View Full Version : Automatic Transmission
- Question on Idle
- what stall to get (brand)
- Need Help!!
- Public THANKS to Jxaxsxoxn!
- Flexplate question? Help please!
- TC Question
- advantage to keep TC locked up?
- Need a Built Trans
- 4L60E vacuum modulator do you need to adjust it?
- Grinding On Lockup
- just lost my 3rd built tranny
- Trans Temps reaching almost 210 degrees.
- Need clarification on Pro Ratchet wiring...HELP
- Speed Inc. MAx Evil
- trans pan
- Do I need to step up gears with 4000 stall?
- Can someone explain STR to me?
- TH400 Questions
- trans help w/a4
- P1860 TCC PWM solenoid Circiut Electrical
- trans wont stay in drive?
- Gear Vendors OD vs. 4L80E Transbrake?
- 4L60E problem
- Rossler TH400 cost?
- SS4000E first impressions!
- TH400 shift delay? whats up with that?
- need a lil help
- Hydra-Matic 6L80 in a 4th gen TA
- Install?
- Two very noob questions
- trex plus 4k stall with a 2.2 str enough?
- anyone running flp stage 4 tranny?
- TCI SSF 3500 Clutch Material?
- Tranny needs rebuilt?
- 400+rwhp/stock tranny?
- when did the transmission change?
- 3200 vig or ss4000 best converter for this set up
- help! TH 400 problem
- Passing gear doesn't work..
- switching from m6 to auto. th350 or th400?
- TC installed=results
- rebuilding a4 need aftermarket hardened and racing parts...please help
- wont move in in drive
- Weird Vibration
- how to check transmission fluid?
- 80-e swap woes...could this be tranny-related
- Shifting Blues
- Anyone Running a TCS Converter?
- passing gear....
- Tilting the 4L60E to remove servo
- Tranny Cooler and Lines...
- Fuddle or TCI whats the difference?
- Preformance transmission button
- Paging John @ Fuddle!
- Should I change my tranny fluid?
- A4 Problems...HELP PLEASE
- 02 xtreme blazer w/cheatr cam
- any body real good with automatics
- Wiring for th400, reverse lights and trunk dont work.
- Converter Install Questions - PLEASE HELP
- Drilling holes in stock flexplate for 6 bolt TC?
- TH350 Speedo Cable...will it leak?
- Wiring N/R on Pro Ratchet, need help.
- TC Guys post 'em if you got 'em...
- what's faster 1/4 mile th400 or t56?
- 14.004 Wtf???
- Converter Install...
- Any differences between truck 4l60e and camaro version?
- Shift kit or change lone pressure?
- derale pan same height as stock ?
- Quik Question
- Weird Lock Up!
- Converter coming loose, mess with my tranny gasket?
- M6 Versus A4
- Yank SS4000E w/ 3.23 gears driveability?
- Where to get a Trans Xmember for TH350 conversion?
- Wich Torque arm question???
- will I have any regrets?
- What Tranny fluid should I use?
- Heres a dumb question
- Its back PO757 code......
- Clunk on floor on take off
- New to autos, need stall help....
- HELLOO trans&rear Mods vs timeslips ?
- 2.73 gear, and high stall shiftpoints
- When a converter locks and unlocks?
- new ss4000 results.
- OK, tranny gurus...explain this:
- Big Problem
- Tranny issues!
- C5 tranny doesnt want to shift... wtf??
- why does 2nd gear band suck
- buying a used tranny
- where do i get a SFI approved flexplate?
- How much should a 4L60E rebuild cost me?
- A4 rebuild questions
- YANK wants to hear from you!
- trans actin up
- FLP l465e versus l460e
- gear question
- A4 shifting question?
- Th400 and stall/gear question...
- tranny code, wtf
- 4L60E Recalibration after Gear Swap??
- 2006 corvette 6-speed auto
- Trans cooler question
- TCI SSF Question
- what auto to buy?
- trans line thread size
- whats the difference
- M6 swap to th350? Info requested?
- lockup speed
- How much HP have you lost with a stall?
- So I plan on getting a converter.....
- looking for good stall
- what the best shifter
- ctp trans?
- WTF??? Torque converter lock up problem
- v6 automatic?
- Anybody use a B&M converter lock-up control?
- FLP 4 problems!
- won't shift into 3rd gear at wot or
- FLP Stage IV...Post up your reviews!
- 8-speed 4l60e??
- NE1 want to decipher a TCC HPT Log?
- 12 bolt rear end
- Anyone ever have a converter bolt fall out??
- new guy few questions,pt4000 yank ?
- Prothane mount installed, not as bad as I thought
- anyone w/ info please help
- What all needed to go th350
- new best stock motor fuddle 4K!!!
- Where to place tranny temp sensor in TH400?
- Clutches locking up in my A4 ... 4l60e ????
- torque converters catalog
- Buyilt 4L60E acting weird! Need help fast!
- Tc
- Need help tranmission just blew
- Fuddle 3400/2.1 str track results
- Skip Shift ?
- 2nd gear limp mode
- Tranny Pump
- Midwest 4200 stall! Good for street/strip?
- Slushbox pissed me off tonight
- B&M Synthetic Trick Shift
- Has my shifter cable gone bad?
- Were Can I find/Purchase A Transmission Rebuid kit AT
- trans rebuild...... new tq converter
- trans rebuilds
- Different types of 4L60e transmissions???
- what kind of stall to use?
- What's a good stall to go with...
- Picture of my B&M Hammer Shifter in M6 console.
- Yank SS3200 or Yank PY3400 stall??
- Need a 1LE trans mount
- Readlined!!!!!!!!!
- another shifter Q
- Front pump seal and bushing
- Vibrations
- M6 to A4 swap?
- Restall a Vig3200?
- Lock-up or non lock-up that is the ?
- different gears in my A4?
- need help asap
- Safe to drive in this condition?
- 4l65e ????
- Converter question?
- 4l60e,th350,700R4??
- Does a new torque converter need an easy break-in period?
- Fuddle rocks!
- Will I need a shift kit and tuning after installing a 3400/2.1 stall???
- 4l60e doesnt like to go in reverse
- Broke in my Fuddle 3800 :D
- Stupid question TransGo kit
- 4L60E weakness ?????
- Switching M6 to A3
- my 2002 Z-28 Transmission!!
- Couldn't get my car in gear this morning
- Stall converter before nitrous
- Difference between 98 and 99 wiring?
- Looking for tranny Cooler for 1000 RWHP
- How many have broken a flexplate on a LS1 F-body?
- 4l60e
- shift kit
- Tranny cooler fits were?
- Recommended stall speed for my mods?
- going to th400, what flexplate do i need?
- TH350 and TH400 differences
- shifter problem
- ShiftKit Problem???
- 2800 Stall?
- Were to get 1/2 barb hose fittings for trans cooler?
- TH400 question, shifting from reverse to first kicks HARD!
- transmission bolts
- TC locking unlocking ramdomly.
- 4.3 Torque Conveter
- adapter plate for powerglide?
- my th400 swap
- Help with ShiftKit
- sending unit
- speedo question for 4l60e in 71 chevy truck
- HEEYY Manually Shifting an A4 ?
- 4l60e output shaft
- HELP Won't shift 2-3 at WOT
- Not happy with Shilf Kit!
- 1998 4l60e vs 1999-2002 4l60e
- auto shifting manually
- TRANSMISSION PERFORM button!!!!
- shifter question...
- Pump Removal
- th350 lokar dip stick
- Very strange trans problem,HELP!!!!!
- Driveshaft for Th-400
- Trans mount options...
- Is a 4000 TC w/ 4.10s,
- newbie ? on converter
- PPM on a TH400
- Is a 3400/2.1 stall too much for a stock 98 Z28 to handle?
- Which Stall To Go With??
- having some 4l60e issues?????
- differences
- noob to torque converters
- 4l60e
- Need Some Help?????
- Flex Plate for 1000 RWHP
- 4L60e sun gear shell and sprag failures???
- If the converter wasn't installed all the way what would happen
- What would happen if type-f fluid was used.
- converting t-56 to built a4 460Le
- Custom TCI verter
- 60ft times with tci 3500 and vig 3600 (post yours)
- B&M Hard Lined , now Tranny Temps Hot (SEE INSIDE!)
- Will the trans hold up on spray?
- TCC Ramp Exceed
- Do you hate your automatic?
- -Fuddle's Fall Clearing-
- Yank Converter - Should I Replace It?
- How did converter install go when you installed it OR how much did you pay a shop?
- A4 reverse sliping...
- 4L60E Interceptor - crap or good product?
- Higher RMP in 4th
- got car back and 1st test ride!!
- anyone run this
- will transfer case bolt up
- The M6 to TH350 swap is done!!
- *Problem* Not sure which forum to use.. ill start here (5-6k rpm fast rev)
- Pump questions?
- Fuddle converter is in
- Torque Converter/Gears for a mild 383 street driven Vette?
- shakeing?
