- Beast vs sonnax vs monster shells vs late stock thoughts?
- Build pics level 2 heavy duty
- Best shifter for 4L60e trans(Show me your set up)
- Stall advice BTR stage 3
- Shorter 4l60E tail housing?
- 200 4R behind LS short crank
- New SS3600, who?
- 4L60E transmission cooler & torque converter
- 4L80e NO 4th/OD
- Turbo 350 fill line
- ATI transmission controller
- Stock 6L 4l80e flexplate Strength
- Shifting issues with 4L60e and TCI Controller
- 4L60e questions
- WOT shifts to OD with the 4L60E/700R4 Opinion
- What are the basics on making a 4L80e tough as possible?
- 4L60E EPC solenoid
- New electronics in older core?
- 4l60e question
- New converter or restall?
- 6l90 flex plate and torque converter on 6l80 transmission
- 4L60E No upshift
- My 94' V6 idles fine, no misfire but feels like it has no power
- Freshly built 4l65e 2-3 flare
- 4l60e to 6l80e 2nd gen silverado 4x4 5.7L LS1 wiring harness help.
- 96 4L60 hard 1-2
- 2003 4L60E No Overdrive After Rebuild
- 675whp Silverado 6L80 Help
- 4L80e swap NNBS (GMT900)
- 4l60e valve body issue?
- 5.3 4L60 transmission compatibility
- Is my cooler big enough?
- turbo 350 pressure
- 6l80 won't shift
- Too much fluid?
- C7 Corvette With Converter Only
- 4l60e line pressure does not increase
- 4l80
- 6L80E - low line pressure
- Swapping 4l60e to th400- be able to reuse aluminum driveshaft?
- B&M Cooler upgrade, -AN fitting question w/pics
- Core Unit Purchasing?
- 2000 silverado 4l60e swap to 2008 4l60e ??
- 60E/ 80E Motorsports ("Mil-Spec+") Wiring still Avail.
- 4l60e Torque converter not engaging pump...
- 4l60e leak
- Need some 4l60 interchange info
- Automatic 4L60E erratic shifting problems
- 4L80E/TH400 parts
- 4L80E whine and looses pressure when hot
- 4l60e rebuild. No input end play...
- No park neutral indicator on dash
- 1000 hp 4l80e build
- 4L60e Can I use the donor shifter?
- Custom Shift Indicator for 4L60E
- Learned a lesson today (4l60)
- 4l60e only shifts manually
- Quick question for the experts: Pump halves compatibility 4L60E
- 4l60e has 1st gear in D but not in any other gear
- 4l60e 1000 horsepower what mods are done to help it survive
- Is this 4l60e overrun hub reusable?
- Good laugh about a 4L60e
- '00 WS6 Auto Locked Up In Reverse
- 4l60 shifter cable not fitting on 4l80
- 4L60E (p0740 p0785 p2761)
- Transmission rebuild questions!
- No second or fourth gear(Automatic transmission)
- Converter feed restriction
- Trans cooler questions
- No Forward clutch clearance
- Another 4l80 yoke post
- Yank Converters SS3600
- Flex plate help
- Need advice
- 4L60E - No forward or reverse gears?
- 6L80E Intermittent No-Movement
- Will an 07 4L80e work on Gen 3 build?
- Why does my rebuilt th400 Leak
- two 4L60E similar problems
- 2015 chevy tahoe 5.3 6L80
- 4l80e no wot kickdowns
- Transmission Conversion
- 2008 4L60e valve body swap (years?)
- 6l80e Converter pad/flex plate measurements
- 4l80e Forward Clutch Fried
- Torque arm relocation bracket
- Removing toque converter cover
- Failing Aftermarket Torque Converter???
- Help with 4l80e final assembly
- 700r4 -4l60e pump
- Stall converter
- TH700 ultimate pan drop upgrades
- 1995 4L80E smooth front planet?
- 01 Silverado Transmission Noise
- 2008 4L60e to 2010 4L60e
- 4l60e shifting issues and Idle issue.
- 98 Corvette built 4l60e went to tuner now car dies when I put in reverse
- Now a sponsor on ls1tech :)
- 4L80 New build no gears - Help Tyrones
- 4L80E Output shaft trouble
- 6L80 performance builds
- 4l60e dumping fluid at WOT
- 4l80 third gear only and other weird stuff...
- 4L60E Forward friction
- Firmer 2-3 shift
- 4l60e not getting info from ecu
- Converter recommendations
- 94 Reman 4L60E
- Holley Terminator X v3 now supports 6L80/90e
- 4l60e fresh build leaking from vent tube.
- 4L60E Low Pressure When Hot After Rebuild
- Yank SS4000 vs. SS3600
- 99 Camaro 4l60e question please help
- 4l60e shift only by high rpm
- Never roll or break an Input sprag again! 4L60E
- 4L80 front end clearances
- 4L60E Barely Moves
- 4l80e extremely slow filling
- 4L60E Swap to 4L70E Reprogram or Retune Required?
- Can a transmission or converter make a knocking sound?
- 8L90E conversion
- 1992 Bronco LS3 Erod Swap.
- 4l80e vent tube puking tranny fluid only with Yank ss!!
- Did i destroy my 4L80e?
- Frank@PerformaBuilt anouncement
- 4L80e bellhousing size?
- 4L80e Hd-2 remove or new valve body
- Wave plates 4l80
- 4L80 fun
- New to LS1Tech
- 4l60e to 4l80e swap
- Low Mileage 4L60E Carnage! Rebuild with Upgrades. Pictures! Some advice?
- Reman 4L60E Not Shifting into 3rd or 4th After Line Popped Out
- Just rebuilt 4L60e still shifts to neutral from 2nd??
- will 99-06 truck PCM run a 96 4l60e
- Torque converter brands
- 4l80e Envoy swap
- Piece broken off TH350. How can I get around this?
- 4l60e swap issues
- 4l60 e questions
- C5 LS1 Flex Plate Question
- motor home 4L80e - ball bearings in tail housing?
- 2-3/4 out on 4l70e
- 4L60E Pump Failure while cruising
- Ordering a 4l80e Converter - Opinions Needed
- Manually shifted automatic transmission or automatic shifted automatic transmission
- Swap 6 speed to automatic transmission
- 4l80e
- Slight 2-3 shift flare
- How to get my 700r4 TV cable to work with my lq9 6.0
- 4L60E 4th gear torque capability
- 4l60e issue
- pressure sensor
- 4l60 e help
- 4l60e losses all gears until restart
- Another 4L60E rebuild based on build thread research
- 4l60e No manual 1st, 3rd gear starts, otherwise shifts fine and locks TC
- Deep pan
- Trans-go HD2 4l80e recommendations
- Rebuilt 4l60e no movement.
- Would a 4L80E fit in a 73 impala with no cutting of the body.
- 700R4 “K”case behind 5.3
- First time with auto transmission
- 4l80e transmission protection rules advice?
- 04+ 4l80e forward gears only
- 4L60E No reverse - Wear gloves to handle this post [Updated]
- Yukon 4l65e Rebuild questions
- 4l60e problem after rebuild
- 4l60 build
- 1st gear+ OD = 5 speed ?
- 4L80 shifter/4th gen Camaro
- 98 4l60e no second gear after sunshell replacement
- 4L80e Superior kit w/ Sonnax separator plate
- 220k 4l60E lost 3/4
- 1-2 Accumulator Housing Springs?
- 4L80E Sonnax Case to Output Shaft Bearing
- Rework
- Mil-Spec/ Motorsports Grade Trans Connectors
- Th400 Valve Body Selection
- 6l80E Torque Converter for towing
- 4l60E damaged in oil channel
- 4L80 trans mount with driveshaft loop
- High line pressure after pan-drop mods
- 4L80E build, things to be mindful of
- ??About 4l60e alto rev input drum saver kit ??
- 2005 Silverado 2wd 5.3 4l60 no 3rd
- 4l80e occasionally shudders on take off
- analog speedometer to vss 4l60e
- 4l60e input drum CARNAGE
- Water from radiator trans cooler has leaked into my freshly rebuilt trans
- 4L80e Direct Clutch Apply/Release Springs
- best reuild kit for 4l60e
- YANK Converter Help
- Early 4l60E vs Late 4l60E internal components.
- 4l80e planetary question
- Swap help
- 2-1 Downshift Clunk
- Does changing ATF fluid lead to slipping?
- 4l80E limp mode
- 4L60E no shift after rebuild
- 2005 4l60e in a 2002 Silverado..which year internal wiring harness?
- 4L60E 2-3 shift flare
- 4L60E $questions
- Pump filter seal area damage
- Gold washer for 2-4 servo
- Flexplate with Circle D Converter
- 4L80e worm track/oil passage
- 4L60E - What else to replace with a new converter and cooler.
- 4L80E Not Pumping Fluid
- 2-4 servo question
- 4L80 With No TCC Lockup
- 4l80e center support won’t seat correctly
- Estimated Power/Should I Upgrade?
- What transmission do I need
- pre-bent transmission lines for TH400 available?
- Transmission does nothing at all
- 4L60e TCC & AFL Separator Plate Hole Size
- Simple 4l60e / Sonnax Question I can't seem to find an answer to
- New way to KILL your 3-4 clutch pack ...thanks SON AXE
- 4l60e rebuild issue
- Does the "Case ID" matter when buying a replacement 4l60E case?
- Sonnax is FUNNY!
- Lubegard ATF additive might be legitment
- LQ4 with 4L60
- Forward clearance
- 4L60E question
- 4L65e 3-4 flare issue
- Wear on hub/sprag assembly
- Can I use Mercon V in a 4L60E?
- Band release hole
- What should I do with this 4L80E?
- Multi disk converters.. Trying to sort the functions.
- 60e Hd2 kit
- 3/4 clutch backing plate installation direction.
- 3-4 clearance
- Fresh rebuilt 4L80e Slips in forward and reverse
- Rebuilt 4l70e failed after week of driving
- Harsh 1-2 shift
- 2001 4l60e rebuild, 4th gear stops engaging after 20mins
- 4l80e center support sits too high
- Question
- 460le tcc cirquit
- Dont know if 41l60e from a 6cylinder 2003 trailblazer will fit in 1999 formula ls1 v8
- LS swapped 69 Firebird 4l60e issues
- funny load downshift
- Stock 4l80 Flexplate with Powerglide
- Ss3200 quick basic question
- 4l80e feels like its slipping
- 4l80
