View Full Version : Conversions & Swaps
- i need a power steering pump!!!!!
- Truck Pan vs F-Body Pan for 2Gen
- 5.3 in a 240sx
- Help with coolant issue!!
- advice/help/info
- 1951 Mercury monarch 5.3 swap.
- My current state of LS1/Nova conversion
- 6.0 LQ4/4L80E Conversion
- Exhaust port, mounting and angle difference between LS1/LS2 and LS7 Heads
- Great recipe for a super budget 5.3L build?
- Another harness option....
- Can anybody in here help me with my suspension?
- my 87 notch lsx project for sell
- carbed lsx box question
- Anyone done an HHR conversion?
- ls1 t56 behind bbc??
- Help with PVC system
- Sweet Video of Jarrell's Procharged 1979 C10 forged LS1 383 Swap
- Where did you all get your motor mounts? 1st gen camaro ls1 swap help
- Ls1 Fox Procharger For Sale
- My C5 drivetrain corvette swap into a 70 c10 truck
- LS1 in a Volvo 240 wagon . . . .
- Questions about 5.3 truck motor, 4L80Es, throttle module, ect
- where and how did you mount the factory LS1 fuse boxes
- carb 5.3 for 72 nova, help ???'s
- Gen III Chevy van engine wiring harness
- Celica tuned and road tested
- ECM Programming??
- wiring issues with ls1 swap
- Schwanke Engines will be at the Sioux Falls Swap Meet
- plug C100 what does pin G go to?
- What are you guys using for throttle linkage brackets?
- If you are building a LSx Chevelle and need some body panels...
- idler pulley Q
- Rack and Pinion install
- BCM Start up
- Need acc bolts or bolt sizes
- procharged 79 c10
- 95 gmc headers for a 6.0 vortec
- belt hittin' the bolt?
- truck water pump question
- 1980 Jeep CJ5....
- Mass air K&N Filter
- C4 Swap
- Need help building a 5.3 for my 68 camaro
- 4L60E Cooler fittings
- Pre-Filter
- Mech drawings or dimensions
- hooker motor mt. adapt.
- Tire size & gear ratio
- 70 camaro ls1
- Truck accessories and Exhaust?
- a few question about AN fittings and the fuel rail AN connection
- Shouldn't be too hard?
- 84 S10 conversion
- LS1 into 96 audi a4 quattro
- v6 to v8
- pcm bracket. what will work?
- how do you make AN fittings connect to braided fuel hose?
- LS1 in 3rd gen not starting??
- 69' Camaro Convertible, 00' WS6 LS1, 6 Speed
- G-body parts i have for sale...
- Accessory Brackets
- Spohn transmission crossmember for sale
- S10 6.0 Long Tube headers???????
- Transadapt Motor Mount Plates
- LS376 + Edelbrock twin carb?
- 67 Chevelle convert on a corvette suspension
- 5.3 build in s10 and wireing questions
- swap help for ls1 in 97
- late model lsx power steering pump question
- AC pressure sensor question
- where did all the ls1 wirin gdiagrams go?
- East Meets West - 240 and LS1, 2, 6
- the old radiator hose question
- 5.3L in a 89' Caprice 9C1
- Anyone interested in A-body big disc's?
- LQ4 Sonoma Pics
- 67 Chevelle LS2 install
- headers for a 6.0 colorado
- check this out!!!!!!!!!!!!!
- 12 Bolt
- how to wire a master disconnect switch?
- LSX Engine Swaps
- what relays and were to buy them
- Length of Hose needed in LS1 swap
- Where to get a transmission bellhousing adapters?
- Firewall Grommet
- Wiring Harness Modifications
- Air pump or no?
- plugs for GM relays?
- 70lsq.com
- Ls6 & Th400
- 68rs,6.0iron,l92..converstion--fuel system!
- My 1993 FD RX7/LSx build...
- Need help finalizing wiring
- Im Way Overwhelmed.... GMPP LSX block in a 70 Chevelle
- My 67 camaro ls1 swap is running!!!!
- 6.0 into 70 Chevelle. Mounting?????
- Testing
- Has anyone done a LSx 80's El Camino?
- Deleted wiring and OBDII code question.
- Curb Weight for your finished LSx Conversion? Any 92+ RX7, 3rd or 2nd Gen Miatas,etc?
- LS1 Distributor?
- ?? About swapping bbc for ls6 in2 1981 impala
- LS1 in a C3 fitment
- wiring and grounds
- ls or 6.0 vortech
- VSS wire splicing
- 93 mustang coupe, carbed ls1 drag car.
- Where can I find some info for a 350 swap into a MKIII Supra?
- flywheel /spacer help needed
- Energy Suspension Motor Mounts
- 95 and '01 f-body clutch questions
- Carbed lq4/lq9 into a '97 T/A.
- 07 6.0 in a 96 caprice
- AJE chrome-moly k-member for fox mustang for sale LS1 mounts
- Street & Performance LS1 Brackets for sale
- 65 Corvette finally running!
- Shops that do conversions?
- LS1 into a Tiburon.Been done?
- 1965 ls1 f85 project pic's
- LSx swap?
- Volt Meter Gauge wiring
- Schwanke Engines 427 L92 in a Dirt Sprint Car
- Rough draft of wiring info...
- 383 carbed 2000 ta
- Have you guys seen this thing? 8 turbos!
- LS364 (carbed) clutch/flywheel question
- 5.3 Vortec in older car..... more power...
- f-body fuel tank wiring question
- LS1 into a '37 Ford
- Mustang II rack and pinion fittings
- ID this intake setup?
- LS1 Rx 7 FC... Front Accesories
- LS2 w/Vette Accessories into A-Body
- a/c compressor
- computer grounds?
- where did you connect your autometer tach & is it working? LS1
- Will LS1 F-body headers fit a '86 Chevy C10 pickup truck w/LS1?
- a few questions about wiring
- how do you connect gauges/idiot lights?
- Ls1 in a street rod!
- Which carb'd intake?
- Summit Radiator
- LS1 in Midyear Vette
- '06 LQ9 - Cruise Control w/ETC - Indicator
- 98 V6 w/ 98 LS1 PCM or 00 PCM?
- Video of My LS1 S10 Xtreme...
- (P/N 713088-P) GM Gen III Vortec engine mount kit
- Anyone have an LS364 carbed motor?
- Yet another Jeep TJ GM motor swap :)
- where is the guy with the 69? camaro ls2 with custom tank made in NC???
- Single Plane Intake And Fuel Injection
- PICS. Hooker mounts & headers in a 69 and a CHEAP T56 crossmember.
- Thoughts about turbo charging?
- Simplest LS accessory belt drive?
- LSx for sale w/ a cheap ride
- I Need Help... T-56 mated with Gen I SBC
- Recommend tires!!
- LS-1 in full size 82 Blazer
- 240 crew: are these the part numbers for the GTO oil pan I need?
- What is needed for LS1 into a LT1 camaro?
- LT1 to LQ4 swap?
- Help me bring life to my 55 Chevy
- ls conversion meeting?
- LS1 T56 to 4L60e - harness conversion
- Noob LS1 in an BMW e30?
- Another Mustang LS2 swap in progress...
- 5.3 in a 1993 jeep yj
- TJ PCM Mounting
- LS Exhaust Manifolds
- 416 l92 in a 92 miata what about headers??
- 460le trans park position question
- LS1 + '79 Malibu = what needs to be done??
- S10 + 5.3L = Security issue
- Mustang swap parts
- suggestions for an injected transplant into 66 Impala
- Exhaust manifold sticky?
- what kinda weights are the LSX foxes?
- L92 & 6L80E into a 1966 GTO anyone?
- March or other pulleys for LS7?
- OBS 1998 4.3L , swap to LSx?
- TW: How much would you pay for a swap kit for a 240sx
- Accessory drive (yet again...)
- LS1 prep before install, been sitting 2+ yrs.
- LS1 Install Question
- Considering LS1 swap in my Mustang...
- AC Compressor Relocation--One approach
- LS6 FC build
- My LS1 + T56 pullout came today
- Phase I 3rd gen LS1/T56 swap
- Thinking about a 240sx swap
- Shop Near Atlanta / Southeast For LSx 1998 Blazer Install
- 416 w/T 56 into 92 Z-28
- 1984-1989 Nissan 300ZX conversions. Are they out there.
- header questions
- Ls1 in a 93-97 Car
- What is required....(transmission related)
- 5.3 in an '86 Sierra
- it runs for real this time!!!!!
- ls1 efi 2 carb swap!
- 944 Porsche LT1 questions
- 2nd gen f-body headers
- C1 and C2
- 74 LS6 CAMARO polished fuel rail pics
- 4l60e into a 240sx chassis
- Vintage air and LS1 compressor
- 86 Chevy 4X4,5.3 swap
- LS3 fox/motor plate - headers ???
- WARNING - Have tissues handy
- third gen swap
- Lokar shifter replacments
- Need A Good Conversion Shop
- A body oil pan clearance
- switching from ls1 to ls2
- 00 LS1,harness etc into a 99+ V6,can you???
- fuel pressure regulator
- ls1 t56 xtreme 2002
- 93 camaro rs...ls1 swap? tranny q's
- LSx pullout What is needed?
- post up some pics of your intake piping!!
- Impala Motor Swap?
- mustang II brakes and springs
- Is "Bad Penny" back together yet????
- Chevlle gas tank ?
- vids of my ls stang with a 300 shot !
- Getting a longblock for a swap. What else is needed?
- Quickest/easiest way to accomplish engine & tranny swap?
- Tuners / PCM reflash / O2 delete / VATS / etc
- Got some video of it running.
- GTM Build
- AC Bracket source?
- LSX in 87' Fox
- 5.3 liter into a YJ.. need LOTS of help!
- ls1 swap in s-10
- s10 owners
- ls1 into a lt1
- LY6 in a '98 Jeep Wrangler
- LSx Identification
- New Project Same 72 2wd blazer
- transmission help
- ls1 fj cruiser
- W body exhaust manifolds
- Just Finishing off AC hoses - Compressor Question
- 5.3 liter for swap
- Twin turbo ls1 in 72 Cutlass
- Just another LS1 Procharged Mustang
- Cruise Control for LS2 DBW
- Which headers and cat back for fox ls1????
