View Full Version : Automatic Transmission
- Aftermarket shifter (200 4R)?
- tci sfi flexplate
- PAN: B&M or Hughes?
- New Tranny For A LS1 F-Body.
- Who makes the best converter for a th400?
- shift points after 3200 stall??
- Transmission shop in Ohio or close
- what is wrong with converter
- a couple of questions about my stall
- What are sings of a transmittion going bad?
- Conveter = tune?
- removal and installing converters
- TC... if you had to choose...
- shift harshness from idle to D or R?
- Torque Management
- 4l80e speed sensor help
- 700R not shifting
- got a 4L80E for the Z
- M6 to T4- how much rwhp loss?
- Sponsor? TH350 tailshaft for LS1 Speedo
- rebuild
- what should i ask for in a rebuild
- TC Failing? What now?
- Need some help and info.
- B&M Hi-Tek Transmission cooler
- Who has a stall with all around race/street tires instead of drag radials?
- rebuild
- TH350...what shifter to use?
- Why swap to an M6?
- Why does car bog so bad on track?
- Slack In The Drive Line???
- anyone using a coan th400
- cold weather slipping?
- Anybody running a Powerglide?
- Question on 3200 stall
- 4L60E Vent
- Tranny Rebuild???
- TC.. do I have a problem??
- is 4400 too much?
- Anybody found an alternative to the crappy TransGo vacuum mod. line?
- please help 9.5 ,10.5, 245 mm?
- removing transmission??
- Transmission Seals
- What to do when no OD on a 4L60E?
- anyone ever use AUTO-RX in thier trans
- Finally done it, the rossler is almost dead
- Possible TQ Lock-up Issue
- Will A New Valve Body Fix A 4l60e Converter Slip, P1870??
- Rebuilding 4l60e
- Cost of 4l60E upgrades to hold.......?
- Best stall for 408?
- Tranny gurus, request opinion!
- 4l80e questions
- 2 overdrives?
- What brand TC?
- 96 Z28 tranny stick keeps coming out?
- *Update on Vibrating Transmission*
- 200-4r Vs TH400
- Overfill...
- I want to get a shift kit???
- hitting the rev limiter on the 3-4 shift
- Transmission shifting question?? please
- NE1 running a 4L80E with Transbrake?
- tci deep trans pan , what filter
- Too Much for a 4L60E?
- th400 converter choice for high hp
- Stuck trans dipstick
- Restall Delima
- converter
- Converter welded to input shaft
- 59k on the trans. wanting to change trans oil
- Problem i think! transmission treatment in oil>??
- 6l80e available for our fbodies?
- truck tranny....
- TH400 swap price
- Who has QTP or Kooks 1 7/8 headers? Do you have to pull a header to drop the A4?
- Very rough 1-2 shift, no DCTs, need help!
- any th400 guys with aftermarket shifters
- Dacco converters...anyone use them?
- What AfterMarket Shifter (post pics)
- ATF fuel and filter change
- shift points 700r4
- shift selonoid
- Stall Converter
- 4l60e...2-3 won't shift
- Yank / Fuddle comparison
- My Car sucks in 4th---Please Help
- Shift Kit???????????
- 4L60E Question
- Got a trans problem! Need advice quick
- hey guys i am a die hard manual guy but i have a torque coverter question
- Speedometer With Th400...
- Transmedic?
- B&M Hammer shifter
- 4L80E...3.23 gears...roll races....whats the best converter???
- Converter and Shift Kit Conversion
- 97 t/a auto questions.
- Transmission wont go into gear
- TH400 Guys
- Another TQ converter thread
- Questions on my converter install???
- will this convertor work
- Fuddle users inside please!
- tci or vigilante
- What converter for a daily driven street Z
- How to put MBA knob on auto??
- Parts Needed For T56 To Th400 Swap!
- Any 4L80E builders
- How much HP can a stock 4l60e handle?
- A4 fluid change - I might have broken something....
- sonnax pinless accumulator
- Quick Shifter Question
- trans go kit w/billet servo ok?
- Fuddle 3000stall, good converter!!
- Fuddle TC.......
- What stall for nx???
- ROCK, FLT, or Rossler...
- How big should I go/what STR?
- Finally Done T56 To Th400 Swap!!!
- After your TC install did you tune your car
- need help guys!!! went to drive to work this morning and no gears!
- th350/400 OD units??
- What tranny fluid
- Any online guides to changing the fluid ???
- who can sell me a basic rebuild kit with new 3-4 clutches
- Help Plz!@!!
- Trans Tuning
- M6 to TH400 Conversion
- Help !!!
- What exactly is a stall used for??
- 4L60 to 6L80 swap
- How long have you had your torque converter?
- what does str stand for?
- Quick Q..
- Where To Order Trans Kits.
- Anyone using Vig converters anymore?
- ford atx dual output torque converter
- 11 sec 700r4?
- So I'm getting a TC, a question about fluid
- 200r4
- new project
- Shop Recommendations
- bad torque convertor.
- Changing Trans Fluid
- trade shift kitted A4 for M6
- how much fluid in a 4l60E?
- 4400 stall only brake stalls to 2200
- car in park but roles?
- M6 to Auto conversion...
- Which transmission do i have?
- Quicker 60fts - 700r4 or 350th?
- Yank ss4000
- help 4l60e won't shift into 3rd on nitros
- problem with second gear!! have you had this problem?
- FKN.. Allen Bolts
- Agood Shop
- Need a stall
- Help replacing my Yank ST3500...
- HELP!!!!! No 2nd Gear
- 4L60E question, dealing with differnce in years
- Daily Driven TH400 guys...
- whats your before and after w/ a stall??
- ARP Bolt Kits?
- car not moving
- how do you pull the seal out of the 4L60E?
- 4L60E overheating?
- WOT Vibration at High Speeds-Please Read
- Complications after a4 to m6 swap?
- YANK has GREAT new's for YOU (Please look)
- Converter Benefits
- str vs 60'
- str vs 60'
- 02 z28 auto to man
- best 3200???
- cost for rebuild..
- 4000 stall to big with these mods?
- vig. 3200 restall
- your opinion about stalls..
- O/D band to clutches
- Need help with cooling lines...
- New Poly Trans. Mount--Amazing Difference!
- Ls1 manual or auto does it matter?
- Annoying problem
- A Little Help On This...yank Ss3600 Torq Converter
- Noticeable difference between SS3600 and SS3800?
- Trans Cooler Question
- variable pitch torque converters
- Yank Ss3600 Converter For My Vette
- lock up clutch??? for a stall
- how much did they charge you??
- Slipping and Overdrive
- torque spec for torque converter bolts?
- I need a tranny
- Differences between a th400 and a th350
- 4l60e w/ trans brake.
- What sets Maximum shift speed (RPM) ? (4LXX-E)
- Need help fluid pouring out overflow tube!!!!
- Mysterious torque management
- Drive Line Slack??
- shift kit questions
- Stress on tranny?
- TCI Flexplate owners inside please!!!
- Removing Tranny w/std jack
- Torque Converter Install
- weird noise
- lockup issue
- wirin up a A4 to a M6 factory harness ...inside
- th400- car setups?
- need drag radials?
- Rock-On Shipment
- ls1 2wd convered to 4x4
- tried the search got nothing...What is the stock str
- Converter bolt question...
- P1870 what should I do? Please help
- WOT Shifting into OD with a 4L60 - Why not!
- Converter Q:
- Drive Shaft Length for TH400 Short Tale
- Stall + Supension?
- Tranny install problems .. !
- Stall Break in
- Converter lock up/dyno???
- need help
- Someone near Lansing, MI or south end of MI to install stall?
- stalled guys espically with 3800!!
- After TC install where to set shift points?
- tranny problems
- FLP tranny problems again...another mystery..try figuring this crap out
- Conveter
- Just sent out my money order to Fuddle
- Guys running th400
- YANK has new LOW pricing for LS1TECH members
- which Brand of torque converter
- 93 auto 6 cylinder
- What converter?
- Experiences on upgraded stall w/street tires?
- stage 3 speed inc yankpt4k problems :(
- converter?
- Front Pump #Q's
- After Reading Draco911's Poll
- When is your A4 about to die?
- Another 4L60E Problem
- LT1 and LS1 4l60E Same?
- rebuild kit for 4l60e ???
- how long will my trans last
- TC cleaning before new tranny
- Drive Shaft Yoke
- trans temp gauge
- What is the lowest 60ft you cut with any size converter???
- Manual Valve Body for 4l60-e
- Last Day For 15% Off All FLT Transmissions
