View Full Version : Automatic Transmission
- I want to put a 700r4 in my 99(5spd) silverado
- Big Stall 4000+ Plus guys i have a question
- Guys with 3500+ converters come in
- How much for a th400 swap?
- New converter Help
- installed 4L65E...got problems?
- 4l80e questions.........HELP
- TransGo Shiftkit for 99Z28
- which trany?
- Do i need a transgo with a tune.
- Redline ATF safe?
- Car show
- 4l60e surging question
- Help! 4L60E won't shift
- B&M Deep Pan and Transpak
- Odd question, but how much does a 4L60e weigh complete?
- Should I do a transgo shift kit with my ST3500?
- Ordered my Glide today...
- Cant get Trans out of car.....Wana get new converter in ASAP
- B&M Converter
- Put In Reverse--Hear A Little Noise
- obd1 high rpm issues...
- How to add VSS to th350?
- P/t F/t Tc
- TH400 and reverse lights/neutral saftey switch
- 4L80E wiring harness for factory computer.
- Need help deciding on converter.
- Will this slow me down
- Anyone have this problem?
- 4L60E tranny fluid
- 99 ls1 Car no longer has 2nd gear!!!
- got ls1 edit programmer installed today and still doesn't have 2nd downshift at wot
- HPP3 settings for A4
- I found an LS1 bellhousing on E-bay
- Two dumb 4l60e questions
- Only dropped .2 in 1/4
- Removing Torque convertor
- have a question about bringing my car to get a tune for my A4 trans
- where do i buy the a good converter for my th350
- Which Converter for my Set-up??
- Verter Choice - Please Confirm my Theory!
- Stall converter install, how much should it cost?
- Will I need to tune after my ST3500 Install?
- Help
- Manual Lock Install???
- YET another tc install question help please
- how much difference b/w the "big name" convertors and "lower priced" ones? TH-400
- 4L60E Problems
- Making a clicking noise when going from park/reverse or park/drive?????
- Help!!!
- TCI3200 Problems!!
- Just got a Camaro with a TC, hows it work?
- are these signs of a failing tranny or rearend?
- TCI 3500 is locking in 3rd or 4th gear and OD
- TH350 valvebody problem?
- Can someone explain why you need a lower stall for N20?
- Locking Torque Convertor
- th350 vs built 4l60E
- Trans-Go Kit Question
- Suggestions Please!
- Help with converter selection!!!
- TH350 detent/kickdown cable, does it control line pressure?
- TH400 Cooler Line Pressure?
- at the radiator, which line is which?
- going th400...have a few questions
- Tranny pops when downshifting
- How does a 3600 Midwest TC compare to a 2800 Yank?
- Will a Converter make my tranny stronger?
- whats the best transmission mount to use for my 00 LS1 camaro?
- Fyi
- 700R4 tranny
- 4l80e into a 72 Chevelle
- Converter questions from a newb
- TCI SSF converter ?
- "Is this normal" questions concerning tranny and stall
- Torque Converter TP4400 Slip speed... what affects slip speed?
- WTF wont my car Shift from 2nd to 3rd & 3rd to 4th at WOT
- Braided line trans cooler lines 4l60e
- i need help bad!
- 4L60E stuck in second :mad:
- torque converter for trex?
- Delayed shift question
- where to install tep sensor into trans???
- Anyone ever used a TCI powerglide?
- bolts for TCI converter?
- TC Lockup wire... which wire on the transmission?
- Cheetah SCS shifter - Do I need the A4 or M6 console?
- ST3500 vs ST3800
- Problem with my 4L60E
- Backing a blown LS6
- TH400 w/Gearvendors Overdrive..question...
- symptoms of a bad converter (stock)
- what good
- which tci converter will go well with my 373 gears
- Installation Cost TC.
- Shift Kit install help!!
- Can a bad verter kill ur traps?
- Car runs hotter now
- Who Has a Vigilante 3800
- what do you think my 1/4 times will be???
- BIG stall question...
- A4 shifting into 4th under full throttle.
- Ordered Vig 3200 today
- TC install help... too far from flywheel?
- Trans slipping after LS6 install???? Help..
- Need comments on Converters!
- 4l80e install?
- PT4000 installed, now code P0757
- Best stall for my 98 Trans Am
- Polyurethane tranny mount vibrations
- th400 to a 4l60e stall
- Tranny not shifting?
- 3200(vig) - 4.10s - A4?
- 4L60E-Which Clutch Set?
- 4L60E / 1-2 Shifting when Hot
- New intake.... Tranny problems?
- V6 tranny?
- possible problem
- Dacco Converters
- Teamtrip Q ........2k xcab
- converter
- A4 and ET Streets
- TransGo Help
- Yank SS or TCI SF
- i need some help
- What do I need to know about a Stall Install?
- 4l60e no od or d
- launchin with 4L60E question....and what is recommended to beefen up the tranny?
- Shifter knob
- Shifter for 4l80e????????
- just installed rock on 4l60e
- tranny won't work
- Tranny Temp Gauge
- TC Install/Swap Guide
- 323s to 342s
- harsh reverse engagement
- 200-4R and 700R4 transmission?
- Some questions about FLP's Stage 4 4L60E Tranny
- Trans Leak
- temp gauge?
- Why would transmission stay in 2nd when in 3rd?
- 4L60E or 4L80E?
- Tuner says bad converter??
- How much tranny fluid for 4L60E with a deep pan
- Please help me pick a stall converter!
- Converter stall question
- 04 silverado 5.3 4l60e
- tci ssf3500 or yank ss4000
- Clunking / Delay...
- Got a great deal on built tranny w/3k stall!
- What to replace 4l60E with???
- Converter confusion: higher STR or steeper gears?
- Looking for new Transmission
- 1-2 shift problem PLEASE HELP
- help choose a converter help!
- Serious Problems After Transgo Install
- Where can I find swap how to?
- Cost of Complete Turbo 400
- Which stall for 125/150 NX, SS4000e or PYE3600
- TCI SF 3000 and N20?
- Servo Q??
- 400 turbo ?
- tsp 231/237,a4,3.42
- Check out my trans cooler setup
- Which Transmission should I go with?
- What cam with 4000-4400 stall?
- Thanks To Dave At Rock On
- FLP 4L60E ROCKS-Thanks to CHUCK-
- Tranny Heat.
- Need help with tranny sell
- Shifts?
- shift question
- 4l60e rebuild
- need help removing tailshaft seal
- cooler line clip part #
- Tranny gone? Need help please!
- HD U-joints?
- 4L60E interchange
- 97 700r4 To 01 4l60e Conversion
- 4L60E Performance rebuild worth it?
- Trouble with 4L60E
- Truck pan w/ drain plug question
- How fast can you spin the 4L80e ??
- Yank TH 350,How much is it going to Cost me,and what Rpm will I have @ 70 mph?
- Question about using 4L65e in truck
- 4L80 question...
- What 60' times are people getting with a TCI SF3000
- 98 4l60E in a 2000 Ta
- Spaying stock and stalled...
- I think it's time for a rebuild
- Tranny problems please help!!
- Need help...
- Shift Solenoid Stuck On... HELP!
- what happens when you get short tailshaft th400?
- SHift Kit?
- Fresh 4L60E and Yank SS4000 verter Synthetic or not?
- truck tranny4l60e
- TCI SSF3500 Install Finished
- Vaccum Modulated 4L60E
- Any guesses on what my shift extension might be?
- Do i have a 3500 or not?
- Ut-oh did I blow my 4L60E tranny?Help
- Trans is slipping in 1st help!
- TCI 3000 vs. Yank SS3600
- Which stall for my application?
- how to hook up speedo???
- Rock on 4l60e
- Few questions about Th400 swap
- Help Tranny acting up
- A4 Flywheel Torque specs and use locktight or anti seize??
- Need to soften 4L60E 1-2 shift - has shift kit
- When you speak of tune.....
- Flp Stage 4 (4l60e)
- 4l60e Woes
- Could a trans blow out because of an engine prob.?
- daily driver question (GTP A4)
- New A4 owner and humming noise at idle
- torque management issues on my 98??!
- Converter install ?
- Converters - how many miles
- which tci to get???
- I think I have a problem
- Where can I buy a used 4l60e Valve body
- TH350 rebuild parts??
- Fact or fiction: Do Yank converters really come with 1 free restall?
- ls1 th 400 what yolk do i need?
- what mph does your a4 shift into 4th gear?
- Can someone tell me WTF this is?
- Diffrent Torque converter = more hp?
- Getting ready for the Glide
- do I need a tune w/ SSF3500, Trans Go, cooler
- Hey Yank ! "Thanks "
- 4L60E swap help
- Tranny Diagnosis..
- help choose a torque converter
- PY3400E Dyno
- Part number for stock tranny cooler lines??
- Tranny Question?
- Anyone have a Derale fan mounted trans cooler?
- TH400 coversion questions????
- trans cooler inlet/outlet lines same as 4l80E?
- Hard 1-2 shifts
- torque converter and dyno
- Question about 0verdrive and Drive....
- TC unlocks at 50mph?
- Good idea to dyno before chosing stall and gears?
- does anybody have a slow 2-1 gear shift?
- FLP level 4
- Flashing your converter!!
