- 97 Trans Cooler Lines
- 4l80 converter wont lock up...
- 4l60e noises...
- Vigilante TC advice
- 700R4 question?
- Need help on what to do
- tranny rebuild
- Doing a burnout at track on slicks to heat up tires
- Installed a Yank, but what's wrong?
- tranny cooling lines
- My POS car v.transmisson
- FLT Level 4?
- Honda Passport Cold shifting Problem.
- Gear Shifter Button (Automatic Tranny) Gets Stuck
- Shift Solenoid B stuck ??'s
- flywheel turned??
- Did I Hook Up The Trans Cooler Correctly ??
- 4l60E Upgrades....help/suggestions needed.
- help on 95 4l60e
- Looser stall???
- coverter rattles!
- Tranny slipped twice.
- The question is......Can you?
- 4L60E Bolt Pattern
- Got a stall? You need a trans temp gauge!
- 6.0 flexplate with 4l60
- What tune should I use for diablosport w/3500 TC
- HELP!!!!! older 4l60 in to a ls1 car
- Exner 4l60e
- 4l80 install goes bad when you receive a 4l60 converter
- wierd problem with 4l60e
- I Need Help With A Th400
- how much
- A question about ss 3600 and STR's.
- whos cammed + stalled with stock tranny?
- wheres john AGAIN
- flt
- Tranny Line E-Clip problems
- Tranny and transgo shift kit?
- performabuilt 4l80r
- Converter and tranny cooler???
- how much is it worth?
- Vig Stall change
- tranny problem?
- How long will my stock A4 last with H/C?
- 2-3 shift is going bad
- Tune and new trans/converter
- Which shift kit should i buy?
- Quick ?
- Th400 problems
- 4.56 Gears with a TH400
- i switched to a TH350 no speedo now but it's banging the rev limiter?
- just how heaby is a 4l80e???
- Torque Converter education
- will a 4l60e out of a s10 work on a lt1 camaro
- Top Bellhousing Bolts on 4l80e
- Too much stall???
- 4l60e wont shift out of 2nd to 3rd what should i do???
- 2-3 shift slip after transgo kit?
- Convertor Question
- digital trans pressure gauge?
- Can't Decide...
- Does this look like a cracked flexplate?
- Just got done rebuilding my tranny,?
- (4l60e)-p01416 what is it?
- Which cooler for trans?
- Recommendations on trans parts??
- Why can't I lock up on the dyno?
- installed prothane tranny mount today ned opinions and help on something...
- converter question???
- 4l60e
- Need advice on torque converter
- opinions on this converter
- Hughes Overhaul kit
- Lokar users inside
- will this stall work
- Odd 2-3 shift problem: 4L60E
- Who knows Fuddle torque converters
- How many have a stall on the stock 4l60e
- spraying nitrous through shifts on stock 4L60E?
- Another 460le goes boom..
- 4l80e Trans Cooler
- 97 vette with 4L80E
- shift linkage on 4l80e
- Problems with the tranny!! Help!
- Hooking up Speedomter to 4L60E
- long time to shift on 100 shot?
- lt1 th400 crossmembebracketr bracket w/ T.A. relocation
- 700-R4 attached to LS1. Convertor Question
- Performance 4L80e rebuild
- Has anyone here went from 3.73s to 3.42s?
- Stock 4l60E pan depth?
- What is this sensor called????
- Anyone know what I need to use to bolt a C5 trans to the motor? No torque tube
- need the speedo wiring
- LT1 -to- LS1
- th 350 guys come in
- Yank 3600 ?
- 4L80- will not shift into overdrive
- 4l80-e dimensions
- new tranny slipping
- put trans back in now gas guage and tcs not working???
- Help! Calling out to the 700R4 pros!
- PN for AN fittings
- Converter experts please teach me
- Torque convertor clutch circuit code came up
- Strange Transmission Problem
- 4L60E 2nd gear slipping?
- converter burn out
- trans slipping or tune problem?
- 4l60e gear lever on tranny question
- Bellhousing bolts and Tranny crossmember bolts for 4l80e
- Tranny cooler lines~ how do they connect?
- V6 3800 Trans??? What is it??
- At Trans available.
- Flexplate int or ext Balance? Or Neutr for Stock 95 Transam?
- tranny install
- Auto : Approx. RPM SHOULD it shift?
- 4L60e Worth
- rpm transmission number
- To Be or Not To Be? ..... Vacuum Modulation?
- HP loss thru a Powerglide???
- random slipping?? i think
- servo installation...
- WTF: tranny acting wierd
- Yank 3600 VIDEO
- Do you think my trans is slipping.
- Tranny help again.
- help!!! rebuilding a 4l60e!!
- T56 To 4L60E. Have Some Questions.
- 4l65E
- code 753
- flexplate good to handle 600rwhp??
- WHAT CARS/TRUCKS DO 4L80e's COME IN?????
- th400 specifications
- 4l60e power limit
- TCI Super Street Fighter Questions
- built 4l60e what should i pay?
- How do I change the filter on my 4l60e tranny?
- 4l60 flexplate shield
- 4l80e shutter
- flexplate shield for 4l60e, I know this is FI
- 4l80e trans for c5 corvette
- Camaro/FIrebird A4 shifter identical?
- 4L80E-HD2-D Shift kit firmness
- need rebuild parts list... everyone PLZ help
- vss ?
- shift kit 4l60e
- Is my trans. goin out?
- how much stronger is the 4l65e?
- Which Transmission to Choose?
- tci 4200 stall drivability?
- 4L60E shifter linkage help!
- Step by Step How to remove 4l60e transmission!!
- need step by step tranny removal
- is my tranny mount bad?
- Sound from transmission volant???
- dexron VI
- Broken Sprag?
- 700R4 Shifter
- lose lock up until I turn my car off
- This may be a dumb "cooler" question...
- Quick ???
- What Aftermarket Shifter For TH400?
- Tranny bouncing off limiter 2-3 shift
- 4L60E or T56
- Question about C5 auto transmission
- car lurches forward
- a4 not going into o/d
- Sould it shift so hard going into second at low speeds?
- transmission slipping??
- Broken 4L60E#2
- Which converter for me?
- no shift or speedo need help
- Scattershield for a 2004R
- **%&** Trying to put 4L****tyE in tonight.. Damn Bell bolts
- 4l60e To Turbo 400 Speedometer Help!
- TH350 or 4L60
- So it's time for a shift kit...got some questions!!!
- M6 to A4 swap parts listing please?
- non lock up converter for light street duty.
- Tranny or stall problems? Maybe?
- 6L90 Aftermarket Parts
- A4 not shifting out of second
- flex plates for LS engines
- 4l60e to th350
- Mileage went down with trans rebuild?
- LS2 flexplate
- All 4L80e owners, I need feed back please
- Built 4L60E stage 3 tranny Makes car jerk around???
- 4L60-e, 4L60e? Difference? Bellhousing difference? HELP!
- tranny mount?
- low gear set for th400
- A4<-->M6 Upper Consoles Interchangable?
- 3rd gear slips...help....
- List of Bolts needed for a 4L60E install?
- Trans. temps.
- help me settle the cooler debate Plus trans update
- best stall for Corvette
- Gearvendors overdrive unit
- servo vs. shift kit
- Couple videos of FLT Lvl 4/PT4400
- Broke another 4L65E input DRUM (pics)
- converter for ms4 cam?
- PT4400=ST3500 in normal driving
- 4l80 shift kit
- aeration in trans fluid
- wheres john at fuddle?
- how bad a burnouts for transmission's
- should I change out the tranny oil...
- Some questions about a stock 4L60E and a D1SC
- Trans cooler and FTRA
- TC lockup question
- 4l80 retorfit in 90 Burb
- wtf did I do???
- clutches burn
- need help
- Performabuilt Level 1 & 150 shot
- 4l80e rebuild - How much power is yours taking like its there job? What upgrades?
- Small screen important?
- 6l80e
- 4L80 right from the start??
- 4L60E cores
- 4L60E transmission & radio
- No third or fourth. 4l60e
- Torque Converter Sugestions
- got a new level 3 race 4l60e!!!!!!
- Going bigger??
- Is it okay to buy a used converter
- New to converters - need help
- Which LS Series OEM Flexplate has a Dual Bolt Pattern for TH350 Install?
- Question on 4l60E
- another th350 ?
- th400 and 5.3L
- 2-3shift revlimiter stall before shifting???? solenoid???
- Lock-up with 4L60E full manual valve body
- seating the converter
- What converter?
- Anyone ever heard of this brand?
- another TH350 question
- 4l60e or 4l65e ???
- Yank SS vs PT series
- What 4l60e rebuild kit???
- What's actually "beefed up" to your TH400?
- $3,000 + Toy Shop= No car. Help Anyone?
- Stall Jerk
- Shift problem at w.o.t
- Pwm ?
- Advice on converter choice (Yank SS3200 vs 3600)
- 1996 4L80E question
