PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 [99] 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. will my trany handle it?
  2. Rebulit 4l60 × CAM swap,, Which first??
  3. V8 vs. V6 4L60E?
  4. 700r4 vs 4L60-E for mock-up
  5. Installed: Performabuilt lvl 2 4L60E
  6. How big is my stall? Vig 3600???
  7. what to do with my old tranny
  8. Help Taking Off 4l60e Help!!
  9. 4l60e, 4l80e, or other?
  10. Trans guys help me out.
  11. Tips on installing my PI stall converter?
  12. My 4L80E Swap with pics
  13. Trans Guru's Inside!
  14. Slipping at all changes but not in gear
  15. Transgo Shift Kit Installed No 1st Gear Now
  16. Need a part #
  17. Doing a stall....tune?
  18. stock tranny
  19. Any tips for lowering tranny temp
  20. Commonly Asked Stall & Transmission Related Questions
  21. hole shoot convertor
  22. Installing SFI approved flex plate shield.. Anyone?
  23. Torque converter tuning question
  24. Trans was just rebuilt and now a few problems
  25. SS3600 vs PI3200 driveability results
  26. transmission coolers
  27. Heads and Cam without an upgraded Torque Converter
  28. TH400 Lokar dipstick tube?
  29. 4L60E-HD2 vs. 4L60E-3 (difference) ??
  30. New 4L60E playing up after instaled - Help Please
  31. Performabuilt Stage II Trans Installed
  32. tranny tuning question
  33. Bucking around 45-50mph when off the gas
  34. m6 to auto swap....
  35. A4 shifter?
  36. trans. shop wants to do all this for 1180, good deal?
  37. Vig 3600 or 3200? and which gears 3.23's or 3.73's?
  38. question about driving with a converter on the street
  39. soundclip inside....does stall seem right?
  40. A4 with 3.42 gears vs 3.73 gears
  41. What stall for TH350?
  42. late trans shift
  43. Clutch pack questions
  44. a little scoring is on my pump, still usable? pics
  45. TH400 in 95 Z
  46. looking for clarification. loosing 3/4 - 4l60e
  47. Rebuilt Trans. Question.
  48. Thinking about doing a stall....
  49. I have a "Shutter" in Reverse(need help)
  50. Swapin 4l80e into M6 car shifter help
  51. 4L60E doesn't shift into 2nd!
  52. 4L60E disassembly
  53. can i keep the 93 tranny when switching to a 94 pcm?
  54. What size stall?
  55. TH400 with TCI Flexplate...SPACER???
  56. Need a new 1-2 solenoid. What else is wrong?
  57. Suggestion for troubleshooting - Auto Trans
  58. 2-3 shift is delayed under full throttle
  59. My trans worth anything?
  60. Metal shavings in transmission pan
  61. 3600 or 4000 - now with poll feature
  62. tranny wont shift please help
  63. Th400 Driveshaft question???
  64. 4L80E wiring diagram
  65. stupid ? about stalls
  66. Is this converter seated? (pics)
  67. Edge Racing "street edge" converter
  68. M6 to Th350 questions
  69. Something odd (TCC issue?)
  70. th400 conversion center console
  71. et's are slower after mods...why?
  72. trans cooler lines leaking... any thoughts?
  73. I have had it with my tranny builder - anyone know of a good th400 rebuild manual
  74. 4l60E issues
  75. any way to find out gear ratio?
  76. racing on the street with a converter
  77. Which filter for fluid change?
  78. major 4l60e problem HELP!!
  79. LOL! 4L60E tailshaft housing is a piece!
  80. Manually shift or leave in drive?
  81. Transmission Problem..Posible 3-4 Shift Solenoid??
  82. What size stall for an ls1
  83. Billet or Corvette Servo.... really worth it?
  84. how much will a stall help
  85. Tranny help
  86. Rebuilding my transmission :)
  87. C5 Converter In A 02ss
  88. Yank Can u help???
  89. too much reading
  90. Tranny mount, Can i install?????
  91. Help Tranny Gurus Please
  92. I Need Some Troubleshooting
  93. Tranny wont engine brake
  94. tranny problems help!!
  95. transmission shifts into P/R/N/D/321 but doesnt move
  96. 4l60e Help Please
  97. Anyone ever heard of....
  98. fluid
  99. Pics of your shift kits installed
  100. Jasper Transmissions SUCK!!!!!
  101. TH350 Overhaul & Shift Kit
  102. 6 speed to auto swap??
  103. TH front pump
  104. Toy Shop in Pomona. Is it worth it?
  105. Do I have a stall?
  106. whats the difference between ......
  107. question about the sticker on the yank converter
  108. Broken bolt on Tranny support.
  109. YANKs Hot June converter Specials are here!
  110. LS1/TH350 combo flywheel needed
  111. trans cooler install questions
  112. Shift kit is here.
  113. how do you remove this
  114. Transmission Sale Today! Level 2 $50 Off And 24000 Cooler
  115. Yank VS ???
  116. Help me pick the right torque converter!!!
  117. Performabuilt Lv.2 Installed..... Finally!
  118. Switching from a Yank SS4000 to a Yank SS3800 = Power Loss?
  119. Common Mistakes with TransGo Jr or regular shift kit installs?
  120. "Torque management" should I cut it off or reduce it?
  121. shift kit? which one?
  122. Torque Specs on new Flexplate
  123. will a 95 Impala SS 4L60E work in LS1
  124. East CoasT Trans Builder?
  125. tci conveter missing bolt and causing vibrations
  126. Trans ???
  127. shift kit a good idea??
  128. Powerglide ?
  129. Blowing Tranny fluid out coolant lines at WOT only, TH350
  130. Looking for updates from peeps w/TCI's.
  131. FUBAR'd my 95 Silverado 4l60e 4l80 upgrade and 4l60e ??questions???
  132. Help with tranny problems, lost 3 and 4
  133. what is the stock stall speed on an a4 z28?
  134. 3-4 shift at 6500+ rpm - What can go wrong?
  135. 4L60E installing parts list
  136. TCI super street fighter
  137. LS2 GTO Guys, Which Converter?
  138. Trans Question!!??
  139. half a quart low
  140. 4l60 e
  141. Do I need to lower shiftpoints
  142. converter install
  143. Tranny Capacity Question
  144. how to check what gears you have.
  145. TCI-built Street fighter TH350, worth the $$$??
  146. physical differences- 700r4/4l60e
  147. Car will not turn over after transmission swap (Help!)
  148. Tansgo HD-2 kit installation instructions
  149. Transmission Replacement parts
  150. 4L60E bouncing off rev limiter WOT 2-3 shift?
  151. New trans rebuild - No 3rd or 4th gear!
  152. Need help quick! TCI 3500 to Yank 4000
  153. Anyone using a Hughes flexplate with their LS1/4l60e combo?
  154. Stock Z with a TH 400!??
  155. Wanted opinions on whether or not a tranny can get this hot
  156. Throwing it into Reverse
  157. engine surge after lock up
  158. trans cooler
  159. Swapping in a 350
  160. b and m
  161. convertor lockup??? or 02???
  162. Can a stall hurt you top end and mph?
  163. Tranny problems, think I finally killed it
  164. TH400 swap help
  165. 4L80E fittings to Tranny cooler Questions
  166. Firewall Dipsticks????
  167. Stall Install
  168. What tools will I need??
  169. will I need to raise my stock shiftpoints with this setup?
  170. Shift kit on the way!!!
  171. neutral safety switch
  172. auto question
  173. Pic of the converter hub crack
  174. stall suggestions?
  175. tci controler info
  176. Will this hurt my Transmission?
  177. Edge stall converter's?
  178. Yank Please help
  179. Shift Kit?????????
  180. Th350 Vaccuuuuuum Modulator Question
  181. How do I lockup my converter for dyno testing???
  182. Installing a trans cooler
  183. Performabuilt th400 Questions
  184. Tranny fluid leaking
  185. **more Problems**
  186. Harlan 2-Step
  187. V6 4L60E as good as a V8 4L60E
  188. Nitrous may be blowing through the converter - which route to go now???
  189. VSS Changes for the M6 to TH400?
  190. Stripped bolt in Aux Valve body, HELP!
  191. Any LT1 guys runing the 4l80
  192. Atf Changing stall Speed?
  193. >>>Any good Socal Trans. shops around?<<<
  194. How hard can it be to rebuild a th350?
  195. Is 4th gear usable WOT 4L60e?
  196. Royal purple tranny fluid
  197. mount
  198. Tuning for stall conveter, info needed!
  199. Is this 3/4 clutch right?
  200. TH400 Question
  201. 4L60E - Time to change fluid! How?
  202. Yank SS3600 on the way!!! What should I expect??
  203. just got a hayden cooler from yank
  204. Wiring harness question
  205. Overfilled causing slippage?
  206. no second gear?
  207. 4L80 w/o electronics parts list for 98 F-body
  208. necessary to break in new tranny??
  209. TH350 cooler lines??
  210. Pictures of aftermarket shifters????
  211. car wont go into park....
  212. Saturday.
  213. Where are you guys dope mounting your tranny coolers??
  214. 95 trans am i need help with my lt1
  215. What 4l80E performance parts would you recommend
  216. 4L80E performance rebuild documnetation (Photos)
  217. Computer Tuned or Tranny Installed Shift Kit
  218. What stall with a GM 847??
  219. how to tune my new stall?
  220. 4L60E Manual Valvebody. Who sells it? Need help
  221. tractor fluid results
  222. Please Help 3600 Stall Do I Need To Do Anything Else Besides Put It On
  223. First time stalled.
  224. Tranny paint?
  225. Help Help Help
  226. TCI Troubles
  227. problem 4l60e
  228. 4L80e information needed
  229. pics after trans willnot shift into 3rd
  230. 4L80E performance parts
  231. Trans Temp High?
  232. question on torque converter fluid and trans fluid
  233. stall ?
  234. M6 2 A3 shifter????
  235. 1995 Z28 A4 wont shift out of 1st at wot
  236. 4L60E - Manual Valve Body, what does it do?
  237. hard to install shift kit?
  238. transmision going bad?
  239. Trans question...please help.
  240. speedo signal issue
  241. biggest trans cooler
  242. Diif between V6 and V8 4l60e
  243. Stall converter question?
  244. Buying a used converter? Good Idea?
  245. 4L80e swap underway, Final questions-those who did it chime in!
  246. Who carries a 4L80 converter for F-bodies
  247. trade a4 for m6
  248. 4L80E flexplate & 4l60e converter
  249. ~~How to replace 2-3 Solenoid??~~
  250. need help
