View Full Version : Automatic Transmission
- 4l80e pump
- Any way to identify an ls torque converter?
- 3600-4k stall on stock 4l60e?
- Y pipe hanger for automatic?
- 4l80e converter choices.. Yank SS vs Edge Street Series
- Think I damaged my 4L80E again...
- TH350 dipstick
- Broken th400 bellhousing, is my converter okay?
- what are the best gears for a 4l60 and a 26" tire
- Red or Blue Locktite For Coverter Bolts
- Shift Kit and Performance mode line pressure question
- Tranny help!!
- trans question
- 4L60E Issue
- Help with 6 speed to 4L60e conversion
- looking to trade my built T56 for built 4l80e
- B&M Prostick cable adjustment
- Dipstick Hitting Hood
- optishift 4l80e tune
- Torque converter bolt installation - nothing is threaded
- Error 4L70E Supermatic GEN2 please help
- 4l60 leaking from harness plug...
- What shifter to go with?
- All Torque Convert
- TCC problem need some advice
- best lock up kit for 200r4?
- Bad need of some 4l60e HELP !
- TransGo 4L60E-HD2 "D" issue
- Limp mode??
- B&M star shifter
- NTC 4l80e transbrake throwing a p0758 code
- 4l60e issue help
- How much HP does a 4L80E use
- Seating Torque Converter (read the sticky)
- sonnax smartech drum
- 4l80e converter
- 2 big tranny coolers
- 4l80e wont shift into 4th intermittently
- Normal Temp Range for Trans w/Big Stall 4L60E?
- manual to automatic conversion Reverse and nuetral lights
- Shout out to FTI tranmissions!
- Need to identify which 4l80e harness I have
- 4L60E SmartTech forward clutch clearance
- 2-3 WOT shift problem
- Tranny swap w/o removing converter?
- What shifter fits good in the console of 02 Camaro for a glide?
- 17 tooth 4l80 vehicle speed sensor reluctor
- Shim between flex plate and crank, ls1-4l60e. stickies didn't help. Please help
- swap 2003 4L60e in 2002 Suburban
- Best non-fan cooler
- freshly rebuilt 4l60e won't shift past seccond
- Location of the 4l60e Transmission Fuses for a '99 Trans A4
- Transgo 4l80 hd2 install. Oil pan hits filter
- I Need A 4L60/65E Tranny In Ft. Lauderdale...
- Th-400 Build questions.
- Adding gears?
- Tci converter alignment issue
- Torque converter drive
- 4L60E slow 3 -> 4?
- Compatability Issue 4L80e
- metric nut size
- 4L60E Limp Mode Please Help!!!!
- O.K. Guys n Gals, I need help!!! A.S.A.P. !!! UPDATE, FIXED!!!
- GM Performance torque converter help
- 4l60e to TH400 price?
- LS1 to Powerglide clarification /Stall converter/flexplate
- UMI.. need 4l80e crossmember swap options.
- 4L60E binds/locks in manual low when hot
- What's this trans and converter worth.
- 4l80e no lock up after overdrive?
- Junkyard tranny - what to inspect?
- 4L60E Torque Converter Swap Please Help!
- Help!!! 4l60e problem
- The Official Auto-to-Manual Transmission Swap Thread
- Converter Recommendations for 4L80E
- Slap Shift/Manual Valve Body Questions
- Help with 4l60e parts list
- 4L80e Slip Yoke
- New flex plate hitting starter gear
- Is this normal for a 4L80e??
- Looking to buy a converter
- 6L80E years ???
- 2005 4l65e valve body harness swap to 2008 valve body harness
- 4L80E issues guru advice needed
- TH400 vs 6L80E????
- 4l80 d1 urban for holding first gear HELP!!!
- 4L80E swap Problems
- Question about FTI SB3200LS converter
- What size stall?
- M6 console- 4L60E
- what caused this?
- My rebuild plan & using shift kit with torque management?
- Question about codes P0700 and P0717
- 4l60e neutral safety switch
- 4l80 wiring
- 4l80e Jake's D1 and Hptuners, 1st gear problem
- 4l80e HD2 shift kit installed wrong/transmission wont engage
- Can someone tell me what yoke i need for my 4L80??
- Leaking Torque Converter
- 2000 4l60e same as 2002??
- help with torque converter identification
- 4l60 valve body gaskets ??
- Trans Advice on LQ9 Swap
- Tci ez transmission controller.
- 4l80e no manual low engine braking, reverse is perfect.
- Converter Cut and Clean
- 4l80e newbie help
- th400 stall?
- Best thing i have ever done for my tempermental 4L60
- 4L60E won't shift 2-3 when flooring it
- vent hose end piece on tranny melted on exhaust, which part do I need?
- Powerglide converter ?'s
- ls1 pcm vs stand alone transmission controller for a 4l80e
- 4l80 yoke help!!!
- SS3200 or SS3600 on a stock '99 Trans Am daily
- Misfire After Tranny Rebuild
- 3600 or 3800 yank ss converter?
- Need advice on stall, 4L80E turbo.
- Transbrake wiring....W pin?
- Reuse aftermarket torque converter after bad 3-4 clutches
- 4L60E second gear issue - Need some advice
- No idle after 4l80e swap.
- Where to order 4l60 billet pump rotor
- Where to find USA-made filter?
- budget 6l80e converter ?'s
- Any 4L60e experts? Super weird issue...
- Freakshow Converters
- trans issue after swap
- 5.3 XJ swap - No TCC lockup
- Am I getting bogus advice about the trans. Cooler for my Astro van?
- pinless acc 1-2 3-4 springs , help
- 4L65E or 4L70E Questions
- Got my yank 3600ss installed and broke in!!!!
- Time for a new trans.
- 4L60 good temperature ??
- Installing sonnax LB1, separator plate and hd2 shift kit.
- Torque specs for transmission pan - 10lb or 100lb?
- Need help with this 4l60E
- Transbrake Button locations
- transmission trouble
- v6 Torque Converter
- 4l80e wiring
- Will it work?
- car sort of lurching forward?
- TH400 Cooler w/Fan HELP
- Need help with 4l60e
- VERY HARD jerk when putting car in drive .. Tranny mount?
- 4L60e or TH400?
- Help with 4L80e build.... (1000+ HP). I need your expert advice:)
- 4l80E that has been sitting
- 4l80 lock up rpm drop
- roller clutch race grind 4l60e?
- Driving with bad 3/4 clutch - reliabilty/long-term?
- 4l60e swap question
- 4l60e comparability years
- Burnt intermediate frictions in 4l80e. found torn lip seal on tear down...
- 4L80E poly mounts?
- 4L80E Swap - Converter and Flexplate Questions
- 4l60e tranny did something weird today
- Installing th400 and have a few questions
- What bolts to use with jw bell on a th400?
- 4l80 line pressure help!
- Help! Transmission overheated, blown.
- Tapping into the Vss on my 4l60e
- Trans issue
- 2001 vs 2004 4L80 compatability
- Added a pint today. 1st in 14 years.
- Help With 700R4 Beast Sunshell Install
- First time 4l60e Rebuild help
- 4l60e Reverse Input drum clearance using Blue Plates
- Need help with a swap!
- Jakes performance 4l80 black box.
- RIP TH350... PG or 400 now?
- FAST/TCI controller accumulator pressure
- 4l80 hp rating and converter options
- P0717, possible to tune out ISS?
- The Dreaded Two-Piece Tranny Mount
- Hitting 4th in 1/4 mile 4L80e
- Tow/haul mode 4l80e
- rebuild kit 4l60e
- 4l60e, output slows as throttle increases
- Will TC not locking cause trans damage?
- Need Help with 4L60 - TC not locking?
- transmission problems on a 4L60E
- What stall in factory 4l80e 2500 van
- 2nd Rebuilt Transmission in 4 years??!!
- Trans mount bolt
- 4l80 swap with 9" rear
- 4L60e vs T-56
- Transmission swap
- shifter help please!
- 4l80e racing characteristics
- will a 4L80E fit in a C6 Z06?
- 4L60E why the low pressure hot?
- What is this? part?
- which will handle more power? 4L80E or 6L80E?
- 4L80E Deep pan for car??
- Help Me identify stall!!
- Need tc recommendation
- th400 issues after b&m shif kit
- Accumulator bushing/spring help needed please!
- Custom mount plate for hurst quRter stick...
- Built stage 2 4l65E or Stock 4l80??????
- Th350 and stick shifter quick ??
- 4l60e no manual first gear and starts in 4th
- Need info ASAP - Can you ship an L60E via FedEx Ground in a Rubbermaid?
- Choosing proper stall
- 4l60e converter question
- best Transmissuin for my application?
- All about Flexplates, Converters, Transmissions and Spacers
- noise going into gear.
- Stock Torque Converter Questions
- Which trans cooler should i go with ?
- shifting
- 4l60e issues??
- Trying to Fit 4L80 into a 3rd Gen Car ???
- 4l60e upgrades? opinions?
- What flex plate to use with my Circle D converter?
- Adaptor for BOP transmission ?
- OEM dipstick installation
- 4l80/tci ez tcu issues
- 4l60e to 4l80e
- 80e paint it or leave it raw aluminum?
- wbody store converters?
- Pretty sure my stock 4l60 just told 525rwhp to kick rocks
- 89 turbo 400 2-3 shift issues
- 4l80e starts in 2nd and had od sometimes
- 4l80 turbo 400 dipstick.
- SBC406 conversion - transmission help
- HELP! 4L80E Output Shaft Only Turns Counterclockwise
- 4L80E converter feels locked all the time...?
- 4l60e temp sender pan location
- Switch wiring
- Car slams into drive from park.
- th400 build
- LS3 + Supermatic 4L85e + TQ = Flex Plate?
- No reverse on TH400, T-brake, RMVB
- Pros and cons of swap
- 4L60E jerking on starts
- drive shaft length running a glide
- Auto tranny slowing car down
- 4L60E Vibration
- Flexplate bolt holes not lining up
- Another 4l60e rebuild thread
- Time for fluid change in 4l60e, this fluid alright?
- th400, soft shift
- Keep flexplate or get new one
- please help my transmission is acting crazy
- Can I see your trans cooler w/fans setup?
- Good place to order a stock torque converter for a 4l60e?
