PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. 4l80e internal harness
  2. Dana Probuilt
  3. Stall converters
  4. 4L60E - M30 shift pattern
  5. 4l80e power ?s
  6. Th350 end of truck cutoff
  7. 80e rebuilders, do you want or need this stuff...
  8. 4l60e slip yoke barrel diameter
  9. Best Flexplate
  10. 4l60e falling in amd out of 3rd gear
  11. 4l60e pump torrington?
  12. lockup problem
  13. 200 4R with out lock up converter gurus come in
  14. What should I do? 4l80e swap wires 60e or 80e segment
  15. 4l80e Fixed Yoke
  16. building a 4l60e or get new tranny?????? HELP
  17. M6 to Th400 swap (already checked sticky)
  18. Th400 factory deep pan depth
  19. Live assembly of black edition
  20. weight stock torque converter ?
  21. Performabuilt black edition specs
  22. Help me diagnose my 4L60E overheating issue
  23. Need help powerglide to LS?????
  24. im about to fix code p1870 1-2 hard shifts . I need some advice!
  25. Converter hits flexplate bolts
  26. At last....
  27. 4L60E question from a first timer
  28. Purchasers of FTI 3200 street brawler enter.
  29. threadlock
  30. Which Trans. 4 '50 Truck
  31. Swap Trans issues
  32. TCI Converter Tightness
  33. Question about Circle-D higher stall and towing.
  34. poly torque arm bushing
  35. 98 A4 4l60e no 4th or tcc lockup
  36. Mad man dipstick
  37. lockup and racing?
  38. Bought 3200ls FTI stall for a bolt on car, what should I expect?
  39. Doing a live assembly of corvette 4l60e
  40. Has anyone swapped a yank for an FTI?
  41. 2000 4l60 Luggs in lockup.
  42. installing yank ss4000 what would you replace while trans is apart?
  43. Help me pick a converter for my cammed 94 LT1!
  44. Ordered a LS 4L80E Trans what would you expect to get?
  45. dipstick bolt
  46. Th350 bop adapter
  47. Tci Th400 transbrake help
  48. Link inside, will this stall fit my 2000 SS?
  49. 4l60e
  50. 4l80e leak front seal?
  51. Parts for rebuilding a 4l60E
  52. th400 swap questions
  53. Who to spec a converter
  54. Converter identification help
  55. 4L60E Boost Valve replacing on 2007 GMC
  56. 1998 Camaro SS Transmission Issue: Help!
  57. convertor stall?
  58. Th400 snap rings
  59. 4L80 shift issue
  60. What would have caused this?
  61. v6 converter with 4l70e trans
  62. 1998 firebird slow to shift
  63. GMPP TPS and VSS signals from ECM Bulkhead connector
  64. Stall help!
  65. F250 trans cooler in Fbody
  66. 4l60e 4th gear problem
  67. No 1st gear from a dig
  68. TH400 lost reverse but backs up when engaging transbrake in neutral.
  69. Help 4L60E issues. 3-4 gears
  70. High performance atf
  71. 4l65E - have an overflow?
  72. 4l60e question
  73. T56 to TH400 swap help!
  74. 6L80E into a 4th gen swaps
  75. 4L60E "Shift Kit" Advice Needed
  76. 4L80E fluid leak
  77. 4l60e to a 4l80e swap in a Silverado?
  78. fbody th 400 ford8.8 driveshaft question
  79. best rebuild kit for 4l60e 550hp
  80. Help!
  81. 4l80e shift kit
  82. 4L60E fluid out the top vent!
  83. Silly question but I have to ask
  84. 4l80 dipstick
  85. Built transmissions
  86. 2016 Camaro 8L90E Converter install
  87. 94 4l60 to 5.3 help
  88. Point me to the correct rebuild kit
  89. 4l80e silenoid problem
  90. 2 step turbo question
  91. 4l60e stock possible issues
  92. Trying to ID Torque Converter
  93. Absolutely Stump'd
  94. New guy, 1st post, 4l80e, pics
  95. Hughes Adapter with TH350 issues
  96. 4L60E Help
  97. Trans Cooler options. JEGS 60345 or B&M 70274
  98. 4l80E late MLP with early harness?
  99. Converter rated by HP not Stall
  100. 98 Trans Am/Firebird A4 Not Downshifting?
  101. 4L-Sh!t
  102. 4L60e weirdness
  103. For those doing their first transmission...don't do this.
  104. Is the Park Prawl controlled hydraulically or mechanically
  105. Th400 direct drum Transbrake Springs = bent retainer??
  106. Is this a 2-3 shift valve?
  107. Th400
  108. 2000 4l60 no lockup in 3rd?
  109. 4l80e swap help
  110. Rebuilt 4L80E 2nd and R only. Think it's the vehicle wiring
  111. Transbrake w/ stock ecm
  112. Th400 and trans shield questions on 4th gen
  113. Th400 forward drum inner seal
  114. Reman 4L60E Leaking
  115. Safe fluid level for 4L80E dry start up
  116. Convert 4wd 4l65e into 2wd for swap
  117. 4L70E: adding stall and corvette servo. Need anything else?
  118. 4l60 Solenoid Kit Master
  119. 4L60E no part throttle power - sluggish
  120. Need help with 4l60E 2002 LT1 4.3, to 2002 LS1 4.3
  121. 4l80E with transbrake Opinions
  122. Powerglide SFI case options
  123. 4l60e lost 3rd but 4th still works
  124. 98 chevy 4l60e transmision
  125. 4l60e question
  126. TCI Outlaw Shifters
  127. 4l60e 1st and reverse only
  128. '04 GTO 4L60e to '99 F-Body Neutral Safety Switch Questions
  129. Jakes D3 Brake power issue
  130. Who is going to be my best bet on specing a converter for my 4.8 Turbo/ Glide combo?
  131. Grooved th400 rear drum.
  132. 4l80 Dipstick
  133. Converter guru's
  134. Torque converter not locking up.
  135. Powerglide front pump, input shaft
  136. shifter cable question
  137. 4l80e
  138. Built 4L60E Fluid Question
  139. Turbo guys with unrestricted Th400 converter feed.
  140. What yoke for this 4l80e shaft
  141. Rebuild kit 4l60E
  142. My 4L60e to Th400 swap
  143. 4L60E > 4L70E swap
  144. Which 4l60e
  145. Monster Transmission
  146. 4l80e issue. need help
  147. Choosing the right 4l80e
  148. Controlling newer 4L80 with PCM
  149. Interchangable Transmissions
  150. Th400 build thread.
  151. Th400 Factory drum @ 800rwhp??
  152. 4l80e intermittent grinding reverse + more hd2
  153. LS1 or 6.0 compatible with 02 4.l60e in truck?
  154. Close ratio 700r4 w/ TH350 first gear...?
  155. high mile 4l60e problems
  156. Questions on Converter Clearance with 6L80
  157. PRNDL delete?
  158. 4L60e From '04 GTO Into '99 T/A Questions
  159. 6L80e, rough/delayed downshifts
  160. ls1 trans to 5.3 motor
  161. Vacuum Mod - 4l80e - Check valve
  162. In desperate need of a madman 4l80e dipstick!!!
  163. Swap a 4L80E into 98-02 F-Body w/4L60E....does it make it slower OR faster???
  164. What does "TCC D2D3D4 Off" and "TCC Cold Off" mean exactly?
  165. F body trans cooler mounting.
  166. Selling a 4l80e advice
  167. 4l65e vigilante 3600 stall price to flush n cut open.
  168. Champion Engines and trans Pros and Cons
  169. 4l60e Gear change - Builders and drag racers
  170. Ok lets play another what broke in my transmission
  171. 4L60 (no E) 13 Vane Pump Rotor in a 10 Vane Housing
  172. driveshaft length questions
  173. 4l60e input shaft and torque converter options
  174. Need opinions on stall deal that i find!!!
  175. Ls3 and 4l60
  176. Joenova 4l80e controller question
  177. Trans cooler
  178. Girlfriends car questions
  179. Silverado SS and Escalade transfer case the same?
  180. Derale with fan dope style
  181. Boost and Th400 Modulator valve
  182. 4l60e only first gear
  183. For no prep racing powerglide or 4l80e
  184. 4L80E wear / past rebuild?
  185. easiest/most cost effective way to mate a 6l80e to a NP205?
  186. Rebuilding a Th400 (I've already searched)
  187. 4l60E not shifting into 3-4
  188. 1500 hp 6L80E?
  189. Read the sticky still confused on lq4
  190. 4x4 to 2wd speed sensor 2005 4l60e
  191. Transmission oil types by years
  192. Silverado 4L80e and transfer case swap problem
  193. Live Facebook video of a level 3 build starting at about 1 pm eastern time
  194. Installing a B&M Pro Stick. Any advice?
  195. TCU TPS Signal with DBW
  196. 4L60E Sonnax AFL valve with TransGo springs?
  197. Auto transmission questions
  198. 4kstall
  199. Ly6 flex plate for 4L80e
  200. Th400 no reverse please help
  201. Noise when engaging into gear
  202. 80E dipstick tube
  203. High Stall Daily Drivers, Pop In For A Sec
  204. 4l80e updated harness
  205. 4l80e Swap frame cutting question
  206. Yet another 4l80e rebuild question
  207. 97 c1500 ls1 swapped
  208. question ( may be a stupid one )
  209. 3200 to 4000rpm Stall question ???
  210. late 4gen fbird 4l60e problem in D
  211. Anyone have any more information about the new 4l75e?
  212. Fresh build on 4l80e, no manual first gear
  213. 1500HP Flexplate options...
  214. POS 2004r is now making noise.
  215. 4L80E input shaft interchange, '92 into '06?
  216. yank ss 3200
  217. 4l80e rebuild and upgrade
  218. Torque converter too tight against flexplate
  219. Converter size in Stock 05 Z71
  220. 1994 4L60E Input shaft spline count vs. everything after....
  221. I can't install converter myself... Average install cost?
  222. Hose heat shielding question
  223. 4L80e no reverse sometimes
  224. 4l60e problems
  225. Purchase a Performabuilt tranny(4L60) or rebuild locally?
  226. 4l60 slight slippage after converter
  227. 4l60e basic upgrade in vehicle
  228. m6 to th4000
  229. 700R4 and LS truck intake
  230. 6l90e swap. What all is involved? New to this world and can use any and all help
  231. 02 S10 ZR2 4L60E 4-3 downshift issue
  232. will Spohn solid motor mounts work with 4l80 conversion on my 4th gen?
  233. Wiring a 4l60e
  234. TH350 launching in 2nd?
  235. Lq4 4l60e questions
  236. 80E parking brake yoke removal
  237. Trans/converter issue?
  238. 4l70e no second gear on fresh trans
  239. Possible issue with 4L80E
  240. New 4L60E scanner reads 4th in manual 3rd
  241. Which transmission shift lever for my 4l85
  242. 4l60e swap
  243. TCI 6x 6speed Auto in a 4th Gen LS1 F-Body?
  244. Updated - 4l60e Tuning w/3600 stall Yank - Sprag Damage
  245. 4l80e with drum brake
  246. need some input on ratchet shifter option? 4l80e, hammer shifter works?
  247. Manual to Auto swap 70 GTO
  248. t42 pigtail/plug
  249. No speedo
  250. Performabuilt Holiday Giveaway !
