View Full Version : Forced Induction
- What do you think I will spend????
- blue smoke at startup?
- Happy Birthday Kyle (NA$TY-TA)!
- Turbo Kit done, with Forward headers!!!
- First E85 LSx setup? Anyone doing this?
- What's the max with this setup?
- Thoughts on this cam for turbo????
- Safe amount of boost on a stock bottom end?
- Cut out after turbo yes or no
- Tuning?
- what is the difference in 98 knock sensors vs 99-02
- Initial Startup/Dyno of My Twin T-67's
- Video of my Nova idling
- Cost to rebuild 60-1 Turbonetics turbos????
- Laminova intercoolers?
- 6.0 heads n/a?
- W2W "SUPER" nova
- Reichard Racing 3.600 DIA Pulley...Boost?
- I hate fuel injection, but i love Forced induction (thinking out of box)
- anyone run boost w/o 2 bar pcm upgrade?
- My thoughts about meth injection
- From nitrous to turbo-----------!!!!!!!!------
- Oil Feed line question with Pic.
- turbo question
- Whats it good for?
- bov?
- STS owners, oil return?
- how much for procharger installed
- Should VE and MAF be calibrated for 9psi?
- leak checks
- DCR, 92 octane, F-1 or YSi trim , and me...
- At 10#`s of boost what would be the hp difference
- Need Vortech Instructions
- Couple shakedown passes *video*
- MP T70s mounted
- Downpipe flex pipe?
- How Much Boost?
- What upgrades could I do with a P1SC Procharger, to get the most out of it?
- Any before/after results of going LSX78 to 90/90 on 346-348 LS1 turbo car
- FMIC Installed (w/pics) Boost control Q too.
- i have a 8 rib ATI kit, what do i upgrade for the SDCE?
- Looking for a Turbo tune in Norfolk, Va area.
- How many larger turbo (80+mm) street cars?
- Paging Intmd8, how is your staged fuel injection working out?
- Big single turbo peepz, what muffler are you running?
- Caveman, did you sell your T-Trim car?
- A realistic HP guess?
- Jose Line One Jose Line One
- how much rwhp per 1 lb of boost???
- F-1 Growl
- Frustrated... Procharger guys... PLEASE HELP!!!
- Strange boost problem
- I bought a Procharger today!!!
- GT42 guys inside...
- Hp/Tq #'s From Truck Mani Setups??
- procharger cam ?
- Timing question...
- What shortblock "upgrades" should i look into for my build?
- Trick to Sealing V-Band clamps?
- pvc question
- need a drain flange...help me out please
- boost + ls1
- 1500 Rwhp.
- Trims?
- Tell me about your ATI 8-Rib experience
- Checklist
- map tune or maf for sc
- z06 Cam after FI
- u guys still using TR6 plugs for 750rwhp?
- cam good for a supercharger
- What do i need to use a MAP sensor instead of MAF?
- 751 RWHP on 93 Octane
- very disappointed in CAS kit...i need some serious help please!!
- What is the rail to rail width on 4'th gen camaros?
- ??? on turbos
- Procharger?
- hi-flo website?
- overboost?
- What heads should i run with supercharger
- pulley size
- Strongest shelf forged piston for turbo 402"?
- Need Advise on Firebird FMIC
- IC or METH ?
- IC Spray
- tial WG & BOV
- Finally gonna be boosted!!!
- TR5, TR6 or which plug for Powerdyne blower.
- blow off valve to the atmo or tie back in
- what did you do to get to 650 or more HP?
- What DCR for 6# Supercharged?
- Supercharger!
- breaking up
- difficulty level of supercharger install?
- 600 Rwhp....
- Where to get 5 inc pipe from????
- car is almost done! not FI tho.
- turbo m6's, what gear do you run??
- MAF Output Choppy
- turbo and stock block..??
- Rear Turbo Pics
- best buy single turbo kit not remote mount?
- Motor Build
- Mufflex + twin turbo
- What TH400 torque converter with your turbo set up??
- Dyno results for twin T70 GTO
- Tuning
- About Cats and Forced Induction
- Which bearing for forced induction?
- 35 rwhp gain with mac midlengths over stock manifolds
- fuse box relocation bracket
- Oil ?
- Holdener F/I power calculation formula
- GMMG + twin turbo ?
- Less cubes > More cubes??? With a procharger at least?
- Muffler for high hp (>800 rwhp)
- guys running stock heads... what times/power?
- ATI belt pully change in vette (Godbless)
- Pics of the Bell IC mounted for the Incons.
- Forward headers done!!!!!!!!!!!!!!!
- New "stock style suspension" LS1 World Record (with timeslip)!
- Roofer Dave's car - Maiden Voyage Videos
- STS Plug Gapping
- blown stock shortblock come inside.....
- 95 Mustang GT with Twin Turbo???
- where do you guys get your cold piping from??
- anyone selling a boost setup?
- The cost of doing it right?
- Wanting to supercharge an LT1, have questions
- just installed d1sc kit on 00 ta blowing belts
- Word has it KP bought a FORD mustang GT
- Cam / FI
- Got her done...
- Boost/Vac source for boost gauge??
- twin turbo 6.0??????
- Help choosing rear gears for Turbo application.
- intercooler reservoir?
- New Record!!!
- H/C vs. F/I
- Need to frabricate a j-tube
- LS1 Camaro Custom Twin Turbo pics?
- Is it ok to have the BOV before the IC?
- Turbo Lag Problem STS
- twin turbo
- Anyone have an extra oil feed elbow (above filter)
- Those with SDCE on LT1
- Turbo position question
- Where to buy pulleys
- Boost line routing???
- New Bell TT Intercooler pics
- Boost gauge line ?
- 96 gt d1 to ls1 ?
- which block
- Can I mount a FMIC (24X12X4) without cutting the bumper brace?
- Make more power by swapping out LS6 cam our LS6 heads in Blown D1SC forged LS6 motor?
- Need help choosing fuel setup
- BOOST or "NOHELP"
- StS users plug gap
- Single digit 6 speed turbo owners help
- First Hi-Flo Dyno Sheet (Smearin's car) finally uploaded!
- Does anyone offer financing on D-1SC's?
- Spal fan installed (now blowing fuses) ...
- For those interested in TT for F-Bodies...
- advantages to electronic boost controler vs manual?
- Motor Plates and Front mounts???
- Opinion on these turbo manifolds
- No more boost leak outta my meth nozzle...
- D1SC 402 without 1 7/8 headers?
- Front mount needed, what to get?
- what responds better to forced induction, LT1 or LS1?
- which to chose
- Got some $ saved up, need help deciding which way to go.
- Edelbrock intake on my Hi-Flo?
- Bob @ EPP
- movies - 2 speed supercharger
- 2 or 3 bar map sensor
- A little help from my buddies...
- To LS1Tech members.....
- Refrigerant intercooler? Why not?
- D1-sc pulley shims?
- Alky pump is on all the time ?????
- Help rate cam specs of 218/228 564-577-116 for D1SC BLown forged LS6!
- Has anyone tried TT on Truck Manifolds?
- Which to go with a 414 and a turbo or?
- GT42 vs T88
- Poll: Best turbo block?
- Is a 224/228 cam, 114 lsa, with .575 lift, good to go with 918 springs on D1SC
- Truck Manifold Turbo Set up FAQ's
- ---- Forced Induction Mod Marker ----
- The Exhaust Cometh
- Got my T76 today, all I'm saying is DANG THATS A BIG TURBO!!!!
- What year for truck manifolds
- Going rate for a used P-1SC?
- BBK 85 mm intake vs. LS6?
- Mike Brown's Turbo Build Pics
- Where can i get a laser alignment tool to line up my charger pulleys?
- not an LS1 but....
- just installed procharger, stumbling off idle
- How to choose a BOV
- Custom STS turbo wanted
- What gaskets for gmpp intake to heads..
- Supercharger Question??
- Info on truck manifolds
- D1-SC mounting bracket?
- Any Appreciable Gains In Going with GMMP Intake vs. LS6/FAST on ATI Pro setup??
- What belt length for MMS crank and 4.0 pulley?
- STS Users
- Max boost?
- STS Turbo Guys
- Anyone have pics or can describe the power steering hose relocation for TTi?
- safe procharger kit for stock engine
- Turbonetics Godzilla BOV
- Wastega Springs
- I want to see pics of 76/88/91+ FM installs
- pillar gauge pod for convert?
- CAS dyno numbers inside
- Anyone have Lt1 SDCE installation instructions??
- LS6 Cam + FI Good/Bad
- FMIC install pics
- A little FI(mainly turbo) help
- 4.25" Procharger pulley + ATI Damper = ?psi
- wanting a good setup
- Vortech Tuner Kits Available!
- FMIC bypass valve
- ATI ProCharger Price Increase Coming Soon!
- Is it common to lose 1~2 psi of boost because of headers?
- YSI trim on LT1??????
- any news from hi flo?
- speed inc shortblock for boost
- t88 and 408 suggestions
- 2.3L turbo build up- got a few questions-(megasquirt)
- GMR speed single kit or D-1SC?
- Procharger boost- does this sound right?
- Forward headers almost done
- Question about TB's
- I hate to sound like a ricer...but...turbo timers?
- Its been a while since
- Why the loss of power?
- FI and living in Houston with Humidity...
- 232/234 bad cam for FI?
- Where to buy...
- UK Ls1 Parts?
- hand ported TB under boost....
- Cpr Sinister Fuel Pumps How Good Are They?
- Why are alot of people running a smaller exaust lobe?
- How many running stock main bolts vs ARP main studs and at what HP??
- STS Boost Question
- TTi uses V band for the downpipe?
- +boost but no power increase??
- AFR 225 or AFR 205
- Question on which headers and cam for supercharged C5????
