View Full Version : Automatic Transmission
- GPZ105 clutch thickness variation problem?
- Final Racing Season
- GM246 Transfer case upgraydd
- 4l80e Torque Management
- GM Transmissions Thru The Years
- 4 X 4 to 2 WD 4L60e
- 4L70E low mile rebuild 3-4 slipping issues
- Transmission ID help
- Trans Cooler
- 4L60E Fam. Alternative HE Frictions
- 700R4 no shift causes
- Rattling sound during coasting to a stop
- 700R4 rear shaft play
- Sonnax overrun area re-inforcement collar sleeve? ?
- 4L80E trans banjo fittings
- brand new 6L90E revving instead of going
- 4L80E flush techniques.....
- C5 4L60E Dimensions
- 4L80e Yoke Question
- 4l80e Not Move in reverse and drive
- 4L60 700R4 camaro Z28 1993 question
- Sonnax 746786L-HD output shaft.
- 4l60e woes
- 4l60 with two pink colored TCC pwm solenoids?
- 4l80e moroso deep pan
- 4l80e swap on Silverado
- 4l60e no 1st and 2nd after band replacement.
- Lost all forward gears. Gained them back after cooling down. Pan is clean’ish
- Having issues with my transmission after having my engine replaced
- 700r4 woes
- 4l60e Tow Haul Isn't Working, please help
- 4L60 builder in ATL? Procharged 2002 ram air
- Need help 4l60e Trans
- Problem New Circle D 3,200 and new Performabuilt stage 2 4l60e
- 6l80e guide?
- Crappy Shifting 4l60e Resolved- *Ehh sort of*
- 4l60e missing 3rd and od
- 4l60e problems and questions
- Torque converter stripped
- Looking for 4l80e builders
- 4l80e tranny torque converter unlocks after 5 seconds
- Shift Feel & ATF Fluid
- 4L60E Billet Transbrake is finally available
- 4l60e input drum cracks or porous?
- 4l60e Rubber Return Line Size
- TH350 Kickdown Cable for 5.3L
- 4L60e Loss of 4th gear and engine braking
- 4L60 pump bushing too small?
- 4l60e or 4l80e?
- 4L60e 2-3 flare
- bushing on the center support
- P1810 Code Hard to Find the Problem
- Whats the symptom of a bad tail house bushing....4L80E.."""NOT THE BUSHING"""
- Is this a crazy idea to cool the 4L60E transmission?
- Possible toasted 3/4 clutch pack, but drives in limp mode.
- 4l60e 2-3 flare..
- TH400 and transbrake question
- 4L60E EPC Solenoid Year Interchange?
- P1870 present with "Transgo Fix"
- Flexplate Help
- 4L80E issue, stuck in limp possible faulty TFT.
- 5.7 to 4l60
- 1994 4l60e Problem
- 05 k2500 4l80 stall shift kit help
- PCM swap & transmission failure
- 4L60 won’t shift out of first !
- 4L60E Stuck - Strange Behavior
- using hydraulic oil as ATF ???
- Th400
- 4L60E slams into drive when cold
- 4l60e TCC vs TCC PWM
- Torque Converter or Something Else?
- Forgot 4l60e plastic thrust washer pump to stator
- Morning carnage TCC clutch delamination
- Ls1 to th350 issue
- 4l60e rough 1-2 shift
- 4L80E Diagnosis: DTC P1810
- Lm7 & 4l60E swap trans issues
- 4L60E TC unlock issue
- 4L60E Trans-Brake or not
- 1994 S10 Blazer Code 83
- 4L70E no TCC lockup
- '94 Camaro trans problem
- 4L80E....multiple codes.....after 4 years of perfect operation....PROBLEM SOLVED>>>>>
- Servos and other mysteries
- 2-3 shift 4l60e
- 4L65e problem
- NEW sonnax 4l60e/700r4 input shafts!!
- 700r4 Tips and Tricks Master Thread
- 2002 Tahoe Downshift Issue / Cruise Intermittently Inop
- Hurst quarter stick cable
- 24x and 4l60e
- Another th400 thread
- 4L80E - Better shifting rigging to use instead of the factory 4L60 stuff...???
- 4l80 swap
- valve body castings
- TH400 Manual VB
- 4l80 won’t move
- Torque converter recommendations
- TransBrake - use question...
- Input Shaft Options
- 4L80 shift question
- 1996 Tahoe 4L60 to 2006 5.3 engine, flywheel kit?
- Yank guys
- 1999 obs tahoe with gen 4 5.3
- 6L80E Stuck in 2nd gear until I clear CEL Codes. Stays in 2nd again when I stop
- 4L80E parts for tight swaps including connector relocation
- remote tuning 6L90E only?
- 4L60 speed sensor wiring?
- 4l80 no line pressure most of the time please help
- Need help with rebuiding or not my Jake's Stage 2 4l80e
- 2nd Gear Launch
- 4L80E - P0753 - Shift Solenoid A Electrical (SES, Pending,Current,History)...........
- Can I control my 4l70e with paddle shifters?
- Torque converter vibrations?
- 3-4 apply plate warping
- 6R80 Locking Up When Shifting to 4th After Rebuild
- Ls with powerglide kickdown cable
- WHo can guess what I did wrong?!?!?!
- Sonnax Front planet set
- AFL valve 4l80e question.
- 6l80e builders in here?
- 4l60e wont shift unless letting off the gas
- ATF- Over full vs Under full AUTO TRANSMISSIONS IN GENERAL
- 700R4 TCC Lockup Question
- Ultimate 6l80
- How to build 4l80e for high torque engine
- Hello I'm a new member seeking help
- Low line pressure 2-3-4
- I need a 60e rebuilt - vetting builders have a few questions
- MSD TCM Help!
- HELP Won't shift to 2nd unless off the gas
- Absolute minimum level of tools needed to rebuild a 4l60e 4l65e 4l70e
- Tc i6 Trailblazer use in 98 camaro
- 4l80e cooler size
- Help needed with Jake's Stage 3 kit
- 4L60 Build Sheet: Thoughts?
- 4L80E in '96 K2500: Rebuild Advice Needed
- 4L80 No gears
- 4l80e Aluminum Direct Drum
- Torque converter
- TH400 swap question
- Any reason to be concerned about alignment with an Automatic?
- T42 Plug
- 4l60 to 4l80 question
- 2000 gmc Sierra 1500 with 4l60e transmission lost all gears
- 4L60 4WD Transfer case swap vs Speed Sensors
- 408 with tall crank flange
- Lowers torque converter stall
- 4L65e fluid capacity
- 4l60e “fresh rebuild” stays in 3rd when in drive
- 4l80e Pump gear wear
- 4l60e dropped into neutral from 2nd fresh rebuild
- T56 or th400
- 4L60E Shift solenoid clip
- 4l80e locks up when commanding 3rd or 4th.
- 4l80E intermediate 5 clutch stack with BTE drum
- 5.3L 4l60E to 6l80E transmission swap
- Tips, Tricks, Mods for the 4L60E OPEN FOR INPUT AND DISCUSSION BY EVERYONE.
- Pump tolerance 4l60
- Wide Mouth Filter 6L80
- Dreaded 4L75e (60 & 70 as well hard 1-2 shift when warm
- P1810 Error code
- Need a reman transmission, recommendations please!
- 4l60e delayed 2-3 shift
- 4l80 output shaft
- 4L80 to 6L80 swap
- 4L60E Stator support shaft bolt size
- 4l60e complete upgrade discussion
- Would there be any reason.....
- 4l80e & 4l85e - information archive
- Dexron VI Syn, is it safe to use in 2001 4L60E?
- Converter to tranny fit?
- 04 Chevy Tahoe
- 4L60E Filter clearance from bottom of pan
- Teeth gone from 3-4 Clutches, pack smoked in 4l65e
- What to do to make converter feel tighter
- 1000+ HP 4L60E Build Notes from a Broken Mind
- What washer for 4l60E input housing
- 4l60e Does not hold the gear
- AT 6L80 deeper pan
- Flywheel for 6.0
- 4l60E Build for a 67 Camaro
- HELP! 4L60E Won't shift into second when WOT.
- Helpful automatic transmission information for GM
- Beware Of Cheap Knockoffs
- Transgo 7cs question
- 4L60E output shafts and their capacities
- Case Damage
- Don't know what torque converter to go with
- LSA/6L80E Clattering noise
- Replacing 3/4 clutch pack question
- D123 trans brake
- fresh rebuilt 4l60e wont shift to third
- 96 4L80e keeps blowing out front seals
- torque converter choice
- line pressure measurement on 99c5
- 4L60E Third Gear Only (no second, no codes)
- 4L60e NigHtMaRe OOOOOoooow!!!!!! MuaHahahaha
- broke my new to me th400?
- Anyone ever used the trango tcc 4l80e kit
- Band lining separation
- Recommended converter
- High torque DCT Transaxle - Mid Engine Race Car Project
- Franks custom trans 4l60e build sheets and prices
- Transbrake solenoid issues
- 2002 4l80e no reverse
- 4l60e longevity tips
- Only stays in 4th when MAF is unplugged...
- overrun clutch (4l60e)
- 4l80e not shifting gears
- Lil advice.
- 4L60E Moves forward on neutral
- 4L80e Slip / Pressure Questions
- 4l60E transmission
- 1993 4l80e swap on 03-06 5.3
- 4L60E - Newbie questions
- pcs set screw (4l60e/1999)
- How to reduce 4L60E line pressure in Reverse
- 4l80e new build slipping in d4 and reverse HELP
- transmission frustration
- Bellhousing match up
- 4l60e delayed engagment into 1st gear upon quick stop. After fluid change, runs ok...
- 4L60e Issue
- 4L80e over heated
- 4l80e binding / dragging in 2nd.
- 4l80e reverse band/pin length
- 4l80e 2nd Gear slipping
- 4l60e binding reverse
- 99-06 4L60e V6 vs V8 differences
- Help request! 4L60E Manual valve linkage lenght?
- 4l70e output shaft
- Sometimes even I can't believe what problems I make for myself
- Anyone used Zero gravity Performance for a 6l80 or 90?
- 4L60E has no 4th gear after upgrades
- TCC takes me from OD to 3rd
- Th350c
- 4l60 auto trans
- 4L60E Leak question
- Help!!!!!
- 4l60e runs perfect until coasts down slight hill
- 4l60e stuck in 3rd
- 6L80 shift problem
- 1994-1995 4L60e to 2000-2006 5.3, what trans mods needed?
- 4L80E TCC Apply Not Commanded
- 2009 up 4l60 to 4l80 Repin?
- 4l65 issue
- How much rotational slop in 4L60E
- LH6 -> LM7 in Beater '06 Envoy Denali
- 98z714l60e problem
