PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 [136] 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. TH400 w/GV Overdrive
  2. question about VIG 3600
  3. shift kit recomendation
  4. rebuild4L60E or speed inc stage 2 or TH400??
  5. Trans Jerking After TC Install
  6. HELP! Vacuum Modulation Install
  7. Th350 is in & it works!
  8. Rattling shifter
  9. why not a 4l80e over a 4l60e
  10. Can someone explain to my why an unlocked converter dynos low?
  11. Pump rotor breakage
  12. A4 not shifting into 3rd
  13. Please explain Torque Mangement!
  14. T-56 - th350 crossmember pics.
  15. Best trans?
  16. Vig 3600 on the way
  17. What to ask and look for in a trans shop?
  18. help ASAP ..!!!
  19. Is the Vigi3200 right for my nitrous setup?
  20. what the hell
  21. Pictures of your th400 Shifters
  22. Vacuum Plate??
  23. Certified shop 4L60E
  24. Blowing through converter?
  25. Trans Cooler question
  26. Anyone ever broke a Rossler 4L60E?
  27. Tranny break in.....
  28. questions bout t56 to th400 swap.
  29. An A4 with a 3.73 is like what gear with an M6?
  30. How much are u guys payin for conv. install
  31. Turbo400 Swap, What To Do About Ses Codes?
  32. 3rd 4l80 now
  33. 4L60E Rear Seal Leak?
  34. Stall - Confusion
  35. 4l60e 4WD vs non 4wd 4l60e ,,,2002
  36. Torque Management?
  37. Drive vs D3?
  38. transmission angle question (TH400)
  39. Shift Kit
  40. Converter Questions
  41. Question on High stall (3000-3500) on Stock Heads/cam
  42. need help asap
  43. Aftermarket Tranny Mount??
  44. Freaky problem
  45. torque convertor?
  46. Oh my god.
  47. Will a 4L60E out of a 2002 4x4 Truck Bolt to a 1998 Tahoe 4x4
  48. torque converter?
  49. tranny mounts
  50. Where to buy Lokar trans dipstick?
  51. Not shifting into 2nd till 4-5Krpm?
  52. TCI tranny controller
  53. Going to ask the NEWBest ? ever
  54. Anybody run a coan convertor
  55. T-56 to TH400 swap weights inside
  56. tranny life question
  57. 4-L60e how much HP can it take?
  58. Yank SS3600 lockup behavior
  59. How much HP can a 4-L-60e handle?
  60. what is it worth? sy3500
  61. doing M6 to A4 swap ?
  62. Wierd Trans problem....screen shot inside
  63. Vaccum module unit from FLP
  64. Rev limiter...
  65. Th350 dipstick?
  66. Pics of m6 crossmember with plate for th350? Help
  67. tc downshift problem true?
  68. whats a fair price?
  69. which converter is for me?
  70. My A4 Broke at the track today :(
  71. TH400 brake??
  72. What kind of sound..
  73. 4l60E Owns
  74. 2nd gear starts
  75. 200-4r questions
  76. 4.3 V6 stall in a camaro
  77. A4 internals
  78. ?P0741 Torque Converter Clutch Circuit Performance or Stuck Off?
  79. TQ Management Question here
  80. Some advice PLEASE. A4 with plenty of cam questions.
  81. who has a speed inc transmission?
  82. would this stall work for me?
  83. 4L60 interchange
  84. Rear end drops down when put into D
  85. Hard shifting...
  86. Yank SS3200
  87. Need help with TH400???????????
  88. New stuff
  89. Where can I buy a powerglide?
  90. should i go to a powerglide?
  91. Trans problem? All trans expets inside please
  92. kickdown solenoid
  93. How often does a th350 low roller go bad?
  94. TCI th400 and speedometer sensor
  95. tranny is making wierd noises
  96. wheel Hop or ?
  97. vid. car on dyno..issues?
  98. I need a new transmission
  99. Need a Pick of a BMR F-Body Torque Arm Relocation mount
  100. 4l60e woes
  101. How to fix
  102. Tranny won't lock up and other problems???
  103. How much will the stall change with more hp?
  104. Can't keep flexplate from turning>>>
  105. Anyone here run their TH350/TH400 in drive?
  106. Tranny shops in Mid-Michigan
  107. How much $$ to install torque converter
  108. 4l60E transbrake
  109. To make your TH350 Speedo work...
  110. Need help choosing a converter for my TH400
  111. TCI tranny controller
  112. Turbo 400 for 1200fwhp
  113. Let's discuss STR...
  114. neutral safety switch,REV lights
  115. all around converter
  116. Towing a jet ski and long skinny trailer with Fbody
  117. 4L60E w/4600UY or TH400 w/4600&T-brake?
  118. vacume modulator?
  119. torque converter a bad idea????
  120. yank ss4000 on a T-rex sound ok?
  121. how hard to install?
  122. Shift Kit: Good or Bad Idea?
  123. T-rex guys inside!
  124. Can't keep tranny cool, please help!
  125. 224/224 581 lift 112 lsa & just stock converter???
  126. used SY3500 tc?
  127. Pro Built Automatics..
  128. stall
  129. 12 pin or 13 pin
  130. Which Stall To Buy!!
  131. How do u like your SS4000?
  132. Torque converter lock up temperature
  133. 3000 stall
  134. What kind of milage can i expect out of a converter?
  135. Neal Chance converters????
  136. synthetic or blend atf
  137. sppedo sensor
  138. 6l80
  139. 3500 stall converter?????
  140. rebuild question
  141. Vig 3800 stall for a stock engine????
  142. How long could a 4l60E with 510 RWHP NA last?
  143. Looking for a deep pan for my 4L60E - Recomendations?
  144. Anyone using this?
  145. Locking TC on Dyno
  146. Third gear sometimes leaves.
  147. shifter question
  148. th400 sprag
  149. Need help from a trans builder on 2-3 shift
  150. 4L60E Rebuild Questions?
  151. Which is the best converter on the highway
  152. 3000,3500??streetracing stall??
  153. who here runs a niel chance vert?
  154. 2-3 clunk
  155. Vigilante PI website
  156. does a 3600 vig act more like a 3800-4000?
  157. will 700r4 hold?
  158. Transmission slipping Bad... What's the deal?
  159. what model and where to get it?
  160. stall install price
  161. Info needed
  162. shifter reccomendations inside
  163. Swapping from 6 speed to TH350
  164. Cracked Flywheel
  165. cooler?
  166. Dowel pin in end of crank
  167. YANK'S new line of transmission crossmembers
  168. Moroso filtered trans cooler??
  169. 4l60e limp mode question
  170. Inspection shield for TH400
  171. Any ideas at all?????
  172. TH400 trans cooler recommendations - best one avail?
  173. Conflicting info: 3500 stall is to big for bolt-on daily driver?
  174. can someone help me? my gpa is dying.. please read
  175. Removing the Torque Converter prccedure?
  176. Time for a bigger converter?
  177. shifter question
  178. Newbie To Stall Converters
  179. Servo's
  180. Its been a min and a day, GM has done their thing with rebuilding only 1600!!!!
  181. vaccum modulated 4l60e
  182. Questions on A4 for street race, Please....
  183. whats a good 4K converter? please?
  184. trans service
  185. Yank Pricing
  186. Transmission locating dowels
  187. question on the converter I ordered
  188. Th350
  189. blew up 4l60
  190. transgo shift kits.
  191. 4L60E retrofit Fbody>>>Truck
  192. line pres. gauge & vac. mod. ?????
  193. converter
  194. 4L60E cant take the abuse!!!!!!
  195. converter
  196. Will an LS1 4L60e work with an LT1 - are they the same?
  197. Who built your 200R4.
  198. Just dropped pan on tranny, and have a few questions.
  199. Magic stick v.3 cam with stock converter?
  200. will a d/s from an m6 fit into an a4 car?
  201. 350 swap?
  202. vibration sf3000
  203. A4 Lockup question?
  204. Manual vs Auto
  205. Torq Converter Bolt Head Size
  206. Car jumps when i start the car!!!
  207. Power Shifting A Stock 4l60e
  208. Seeking some TC recommendations
  209. genral motors is doing something right, 60e is off the chain!!
  210. Tranny problems after converter install
  211. old school transmission question
  212. Servo questions
  213. Lockup switch on a 700r4
  214. My stock 04 GTO shifts much firmer than other GM autos..why?
  215. soon to rebuild my 4L60E, need a converter
  216. 4L60E & Code P1870
  217. My hats off to GM, very pleased with rebuilt 3yr 50k warranty? Unheard of!!!!
  218. Questions on the Vig Multi-disk
  219. To jaxosxon, Thanks for everything, u 2 dave at rock.
  220. broke 4l60e
  221. Help
  222. trans will not shift,stays in drive
  223. TH350/TH400 peeps, any regrets?
  224. Trans Lines?
  225. torque spects on trans pan??
  226. 4l60 doesnt like the new setup
  227. 3-2 downshift vs 2-3 up
  228. Need ur help choosing clutchs!
  229. TC ?- mayb if someone answers it this way
  230. Another "P0757 SSBS0" Problem
  231. Question about slippage
  232. What I learned swapping to a TH350
  233. TH350, TH400 and 200 Questions
  234. 4l60-4l65 swap
  235. What transmission do i have?
  236. Tranny help???
  237. A4; 4L60E or 4L80E
  238. Need Some Advice
  239. B&M Shift Plus??
  240. Rebuild or shift kit???
  241. driveshaft swapping?
  242. tci ssf3800
  243. Transmission is dieing?
  244. Midplate or solid mounts
  245. TH400 cooler question
  246. Converter problem?
  247. Anyone know the problem here??
  248. Ok, questions to simple to get a answer? Heres 1 that I dont think is simple....
  249. Is this a converter issue?
  250. 4L60E is killing me, and my tranny guy#$^#
