View Full Version : Automatic Transmission
- huge tranny leak
- Truck 4L60e, built by who?
- Do i need a shift kit with a new converter even though i have LT1 Edit
- Stall w/turbo
- Where to get a 4L80E?
- Tourqe Converter
- Lighter Flexplate
- changing stalls!!
- Question about Drivability..
- going to a 4l80e
- Would this work well together?
- Opinions of Yank's SS3400
- Shifting Question....
- problems with my fuddle possibly
- LS1 and LT1 4L60E tranny - how different?
- help quick? inside TH400 owners
- Tranny Coolant Lines
- HP tuners and the 4L60E
- how much power can a stock a4 trans take?
- Need help
- No second gear after normal driving.
- 4l60e
- Bellhousing bolt size on 5.3 block
- Transmission died
- Tranny won't shift out of 3rd gear
- flywheel weight ??'s
- Aftermarket shifter install's. post your pics
- Might be picking up a 98 Z28 w/ turbo and blown tranny...need tranny advice (A4)
- Converter for TH400?
- Help me Choose a TC
- convertor question
- Stall questions
- Choosing a Transmission --- Help
- Transmission Perform Button?
- Occasional hard shifting
- Need Spline Count/Size for 4L60E DS Slip Yoke
- What Stall??
- Trans Whine
- Tranny cooler
- 700r4 shift points
- 3rd and 4th gone
- Thinking of going back to electronic shift...
- Got my Fuddle in
- Tranny swap???
- Stall Setup?
- Paging 1jfuddle
- HELP PLEASE!! NO Second Gear
- stock gears and TC in a 94 T/A
- just bought my transgo s/k
- Trans fluid additives & flush
- those who are thinking of getting a fuddle converter
- The NEW YANK PE4400!!!!
- Will increased power and torque change stall points and shift extension upwards?
- NE1 using BMR TA Relocation with TH350 ?
- what do i need....
- I Need Help Bad
- tranny launching help
- Tranny Coolers
- A new one?
- LT1 vs. LS1 Torque converters
- what brand stall
- Whats the best trans cooler for a 05 GTO with a 3200 Vig
- What TC's to use for TH350 & LS1?
- BW high energy 3-4 sucks, one step backwards
- lock-up or no lock-uo for my 350??
- stall question
- ss3200 owners in here please!
- Disadvantages with a th400 over a 4L60E?
- Which aftermarket pan is everyone using
- stupid converter question
- help with a converter
- Built 4L60E vs. TH400?
- Emergency neutral with a RMVB?
- Is changing Transmision fluid an easy task ???
- trans wont shift
- transmission drip
- Clicking from TC.....NEED HELP ASAP
- 4l60e HELP
- new tranny and still 3rd gear vibration!
- stuck
- TC or Gears
- What too look for in pan?
- (hitting Rev Limiter) Need Help!!!!
- Need Tranny Help: Space between TC and flywheel: Need washers?????????
- Who all makes Flexplates for LS1 w/ TH350???
- How much hp can stock motor adn tranny handle
- 4l60 vs 4l60e?
- Problems.. need help
- Drivability of the SS3600
- Quick question about my cable modulated 700r4
- 2nd gear gone in my A4?
- How well would a yankss 4400 stall do on a stock ls1?
- Red warning light on dash after TC install
- C5 Torque converter install
- Will a Trans Go shift kit aleviate a p1870 code?
- trans temp gauge
- New to TC's...Lil Help!
- Torque converter won't lock up, Can I drive it?
- need some help....
- Got my New Yank SE4400 Today!
- What does sticking in 2nd gear mean?
- No 3rd or 4th gear
- Converter Condition
- 700R4 Help
- dipstick for th400?
- Is a tranny temp gauge needed after installing higher stall converter???
- No 2nd or 4th gear
- No 4th Gear
- Shifting
- What would cause...
- Gears on A4 thrown off
- Hardest launching method
- Getting ready to order.... Which company?
- TH400 Help
- why is my tranny whining?
- B&M cooler and fittings leaking
- its time to rebuild the ol' 4l60e
- 4L60-E Build Up
- 4l80e bolt right up to an LS1?
- Probuilt I have a question
- looking for a web site/guide to...
- turbo 400 ?
- Need a Transmission Shop
- Hayden trans cooler question?
- Another 4l60e problem
- 4l60 will not separate HELP!!!
- C5 automatic ?s
- Do you take the bellhousing off to pull the pump on a 4L60E?
- fuddle VS. TCI
- Torque converter lockup cycling
- Converter for a lighter car (~2500lbs)
- Do I really need a lock-up converter?
- Lockup coverter (multi plate) problems
- TCI Converter and 3-4 upgrades, now bad 2-3 flare
- Post your 60ft times and what stall
- Can i fit a th350 in a 01 Ls1 camaro and how?
- 4l80E build-up help
- Input Shaft/Housing Differences
- Want To Get Of Hold Of Trans King
- Red Lining ????
- converter not locking up
- how low a stall can i go?
- converter?
- Shift kit help
- Anybody know the stock converter specs?..
- Q:trans shop owners /builders
- What do I need to swap to TH400?
- Those with TCi deep pan
- Do I have automatic trans problems with a p1870 code??
- 98-00 vs. 01-02 Flexplate ?
- Th350 Tail
- need 4l60e rebuild help
- Car threw a p1870 Code.
- WTF would make a ticking sound from trans
- Installing converter without removing exhaust
- Transmission problems Help
- tcc locking pressure adjustable?
- LS1 Vs LT1 tranny
- Do you need to remove the VB to install the vac mod kit?
- Anyone consider adding a trans pressure gage?
- TCI Bolts, ARP bolts, and OEM bolts, WTF.
- Stock 4L60E vs FPL level5 4L65E
- Bellhousing/Torque Converter question.
- Vac Modulator with a Blower --By pass?
- I need serious help and fast
- What size stall should I put on my car
- SS4000 & 3.73 Results :( NEED SLICKS
- TransGo questions
- how fast were you running before you built your 4l60e?
- SS3800 Results
- who runs the fuddle with spray?
- stall?
- Vibration between 60-70mph
- which tranny cooler??
- tranny on the way out? been tuning
- SS 3200 good choice?
- 1997 Camaro SS Tranny Blew! HELP!!
- Which One?
- BMR TA Relocation Kit
- violent bang
- Lock Up Problem With Yank 4400 Stall
- Slipping at WOT?
- 4l70 ?
- 1-2 shift clunk from rear
- converter, trans, a sometime problem
- someone explain a TC to me
- Need advice for P0751 code
- Anyone have Yank SS3200 before and after dyno run numbers?
- fuddle 4000/2.5, anyone have this? what are ur 60 fts, i just ordered one
- Tranny slip
- 4L60E Housing Problems
- 4L60 builders who have installed a Vaccum modulator have a question for you
- spacer
- Flex plate conversion for LT1 converter
- How can you tell if your TC has gone bad/been damaged?
- Does a lower STR result in torque multiplication for a longer period of time?
- Before the transgo install?
- manual valve body on 4L60
- General 4L60E to TH350 question?
- Fuddle Stall
- To go vacuum modulation or not?!?!?
- Best Street/strip tranny?
- Shifter nob
- What convertor for bolt-on/spray
- tranny question
- Rebuilding My Tranny
- TH400 sometimes barely moves in reverse?
- 700R4 to 4L60E
- Passenger Sun Visor Fell Off
- I had to have overfilled this thing
- 4L80e Identification Quiz... Pics Included
- Almsot complete with TH350 conversion
- There here!! Yanks new converters
- Ok new delema.....my 4th 4L60E took a Dump.
- transmission install question
- My transmission isnt working right
- A4 problem wont lock up on dyno
- 4L60E tail housing
- Rear end
- Anyone heard of Mad Dog Transmissions in Tampa, Fl
- 4L80E guru's inside
- Yank's year end sale is here!!!
- kevlar band vs. "high energy" band?!?!
- torque management question
- my hatch button doesnt work after th350 swap?
- th350 12bolt no abs- i need the speedometer!
- Stall size for Daily Driver and to match a cam
- BMR TA Relocation vs. my jobber TA mount on TH350
- valve body problem?
- 95 z28 auto help!
- 6.0-Th350 flexplate spacer questions.
- TC Install Help: Can't get flex plate bolts off!
- Tailshaft info needed...
- Fuddle Update
- Tranny Temp Gauge ?
- how to install torque converter
- 4L80E converter w/dual element stator
- PT4000 vs SS4000 differance
- A4 tranny problems, wont shift!! help
- GM deep trans pan?
- Weird clunking noise's..
- Anyone use a line type trans cooler like...
- Stall info
- Pics of a th400/GV OD?
- Ram Adjustable Master
- Putting in a new tranny, anything I should know??
- Dextron III for me
- Question on Idle
- what stall to get (brand)
