- stock short block ???
- do i need this stuff ??
- fan troubleshooting
- Low oil pressure
- Looking at a new short block
- Just Got This Ad From Summit
- Replacing opti
- '93 egr/air delete
- I have the worst luck w/ forks.
- MSD wiring Harness Part #
- Bout to slap on the heads
- muffler help
- Intake airflow restriction?
- Tail Light question
- What KOOKS give you that PACESETTERS don't for extra $600+ ??!!!
- What spark plug gap should I run?
- Motor Mount Issues... The never ending list!
- HELP! Watch this video and tell me what's wrong
- Stage 8 locking bolts supports our Military!
- Winter Project Almost Done
- BBK Under Drive Pulley
- 383 cam clerance question
- coil question.....
- 355 No Power, Shakes.
- tune needed for converter swap?
- exhaust , Dual or single?
- worthwhile for a tune?
- Vigilante vs. Yank
- 1994 Z28 Headers and exhaust
- Dyno tune Ai 355
- Dipstick tube question
- Uh Oh .. This is not good.. Help Plz..
- oil presure drop
- Running Rich?
- AIR Pump relay for bottle heater
- Trying to pick a cam
- Everyday Drag Wheels?
- msd 6al wiring diagram LT1?
- oil pump dilema
- Who knows of a good shop or electrical guru in SE Michigan?
- Tuning questions
- 2000 ss rear hatch on a 93 z
- Voltage drop - effects?
- I got a Loudmouth 2 installed today...questions!
- Delteq and MSD 4 DIS
- Need a little help here guys
- 1995 LT1 camaro
- LT1 Engine Bay Delete
- Interest Thread - 93-97 LT1 Firebird Bi-Xenon Projector Kit
- 8.8 Build Questions
- Fuel Gauge Off
- LT-1 Stock Cam Rocker Arm help!
- Tranny Swap
- Does anyone know where...
- 3:23 to 3:73
- what kind of power does a 383 make?
- Oil pan, pump and pickup
- flow question
- dyno sheet - does this look right?
- Intake Elbow
- 52 tb and 30lb injector
- Odd problem, car randomly runs on four cylinders
- ASR Removal
- oil pressure???
- Want to remove washer fluid container and wipers
- how will my car sit?
- It's alive!!!!
- Need help with coilovers
- oil pump pickup tube
- A Long Time Coming, My Build
- T56
- liquid coming from my piston!
- At What point does a stock style CAI become a restriction
- 94 LT1 IAC install
- Help with a delteq
- Why do I smell gas?!?!
- Timing Chain Questions!
- low coolant level sensor and retaining clip....
- trans issue
- Fresh Start
- need some advice
- Trickflow Top End Kit/ 383 Kit
- Custom Fuel Rail Covers
- 93 z28
- IAC OHM Test
- What cam is in this Camaro? Video in.
- My build thread! PICS!
- 93 z28 hits rev at 107
- lsx xwap question ?????
- LT4 Hotcam & tune, sniffer test?
- oil color?
- how to check used optispark?
- Idle Surging Need Help
- Drama thread/Mod Roll Call
- nos plate question
- Did I do it right?
- LT1 PICS Cant Wait For Summer
- What is this...I broke it...
- JET DST and autotap??
- Ported Intake Manifold ??
- Spark Pluggs!!!!
- Crankshaft seal
- how to pick the rite stall ?
- Fuel recommendation for 350cid LT1 with 1.7rrs, Hot Cam and AFR 180cc heads
- LT-1 Build What you think?
- Newbie question: What to do next?
- Need help: K member won't lower!
- Engine out the bottom
- problem making hp passed 4500
- Parting out the Camaro..
- timing
- Speed Inc. is the shiz!!
- best tuner
- putting cats in LPP OFY
- 1.6rr = New Valve Cover???
- Stock Timing
- keeping the valves seated, replacing valve springs, seats, ect...
- Keep stock oil pan...?
- Fuel pressure gage?
- Miss Fire help..
- spark plug
- A4 trans cooling lines
- 1997 Trans Am with 1994 Engine Harness
- trickflow 185
- ewp leak
- problem
- thunderracing / racetronix
- Steering problems?
- th350
- bosch 13111?
- TB Bypass question
- flowmaster 10 series
- Head Bolt Part #
- Preparations
- Help Removing 1996 TA Trunk Struts
- Long Tube How-To
- LT4 10mm rocker studs??
- fuel gauge an sending unit ?s
- What anifreeze?
- New to forum...just saying thanks...
- new to the lt 1 game
- Stock Exhaust
- Auto LT1 Camaro vs. Manual LT1 Camaro...
- Specific oil pan removal question.
- how to read a wideband?
- A/C system
- Simple Vacume Line Question
- Factory cam, 2800-3200 stall too big?
- 30lb injectors
- For sale Hughes 4l60e and vented opti conversion Cheap!!!!!
- LT4 Edelbrock intake ?
- Need advice for my new lt1
- BBK Shorties
- banjo bolt on crossover tube
- looking for nitrous plate for lt1
- 2 quick questions
- LT1 cold air vs LS1 lid swap
- Wide band O2
- Exhaust Ideas
- AR3933 plug question for lt1 with nitrous use
- Head casting number help
- Starter Died :(
- Anyone have pics of UMI's tunnel brace/safey loop installed?
- SLP Cold Air Intake?
- Headlight Mod
- Engine/Transmission Heat
- what should i do for performance???
- bought my old 94 lt1 back
- EFI connections Porn
- LT1 Gaskets D@MN Pricey
- March Engine Build!!!!!
- What valve train parts for cc503
- Shift Kits
- R&R kmember...now brakes don't work.
- THIS F*CK*&G Pulley!!
- Oil Weight on 138K LT1
- another lt1 has me stumped its surging
- Consistent backfire out exhaust?
- A noise, then zero oil pressure
- Nitrous Dave elbow and a Super Victor questions?
- Pix needed to help me make up my mind.
- Power steering pump pulley
- Fs/Ft : 93 Firebird Formula V8
- Where to Dynotune?
- Having a hard time with start up.
- Headers
- Pushrod length
- were to get best 383 shortblock
- New 97 z28, needs help.
- Friendly Debate
- Battery Tie Down
- Trifecta Tuning and wide band questions
- EFI Connection LS1 coil conversion for LT1?
- hydro booster. has anyone seen the setup?
- Lt4 tob
- scanned my 94 z28 today need some help identifying codes
- Datamaster Results
- which would you do??
- arp head bolts. what sealant?
- How much power will lt4 heads provide over stock?
- Exhaust install question
- MAF and VE Tables Question
- Hypertech or PCMforless?
- 0 oil psi at idle
- Pacesetter Header Question
- Time for some serious spark plugs!!*!
- Why are my fans being retarded???
- Head gaskets failed on my LT1
- I hate my LT1.
- UPS guy came by friday
- 93-97 Camaro HID kit need some help
- 4,000 rpm rev limiter symptoms
- Lt1 Turbo Motor, Turbo system, DFI for sale
- easy and cheap mods???
- is lt1 worth it?
- slave cylinder question (sorta urgent)
- efi conn. 24x Q...
- Any input on this rear?
- 2010 LTX Shootout Registration is now Open!!!
- Max compresson for 91 octane?
- So I think I diagnosed my problem as the WP
- Suggestions for car...
- Compression test. Should I be worried.
- Oil, Oil, Everywhere And More!! L@@K!
- 95 B4C With upgrades? Should I buy it ?
- Lt1 brakes to ls1 brakes. Stops the same?
- Compression question
- what headgaskets?
- Anyone using Tunerpro
- Is My Oil Pump Bad?! Video!
- skip shift delete
- Trouble Replacing Valve Springs?! Help!
- What you guys think
- Got my heads back.
- Is this the impala Head Gasket?
- Gaskets
- Who will win
- Getting occasional backfiring...
- SLP Loudmouth Cat Back
- where to buy rear end gears for my 95 t/a
- SLP LM2 Tubing
- Problem with Injector
- engine wine?
- Problems? Overheated top end rebuild
- what rods pistons for 355
- Please help me get these rockers set!!!
- Engine bay rebuild thread..
- ARP Main Stud kit for LT1
- Need a little help please.
