View Full Version : Automatic Transmission
- 2000 4L60e 1-2-2-1 Shift pattern with no codes after rebuild
- 4l60e lockup for 3rd gear or not?
- Stall in stock 4L60e
- Why 4L80e sprag and intermediate clutch pack failure
- Overdrive in auto 4l60
- Too much stall for a street 4L60E ?
- Trans Rebuild Opinion
- Help Go shift 4l65e won't shift
- 4l80 overheating…maybe
- Improved Racing 6L80 thermostat install
- 4L80E Forward Drum Question
- Help: 3/4 clearance is off and what hole sizes for separator plate?
- 5.3L (LM7) with 4L60E transmission
- 4L80e longer flex plate bolts
- 4L60 Advice P1870
- shifting to early 4l60e
- Rebuild kit 4l60e 2004 5 pinion
- 4L80E Low Pressure in 2nd/3rd, Normal pressure in 1st & Rev
- Temp Sensor ideal location, 4L65e
- 4l80e help pls!
- ‘00 Z28 4l60e feels like it’s towing an anchor (intermittent)
- 4L80e swap problem
- 4l80e VB opinion please
- 4L60-E trans , after rebuilding my tranys I got no forward gears only rever
- The infamous I6 Trailblazer Converter & other opinions needed
- High HP (1500hp+) 4L80e Parts Selection
- 4L60e no reverse after being in drive
- Will the EFI fuel disconnect tube work on the trans...
- How to upgrade turbo 400
- 1996 blazer 4l60e with a 2003 lm7
- TBSS 4L80 or 4L70?
- Goddammit - another 4l60 build
- Another leaking 4L60E
- 2010 Texas edition 5.3
- Blocking 3-2 valves
- 4L60e mostly stock but sturdy build
- FLT Transmissions still in business?
- 4l80e rebuild kit recommendation
- Newbie here from South Africa
- 4l60e Input Drum Hole Welded
- Which 4L60E 1-2 accumulator piston...
- 47391 cooler & knockoffs--ANYBODY use this cooler?
- 4L60E shift cable retainer/grommet
- 4l60e In 2002 camaro z28
- 4l60e stange issue
- 4l80 torque converter
- 4L80E build check
- 4l60e. 4wd need trans info
- 4L60E Tuning Benefits?
- 4l60E overdrive issues
- Those with Holley, converter question
- How often is pressure over 200psi? 250psi?
- 4spd Auto 1996 lt1 (REBUILDING TRANSMISSION QUESTION)
- TH400 to LY6
- 4l60e questions
- quick question about 4l60e pump diagnosis
- Valve body repair HD 2-3 shift valve
- AN fittings for radiator transmission cooler lines
- Has anybody used the Superior Pressure Riser?
- 4l60e case bushing failure...
- 4L60E Top Bellhousing Bolts Wont Line Up
- WITH a 4l60e assembled but without bellhousing...
- 4l60e
- Transmission Teardown Table
- 4L80E Valve body ID
- 4l60e 9cfd to 6chd swap
- Buying used transmission
- 4l60e 2nd and ov drive gone.
- Stand alone transmission controller or factory PCM?
- Is there a trans PSI gauge, for in-vehicle mounting?
- First 4L80e hop-up?
- 5.3 4l60 to 6.0
- 4L80e build thread, why am I doing this
- Slip yoke length 4L80e
- 4l65e Internal neutral switch
- 4l80e early pump mods already done?
- Brand New Circle D converter grinding under load
- Stall recommendation?
- 4l60e temps keep rising
- Powerglide recommendations
- 4l65e swap slipping gears
- Triple Disk Lock-Up, Racing and HP
- Trans pressures vs cooler burst pressures...
- Using tow/haul 2008+
- 4L60E Problems (slipping/not shifting)
- 4l80e rear cooler port size
- shifter advice
- 4l80e towing converter zero slip without tcc engaged
- Flywheel between lq4 and 4l80e
- S10 Lq4 swap converter choice
- 4l60e trans go shift kit ??
- M30 4l60 Problems
- 3700 RPM stall, only flashes up to 2500rpm.. what gives?
- 4l60e shift kit with tune?
- 8L90 or 10L90 ?
- Checking 4l60e line pressures
- Shifting Issue?
- Best Budget 4L80 Triple Disc 3000-3500rpm Converter?
- Strange Coincidence
- What size stall
- LS3 swap into Buick Roadmaster Wagon - 4L65E unable to select gears
- 4l80e input shaft
- Need a quick answer. Will this slip yoke work with my trans (4l80e)
- 4l80e dipstick issue
- plastic check ball in valve body
- 2003 hummer h2 6.0 torque converter shims
- Opinions on Hughes torque converters. ?
- 4l60e without 4th/OD
- Most durable HD 3/4 clutch pack (4l60e)
- 4l6** transmissions, hydraulic vs PWM control.
- Stock 4L80e/ LY6 LSA
- Can I put a (ISS) on a 2004 4L60e pump?
- Fresh rebuild 4l60e
- 4l80e reverse check ball with internal dual feed
- mixed thickness clutches...
- Chevrolet Performance 4L75E-R
- 4L60 Budget repair
- 4l80e making noise
- Funny Things heard about Trans. Building
- 4L80E Question
- Bought a truck with a rebuilt trans...
- 06 4.8l to a 08 4l80e
- Flex plate spacer on 2011 5.3 LMG out of a tahoe
- 383 SBC mated to 4L60e
- 4L80, keeps breaking input shafts, time to give up?
- Broken pump gear 4l80
- Powerglide to 6.0 problem
- Removing roll pin on 700r4 vb for the tv valve
- 2006 gto bell housing
- 4L60E does not move in D but does in 3
- The truth about beefing up the 4l60e
- Ls1 flexplate install
- Best 3-4 clutch clearance in Sonnax Smart Housing...
- 4l80e swap 1-2 shifts only
- 4L60E No 4th after shift kit and Valvebody Mods.
- Is this normal for input shaft?
- Mid plate converter in 5.3l
- 4l60e & the autobahn
- 4L60E No TCC and intermittent 4th gear
- LT F-Body 4L80E Swap Writeup?
- 4l60e input drum question.
- No 2nd on 3-2 Downshift but 2nd works fine?
- 4l60e 2nd accumulator
- What does the PCM need to see to lock torque converter
- 4l60e id
- Can a 4L65e be built to handle 650 crank hp?
- Looking to buy a 4l80 for my build any recommendations?
- 4L65E went boom!
- 4L80E Build
- 4l80e low profile pan
- Has anyone removed a Sonnax reinforcement sleeve to replace the input shaft on a '60e
- 4L60 Rebuild Reccomendations for Truck?
- 9.5 PTC Converter won't loosen up.
- Help with a 200R4
- Burnt overrun clutches, newly built 4L80E
- Tuning a 6L80E trans and converter recommendation
- 4l60e TCC apply issue
- Quick 700r4 question…..
- I’ll never use a 4 pinion planet again
- 4l80e extremely high line pressure in park
- 4l60e Interchange
- 9.5" non lockup vs 10" lockup in 4L80E street car
- V8 swap with 4l60 then a 4l80 swap later
- 4l60
- 4l60e no 1st or 4th
- Btr truck yeah 2500-3000 stall on btr stage 4 ls2 cam
- (curious inquiry) overheated 4l60e
- 4l60e no reverse
- 4l60 Wont shift at WOT
- Fluid
- Moroso 4l80e Deep pan - which filter
- 98 Camaro with 4l60e I think.
- help me decide what to do with my 4l80e
- 4l60e pump HELP needed, thanks
- 4L60e changing gears too soon. Long post.
- th400 -clicking?
- 4L80E Replacement Case?
- Built 60e no gears
- 97 Camaro shifter shaft seal
- Best driving street converter for LS3/TH400
- 5.3 LM7 with 200-4R
- ATF Cooler Lines
- 93 350tbi/4l60e
- Btr 3000 to 3200 stall converter
- Is a 03 4l60 same as 07 4l60
- High fluid level and slipping
- 6l80e no first, the rest is fine
- 4L60E 3-2 eliminated by GM on 2008+ years
- 4L60E Low Line Pressure
- Converter install issue TH400
- TCC Lock Up Issue
- 7 Stack clutch .076 steels
- Blind hole for accumulator pin 4L60E Family
- 4l80e won't shift for a few minutes after start up
- poor fitting sun tube to direct drum
- The ultimate pan drop upgrades(4L60e)
- Help with snap ring issue
- 4L80E short shifting
- Evaluate 4L60e case damage after rear planet failure
- Question on a 4l60e being paired with a 5.3l going into a 95 v6 f body
- 4l60e converter locking up in 3rd gear
- 4l80e p1810 p0706 no line pressure
- 4l80e driving me crazy!
- PNP 1999 Silverado
- To Peen or Not to Peen... that is the question.
- can you bolt ls style 4l60e behind a gen 1 small block
- 02 WS6 / 4L60E Shifting Problems
- Parts spacer for ls swap 4l60E
- 4L60e Line pressure by gears
- Built 4L60E trans fluid question???
- Stall question
- 4l65E sounds like a misquit0...
- T56 to 4l80 tcc swap questions
- Powerglide vs Th400 6.0 Turbo LS Foxbody
- 2018 Camaro auto trans
- 4l60e wont move in any gear when it gets warm
- 4l60e 8000rpm +
- Best switched power source for Pin "E" on 13 pin 4L40e connector
- 99 Camaro with 4L60e and suddenly not moving
- 2007 4l60e 13 to 10 Vane...
- 4l60e slipping while in lockup
- 4l60e pin adjustment
- PSA - 4L60E w/2-3 & reverse Shift problem & Teminator X max
- 2000 Pontiac Firebird. Parked up hill, torque lock.
- 98 4L60E transmissions
- 1996 4l60E interchange question
- 4L60E Linkage
- GM 9.5in 245mm impeller ID
- 6l80 harness plug different need help finding a pin out diagram
- 4l80e Noise After Fresh Build (With Video)
- 4l70E TBSS 2nd time losing 3-4 and soft lock-up.
- 4L60E Tranmission Rebuld
- Which shift kit? Or just boost and 2-3 valve and plate mods?
- 4l60e speed sensor not reading after rebuild
- 2001 C5 Auto Transmission slipping
- 3-2 downshift flare 4l60e
- 4L80E in work truck
- 4l60e reverse piston
- Will transmissions interchange
- Transmission won’t shift!!
- Whats wrong with my 4L80e :(
- tci converter?
- 4L60E 2-4 shift issues
- Mrvedit
- Vibration in 3rd gear
- Tbss stuck in 1st #YeaImNew been searching and searching
- 4l80e won't shift past second
- 4l60e slips in all gears
- Problems with Running a 4L80E at Full Line Pressure?
- Stall speed recommendation
