Module
- Installing Adjustable PHB Question.
- Torque arm relocation fitment question
- Compressing stock springs
- Abs problems
- PowerStop Rotors?
- Took a Ferrari 458 around a track, here's how it compares to my track prepped F-Body
- GTO Strut Tower Trouble
- FINALLY the Strano/JD_AMG theory CONFIRMED
- Relocating Upper Panhard Rod
- diy torque arm relocation mount
- 1999 Z28 suspension rebuild
- koni front 8241-1139Sport not compatible with spring FCS20170 60116
- Steering play issues
- Power Steering Rack...
- In car video of Strano Performance Camaro SS, 2017 MotorState Challenge
- UMI / Strano / AFCO review
- 2006 Z06 suspension, anyone care to break it down?
- WS6 Rear-end Issues?
- Shift linkage
- Renz Fab rear CTS-V V2 bracket help
- bent A-arm
- Pinion Angle
- Do you have to torque the sway bar end links?
- clunk or thud under hard acceleration. is stock trans mount too weak?
- BMR K Member Control Arm bolts won't hold - HELP
- Need help planning
- 99-02 F-Body ABS better than 98 ABS?
- Mountain/Momentum Driving and F-bodies
- Bilstein
- Blown brake hard line 1998 Firebird
- Koni Replacement parts
- Preventing the torque mount from ripping out???
- LSA power steering flow rates
- Coilovers with Wolfe mini-tub?
- 22077190 spring
- how to spot springs
- aerospace pro street brakes
- Wilwood Rotor replacement, scary!!
- Suspension set up
- Anyone use this rear brake kit?
- Sway bar or Anti roll bar.. BMR
- 02 Camaro Power Steering Leak
- Koni STR.T/Strano Spring Review
- Calibres heat.
- Koni STR.t front/Koni Yellow rear
- UMI Independence Day Sale- Now through July 4th
- Front End Torques Specs Needed
- Koni's on Lower Perch- Y or N and How
- Bump steer end links
- What the hell happened? Koni/BMR issue
- Test day at the track. It's how we learn around here, video inside.
- Master cylinder and clutch questions
- Steering axis inclination SAI
- anti dive front control arm rear bushing
- front lower control arm bushing hole slot in rubber & orientation
- Any Drilled and slotted rotor deals?
- Stock Torque Arm on 12 Bolt Rear???
- F body with CTS-V brakes question.
- Will these fit?
- Adjusting Koni SA shocks
- BMR Suspension New Product - Twin-Tube Strut Tower Brace for 2016+ V8 Camaro - STB019
- Tunnel Mounted TA... something missing?
- BMR anti-roll bar install Q's!
- Smaller caliper
- UMI Releases New Product: Lightweight solid engine mounts for the 93-02 GM F-Body
- Occasional wheel / suspension hop ONLY in reverse.
- Rear end feeling like its twisting
- f-body irs kit
- what strut nut tool or socket for koni front
- suspension upgrade
- Steering column rebuild kits
- UMI Adjustable Torque Arm
- 2002 SS rear jounce bumper relocation.
- How to prep a rod/poly panhard bar for install?
- Another win for UMI
- UMI Releases New Product: Bumpsteer Kit for 93-02 F-body
