PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 [113] 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. converter not locking up...
  2. tranny length? 4l60e-TH350 anyone got measurements?
  3. A4 or M6
  4. th 350 internals
  5. Drivetrain issues
  6. 2wd trail blazer SS & 4l80e?
  7. Yank PT 4400 DD
  8. trans is broke. help!
  9. 6-7 lbs of boost on tranny!!
  10. best rear gear and stall rpm choice
  11. Torque converter bolts
  12. B&M pro ratchet shifter question
  13. which stall for my mods
  14. To much converter?
  15. stall converter with 273's
  16. Superior Shift Improver Kit and P1870
  17. Going TH-350
  18. FLT got a question? 4l80 case adapters fittings
  19. Need Advice On Launching A4 For Best Et's
  20. manual valve body
  21. 4l60e dead
  22. what is a 4l80e???????
  23. Tranny Mount ???
  24. Are TH350 and 700r4 input shafts the same??
  25. Wheels moving in neutral?
  26. Trans problem
  27. lock up?
  28. Am i makin a newbie mistake?
  29. another ignorant flexplate question
  30. Will stock stall work with LS6 cam
  31. P1870 and Shifting Trouble
  32. What flex plate?
  33. max rwhp for 4l60
  34. Stock shft knob removal
  35. tranny installed now car runs like crap...
  36. Please help..
  37. Trans Go vaccum modulater...
  38. shift kit install???, no reverse or 3rd,4th
  39. best shift kit for 02 Z28...?
  40. need help>vent line location??
  41. Advice Please: Which would you purchase Yank or Vigilante.
  42. ls1 to 350 turbo
  43. Where do I mount a transmission cooler?
  44. trans issues
  45. 4L60E - 4L80E swap in a 94 Z28
  46. M6 swap to a 700R4
  47. Whit kind of tranny?
  48. TH2004R Help, WTB
  49. What to get with $1000 bux??
  50. what mph lockup is recommended?
  51. Looking for feedback from people with a glide...
  52. audi s4 trans in a Z28?
  53. Got my stall in and..............
  54. Help, what is....
  55. trans took a dump.
  56. Tranny Coolers
  57. My beater has a tranny issue. Please help diagnose.
  58. What company makes the strongest 4l60e?
  59. What is your launch rpm with stall?
  60. I need an SFI approved flexplate
  61. different transgo shift kits?
  62. Installed the Fuddle today....
  63. Anyone in here running a Th350 or th400 as daily driver
  64. Gear vendor questions.
  65. auto tach question
  66. Do i have to many miles too....
  67. tranny question
  68. what is this called?
  69. Vigilante 3000 and 3.73's Good Match?
  70. how long will it last???
  71. Sponsor Feedback and Sales Questions Do not Belong in this Forum!!
  72. stall
  73. cross member when converting to a th400
  74. Some Help "STR" ???
  75. nitrous on stock converter
  76. 2-3 shift hitting the rev limiter???
  77. Bad Flexplate? In need of some help quick
  78. 700R4/4L60 shot craps.new one coming.. non lockup or lockup stall
  79. 4l60e converter in 4l80e?
  80. Stock trans temp sensor
  81. torque convertor dust shield
  82. Roll Racing
  83. 4l60e 1st Gear Only...help Please?!?!
  84. 4l60e B&m ratchet installation HELP!!
  85. i sacked up and pulled it out
  86. 4L60E OEM flaws?
  87. Is the 98 4l60e different from the 99-02?
  88. Measuring torque converter efficiency
  89. Stall ET times?
  90. stall
  91. how can i drain alittle tranny fluid
  92. SFI Flexplate for TH400
  93. shift linkage and 02
  94. Holes in TCI flexplate won't line up
  95. stalling the car up
  96. 4l60e: How to replace the transmission pump?
  97. Stall Installed
  98. 2000 Monte Carlo 4T60E, hard shifting
  99. pinging noise when in reverse ?
  100. 97 chevy 4l60e 1st and reverse grabbing
  101. Clunk when shifting
  102. Torque Converter?
  103. Drivetrain clunk...
  104. tranny broke , any ideas?
  105. Fastest on 4L80, Who makes it??
  106. rapid shifter?
  107. Yank/ Vig 3600
  108. i have a small problem...
  109. Tranmission Sound
  110. Help got a P1870 Code
  111. 4l60e wont go into gear
  112. Paging Fuddle...
  113. stall question
  114. which one works best
  115. tightest converter???
  116. 4L60E/Th400 info
  117. tranny temps
  118. help please with 2-3 shift
  119. screwed of course
  120. where to get B&M cooler kit for our cars
  121. Help!! Car Kills Pumps Asap!
  122. tranny cooler fan - on all the time
  123. TCI SFI Flywheel
  124. 3 Pumps Broken
  125. stay auto or go six speed?
  126. Will this tranny fit my car?
  127. what does everyone think???
  128. C5 Tranny Install, how many hours? Labor Cost?
  129. trans cooler install
  130. What size stall???
  131. Oil Pump Removal
  132. Need stall help....
  133. yank?
  134. yank?
  135. Anyone running a small stall like 2,600, 2,800 or 3,000 and if so why?
  136. FLT stage 3 or 4?????
  137. Gear calculations on th-350 swap
  138. What MPH should 3rd gear take me to?
  139. Tranny Temperature Question?
  140. rock-on transmission????????
  141. rebuild kits
  142. help with good transmission service
  143. Where should I shift?
  144. new 4k fuddle installed
  145. New Tc Tune
  146. flt stage 3?????
  147. Installing TC need some help
  148. F-Body 4L80E conversions - help please
  149. gettin a 3400 stall
  150. tranny
  151. problem with rock on tranny
  152. low tranny fluid?! why! so confused...
  153. Change tranny fluid or leave alone?
  154. Can anybody help with a harlan 2-step?
  155. Flushed my trans fluid this weekend...
  156. Need Transmission Help! No Gears
  157. Will a yank for a 4l60 fit the new A6 6l80??
  158. need help on stall!
  159. Newbee question 4L60E v.s. TH400
  160. If I go with a Fuddle stall should I get the Performance or the HP/Street Series??
  161. Average cost to get a 4l60e rebuilt?
  162. help! where did 2nd gear go?!?
  163. Shout out for Fuddle
  164. Just curious
  165. stalled guys, just a quick question..
  166. about my tranny....
  167. Well tranny finally went...
  168. Difference in 4l60e???
  169. what stall should i get ??
  170. Th400, low torque #'s????
  171. Tranny Fluid Change - What do I need?
  172. YANK SS4000 Torque Converter GREAT SHAPE!
  173. Help
  174. P1870 Code on the 4l60e
  175. Auto Gear Shift Expertise Needed
  176. Wondering whats the normal temperature for a auto to run?
  177. part numbers???
  178. Looking for an indepth book
  179. Transgo Shift Kit:How hard to install?
  180. converter lock-up solenoid...4L60E...part number?????
  181. th400 is in!! why is there lag going to second gear??
  182. ratchets?
  183. Anyone want to take a shot at why
  184. Need stall help
  185. Can you fill the TC with fluid...
  186. Who Has Got The Yank SS Series Converter the Cheapest?
  187. What pins to tap into
  188. shifting problem?please help!!
  189. only reverse?
  190. Bm shift install help
  191. It Wont Shift Out Of First!
  192. What Is this on my Converter? Pics Inside.
  193. what kind of gear are you guys running with a 26" tire?
  194. Tranny/TC Problem?
  195. shift points and pressure
  196. 4160e 98 trans Wont shift out at WOT....
  197. 4l80e speedo
  198. 4l80e To Fit In A Corvette
  199. Stalled Guys from a roll
  200. My stage 3 trans lost 2nd
  201. 400rwhp+H/C A4 cars please come in
  202. anyone with Big Stuff 3 and auto transmission
  203. Is this tranny on its way out? times/MPH
  204. Is B&M Shiftplus really bad or just a myth???
  205. Chatter comming out of lockup.. ?
  206. New stall for 95
  207. Rmvb 4L60e??
  208. I got 95 transam convt. I got its transm. down.. burned the clutches of trans..
  209. Transmission problem??
  210. M6 To Th400
  211. th400 swap does it need retune
  212. stock HP Vs. 4l60e tranny. UHH. look
  213. Stock Stall ?
  214. how hot does your tranny get?
  215. bad leak broken part please help!
  216. Anyone have this problem??
  217. 4l60 trouble
  218. WTF's going on with my A4
  219. 4000 stall people with granny gears
  220. Gears or Stall???
  221. 1-2 and 2-3 shifts
  222. thining of going M6->TH350, read faq's and still have questions
  223. tci tcu help
  224. 1LE tranny mount fit 01 A4?
  225. who has over 400rwhp on stock trans?
  226. kickdown
  227. Happy fuddle customer
  228. DS length
  229. Redline Transmissions Ft Lauderdale
  230. My Tranny Soudns Like Its Slipping Help!!!
  231. Stalled A4 owners...
  232. Big thanks to Dave @ Rock-On
  233. I'm nervous about this stall I just bought...
  234. Out Put Shaft Seal R+R?
  235. 4l60e worth keeping?
  236. rock-on transmissions..
  237. "Planetary gearset noise" any suggestions or ideas?
  238. 4l80e?
  239. $2600 to rebuild auto tranny?
  240. a4 problems?
  241. P1786: 3-2 downshift fault
  242. what shift kit you guys buyin?
  243. screwed up my shift kit install. need help badly
  244. kickdown cable on th-350
  245. Will a 4l60E bolt into a Old Small Block Chevy???
  246. Need a quick question answered.. tranny cooler..
  247. coan transmission
  248. torque converters????
  249. 1>2 WOT shift getting soft
  250. DRC built TH400
