PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 [134] 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. help: loud vibrating noise when in gear
  2. can you still use the transgo washers with the Pinless Accumulator Pistons???
  3. Torque converter bolt size for a TCI converter?
  4. Trans Help! 4L60E!
  5. trying to find flexplate and converter for th400
  6. Just drove the TCI3000!!!!!
  7. Which shifter for t-400?
  8. how much trans fluid do you need to put into a new converter?
  9. 4L60E issues...
  10. Help: 99 t.a. trans
  11. Need info TCI 3000 in a GTO.....
  12. Neutral Safety/ Backup Lights
  13. Which auto for boosted application?
  14. will any th400 converter work or do i need one specific for a4-th400 conversion?
  15. slippin clutch only in reverse ?
  16. Built 4L60E?
  17. idle problems
  18. reprogramming???
  19. th350 and 12 bolt drive shaft lenght?
  20. 1-2 Clutch Pack
  21. Difference in strength between TH350 and TH350C Lockup converter
  22. 4L80E with trans brake?
  23. Having a problem with the Hurst tranny swap kit>>
  24. TCI Rebuild kit
  25. 700r4 transmission
  26. ? about my th350 stall bolting up.
  27. GM six-speed automatic transmission
  28. Th350 in and running
  29. 2002 Gmc Sierra Transmission Question
  30. Roll racing in a SS4000.....
  31. Tuning for 3600 stall?
  32. What Stall For My Setup???
  33. 4L60E - Cold shifting question
  34. BIG PROBLEM from france
  35. Stall install
  36. Torque Converter Question
  37. A4 tranny strongest cheapest
  38. Yank SC3000 going in tomorrow 4/14 HELP!!!
  39. lokking for a 200-r4
  40. same converter different power levels
  41. how much power is too much for a stock a4?
  42. Just ordered my SS4000!
  43. What all is needed for T350 swap?
  44. Guys that run a stall bigger than 4400, come inside!
  45. 4L60E No Overdrive
  46. Rubbing noise???? Help!
  47. cant do a burnout???!!!
  48. how soon do i need a tune after installing a 3500 TCI
  49. Where to lock up YankPT4000
  50. GM media PICs of the 2006 6L80E
  51. help fast please!!!!!!!!!!!!!1
  52. Valvebody Working Right? Help
  53. dipstick tube.......
  54. at what point do the 4l60s have problems?
  55. 4l65e
  56. Stall STR and High End Effeciency.
  57. ?????????????
  58. Who builds a strong 4L60E?
  59. Auto not shifting right.......
  60. What RPM does your A4 shift at during WOT?
  61. converter help
  62. aftermarket transmission pan
  63. Who builds the best auto
  64. who is ed wright??
  65. hurst quarter stick console mount? th350
  66. What's This Noise?: Loud ticking after converter install (long)
  67. PermaCool Dual Cooler with fan? TRANS AM 1996 - trans. & engine cooling - NEED HELP!
  68. Biggest Stall? (Daily Driver)
  69. MY TCI 3000 stall review
  70. Need help installing my trans cooler on my 98 TA
  71. i have mods what tranny do i need to get?
  72. Why does the center console/shifter area jerk up whenever my car makes the 2-3 shift?
  73. M6 to A3(th400) What speed sensor do I need?
  74. all th400 people inside:need help
  75. torque converter install
  76. automatic th400?
  77. Red Alto
  78. Poly Trans Mount good idea?
  79. Which rebuild kit
  80. Quick Question
  81. Vig. Multi-Disc.
  82. Downshifting TH400
  83. Hard shift from 1-2
  84. Help.....NO OD??!!
  85. ssf3500 less pull more punch
  86. what trans fluid
  87. th 400 installed price?
  88. 4L60E SES Code
  89. TH-400 slipping
  90. TH-400 or TH-300 w/ Current Set-up
  91. Do I need a deep tranny pan?
  92. will this tranny hold?
  93. It's BACK the "SUPER YANK 3500"
  94. 2 to 3 shift problem
  95. lockup solenoid question
  96. torque arm mount for 4l60-e
  97. 94 to 95+ A4 swap
  98. converter stalling at idle?
  99. how do you figure top speed in a stalled TH350?
  100. f-body 4l60e?
  101. 4l60e to 350 wiring issues help
  102. Torque arm options with t-400?
  103. Need Tranny Temp Options...
  104. Please Help, PRNDL switch question
  105. Re tune needed when going to a higher stall
  106. Will a 700r4 work with an LS1 if I use a LS1 torque converter
  107. another lock up problem
  108. STR--- what to get..
  109. Car wants to shift......but just kina sputters?
  110. top speed of th400
  111. vigi 3500?
  112. YANK's NEW PRODUCT LS/1 400 transmission
  113. lockup in 3rd + nitrous?
  114. What sort of stall to get?
  115. TCI Trans-Scat and other shift kit questions
  116. Flexplate advice?
  117. th350 aftermarket valvebodies???
  118. Tcissf
  119. 4l60e question
  120. ssf 4200 installed; few q's
  121. shifts high
  122. 4L60E won't upshift in drive at WOT
  123. 2000 Bird with 8k miles...change tranny fluid?
  124. trans and 1st gear?
  125. 228/230 + 373 Gears = What Stall Speed?
  126. Getting a converter in a couple of months...tranny fluid quesiton?
  127. Having my TCI SSF3500 installed tomorrow...
  128. TH400 - 1st gear hard to shift into 2nd after putting car in Park
  129. th350 driveshaft
  130. ls1, th400, and ford 9"
  131. TCI 4000 won't lock up??
  132. Trans rebuilders inside...
  133. Reverse in a TH400 - use t-brake???
  134. Do I need an A4 harness or can I re-wire my M6?
  135. what RPM to stall to>?
  136. Trans Brake guys...
  137. Quick question that you may not have thought of....
  138. problems with converter.
  139. no 3nd gear no lockup
  140. VDO Vehicle speed sensor for TH350-400
  141. custom driveshaft
  142. Th350?
  143. lost top end?
  144. TH400 to a 460LE
  145. Need Help Fast
  146. Rebuild or New
  147. transgo shift kit
  148. Performance & racing question
  149. drivability with a converter
  150. Thanks Dave@Yank, leaky Y3000 pics inside...
  151. which tranny should i chose???
  152. turbo 400
  153. Where to from here, I'm still doing research now...
  154. Problems with my TH400 PLEASE HELP
  155. NEW GM FLUID for 2006 Good news
  156. If the fluid in the tranny looks a little clear now...
  157. Flexplate, TCI or ATI?
  158. Another TH350 or TH400 thread
  159. Availability of 4L80's in northern ca
  160. 4L60E Help....
  161. 350 turbo output shaft
  162. 1998 Ta 4l60e
  163. Installed stall converter, now leaking?
  164. "Street Only" 4L60e Questions
  165. trans mount?
  166. overdrive
  167. Flexplate nicks back of engine at start up????
  168. steel pan vs aluminum pan
  169. 4L80e/TransGo Shift Kit/Line Pressure
  170. Trans wont reverse
  171. 3-1 downshift damage
  172. need 2nd opinion on vig converter
  173. Time for a new tranny...tell me what to get
  174. Any Bullet Proof 4 speed?
  175. speedometer recalibration
  176. is it possible to deleted 2nd gear through programming??
  177. cut a lil into driveshaft !
  178. What's the highest stall you'd go with bolt ons only?
  179. shifting hard, real hard
  180. which tranny cooler ?
  181. new tci converter!
  182. chatter
  183. need help after th400 install
  184. TQ converter install guides??
  185. Truck converter in car transmission?= explosion?????
  186. 3600 Vigilante
  187. pilot bearing help (doing A4->M6 swap)
  188. Who has problems or vibrations after a torque converter install?
  189. tc install thrown code
  190. Speedo / miles problem – am I going faster/slower in the same distance traveled
  191. Does anybodys tranny do this?
  192. 4.10's w/3500 stall?
  193. Converters the Same in LS1's and 4.3 Trail Blazers?
  194. Do OBD-I f-bodies (Pre-96) have Pulse Width Modulation?
  195. car wont shift to 4th! help!
  196. Rattle after TC Install
  197. got a big problem with a vacuum system
  198. Is my trasmission screwed?
  199. aftermarket flexplate t/c bolt hole?
  200. Fuddle install is done
  201. Downshift problem.. shaking..
  202. do i need a transgo to go w/ my TCI 3500
  203. B&M Precision Shift Control Gate 93-02 Camaro
  204. Why is my pan leaking??
  205. SS4000e!
  206. 2-3 or nuetral?
  207. Which Trans
  208. Do I have enough stall?
  209. TCI Streetfighter 3000 with 2.73's?
  210. 4l60-e
  211. Trans go downshifting?
  212. Weight of stock stall converter?
  213. E-clips own me
  214. Torque Converter Clutches
  215. Traction Control
  216. which of these three converters?
  217. 200 r4 street strip feedback
  218. 4L65E flexplate
  219. B&M Shift plus
  220. 02 WS6 need a flexplate upgrade with convertor?
  221. Better choice: TCI SF3000 or TCI SSF3500?
  222. oversized transmission pan? Filter?
  223. Track Events Auto vs. Manual
  224. 4l60e ???
  225. TC install question
  226. Is Turning An A4 Into A 6spd As Crazy As It Sounds?
  227. Precision Industries Warranty
  228. Baro?
  229. Yank TH400 + torque arm mount pics
  230. swapping 2:73 to 3:42 without tune
  231. 4L80 swap guys, what year trans did you use?
  232. 2nd gear start on A4 LS1 possible ??
  233. anyone running a vig 4000
  234. SY3500 lacking?
  235. Best way to get TCI custom converter?
  236. question for peeps who did m6 to a4
  237. Speedo Correction w/ TH400
  238. GearVendors OD unit?
  239. Got the TH400 today!
  240. trans brake in a th350
  241. trans"what the f!!!!"
  242. cooler size??
  243. flywheel bolts make leak?
  244. People with TC and headers, which first.......?
  245. Are all stalls created equally
  246. Effects of Converter on the Daily Drive
  247. tranny problem
  248. how is this torque converter???
  249. Advise: My tci 3,200 stall makes a wierd noise when it goes into O/D.
  250. Opinions on vig multi disc convters
