PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 [93] 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Best 4L60E performance rebuild company???
  2. Rattling noise
  3. th 350
  4. neal chance converters
  5. What do you guys think of this kit
  6. 4l80e questions
  7. Problems after trans go install.
  8. Stall suggestions?
  9. Difference
  10. What is my best option??
  11. 4l80e with fmvb able to lockup?
  12. FLT level 4/Yank PT4400 full review
  13. TREX users step in
  14. 700r4 kickdown
  15. Ratchthed
  16. Transmission rebuild question
  17. Higher shift RPM when COLD?
  18. Trans slipping in overdrive only when hot????
  19. Aftermarket Shifters??
  20. Best Tranny
  21. Who makes a good kit
  22. Power Gluide Or Th400
  23. '94 4L60E finally giving up the ghost ...
  24. My 4L60E isn't shifting automatically, Help
  25. to glide, or not to glide
  26. Cooler install question
  27. B&M Holeshot 2400
  28. trans cooler
  29. what trans should i use
  30. Performabuilt 20% off sale
  31. DO NOT BUY from TRANZPARTS1 on Ebay!!
  32. yr95-4l60e oil recomendation
  33. Goodfellas Transmissions
  34. 4l60e housing?
  35. Yanks October sale still going strong!
  36. Whos running a YANK SS4000???? too much??
  37. Possable tranny vibration.
  38. Need a shop to do a swap! Th350 to 4l60e!
  39. Performa Level 2 or 3 for me ????
  40. tranny is installed, where does this go.
  41. Can an LS2 be run with a 200 4r ?
  42. Aluminum Accumulator Pistons on a Stock 4L60E
  43. ACE Transmissions Has A New Converter Line and a new Sale!
  44. PMAC/Century Converter any good?
  45. a6 swap?
  46. Help bouncing off the rev limiter!!!
  47. Tuning issue or bad stall?
  48. tuning or tranny problem?
  49. Two questions
  50. my th350 has the vaccum htingy on it... how do i use it?
  51. Tranny Cooler ????
  52. Transgo 4L60E Boost Valve ?
  53. better e.t. without tm
  54. Transmission Recommendation Needed
  55. Is this normal?
  56. flex plate?
  57. Is a Trans Brake worth it?
  58. Advice on which 4L80E to buy!
  59. th350 problems
  60. what year 4L80E is best
  61. Deeper Trans Pan on Stock Trans at 80k, worth it?
  62. FS: RPM stage 5 4L60e, SS 3600, A4 Conversion items
  63. need some help here
  64. Tranny rattles in R or D
  65. rebuilding th400, what needs to be done
  66. how to get tranny to hit harder on shifts?
  67. Going to a 700r4
  68. The Nova
  69. lazy lock-up
  70. Got the gears and the programmer, now the Tranny?
  71. SS3800 & 3.73's installed
  72. weird problem
  73. question about my converter?
  74. what would be the best way to go????
  75. Yank SS3600 shift extension
  76. TH350 speed sensor
  77. Bouncing rev limiter someone help!!!
  78. Time for a tighter converter
  79. Who is the best Tranny Builder?
  80. Urgent help
  81. has anyone heard of an A4 4l60e shifting 5 times
  82. has anyone heard of an A4 shifting 5 times
  83. Maybe a dumb question?
  84. a4 lovers
  85. non pwm tranny in a pwm car
  86. WOT; it hits the rev. limiter?? need help
  87. To much stall for such a stock engine?
  88. V6 to v8 trans difference
  89. Performabuilt freshen up ?
  90. Anyone run 2 tranny coolers in parrallel
  91. POS TCI Lock up Question
  92. Tires spinning too much on 2 -1 downshift
  93. gas it or ease into?
  94. opionions please!
  95. Switching from th350 to th400. Cross member ?s
  96. What reluctor should I get for my th400 swap?
  97. shifter questions / opinion
  98. How bad is my tranny slipping?
  99. Grabing 2nd easy quik??
  100. Tranny problem....what is up...
  101. Need some help. Bad vibration after new trans and converter..
  102. Tranny Locks up in 1st
  103. Look for new Package deals from ACE!
  104. Th350 Questions -
  105. bad shift noids ?
  106. Installing new converter, have a couple questions.
  107. A4 to TH400 install swap now my car won't start.
  108. WOT.. Wont shift into 4th.. OD
  109. Self Built 4L60E (on my 95 LT-1 Vette) Squeals for 5 minutes on Startup
  110. Tranny question?
  111. what trans
  112. The analysis
  113. 4l80e a DOG off the line!
  114. 4L60E Torque converter lockup problem with 94 LT1, NEED HELP!
  115. can performabuilt
  116. guys with performabuilt
  117. breaking bellhousings
  118. anyone have one of these laying around?
  119. Help. is it normal or something is wrong?
  120. Th400 Experts Help Needed!?
  121. How does a 4l60 1-2 Accumulator operate?
  122. PO757 Fluke? 2-3 Solonoid
  123. Tune PCM to make converter lock in 3rd?
  124. 2001 Caprice 4l60e
  125. TCI now has 4l80e to ls1 flexplate
  126. th-350 in LT1 car
  127. Converter Wont lock after Manual Valvebody
  128. Trans problem??
  129. 4L60E Vacuum modulator or not??
  130. difference?
  131. Wot Lockup
  132. FLT takes the wow factor!!! Lot of Pics
  133. Guys w/ TCI SSF4000's come in..
  134. what tranny could i use?
  135. Help
  136. difference between lt1 and ls1 4l60e's
  137. WTF ....tranny bolts breakin / rusted!!
  138. How did you guys get the top 4 bellhousing bolts out?
  139. Tranny or rear?
  140. is this streetable???
  141. Need a tranny tune.
  142. 4th gear flare need help from the pros
  143. Huge Tranny Problem Please help
  144. Prothane trans mount Problem
  145. What tranny cooler for YankSS4000?
  146. Looking for feed back on Fuddle Racing Converters
  147. Converter install question/problem...
  148. Will an LT1 verter work in an LS1 tranny??
  149. What size stall for a TR 230??
  150. Finish Line Transmissions Is Proud To Announce
  151. Because you Asked!
  152. info needed on stall's....
  153. Stall Recommendation
  154. My Art Carr 3600/3800 Nitrous stall sucks on motor!
  155. Converter Question
  156. Strange Vibration
  157. So i blew my tranny
  158. Clips for cooler line coming out of trans. 4L60
  159. 4l60e help
  160. Tranny problems, revs in gear but rev. works
  161. Solenoid Problems
  162. car won't shift out of second @wot
  163. How long did your stock trans last w/a stall?
  164. what shifter cable
  165. Fresh Rebuild acting up bad!!! HELP!!!
  166. Help me Please
  167. Lockup Trouble..
  168. transmission leak after converter install
  169. can you downshift a rmvb th350
  170. 200 4r
  171. Time to rebuild or tuning issue?
  172. does anyone's stock 4l60e eat fluid?
  173. picking up my first th350 tranny.. questions
  174. how to shift a A4?
  175. Transmission service port above linkage, safe for temp sender?
  176. Another 4L60e problem
  177. 4l60e drive and overdrive revving out
  178. Yank ss3600 on street tires
  179. downshifts are firm after tune
  180. 4l60E car won't move
  181. Fluid
  182. Rebuilt Trans and seems slower?
  183. Yank SS3600 Installed....
  184. Transmission Fluid
  185. 4L60E Transmission Mounts
  186. The hole this is funny
  187. LOUD clunking noise coming from stall convertor area....
  188. 4L60E interchange
  189. what would cause car to misfire in first and second but not 3rd
  190. How soon must I tune? Installing a Fuddle 3600...
  191. Trany Slipping!!!
  192. Code-Torque Convertor Quad Driver Module?
  193. just got my th400 almost in...
  194. 94 camaro 4l60e tranny problems
  195. 4L80E in 67 bird
  196. tail shaft housing?
  197. transmission shift points
  198. Th400 Or 4l80e
  199. tune for yank 4200
  200. Help with t56 to turbo 350
  201. Broken/Cracked Flexplate..
  202. Need a 4L80E built. I think????
  203. 4L85e
  204. 700r4 dilema
  205. listen to this!!
  206. What stall do i need??
  207. Where to get pigtail for TH400 VSS
  208. Best trans cooler
  209. ACE Racing Transmissions Halloween Sale
  210. 4l60e problem
  211. What size fitting is the pressure port on a 4l60e
  212. shims between converter and flexplate?
  213. I have a tranny ?
  214. converter for 4l60
  215. anyone have a clip of a th400 with a 4500 stall
  216. Excellent...
  217. Best deal for Vigilante Conterters
  218. TH400 Shifting
  219. OD in my 4l80e doesn't work correctly...
  220. M6 Tranny Mount work on A4#
  221. not again...:(
  222. tci flywheel choice for th-350 swap?
  223. Need tranny help!!! A4
  224. P0757 symptom
  225. stock tune with 4000 converter
  226. what everyone shifting at with yank pe 4200
  227. 4l60e rebuild kits.
  228. Blew up torque converter
  229. M6 to TH 350 SPEED O
  230. trans problem need help!!
  231. Please Help ? About Trans Cooler Lines
  232. Am I askin for trouble???
  233. computer shift OR manual shift??
  234. Fuddle 3600 to Yank PT4000..opinions?
  235. shift bracket (side transmission)
  236. turbo 400 questions?
  237. Th-350 Swap What Flywheel?
  238. To stall or not to stall?
  239. 3200 Stall?
  240. TH 350 to an LS2
  241. Hows it look? Yes? No?
  242. Converter Question.
  243. How Tuff Is A 6l80
  244. Anyone have these problems after 4l80e swap?
  245. motor oil in your tranny???
  246. speedometer problem
  247. Is this Normal?
  248. Lock the convertor while running?
  249. PT4000 or PT4400??
  250. Newbie Needs ur help
