View Full Version : Automatic Transmission
- Yank ST3100
- Torque Sequence
- 4l70 guts in a 4l60e
- Manual to auto
- would the below shifter wok on the 4l60e?
- Hard shift from park to drive/reverse
- The common p1870 code?? Need help noob with transmissions
- Car won't start after trans swap...
- shifts fine except when i mash the gas
- i lost lockup with converter swap?
- 4L60E power level
- stock 4l80e hp capacity?
- 4L60E 2nd gear seems like it is completely gone need help
- Need feedback on your 4l80e from one of our vendors
- 6.0 Conversion w/ 4l60e - Source for Core?
- intalling a torque converter/cooler/trans temp gauge
- recomend a performance 4l60e?
- 2-Step?
- Transmission temperature questions
- manual valve body on a 4l60e
- 4L60E to 6L80E
- Idling problem after converter install
- no 1-2 shift with 4l80e when manual shifting?
- Sponsors: Close 1-2 gear ratio 4l60e w/ 1:.70 OD?
- Auto shift problems
- when i put into revers the car dies on me
- Need Help
- 700R4 problem, please help!!
- Need help with hard shifting (new) transmission
- Fried 4l60e what to do
- Shift Kit on Stock Tune
- 4l60-E question
- converter difference between 9" an 10"
- best fitting th400 scattershield?
- did ETs improve from just trans swapp
- Fluid Starvation Issue? 4L80
- ss4000 chattering or something else making noise ?
- 94 4l60-e behind a sbc 350 in a 74chevelle
- Sputtering/stalling at high RPM with Brand new level 4 FLT trans
- Got a good one for you
- Is it possible to have trans fluid to cold?
- ford aod/4stb ???
- auto transmission problems
- weird problem...any suggestions?
- Fresh rebuild now what?
- help me decide...
- Tune for converter install?
- need help on a new transmission not shifting right
- Changing Trans fluid 700 miles after rebuild?
- 4l60 shift kit DIY install?
- Whats involved with swapping from a 6 speed to an automatic?
- Hipsters transbrake
- Transmission temperature gauge kits?
- 94 LT1 swap into 93 C1500
- turbo 350 and 94 lt1? will the convertor bolt up?
- 4L60E for 800 rwhp
- need help with manual valve body on a 4l60e
- ......Trans service 2000 Z28
- Does anyone have a pro stick in there car? tips on how to do a swap? Pics?
- Differences in 94 and 95 4L60Es?
- TCI deep trans pan
- A bad day....
- 2-3 shift issue
- th400/csr shield-help needed
- Second Gear Start question
- Knob question
- th400 type f , dex 3 , mix or what guys
- caint wait!
- trans questions
- Stall it while trans is out?
- Need new built-up valve body....blew tranny last night
- trans question...
- dipstick issue installing FAST 102 on LS1 with stock LS2 rails
- out seal leaking ...2000 Z28
- 700R4/4L60E 1-2 gear ratios
- So is this a normal thing to break?
- 4L60E shifting issues
- 1999 trans am (firebird) tranny help
- D and OD feel like Neutral in my 98 A4
- Install new flexplate along with aftermarket stall?
- What Shifter for th400 With a brake?
- LT1 stall converter help
- Got a b&m #70264 dope style with high stall? Comeon in...
- CANNOT get third bolt out on driver side! help
- Transgo HD2 kit-install while trans in car?
- Th400 to ls1
- Signs of a converter that unlocks/locks too early
- can i replace my 4l60e with a 4l80e
- Accelerating in 4th question
- 4l60e problems
- 95 camaro wont start all the time???
- 4l80 t-brake vb problems. Trinity?
- Circle D - Product Update
- Car shift aggressively from 1st to 2nd
- Should I Install The TransGo HD-2 Shift Kit?
- need help with selecting a torque converter
- '95 4L60E - problems in 1st gear only
- ebay tranny oil pan
- need help
- Manual valve body drivability
- What could cause soft shifts suddenly?
- tranny install and tune ?????
- need a new tranny to hold up to about 450hp at the crank
- difficulty to install converter?
- Is 3200 enough stall for my Z28?
- Stay auto?
- Where can I get 3/8" tube with GM trans cooler flare? (see picture)
- Sonnax Super Hold Servo(s) in a stock 4L60e?
- Running 4000 RPMs in 4th gear at 35MPH?
- Circle D 3B converter
- Newb 4l60e question
- th350, 700r4 or rebuild 4l60e myself?
- Just wanted to give circle d some props for a great converter!
- th350 operating temperture debate, need advice
- Disable Torque Management (automatic)
- 2.73 and ss3200 or ss3600
- Would a tranny blanket stop this?
- 79 Camaro... B&M Kit
- FLT level4 = to pb level2?
- question on th400
- need driveshaft advice
- 2009 silverado transmission help
- Tranny slipping??
- Too Much Line Pressure in 3rd?
- 370 with a tc78 What converter and rear gear? th400 and 9"
- YANK 3600 vs. 3200 Advice
- transbrake on 4l60e
- El Torro cam with low stall converter need advise
- Harlan 2 Step Question on Wiring = HELP!
- Thanks Chris @ Circle D
- Broken tranny for sale
- went in for a stall...got a call suggesting a rebuild haha
- th400 manual valve body with transbrake
- Torque converter info
- Anyone ever notice a noisy whine from your truck transmission when its cold?
- 4160e sluggish shifts
- 94 m6 to an a4 swap
- 4l60e oil cold
- Trans has hit 140k and is finally slipping...what to do next?
- TH350 No Reverse.
- no 3rd gear/"slipping" 2nd 4l60e issue
- Thinking about getting a 3200 circle D converter
- What Cooler Are You 4k Stall Guys Using To Keep Cool?
- 350 turbo cooler
- help please 4l60e
- car jerks forward when I start it
- Servicing a 4l60e??
- 94 Z28 A4 1-2 and 3-4 shift issues
- Anyone running some sort of ratchet shifter in their GTO??
- 4l60e questions
- 4l60 differences
- TH400 Swap From 4l60e
- Help!
- Novice 4L60E Rebuild
- Complete Auto NEWB . Racing with a auto ..
- Tc bolts
- 4L80E case wiring plug help..
- Torque converter unlocks at random?
- tran change 4l60 to350
- Torque converter noise?
- 4l60e ?
- lvl 2 or 3
- T56 swap to Automatic
- (Tranny issues), please help
- No second gear in my 4l60e
- 4l80e problems...... No pressure
- Can someone help identify this converter
- 95 4l60e
- Which Tranny 4L60/65 or 70 ?
- Transmission slippage after what seems like an electrical fault
- Only 2nd gear works.
- New Performabuilt Level 2 - Shudder in 3rd... any thoughts?
- (Tranny Issues)
- How To Make 6L90 Work With 02 LQ9?
- 4L60E interchange
- TC Question
- Mating 700R4 to a 5.3LS
- 4L60E, 4L80E questions.
- 4L80E questions
- Lokar dipstick ?
- t56 to th400 4c circle d stall
- Best Torque Converter
- FTI Converter sale for SEPT
- 6L80/90E vs 4L65/70E vs 4L80E Debate
- 4l60e park issue
- Automatic Transmission Mount Advise
- Transmission/driveline shudder at exactly 80mph
- Torque Converter Vibration
- Circle D Transmissions
- Thoughts on my trans cooler location
- 4L60E shift pressure
- Tranny sound. Is this normal?
- 94 formula loosing gears
- Temp gauge
- LQ4 New Edge Mustang, Which transmission??
- Dented Trannsmission Housing
- Converter won't lock and have code p1810
- TH350 Cracked Bellhousing
- *Revised as off 9/14* FLT Labor Day/September Special
- broken pump?
- Performabuilt
- Q about oil pan and dip stick
- A4 Shifting on normal driving?
- Need some help with stall converter and cam setup
- 95 4L60E Downshift Woes
- who knows there DIPSTICKs
- Ever wonder why a Stalled Auto will out run the M6
- m6 to th400
- TH350 Fitting question!
- Neutral saftey switch on 4l80 swap
- New stall - cooler install
- need help with feed hole sizes on a 4l60e with billet servos
- Aftermarket or GM automatic transmission dipstick tube?
- Fluid out the vent tube?
- tranny slipping in 4th..WTF
- wont hold gear past 4500 with shifter in 3
- 4l60e mannual vavle body
- Electrical Problem with 93 4L60E???
- Ideas on new trans for 99z
- Circle D converter. Sort of....
- 4l60e
- Help with stall on the juice.
- b&m shift kit
- TC stopped locking up,1870 code.
- 4L80e rebuild / upgrade prep, would love advice
- 700-R4 pices
- building my own tranny
- pressure drop
- Linkage
- why does dipstick say 80% on it
- 4l60e Shift kit???
- What filter Derale 4L60 pan?
- Help... Problems with 4l60e to 4l80e swap P0758 and P0753
- Converters And STR
- T-56 To Th400 Swap Article
- Really Need Some Advice...4L60E will not work after mutiple rebuilds
- Automatic Shifter Adapter!!!!!
- Swapping m6 to TH400, couple questions
- Low RPM In Reverse 3500 Stall
- Stall converter question
- 4l60 1-2 shift
- 4l80e question
- Is the 4L80E worth the extra weight?
- Wierd vibration while in Drive...
- tail piece part number?
- How long will my 4L60e last?
- A little Props to the Day family
- Slip Yoke Question for Th400
- need a auto w/od to hold around 650whp :/
