View Full Version : Automatic Transmission
- TCI Flexplate
- B&M tranny cooler installed what a great investment
- TCI SSF 3500 is in, results inside
- Launch problems with TCI Streetfighter?
- Any NA guys running vig 3600 multi disc
- What size are the converter bolts?
- Please help ...Stroker 406 and Th700r4's
- 4l80e ???
- Converter ?'s here
- 4L60 done right
- converter help
- new to a4
- How to get madman dipstick in T400
- Noise after HPP shift firmness install on 4L60E ???!!!
- tranny cooler
- NO GO AT 80mph WTF!!!!
- TCI shift kit vs. TQ mngt will i have problems?
- Best TC for bolt on 2.73 A4?
- TH-350 Conversion
- Anyone in here have the Gearvendors Under/Overdrive w/TH400?
- my 3600 stall at 2500
- Tranny cooler question...
- Ordering TCI SSF3500, Ed Wright said car should be tuned?
- Problems with converters?
- 4L60E to a 350th swap?
- TH350 vs TH400
- How Bad is this: Autotap Code P1870 Transmission Slipping?
- converters
- trouble changing converters
- My car feels like its choking!
- How does one get a hold of Kevin Winstead at TCI?
- converter lock up switch
- T/C Unlocked vs Locked #'s
- Here's a challenge!
- SS3800, or PT4000? opinions needed
- Most bang for the buck converter. Part II
- tci or transgo?
- Manual Valve body for 4L60E
- Converter Help
- TCI,TCS,Yank......best bang for my buck?
- shift kit or computer editing
- whats faster 6 speed of auto
- Conv. Installation
- Experiences with TCI converters
- TCI or TransGO shift kits?
- How much line pressure?
- HP loss with TC ?
- M6 to T400 shifter install questions
- f body & 5.3 truck same converter?
- Noob help please - new plan of action. A4 2.73 YANKSS36/3800
- Symptoms of Torque management? 98 car a4 built
- Locking Converter?
- Can't stay locked on the Hwy.
- converter question
- stall converters
- TCS you need to step -up!
- TCI SSF 3500 good choice for big nitrous th350/ls1?
- Should I restall or stay with what I have?
- TH 350
- TCS users/ex-users inside please.
- converter experts..ss3800 or pt4000
- Keep the 2.73's? Plan of attack for mods Advice fellow A4ers
- CONVERTER GEAR COMBO QUESTION
- people with the SY3500
- Is the converter going bad?
- GM 4L60E vs. Ford 4R70W
- 4L60E Transmission slipping Any Ideas?
- 4l60 output shaft lat movement..how much
- Need help finding a core. (200-4R)
- Trans brake
- Converter is going south!!! Should i....
- TCC Lock UP Switch
- TCS converter handle being locked up at WOT in 3rd?
- How many lock there converters at track
- TH350 or 400 swap writeup
- Ultimate centrifugal charger converter?
- where can i get the ss grill?
- Loss of power
- Stall break in
- Need part number for TCI flexplate for 4l60e
- got no speedo?
- new car, what do i do first?
- Different input shafts for 4L60E
- Who has fried an A4???
- flexplate comparison pictures
- Built tranny last as long as a stock tranny?
- Aftermarket AL trans pan
- HURST or B&M shifters which is the better one?
- A4 guys: how to dyno the car(keep it from kickin in 2nd)
- Vigalinte torque converter question
- Flexplate wobble...
- TCI flexplate, will it work with a TH400?
- Is this a good idea?
- what did u pay for stall and shift kit install?
- stall converter?????????
- A4 and M6 radiator the same??
- what a difference a transmission makes...thanks fbodytrans
- TCS doing me wrong
- Hot trans...
- trans harness pinouts?
- Converter install problem... HELP!!!!!
- deleting torque management on a stock tranny.
- Signs of a bad torque converter??
- What converter bolts...kinda urgent
- TRAILBLAZER CONVERTER IN F-BODY??
- shift extension question
- Baddest verter for 3.23s?
- whats wrong?
- Need pictures/tips on installing Trans cooler
- Who had to shim up their T400? (Using M6 crossmember)
- Anyone have the DOPE tranny cooler install?
- Vacuum Modulation in 4L60
- Looking for the DOPE Tranny cooler install.
- differences in single disc and multidisc Vigis..
- yank ss3600 or ss3800 for mostly street car???
- Adding a magnet to the B&M Deep trans pan.
- Difference between SS4000 and PT4000?
- Installing Built Trans...What Cooler to go with??!!
- what converter
- What gains from SY3500 to SS4000?
- TCI 3000,3500 guys in here please.
- Got my cmotorsports tranny today...
- has yank kicked precision back
- TCI 3000 or custom? Anyone have these?
- Changing transmission fluid...
- Shifting quick
- Can't get ahold of TCS...?
- Shift extensions
- brake stall ? please help
- What is my stock gear?
- Stand alone transmission computer?
- has anyone installed a tranny cooler that has its own fan?
- Change fluid when?
- Convertor question w/ 350,400 or PG to LS1
- How do you get the speedo to work with a Turbo 400?
- Flexplate install ????'s
- How to tell if my tranny is slipping?
- put 3200vig in and car shakes like hell ???
- New tranny pan?
- Convertor for 427
- more 4l60 shifting q's
- Shifting help
- tranny mount?
- typical gains from vig 2800?
- tci3500 w/3.73
- Tranny power loss
- Questions about Yank 4l60e crossmember
- What the HELL is going on?
- 3-4 Clutches Keep Burning up...........????
- What converter for 422 and occasional spray
- 2.73's and a big stall
- Has anybody ever used the SLP 2600 converter ????
- flexplate is cracked!
- tranny cooler mounting options...
- vig 3600 with new cam
- is there a way to calculate converter efficiency and STR?
- New TCS Tranny is in...Racing tonight!
- Results and impressions between TCS 4200 Vs. TCS 4400
- 4l80e rocks
- Ways to tighten converter with tuning?
- Anyone ever mount a Hurst Quarter Stick in our cars.........
- 4l60 e prob's
- Flywheel lock tool? How to lock flywheel for cam swap
- Best "built" 4L60
- shift kit
- Ford tranny in an F body???????
- Only cutting 1.8's, new converter or gears?
- Tbyrne stall converters group purchase
- what to use on big hp c5 for a trans
- Converter questions
- Transgo and B&M
- Busted Tranny mount?
- 97 z28 camaro
- How much RWHP will you lose with 27% converter slippage?
- No go in 4L60E
- Stall convertor ????
- Dyno on n20 shows much higher rpm vs speed than N/A???
- converter w/ cam
- Tranny chattering on decel
- what do i need to switch from a4 to th350
- HPP3 and edit ?'s
- DTC P0751
- Would I need tuning with a TCI 3500
- TH 400 converter
- High Voltage in Tranny (HELP)
- Stall speed Changed by torque?
- Why does the dyno graph with a Vig 3600 have a flat line?
- Upgrading to a SS36/3800 from a Vig 3600? worth it?
- 2-3 shift problem
- TCI Super Street Fighter 3500
- Whats it worth?
- hpp3
- TH350 vs TH400
- How bad is this: Converter Cycling?
- 99 M6ta swap to a 98camaroauto swap Q
- Flywheel Question??
- Vibration in 3rd
- Help me pick a converter for the new combo :)
- First impressions of my new Vigilante 3200
- won't kick down after gear swap
- Valvoline "MaxLife" ATF - better than standard?
- tranny swap, pinched a wire
- tranny swap
- whos got a pt4400 in a daily driver?
- Who here has had great luck with speed inc stage 2 or 3 4l60
- 1998 ta 4l60e problems
- Best fluid for a race T400?
- Just ordered a TCS Phoenix 4000 Converter
- Post Up,Pros/Cons, How Well Your Built A4 is Working
- LS1 SFI Approved Flexplates IN STOCK!!
- B&M Hi-Tek: Cooling system vs. Super coolers
- Anyone know a convert brand/model that stalls to 5000+
- Help!! Somthing is wrong with my A4!
- PO757?
- stock 4l60E how much hp?
- first impressions of TCS 3800
- NEED HELP WITH SHIFT POINTS (USING PREDATOR)
- what speed in each gear ?
- First time to track with PT4400
- 4L60-E with 3.23's
- Torque Converter
- Vig problem maybe??
- Is it a good idea to use mobil 1 atf in our transmissions?
- Where to order?
- To those that have converted from an M6 to an A4.
- Need Help with TH400
- th400 with od?
- Help Picking Stall speed(TH350)
- Park to Drive problem
- This TCS 4200 ROCKS!!!
- I need your opinion on this!!!!
- Trans shifting early at WOT
- How hard is it to switch pedals? (manual to auto)
- Anyone with pictures of elec connection to an A4
- How much did you gain by locking your TCI3500?
- Stock converter problems on built Trans
- A4 guys, quick question?¿
- problem with trans !
- truck tranny
- Locking converter
- T350 Conversion
- what parts do i need for beefed up 4L60E?
- PLEASE HELP - Built 4L60e pops out of gear at WOT
- What is stock Torque Management setting on 01 Z28
- Flexplates: GM (OEM) vs. TCI vs. Madman
- Take rear w/3.42's out of formula for free???
- lock up conv questions
- Still hitting rev limiter between 2-3!!!
