View Full Version : Automatic Transmission
- 4L60E yoke/drive shaft 1969 Camaro
- Can you short shift a 4l80e without a fmvb
- 4l70e Supermatic not recognizing shifter position
- corvette tranny conversion
- off name shop's level 2 4l60 issue?
- 4l80e
- TC install
- North texas converter
- Help identifying what is inside this powerglide
- 4l80 with trans break
- Stand alone harness transmission help
- 4l80e wont stay in 1st when i put it in 1 on shift selector
- oil pain on 4l80e doesnt fit after Transgo HD install
- 4l60e/3200 circle D stall - pops into neutral at dead stop?
- Stall or No Stall?
- Considering selling my Jakes 4l80e in favor of a Glide
- Low reverse seals keep breaking.
- th400 to s60 driveshaft, which is cheaper?
- 8L90 vs New 10-speed Ford Co-developed Trans
- 4l60e rebuild question
- th400 swap, what trans mount do i need?
- 01 chevy 4x4 truck trans
- 4l60e to 4l80
- Lost a snap ring on a 4l60e can somebody name it?
- 4L60E trouble
- Bad idle after swap
- ATI rmvb th400, no 3rd gear at wot??
- Th400 broke?
- Help diagnose my carnage
- th400 to strange s60 driveshaft longer or shorter
- Blew my T56 today at the track, what do do next?
- 4l80e speedo hook up
- Using AN line for trans cooler
- Cruise control not working after trans swap
- ATI Converter 4l60 users?
- Building a 4L65E to handle serious power
- Delete P0751/P0757
- 5.3 to Turbo 350 bolt size.
- 4L80 output shaft?????
- What Stall?
- LS-1motor 4L60-E tranny
- Ratchet shifter for TH400
- North Texas Converter SALE!!!
- Rossler TH400
- 4l60e line pressure
- 4L60E problems
- Unifit TH350 bellhousing
- T56 swap for A4
- ET drop with trans swap
- Yank Stall Slipping??? Please help
- B&M cooler install "266" with braided line DOPE style
- 4l80e - Car dies when put into gear
- Precision Torque Converters?
- Transmission removal questions
- Best street/track shifter for mildly built 4L80E?
- what transmission to use
- Converter, motor or tuning issue.
- 4L80e Help
- TH400 experts inside please
- building a mild race 4L60E.... for offroad?
- TH350: 1st gear locked up, now slipping?
- post transgo sk4l60e install ??
- precision performance products shifters
- 4l60e no 3rd gear in drive
- What else do i need for stall install??
- CSR trans shield in stock?
- fresh 4l60e leaking from inside bell??????
- dipstick tube leak
- Trans Brake on supercharged cars
- Torque converter shift extension
- hotrod build trans harness question
- looking for some input
- 4l80e TCC Dragging
- Competent Tranny Shop in Phoenix for a 4L60E
- Newbie Question Regarding Stall Converter
- 4L80E W/HD-2 Burned Up Direct Clutch Twice, Suggestions?
- M6 to TH350 crossmember
- Plz help! 4L60E: Lost 1st & 4th (OD) after pump change
- 4l80e check balls
- Need converter advice
- 4l60e? U-joint? clunk Low RPMs & 1st-2nd shift
- Help spec auto trans for turbo build
- Transmission Fluid Overfilled - Yay or nay?
- Need Help, No Keys
- First time at the track no 2-3rd shift
- Best transmission cooler
- V6 4l60 to 5.3 help please
- wiring trans brake/ 2 step?
- How much is heat affecting the transmissions?
- Problems with my 4l60e!!! need help!
- 4l80e Rebuild kit
- Check engine code P1570
- 60/4l80 trans tuning, is there any difference?
- What tranny to go to from manual
- Problems with my th350
- Switch from SS3400 to SS4000
- th400 and 4l80e steels
- 4L80E swap experince come inside
- T400 swap getting rid of skip shift error code
- Is '06 4L60E pump and '04 pump interchangeable?
- Trans help
- Horrible Gas Mileage???
- Issue: Flex Plate, TC, 6L80e trans?
- 4L60E Fluid and Filter Refresh
- 4L60E transmission issue.
- 4L80E front seal part #?
- 4l80e false shifting help
- 4L60e valve body ?
- No movement after 97 4l60e warms
- A/C Delco part numbers
- Shipping a transmission
- LQ4 6.0 with TH400...need suggestions
- What size Trans cooler?
- Trans dipstick
- stock LS1 Formula, converter decisions
- 00' formula, A4 trans, shifting into 4th at WOT??
- 4L60E Input shaft stuck
- 4l70e true tech rebuild kit??
- 4l65e lost all gears then came back
- GM 4L85 SuperMatic
- Please help! 80e swap have reverse and what seems to be 3rd only
- Front Pump
- 4l80E Trans Tuning Help
- How important is the PRND switch - 4l80e
- LS1 to th350 or powerglide
- Converter won't stay locked while cruising
- 4l80e MVB issues
- 4L80E, American Musclecar, European Customer
- Make me a Believer?
- Circle D 3200 stall ?
- 4l80 drive shaft
- 4L60E Temperature Sensor question. Why does it have one and what does it do?
- HELP URGENT!! 4l60e leaking from bellhousing!
- 4l65 late/no shift issues
- Th-350 stall question
- Rebuilt with shift kit, have tuning ?....
- North Texas converter
- Oh I so want to cry...stripped coolant threads!
- DFW area racer currently using TH400 needed for testing
- 4L60 Vibration Help
- 4L60E shifting issues
- Trans cooler temp switch location
- 4L80E seal ?
- no vss signal to speedo or snap on solus scanner
- trans acted like it went into neutral, help!
- stall converter
- 4L60E no D or 3
- 200k mile 4l60 question
- Yank SS3600 Fitment Question
- Weird vibration comes and goes th400 9"
- t-400 tranny cooler line pressure
- 2000 4L60E to 1997 4L60E Swap?
- Transmissions on Sale
- Torque converter
- Is a triple disc circle D converter actually a twin?
- Th400 swap no mph
- 4l60e lost 1st and 4th after converter install
- Snap Ring Pliers
- Park neutral switch troubleshooting
- Introducing the new performabuilt black edition 4l6xe series
- does downshifting manually hurt the tranny?
- 4L80E pump noise
- 4l80e swaped but wont down shift
- Trans Line Pressure Bypass Set Up?
- tuning question
- Advice on Torque Converter
- 2004 Tahoe 4l60e
- Transmission dipstick tube/EGR hose removal
- Need help 6 speed to auto question
- TSI Racing Rebuilt 4L60E's Overrun Sprague Assembly Broke, what's better?
- Question about 4l60e connector
- 4L80E question
- 700R4 to SBC 4L60E to LM7
- Won't go 2-3 at wot? 4l60e
- Announcement from PerformaBuilt
- 5HMD T7209AA 6.0L GTO 4L65E does it have a front input shift speed sensor
- Unable To Separate 3-Piece Oil Pump Body On A 4T65E
- fti 3600 help!!!
- Swap question
- I know! Another 4l80 question...
- 4L80e Rear Cooler Fitting
- Help with 4l60e, high rpm low speed, no OD *** Update: Fluid pic
- How are the trutech 60e rebuild kits?
- Whick size/type circle d converter for my setup?
- rebuilt 4l60e dragging in reverse
- 4L80E tc question
- 400 swap speedo question
- stall and frost tune questions...
- Trans Brake issues
- Circle D Free Shipping In July!
- 2002 4l60e horsepower?
- veter dragging badly!!!
- 1000rwhp/4L80E / Boost / Vacuum Modulator (yes or no)?
- 4l80e swap. trans won't shift at all
- 98 4l60e torque converter
- Transmission swap
- 4l65 E conversion questions
- Whats a good tc?
- 4L60E No Park/Neutral no 2-3 WOT
- Which 4l80 kit to buy?
- New to Automatics. Converter Help Please
- 4L60E or 4L65E
- lq4/th350
- 4L80e Not shifting to 3rd at WOT
- 4l60e help!!!!! Urgent!!!
- Converter swap ? About fluid n filter
- Preventative Measures 4L60E
- Rebuilt trans just killed the 3/4 clutch pack again
- trans brake stall help
- Cam/boltons/125 shot.. What's trans do I need?
- Another 4L60 Issue
- Manual 4l80e Shift Pattern ?
- 4l60e lost 3rd and 4th.
- PCM of NC Transmission Cooler
- B&M pro stick question
- 1991-96 4L80E to LS engine
- How much hp can it hold? 4l60e
- Replacement Trans cooler fitting
- 4l60E with no third or forth gear.....
- setting up 4l80e for specific swap
- 2001 Camaro Z28 4L60E shift problems
- Transmission fluid temps.....whats too cool....?
- 4L60e "skipping" 2nd at WOT
- 4l80 conversion advice
- Question a modifying 2004r governor
- How to measure pinion ange etc?
- HELP: Issue with 2-3 shift in LVL 7 RPM trans!
- Summer sale on TH400's Powerglides, and TH350's.
- 01 ls1 motor what year 4l60 can i use?
- School me on converters please.
- Are they not the same?
- PCM of NC Cooler Vs B&M Super Cooler
- Difference in TH400 and 4l60 converters
- 4L60E....100% Complete Rebuild kit.......who sells it...?
- Performance gains
- Transmission coolers. By pass the stock or no?
- 4l60e rebuild problems
- 4L80E swap. Not going into any gears.
- 4L60E Valve Body
- New converter - street monster..
- th350 electric speedo
- 4l60e possible vibration issue
- Hard shift from 1st to 2nd HELP
- Strange occurance with '00 SS
- built 4l80 is slipping 2nd suddenly
- lq4 to circle d w/ls1 bolt pattern
- Looking For Advise On A 4L60E Rebuild Kit
- Broken intermediate snap ring 4L80E
- converter install
- 80e swap 3rd tq lock but no od
