PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 [74] 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. how does the condition of this stall look to you?
  2. PT4000 owners.. need some advice
  3. Explain to me loss of HP though a slipping A4
  4. Am I the first person to go from a T56 to a 4L80E?
  5. 4L60e Rebuild... What caused my failure?
  6. trans temps
  7. guys with th350
  8. 1-2 Shift solenoid..not the same?
  9. 700r4 help please!
  10. Performa trans Yank stall.....problems.
  11. Need input FAST !! Tranny in limp, not working
  12. YANK stall
  13. Need Pro advice AGAIN lol
  14. TH350 speedo problem
  15. What stall need help!!!
  16. What stall need help!!!
  17. any write ups on removing/installing a 4l60e
  18. Im tied between the two..
  19. 65000 mile a4...stall or not???
  20. torque arm bolts just spinning
  21. auto to manual pedal assembly, brake stiffer?
  22. Yank SS4000 for 4L80E for sale
  23. return line
  24. Help New trans/converter wont hold fluid
  25. stall or trans bad
  26. Have a PT4000 Converter, But want a converter that hits hard & gas milage!
  27. rev limiter?
  28. stall without tune
  29. good turbo converter around 3200 stall?
  30. shift kit debate.
  31. 4L80E swap isn't working correctly...need help.
  32. Where can transmission pan magnets be purchased??
  33. Is this normal???
  34. 3-4 clutch pack ?
  35. Okay to drive with leak???
  36. Help with picking a stall
  37. Help with choosing stall speed
  38. Dipstick Tube??!!
  39. Need help selecting stall speed 2.73 6l80e
  40. 4l60e to 4l65e
  41. Trans Temp Sending Unit
  42. opened up a 2 yr old FLT trans :)
  43. 700R A4 question
  44. 4L80E - IRS driveshaft question
  45. 6l80e
  46. turbo 400/4l80e SFI flywheel
  47. Quick convertor questions
  48. possible transmission problem...
  49. Bbody tranny swap question...
  50. Stock Torque Converter Question
  51. Stall Converter Bolts
  52. Changing convertors, do I need to retune?
  53. 4l60e electrical seal?
  54. Shopping for stall... (what would you get?)
  55. th400 w/ no stall??
  56. Newbie question about shift kits
  57. Need a convertor. New or restall mine
  58. Lost tranny fluid!!!
  59. Will an electric trans pump work with the engine off
  60. Question about 4.10's
  61. Fuddle Converter?
  62. Shift Points?
  63. converter problems
  64. I need serious insight on 6l80e before purchasing
  65. Engine braking A4 = TCC Death?
  66. 4l60e problem - Help!
  67. building a powerglide
  68. What rebuild kit for my 4L60E?
  69. best current price on billet putput shaft?
  70. 4l60e worn check ball symptoms
  71. The 4l60e
  72. FLT have a tech question for ya
  73. stall questions
  74. Killed 3rd gear in my 4L60E today
  75. Quick shift kit qeustion
  76. B&M Magnum Grip Pro Stick Shifters with electrical shfiter soleniod!
  77. What is the problem?
  78. What stall and what company?
  79. Got the SS4000 Installed.
  80. Would you consider this a loose converter?
  81. Rebuilt 4L60E with New Converter Problems
  82. Stall too big
  83. Transmission experts I think I got my first problem
  84. Tranny experts A6 tranny sound.. please help
  85. Help with crazy mechanic
  86. When you go with a high stall, should you change the seperator plate hole sizes?
  87. 1994 60-e in a 99
  88. parts necessary for a stronger 4l60e
  89. got the 4l80e switched back to auto mod
  90. 4l60e stall question
  91. FLT come inside please!
  92. wtf 4l60e acting up!!!!!!
  93. can i use a truck flexplate
  94. Tuff Decision: free 4L60E or not free 4L80E...
  95. Drive Shaft Sponsor
  96. 4L60 or 4L80 behind L92? need help deciding
  97. TCI flexplate, th400, aftermarket TC, TC bolt head protrusion ?'s
  98. 4l80 in camaro
  99. 4L60E vent
  100. Trans stuck to the Engine
  101. Transmission Install
  102. TH400 robbing hp?
  103. diff between 94-96 and 98-02 4l60e?
  104. help me diagnose auto tranny problem
  105. 8" race converter and street driving
  106. Re-stall
  107. Source of Transmission fluid leak?
  108. 4L80E question - can I move the vehicle around?
  109. Transmission/Converter R&R How-To/Write Up
  110. 4L60E shifters ?
  111. TCI torque converter issues?
  112. converter locking in 2nd & 3rd @ WOT...EFILive
  113. Should i replace my Flexplate?
  114. Tranny acting up on trips in OD
  115. 4l60e transmission shift problems 1-2, 2-3, 3-OD
  116. what could be wrong?
  117. converter locked up when i start car. brand new
  118. torque converter and . . .
  119. Questions about my dipstick th400
  120. 4L80, from 4WD to 2WD, what do I need?
  121. Short Tale TH400
  122. TCI vs Yank
  123. Which Flexplate is right for my DD?
  124. 4l80e vibration when giving any kind of real load
  125. 2-3 shift hittin limiter @ WOT, brought shift point down
  126. 370, PT88, TH400, what converter?
  127. 700r4 speedo?
  128. Big thanks to APF, Circle-D and SpeedInc.
  129. Anyone use the B&M Starshifter? Couple questions...
  130. 4L60E identification ???????
  131. Lokar dipstick tube question
  132. Turbo 350 to 6.0L
  133. u joints
  134. 4L60E longevity questions - NON Fbody
  135. th400 install questions. pcm, limp mode, and driving...
  136. TH350 swap, need a new driveshaft?
  137. Shift solenoid question?
  138. 4l60e question
  139. 4l80e-switching from man. to auto
  140. Finish Line Trans Shipping Special
  141. High RPM Vibration
  142. Z06 or any C5 M6 to A4 conversions
  143. stall speed on stock converter??
  144. Picking the right stall/ company
  145. Need help with TH350
  146. LS2 to 4l60E Ouestions??
  147. GTO with Speedometer issue after TH400 swap
  148. Thanks PerformaBuilt!!!!!!!!!
  149. Need stall speed opinions
  150. stall question
  151. Delay in downshift when in D vs OD
  152. lots of play in my rear shaft on a 4L60e
  153. Who has the best price on LS1 4L80 crossmember ?
  154. 4l60e to 4l65e swap question
  155. 4l60E ???'s
  156. New trans question
  157. Help get rid of my stall wall plz!
  158. what trans is right for me?
  159. Second Overdrive in a 4L70E
  160. FLT Props again
  161. rebuild or new ?
  162. Scared to go from Yank SS to the PT
  163. need torque arm / exhaust mount
  164. what years work with my 2005 6.0 truck engine
  165. 228R and stock stall
  166. One bolt left before trans can come out - PLEASE HELP!!!
  167. Help me piece together a 4L60 build
  168. Flywheel or converter causing vibration
  169. 4L60E Rebuilt Transmission sticking when shifting into First Gear
  170. anybody running Art Carr converter?
  171. wow my new bmr stuff is so purdy you almost dont wanna put it on LOL
  172. Big thanks to FLT and FTI
  173. Cracked flexplate :(
  174. 4L60E servos...which ones?
  175. Slack in tranny
  176. Help please
  177. Which converter?
  178. stock cam and stahl
  179. Do i need a trans cooler with stall
  180. noob question.. WOT-shift into 4th w/4l80e
  181. Trans Fluid
  182. Should i Stall My Stock 4l60e Or Not????
  183. Calling all datamaster/tuning trans gurus to help. Can somebody check out my datalog?
  184. Please help....shifter problems?
  185. stock stall??????????????
  186. 4l80e converter lock-up question!
  187. FAST/TCI Trans Controller
  188. 4l60e problems
  189. A few transmission problems "4L60E stock"
  190. Should I get a stall converter?
  191. 4l60E 3.23 Gears Shift points?
  192. Stock stall number?
  193. Gears with a Glide and N2O
  194. How much stall-stock ls1 converter?
  195. Trans failure?
  196. 4L60e to a truck 4L65E
  197. transmission help needed!!!
  198. Custom stall help
  199. Need a REAL race converter
  200. Trinity 4l80 brake and pcs controller ordered
  201. too much clearance
  202. Silverado Trans to Z28
  203. m6 to a4 swap
  204. 4L60E problem or comp problem? HELP!!
  205. FMVB 4L80 guys
  206. light clunk, knock, tap, noise while cruising and giving gas . .
  207. Looking for stock, to low stall, converter. Are these OK?
  208. fbody 4l60e questions
  209. Changing Shift pattern... HELP! (please...)
  210. New converter, new problems?
  211. Setting Base Line Pressure
  212. shift problems with drag radials only
  213. Will a 9.5 inch converter fit in a stock 4l60e
  214. Quick Question
  215. 4L60E whats differant 01-05
  216. Crank Spacer
  217. Anyone using a transbrake with 4L60?
  218. Cirlce-D 4C just installed
  219. IS it broke?
  220. *prototype th350 crossmember*
  221. Shift Solenoid or worse??
  222. New converter + HD2 kit, slipping like a mofo
  223. Help with transmission!!!
  224. another gear tire question
  225. 100k plus miles --Service trans ????
  226. Driveline play
  227. Interesting smell...
  228. Trans Issue????
  229. Those of you using a PI 4l80e converter
  230. FLT power levels?
  231. Yank Warranty/Rebuild Options?
  232. Kolene steels?
  233. Converter help, mid 10 sec all motor LT1
  234. Which converter???
  235. Ordered ths SS4000 Friday
  236. torque converter
  237. Pump failure - any idea what caused it???
  238. F**K prothane tranny mounts!!!
  239. Ordered a yank ss3600 last week, have some questions
  240. wiring up a TH 400
  241. Did you like your switch from A4 to M6 or M6 to A4
  242. Shift Pattern Reverse or Foward
  243. wich stall is best for me ?
  244. stock drivetrain? stall? 400hp?
  245. What would cause 4th gear (OD) to not engage ?
  246. TCI 6 Speed Auto
  247. shift cable need adjusting?
  248. Ever had problem with TC bolts? Striped! lots of grinding!!!
  249. torque converter shutter/problem
  250. Converter hard apply
