PDA
View Full Version : Automatic Transmission
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. LM7 5.3 with 700R4 - can't get the transmission to shift right
  2. Help with 4l60e
  3. 4L80 Lost 4th, 3rd, and Reverse. Can I fix it ?
  4. Biizzare question presure issue
  5. 4L60E 2-3 flare after transgo shift kit
  6. CVB oversize AFL valve install
  7. printable 4L60e separator plate labled
  8. Accidently ordered 5/16" checkballs for 4l60e
  9. 1993 4l80e 4l80e Automatic steel Transmission Pan.
  10. Removing bonded gasket from valve body/trans
  11. 4l60E Separator Plate Holes
  12. 4l60e shift kit install - boost valve stuck?
  13. 4l60 to a earlier 6.0 with long crankshaft
  14. First 4L60E build 2-3 clunk
  15. Going in OD under power
  16. Trans and rear end for cam only nitrous car
  17. Sonnax HD overrun hub
  18. 4L60 Inspect and possible rebuild
  19. Thanks, Frank...
  20. 2/4 servo
  21. 4l60e proper rebuild for $1100
  22. My 10L80/10L90/10R80 Stand-Alone Transmission Controller
  23. 4L60E getting very hot
  24. 4x4 service light came on, went into neutral and lost all gears at a stop sign
  25. Hard 1-2 shift on LS swap, Need help
  26. First time 4L60e transmission build
  27. Transmission band tabs
  28. 4l60e hd2 kit
  29. 4l80e leaking, question about output shaft seal
  30. 4L60e HELP
  31. 2nd gear 4L60e doesn’t engage until I rev match it
  32. 4L60E TCC Lock Solenoid Confusion
  33. Line pressure drops with increased throttle
  34. 4l60e rebuild, no drive but have reverse, manual 1st and 2nd.
  35. 4l60e locked up
  36. 4l60E for stock 5.3 LM7 or 6.0 LQ9?
  37. 4L60/700R4 TCC Lockup in 3rd
  38. trans not shifting
  39. Full Trans Flush
  40. Will a 4.3 V6 4L60 work with 02 ls
  41. TH400 won't engage since Swap
  42. Cant get converter to seat
  43. Questions regarding converters
  44. SOLVED: 4L80E Hard Shifting in "D" but not in "3"
  45. TH400 question: slow movement when cold?
  46. LS# Connect and Cruise Trans Bulkhead Connector Issue
  47. Issues getting a 4L65e back together
  48. Questions after rebuild, line pressure, delayed first gear engage from stop
  49. 4l60E manual shift
  50. 4L60E 1st-2nd Hard Shift Until Hot
  51. 4L60E plug kit
  52. First 4l60e rubuild
  53. LT1 vs 3800 V6 Trans
  54. 4L80 Clutch Setup
  55. Bellhousing stuck to block, suggestions?
  56. Th350 hydraulic schematics
  57. Rebuild kit for 4l65e
  58. New Here! P1860 Popping Up On Start
  59. i’m new to this and idk what to do
  60. 4l60e or 80e?
  61. 4L85E Supermatic
  62. 4L80 gear whine in park
  63. 1993 camaro 2005 4l60e swap
  64. shifting but not shifting 4L80e basket case
  65. Interesting idea transmission
  66. Vorteciroc tech thread (sticky hopefull)
  67. 4l80e input-shaft to forward clutch drum wear
  68. 4l80e swapped stepside Silverado
  69. 4l60e 3-4 air check cross leak
  70. 4l60e not engaging gears
  71. Won’t hold 1st gear in manual first
  72. Transplanted '05 LQ4 5.3 in '96 Silverado. Trans problems.
  73. 4l60e intermittent slip in 1st
  74. 2008 4l60e 4wd to 2wd using older 2wd case
  75. Stall converter choice
  76. No 1/2 4L60E
  77. 4L60E pump in a 700R4
  78. What can i do to this 4L80E?
  79. Transbrake on daily driver
  80. Th400 no front endplay
  81. Gauging interest in mechanical extension housings for 4L60/4L80/6L80
  82. 5/16 inch hex plug in Jake’s D3 kit. Where does it go?
  83. 1998 4l60e 4wd vs 2002 4l60e 4wd
  84. Question On Viability of using HPTuners over Existing LS1Edit tune
  85. 4l60e NO first gear, takes off in third
  86. 6L80e behind a LS3 - shifting into 6th
  87. Circle D triple disc lockup settings?
  88. 4l60e no ISS issues
  89. 4l60e to 4l80e segment swap no shifting
  90. 4l60e problems please help!
  91. Selecting a converter for towing/boost - technical discussion
  92. Which flexplate do I need?
  93. 4L60E no shift freshly rebuilt
  94. help 4l80e daily transbrake
  95. 2008 Silverado 4l60e 4x4 swap to 4l65?
  96. Transmission adaptives (TAP cells)
  97. TH400 direct clutch issues.
  98. 4l60e rebuild questions
  99. Just to Clarify on Fluids
  100. Feel kinda dumb
  101. Ls my sonoma
  102. Hard shifts and high pressures on new 4L80e
  103. 4L60e low/reverse clutch
  104. 4l60e case replacement
  105. TC/lockup
  106. Jake's 4L80e D3
  107. 4L80E starts in 2nd gear, 1st gear like transbrake is on
  108. Transmission issues
  109. 4l80e Cracked Housing?
  110. 4l80e not going into OD
  111. 53. with 4l65E driving through brakes.
  112. 4x4 4l60e weird slip in 1st gear
  113. Advice or Suggestions On Installing TransGo HD2 4L80e
  114. LS1 and 4L60e creep speed
  115. TH350C Lockup function
  116. Bolt together TC upgrade?
  117. Wiring electronic sport shifter to 4L60e ?
  118. 4l60e no reverse
  119. 4th Gen 4L60E Cooler Port Hose Ends
  120. New engine with bad transmission news 6l80
  121. Best rear gear to run with 4l80e
  122. The Transmission shop?
  123. 4l80 pump to case bolt threads gave up on me
  124. Franks 4L60 stock build thread?
  125. 4L60E Lubrication circuits
  126. Tcc circuit test rig
  127. 700R4, question
  128. 4l80e Press On Reluctor
  129. 2004 Silverado 1500 4x4 TCC Wiring
  130. 94 gmc sierra..
  131. I sold a 4L80E but the buyer says it won't go in reverse.
  132. 4L60e Output Shaft End Play
  133. Tapping 4L80E to measure converter charge pressure when locked?
  134. 4l80e hd2 to internal dual feed
  135. Ok my turn to ask something 4l80e
  136. 4l60e front pump failer with 04 lq4 in 98 camaro
  137. 60E Using Manual D3 A Lot - Any Excessive Wear??
  138. 4l60e weak swap to 80e
  139. Trans Am 1994 4l60e stuck in first Gear
  140. 4l60e to replace slipping 4l65e
  141. Rebuilt 4l70 stuck in 3rd. Possible bad 2-3 solenoid?
  142. 1994 4l60e valve body mods?
  143. GM must face big class action over faulty transmissions
  144. No forward gears unless in D3 with harness unplugged
  145. 4L60:Driving with No TCC Lockup
  146. Torque converter cover 4L60 E , can’t find a fit
  147. Sonnax AS1-01K TV Cable Corrector Kit
  148. Rebuilt 4l60e and the whole vehicle died after 200 miles
  149. 4l60e to 4l80e Reverse lights in park
  150. Mystery lost all gears & reverse 4L60E
  151. tcc problems again
  152. Wear on one side of clutch sets ?
  153. Shop says computer not telling 4l60e to lockup in 3rd & 4th
  154. Vacumn source
  155. 4L80 Jaguar 1st and R noise/grind issue
  156. a little gratitude
  157. 1998 4L60e on a 6.0 ls
  158. Franks Custom Transmission
  159. Transmission Guage
  160. Hate to see this forum dying away :(
  161. Torque Converter Break In
  162. 4L60/700R4 Mystery Core
  163. 4l80 swap
  164. Tcc locks then unlocks
  165. Yank rebuild??
  166. 95 Trans Am Reading the Transmission Dipstick/Transmission Slip
  167. 95 Trans Am Torque Converter Cover
  168. Yank 3600 Torque Converter
  169. How to and how i build a 4l60e step by step thread , will take time
  170. 4l80e won’t shift into overdrive
  171. 4l60e Help
  172. 4l60 street trans
  173. 4l60 swap
  174. Vane size
  175. Tranny swap question
  176. U-joint question
  177. P0740 Code
  178. 4l60e Pump Diagnosis - What happened to my pump?
  179. Torque converter help
  180. Sonnax HD 2-3 Shift Valve - 4L60E
  181. Glide or 400? No prep
  182. TG pump rings -when do you have to use them?
  183. Pump or VB - what's that noise?
  184. 4l80e swap using Borg 4481 tfcase
  185. 4l60e electrical problems
  186. P0758 Trouble
  187. 4L60E Low Reverse setup?
  188. 4l80e year preference
  189. Need some true LS boys ta help on this one.
  190. Compatibility Questions - 4L60E - TransGo & Sonnax Parts
  191. Non toxic parts washer solvent?
  192. 4l80e differences by year??
  193. Swap years for a 2011 silverado 6l80e transmission ?
  194. I give up, 4L80 build, questions
  195. 10 speed in our 4th gen’s
  196. 4l60e trasfer case to pasenger side?
  197. 4l60e shift problems
  198. 4L60e question
  199. Question about Sonnax sleeve converter regulator valve
  200. 4l60e with Gm np241C vs Jeep np231j
  201. Stator Shaft or TQ Converter?
  202. catastrophic failure of 4l60e tail housing?
  203. Synthetic ATF
  204. Riddle me this (4l60 question)
  205. My 4L60e build List, will you check me?
  206. 4L60 - 4L80 P1860 Code No Lockup
  207. LQ4/4l60e swap P0785
  208. 4l80e 300,000km, self rebuild questions
  209. Dipstick level
  210. Transmission Rebuild
  211. Rattle, no movement, leak
  212. 1999 Trans Am Jerking into drive and reverse
  213. Boost Valve replacement Cost on 4L60E
  214. Broken Superior 4L60E 3rd Auumulator Switch - K0136?
  215. Trans decision
  216. Reaction shaft
  217. 4-L60E, won't shift when in low range, NP 241 c transfer case rear speed sensor outpu
  218. 4L60E lost 4th.
  219. Converter recommendations and tips for Blazer LS swap
  220. 4L60E, can it be unpluged to perfrom a wire test?
  221. For those that have made the switch to an Aluminum Pan 4L60e what is the go to?
  222. C-5 filter
  223. Do you feel the Downshifts on your 4L60E ?
  224. Vac Check
  225. 4l60e No Downshift in LS Swap
  226. A Tale of Two Converters (Possibly Three)
  227. 4l60e all neutrals. My fault?
  228. 4l60e no gasket surprise
  229. 4l80e direct clutch freeplay test
  230. 04 Silverado 1500: No 1st or 4th after warm up
  231. 4L80E Lockup in Second Gear
  232. Offer on the table
  233. Coupler Block
  234. 1995 4l60e line pressures
  235. Flywheel wedged to JW Bell
  236. 4L60 Leak - I made it worse
  237. 4L60e troubles
  238. GPZ105 clutch thickness variation problem?
  239. Final Racing Season
  240. GM246 Transfer case upgraydd
  241. 4l80e Torque Management
  242. GM Transmissions Thru The Years
  243. 4 X 4 to 2 WD 4L60e
  244. 4L70E low mile rebuild 3-4 slipping issues
  245. Transmission ID help
  246. Trans Cooler
  247. 4L60E Fam. Alternative HE Frictions
  248. 700R4 no shift causes
  249. Rattling sound during coasting to a stop
  250. 700R4 rear shaft play
