View Full Version : Automatic Transmission
- Tranny Cooler...BUT FTRA in the way....
- LT1: ST3500 or PY3600e
- A4 gear calculator
- ??for those with a vig2800 and a 2001/02
- 3.73 install..
- Newbie converter question. Tranny cooler?
- Drill into tranny plan to get accurate temp reading?
- Yank has fixed the ST3500+ses code problem!!!
- Converter flash? Don’t say oh no.
- Anyone have Yank ST3800 or ST4000?
- A4 Owners with Transgo shift kit please look inside
- Question concerning A4 transmission
- trans go shift kit worth doing? easy install?
- Tranny problem 2-3 shift
- Vigi3200 Question
- flash stall to 5700 with a TP4400 converter???
- BIG Thanks to...Yank, FLP, & Moser
- Vig 2800 ?
- 3.73's tamed down vig 3200
- What wire for verter lock up on 98??
- DYNO SHEETS FROM TH400 dyno....inside
- What is the ideal Trans Temp
- Need 4L60E expert, wierd problem
- ANYONE KNOW CONVERTER BOLT SIZE
- How do you test the stall speed of a converter?
- ST3500 Shudder
- FLP Level IV Tranny Woohoo!!!!
- High speed vibrations after 12 bolt install
- PLEASE HELP! installing 12 bolt, need "gears" on 10 bolt axle ends?
- Upgrading to PT4400 from Vig 3200!
- Broken a Flexplate?
- ST3500 with which 3:73 or 4:10
- Whays the best 60' time with SY-3500
- installing moser 12 bolt/ sway bar/brake bleeding/u joint
- ST3500 owners please help a brother out with his idle!
- OMG! installed my vig 3200!
- Got the car back...dynoed with TH400....look inside...
- TH400 install. Any tips. I need to wire the backup lights especially
- A4 to M6 Tranny swap
- Request for Vig3200 AutoTap files
- Crazy acting PI3200
- Difference between these 2 converters
- Trans Temp Gauge
- car surging after ST3500 install
- Problem with transmission on my A4....I think?
- Positive TH400/Gearvendors results
- Which Yank??????
- GRRR vig 3300 install too much room between flexplate and converter
- Help reinstalling the master/slave cylinder
- HELP AGAIN PLEASE! converter too far from flexplate! washers?
- Which converter should I get?
- Is there a difference in A4 flywheels and M6 flywheels?
- anyone know about VSS signal on auto tranny
- Transmission/converter question
- Need help installing new master/slave can not find retaining clip..
- Paint cracking on torque converter. what could cause it? Help
- HELP! installing vig 3200/ remove check ball at end of input shaft?
- Why not lock the converter in 2nd gear?
- Gear for a SY3500
- Pressure plate question????????
- Effects of air temp on converter performance?
- Nitrous converter
- Update on Cartek install.....
- need tips on installing converter!!
- Time for converter change, what should I do next?
- Impression o f Vig.3200 on Fiance
- installin 12 bolt w/ 3.73's & vig 3200 shift points w/ hypertech?
- How do you properly bleed a newly installed Adj master???
- Vig3600 or Yank ST3500
- Ram Installed What a PITA!
- LT1 vs LS1 stall?
- 4L60e Rebuild... Best way to do it???
- trans cooler install/ which line is return?
- Any fast Yank ULTRA THRUSTER cars out there?
- convertor questions
- Converter ???
- transmision coolers
- Disappointing TH400\Gearvendors results
- Transgo shift kit or hpp3 shift firmness?
- HTF to get B&M trans cooler in front of radiator?
- Converter still locking/unlocking at 50-65
- which converter for tnt shot?
- Anyone runnin' 3.73's with a 2800 stall??
- Converter and gearing question....
- How Streetable is a 3500 Converter
- A to Z TH400 Install ?
- any tips for installing 12 bolt & converter?
- How is a SY4000 compared to a ST3500 on N20?
- Shifter Installation Question
- ST3500 stock trans and motor
- 4L60E w/ vacuum modulator = Code P0748
- where to mount trans cooler? pics?
- What parts are involved in tranny temp gauge install?
- what happened to yank's website?
- FLP or SLP long tube headers....which one?
- SY4000 owners and converter experts inside.
- Clunking when going over bumps after relocation bracket install (please read & help)
- ST3500 users or similar: What are your shift points?
- Torque Converter and warranty issues
- Charging probs with ST3500...
- For those of you running the Yank steath 2600
- what's the stock converter in a 99 TA with Auto?
- choose my converter for me>>>
- Vig 3600 locks/unlocks while going 55-65??? wtf?
- Yank and Converter experts, please tell me what you think!
- Curious about dyno numbers and different converter?
- Converter Help
- 3.73's or Vig 3200 ? what first ??
- 3300 yank converter?
- Any info on installing the BMR Torque arm?
- Manual valve body?
- A4 peeps - maf and transmission concerns
- Properly sizing a converter...
- FTRA and trans cooler
- How many tenths would a vig3200 give over a vig2800?
- help me spend $ more boost?converter?12 bolt?
- Vig. 3200, Thanks Paul
- How many of you have done the A4 to M6 thing?
- Help me install my MAC rear-end cover.
- Vig 3200 in for about 3 weeks. My thoughts
- TH350 installers! Use stock LS1 A4 tranny crossmember?
- ever heard of continental converters!!!?? What to get!?!?
- ST-3500 to a SY4000, what *mph* would be gained?
- Vig 2800 that was in '98 can go into '00, right?
- Best converter for my setup?
- Trans cooler install help.
- Installed Ground Control! Pics inside......
- Tranny/Converter ?
- SY3500 to ST3800
- Vig 2800 or Vig3200 ?
- TT2800 vs Yank3000
- Wilwood brakes installed.. pics
- vig 3400 or yany py3600e
- Converter Question (avoiding disaster)
- Atap results: line pressure at shift
- anybody running a non loch-up converter in your daily driver?
- LCA install question
- Gas Milage down with converter.
- New converter question?
- Who make a lockup converter for a TH400?
- ST3500 waiting period...
- Allright converter masters, answer me this
- yank/ posi lock?? py3600e
- Converter experts, advice please.
- help with gears and A4
- Technical Question about Vigilante Converters
- HELP! which converter with my mods? vig 3200?
- 96 s10 blazer tranny 700r4?
- 4L60E experts, need some help
- Pro Thruster 4000?
- Shift kit with convertor?
- Just installed SLP Eibachs @ Bilsteins
- PRO 5.0 shifter installed :-)
- Any difference in LT1 and LS1 4L60E?
- Normal/performance shift programs- A4??????
- 4L60E and 700R4 same trans pans?
- Lube Gard! Shudder problem fix?? (ST3500)
- If locking a convertor is so easy, why doesn't everyone do it?
- Pros and Cons of Vig and Yank
- lock up convertor
- Monitoring A4 solenoid current
- Tranny Cooler
- Big A4 problem
- M6 to A4 questions
- I tested my shift extension on the Yank ST3800
- ST3500/VIG3200 ET GAINS-ANYONE
- 4L60E vs. 4L80E
- Brake line install help.
- TH350/400 users
- Using the Hypertech to adjust shift points after custom tune
- A4 Shifter Linkage Problems!!!
- Vig 3800
- A4 TO M6 QUESTION
- A4 to M6 conversion question
- Who has fried their stock A4 tranny and what were the symptoms?
- Individual Gear ratios of A4
- Yank tp 4600 converter question
- A4 Torque Arm on a M6?
- 4.30 Gears & Spool Installed!
- Line Lock Install problems
- Vigilante 2800 How Loose
- Vig 3200, Will my mph go up or down?
- Drive Shaft loop with FLP's?
- One more: Does your converter stay unlocked when cold?
- Best mail order A4 rebuild kit?
- Link to Vig 2800, Vig 3600 & Yank 4200 Comparison
- converter recomendations
- VIG3200 WITH SHIFTKIT
- Interesting observations regarding A4 lock-up & line pressure
- Is it bad to shift an A4 from Overdrive to Drive to slow down?
- Converter locking prob with the Ported MAF ends!!!
- Did A4 Trans Mount change in 01-02????
- I got a great new A4 toy...
- Vigilante 2600 vs. Pro Torque 2400
- How do I shift my A4 based on RPM's?
- Torque Converter/Tranny Question
- Shift point question
- Will a Yank LS1conv. fit an LT1?
- Problem w/ reverse: A4/SY3500/Tranny rebuild
- Tranny Cooler Placement + FTRA! Help!
- Can an LED be rigged to show converter lockup
- What do you think would be better? 3.73's with ST or SY3500 :)
- Before/After dyno of M6/10-bolt to TH400/9"
- what DSL works with flps?
- Just installed a SY3500!!!! WOW
- What is throttle pressure...
- Vigilante 2600
- What tranny cooler do y'all use?
- Post your 60's with a Yank TP4400
- Whats your best 60ft w/ vig3600?
- Yank back-log nearly gone: Same day service just days away!
- RATECH gear install kits - what is the deal
- maybe just a pressure plate?
- If you broke a 10 bolt with an A4
- Just Installed YTP4000....Can Someone Help w/ Problem?
- 3.73 gears and shift points
- 4L80E, anyone have experience with it?
- Who has 4.10's in an A4???
- Will a TCI streetfighter 10" converter fit on a 99 3.8L firebird?
- Pressure Control Solenoid Amperage Readings
- Help Quick! Installing a 12bolt...
- Which Flexplate?
- Most effective gears with an A4 and a 100% stock motor?
- Estimated cost of gear and converter install?
- Has anyone used a 4L80E?
- Hard to install right rear airbag? Pointers for pressure?
- What is a "Lock up" converter
- ? about removing check ball when installing PI3200
- Yanks site still doesn't work!
- Got a Vig 3600 what about YANK??
- Questions SFC Install...
- Yank's site down?
- advice for a Hughes-built 4l60e????
- Install of Sub Frame Connectors
- ST3500-ST3800---differences
- Where to buy my converter
- 3.23 --> 3.73 gears with Y3000 ?
- Upgrade Vig2800 to Vig3200 or change gears from 3.23 to 3.73?
- A4 not shifting
- Can you test flash stall in 2nd?
- A4 looking for M6 for swap :)
- Why would ppl want to trade for an A4
- torqe conv. install help/info??
- Which converter should I get???
- Which converter with 3.73s??
- Manual valve body 4l60e??
- Yank convertor deal!!!
- Manually Downshifting an A4...Are you brave enough??
- Convertor install?
- Need some convertor help (2002 ST3500?)
