View Full Version : Automatic Transmission
- Got the TH400 today!
- trans brake in a th350
- trans"what the f!!!!"
- cooler size??
- flywheel bolts make leak?
- People with TC and headers, which first.......?
- Are all stalls created equally
- Effects of Converter on the Daily Drive
- tranny problem
- how is this torque converter???
- Advise: My tci 3,200 stall makes a wierd noise when it goes into O/D.
- Opinions on vig multi disc convters
- hesitation when starting off
- Converter Install Cost
- Diffrences between TCI 3500 and 3800??
- Question about pt4000
- no downshift before WOT? need to tune?
- A4 shifter hard to shift from park
- Th350 speedo question
- fine until 46xx rpms +
- install question
- New shift knob... $3.25
- Converter help, which one!!!
- Gear Vendors overdrive
- Converter causing trans slipping on 1-2 shift?
- will a 4L60E from 1994 trans am work in an LS1?
- trans leakings fluid
- 4l60e vacuum lines????
- Torque Converter Question.
- Manual vs. WOT downshifts?
- searched the forums but...
- YANK'S th400 install kit on SALE
- 4L70E is coming in 2006
- straight cut gears th400
- tuning question??? need help 2nd trans in 2 weeks
- new converter install but my tuning is wack!
- TCS converter
- nitrous and tranbrake
- mysterious tranny leak?
- Transmission slippage vs pressure evaluation
- What could cause vibration at 2,500+rpms after tranny/tc swap?
- Rossler Transmission
- Fun Converter
- Torque converter installation faq?
- ATTN: Yank....
- questions about manually locking converter
- Anybody used fuddleracing stall converters?
- HELP! 4L60E problems....
- Fuddle Racing
- Strange nois on decelleration when in low gear...
- fuddle stall ?
- can a vig handle spray??????
- simple TH400 question...
- need 4L60E help ASAP
- ss4000e
- 408ci and TH400 combo = 70mph @ 4000rpm. Can I safely drive at this high of an RPM?
- Noise at start up
- Will this help the tranny live?
- Tci Ssf 3500?
- Converter wont let it do the 2nd to 3rd shift?
- T-56 to TH400 Swap 1/4 mile time?
- Urgent - Need info, ordering new converter asap !
- Aftermarket Shifters ?
- 700R4/4L60 or 2004R in a 67 camaro?
- What do look for in a used stall converter.
- Change transmission fluid?
- Automatic Transmission Not Shifting
- p1870 code and now limp mode
- Trans acting weird after throttle body install
- info on a 4l60e
- Torn between SS3200 and SS3600
- Can this work ?
- Normal losses from A4 to TH400??
- Looking for Good Tranny Builder in So. Cal
- 4l60E Slip Yoke Dimensions
- What TC do you have/ What stall.
- FTP Trans Tuner...?
- 4l80E solid pinion bearing spacer
- Converter same for 80e and 60e?
- Thinking bout converting to A4...need help
- Converter Help
- No 2nd gear 4l60e
- Where to get speedo ring for T-350
- 4L60E (A4) tailshaft housing swap Q
- no shift 2nd to 3rd
- What MPH shifts for 342 gears with an automatic?
- Tranny noise
- Converter tuned?
- How many miles on your aftermarket converter?
- What happens when my stall gives up?
- A guys trying to sell me a 4200 TCI converter>>
- 3rd gear problem at the track
- Highest possible stall..
- converter 3000 to3600 gains
- Am I doing any damage?
- has this worked for anyone.
- Will a 99 Flexplate work with a th400 swap?
- need help po758 codes
- should i put a m6 into my car
- Who makes the best turbo 400 tranny
- Tranny temp?
- stall speeds?
- Rossler 4l60e
- Need help with a 4l60-E please
- Transmission
- Any LS1 F-cars using a 4L60e Trailblazer converter?
- c5 ptk project
- transgo kit
- TCI ssf 3500 tuning?
- My Trans Is Fixed!!! Updated to 4L65E
- converter time gain question
- TH 350 and a 98 flexplate?
- My New Rossler 1.96 PG
- Help me find a converter for my car
- Trans temp fitting on 4L60E?
- NE Jumpboxes, or just Vacuum for shifts on TH400???
- 1-2 Shift
- !WTF! Law guys in here. *Long but need advice.*
- TCI SSF 3500 users, MPH gains ??
- need a favor
- converter mounting question
- TCI Breakaway TC Clutch
- Driving in Regular D under 50mph, ok consistently?
- ft lbs of torque on a flex plate?
- Tuning for better stall gas mileage?
- 4L60 Brake safety cable removal
- Special CONVERTER offer from YANK
- Crossmember questions
- 2-3 shift problem, searched.. Unique?
- Adding Jumbo Servos to Transgo
- 4l80e man valve body?
- trans mount question i know i know
- TH350 Crossmember Pics
- Th400 help.
- TCI SF 3000 Impresssions (Long)
- 4L60E to TH400 swap kit
- Does anyone sell a TH400 conversion kit???
- Need a transmission
- Tranny problem i think.
- Anyone using Edge Racing Converters or Fuddle Racing Converters?
- shifter for 4l60 or 80
- trans mount
- How big of a Stall on stock transmission?
- TH 350 Help!
- Th-400
- Transmission to blame?
- 2004 GTO trans cooler line fittings
- How good are the SLP 4l60e's???
- What does Rossler do that FLP doesn't?
- Midwest racing 3600 stall 2.6 stator
- Need to know what stall to run
- blinker problem after converter swap
- 4000 stall ?
- Converter for car setup?
- SY3500 installed!! is something wrong?
- Place to get trans flushed
- Transmission mechanics in texas
- TH-400 "Automatic" ?s
- 4l60E
- high trans temps- getting frustrated
- 4L60E shifting
- break in period for stall converter?
- Just ordered TH400!
- 4l60E Wiring harness
- A4 better in 3rd?
- HPP3 and shifting
- LS1's love a high stall converter???
- Yank SS3600 questions
- tranny temp questions
- Advise: Need input on how everyone had there transgo kit set up?
- tranny help
- 3800 stall whats your trans temp?
- i need a converter for a good sized cam, that wont kill my n2o or wallet
- I am completely confused...
- YANK wants to know!!
- 4l60 return line
- Electric trans temp gauge?
- Is my 4L60E going bad?
- what B&M trans cooler to get?
- a few questions about a torque converter for my LS1
- which stall?
- will i kill my trans
- custom th400 cross member-pics
- Transmission Cooler Install Questions
- Transgo and a Crane Pwrtnr?
- Shift point RPM thresholds (obd 1)?
- What Stall W/ AFR 224/228/581/581
- speed inc 4l60e
- vacuum modulated or not?
- Century Racing Transmissions (Houston, TX) Rocks!
- Converter Install
- B&M Pro Stick install - pics
- Warranty question
- Klunk!!!!!! in third gear.HELP!!!
- Trans line pressure gauge - sender?
- Please Help!!!! tranny problem
- Rebuilding tranny, what should I use for assembly lube ?
- How streetable are the 4000+ converters?
- when you got a tune for the converter when does yours lock up?
- Trans Slippage ~ Need Some Help Please!!
- Are F-body and vette 4l60e TC's the same?
- 4L60E Vaccum Line?
- More mph help
- Is there a trans brake for a 4L60E or 4L80E?
- 4L60E or 4L80E? Which one?
- Tranny/Converter Problem, Please Help!
- hard 1-2 shifts
- Can A Torque Converter be Sexy?
- torque converter a bad idea?
- Bad converter or something else?
- Is an automatic tranny better than manual? Help please?
- Line pressure
- The shakedown on STR
- Confused. High stall and stock camshaft....
- Problems with Torque Converter Lockup??
- Need Some Advice
- Do I need a re-stall?
- Yank SS3600
- M6 to A4
- Best sixty foot acheived with a TCI SF3000 and SSF3500?
- Torque converter question. Is it possible....?
- Racing, Locked Or Unlocked???
- TCI vs. Yank 4400 results
- What #'s are u making w/ T-350 & Cam/Bolt-ons??
- A little torqued!!
- What kind of 4 speed Autos are out there?
- 1 pc or 2 pc case?
- 1-2 accumulator
- Verter guru's.....Inside!!!
- will I reget switching to an m6?
- Th400 Tailahaft/output shaft length
- I didn't think I could do it. Ratchet shifter in a a4.
- What size cam and converter are you running?
- TCI 3500 Killed my tranny
- Truck torque converter
- Tq Converter
- Torque Converter
- best trans for the money
- th350 vs th400
- MPH Specific Vibration??
- How Do I Make the Shift Occur Faster (4L65E)?
- pro rachet good idea for 4l60e
- N20 with the yank PT4400?
- 4l60e v8 to v6
- what diameter are stall converters
- new tci ssf3500 installed question
- Trans Problems
- no od
- VIgilante Convertor??
- converter decision?
