View Full Version : LT1-LT4 Modifications
- Help Me Choose TD Mufflers
- valve spring questions
- 96 Impala
- 12 Second LT1
- Dif between optispark n disturb
- Losing interest. Should I sell or part out?
- heated 02 sensor, or no?
- 1994 Z/28 Engine removal/rebuild
- $51 for lifters..... each?????wtf
- rpms drop and bog at 2200 rpm
- Car issues : Need help!
- Cam Swap....Have a question.....
- Wtf
- weird problem
- Fel-Pro Q1406, which side facing header(manifold)
- Fluidampr LT1 OBD-I woodruff key & installation questions .
- template/guide for porting heads?
- M6 swap. couple ?'s
- Wtf help me :)
- where can i get my lt1 tuned
- LT1 running rough & doesn't want to stay running
- What to tune with?
- rod bolt upgrade
- Going full roller on LT1
- pain in my ass
- vehicle issues
- can anyone help me
- engine build ?s
- Those felpro blue oil pan gaskets reusable?
- Pulling Motor From the top WITH tranny attached.
- LTX Shootout "Street Stock" Rules
- Looking for .bin file?
- ASS picture
- Z06 Wheels on Camaro??
- Low RPM Miss/jerk HELP!!
- compression testing questions
- What timing chain?
- fuel pressure regulator question
- tint pics
- Torque converter failure or transmission failure pt 2
- 94 Vette Coolant temp sensor
- supporting engine for k member swap?
- Operation Black Hawk
- CC503 vs. CC306
- Help!!!
- i wasn't aware that the LT1 is a 265 cu in DOHC v8
- LTCC Instructions
- 02 Extensions?
- help with header install
- 42lb fuel injectors
- 24x Kit, A Couple Questions
- Autometer oil pres./water temp gauge install
- Found some damage to my valvetrain! A Little Help?
- CC306 Vs CC503
- plug wire routing question
- LT1 on LS1 tech
- Rack and pinion install?
- LTX dvd
- Messed around with the car today
- poor attention to detail - kooks, stainless works
- Pics of LPP vs. Ebay headers side-by-side
- can a msd digital 6 plus be fixed?
- mig welder of choice
- what this tube for??
- timing cover vs oil pan gasket
- Cometic Head Gasket
- ProCharger LT1 Parts at Brute Speed
- LT1-LT4 Swap problems.
- 383 oil pan questions???
- driver window trouble Help
- CC 280XFI or Lunatti VOODOO 60122
- 1 7/8 headers
- Using rear o2 harness for headers???
- How much did you gain?
- New PB at Fontana today...
- How much power is possible through LT4 Heads ??
- 398 stoker setup needs your help!!
- 6LE Stainless ORY-pipe install issues
- Programmer
- off road y pipe fab
- Bin file for Tuner CATS
- LT1 Engine Removal
- Fabbing up a mechanical oil pressure gauge.
- parts needed to finish
- help trying to put injectors back in!!
- msd otvc
- Exhaust new here
- 02 sensor
- injector o ring kit
- MSD 6AL Question!!!
- Kooks and Plug Wires
- Anyone got an AS&M mono blade for sale?
- Chandler Opti Install...
- lt1 max valve lift/duration
- wiper arm removal
- Anybody have an extra crank hub washer laying around
- Piston Recommendations
- fuel injector leak
- Jet Performance Module Install on LT1?
- Anywhere to find former owners names/addresses for free?
- What % tint should I go with? Post some pictures of
- Willl this cause a no start?
- Crankshaft Key!!!!
- Identify Rocker Arms and Push Rods?
- shocks
- Bolt on car.. looking for advice on tuning
- horible vibration
- injectors not firing due to ????? opti???
- intakes???
- ebay headers
- Exhaust Setup
- Quick egr Question
- Nitrous Timing Retard using MSD Optispark Distributor?
- SBC Timing Cover on LT1 Block????
- Single plane with LS1 style TB???????
- Trickflow head/cam combo
- Any advice for a guy about to install EFI Connections Kit?
- Smallest but quietest mufflers?
- exhaust cutout size and placement
- fuel pressure need help!!!
- driveshaft coupler connector?
- What head gaskets for 4.030 bore motor
- LT1 high idle, IAC?
- How much is this car worth (97 TA)
- Faded Trans Am tail lights.. Anyone ever pull them apart to repair them?
- Can I calculate my compression ratio CR with these informations ?
- tuning
- Could this be a problem for spray?
- My CNC'd Brodix IK210's came into today, pics!!!!
- what is this
- what is line on back of heads for?
- DD cam
- *96Z28 vs. STI - Help me Out!*
- Got my scat forged rods in today! ?'S
- What do you think this car should run at the track?
- Rocker selection help
- post pass opti issues
- MLS head gasket leak?
- LT1 Dash questions
- What tig welders do you guys like to use?
- evap?
- Running out of things to replace to fix my problem...No codes...please help
- Idle raises when I pump the brakes hard...?
- Lt1 intake
- Dash light out.. Cant see anything..
- 1.7 Rockers with Hot Cam?
- Jegs or Street Fire?
- overheating again
- help me pick gear / tire
- MSD 6AL2 questions
- Car misses/loads up when wet?
- Will a ported intake work with stock exaust manifold?
- Power gains from a 52mm - 58mm tb on a H/C car?
- stock bottom LE2 cc306 and 5psi?? hp est
- Watching the superbowl? or working on your car?
- throttle cable?
- transmission help
- Is it bad that I can change transmissions faster then I can do an intake gasket swap?
- tunerpro questions
- Whats the best way to...
- need help
- LE2 Track Times
- Speedometer stoped working, after T56 rebuild.
- should i chang cams?
- Valvetrain in Winter..
- Best & Cheapest way to build 355 LT1
- should i buy these or better?
- Trouble codes 16 and 26?
- high milage lt1 guys, step in
- strange question
- Need help getting motor at TDC
- MAF replacement
- balancer and hub question
- opi spark
- need help reassembling motor
- TPS no voltage (and some other issues)
- Problem? Any ideas...........
- Tuner Pro/ OBD 16 pin HELP!!
- Kooks True Dual System
- My heads are on the way to Lloyd
- HELP! Battery Relocation Issue....
- coolant flush question
- Quick gear install kit question
- engine still runs hot!
- What else do us LTx guys need?
- LT1 block
- think im gonna go to the track again
- Oil pump drive mods...
- Wideband Install Q..
- gear installation kit??????????
- cant find elbow sleeve?
- Door handle question
- Supercharger?
- Will this "ebay" Y-pipe work with my headers?
- NEW lt1 hauler!! well new to me
- lt1 exaust
- lt1 exaust
- 20 Degree and low coolant light come up
- Best tune?
- Timing cover seal installer
- interior parts
- A few seconds..
- Fast LT1 guys come in... 383LT1, Fast DFI etc... Come
- OTVC plug wires
- Tranny Question
- Intake Elbow
- what cube LT1 should i build??
- Sweet Z28 Convertible inside!
- Camaro gt1 hood
- OBDII to OBDI conversion
- 1993-1997 Stainless Steel Y-Pipe $80 SHIPPED
- Ls1Tech Calender.
- Very low end miss.
- Best mid length headers for 95 z28..??
- codes from AZ
- crank repair sleeve
- Shift light
- Need help picking a stall for a Turbo LT1
- carb intake question
- 95 Trans Am spark plug stuck not stripped, maybe rusted shut, and feul promblems
- 52mm TB to 58mm TB no tune?
- Getting the car back on the road after almost 2 years
- Strange 12 or 9
- Stall Question
- Right bank killing O2 sensors?
- Changing wiring harnesses
- Rotating Assembly
- Coolant Frozen
- NPT plug size in LT1 heads? Is it 1/4"-20?
- Best oil for my LT1?
- LT1 fuel fire n o start
- Question!!!!
- How to change rev limiter ?
- Ever Use These Head Gaskets?
- Replacing opti, do water pump at same time?
- Ring gap, this ok?
- head gasket question
- arp headbolts
- Looking for a Vic E
- GAS!! epic fail
- Keep Cam....or... Sell to buy Stall?
- 1996 WS6 Smells Like gas inside and outside of car.
- Car Still Slow, Getting Sick Of It
- 1996 WS6 6speed Transmission shakes when i let clutch out?
- Who wants a little LT4 manifold??
- Cracked Dash? Need Advice
- piston and ring kit.
- heads/cam
