View Full Version : Automatic Transmission
- need intake vaccum source for th400!
- my th400 decision
- A4 transmission leaks at the rear.
- getting th400, manual valve body?
- Specs on PI Vigilante 3600
- hard to manually shift th400 w/o hitting limiter?
- which to get th400 0r 350?
- more th350 ?'s
- will a th350 bolt right to a LS1? more th350?'s
- th350-400 or flp 4l60e? have to manually shift th350/400?
- Anyone know the weight of the TH400 and T56?
- ABS & Low trac lights on after 12 bolt install...
- TH400 Conversion info needed
- Slave cylinder Install?
- Lighter flywheel in a A4 worth it.
- what tranny's are direct "bolt-in" replacement for the 4L60E??
- Pro 5.0 installed - doesn't feel right
- Want H/C need tranny first... should I bump stall up?
- Front Pump Seal Leaking Since Yank Install: Why?
- Any F-Body with 4L80E?
- help me choose a Tq converter..dyno graph inside
- Auto 2-3 shift bouncing off rev liter at WOT
- Is an A4 to M6 swap a completly bolt in job?
- Transgo, worth it?
- Anyone watch tcc slip speed w/ after market converter
- Thanks Joseph...Gear Install
- Locking the converter on the dyno...
- Converter locks in 3rd, but not 4th?
- I might have been sold a rebuilt yank converter and told it was new
- what converter w/ tnt 100 shot/mti heads cam
- Pinch in my tranny cooler?
- ANYONE,I need some shift point help!!!!
- With 4:10 Gears, what would be one's speed at 6700 rpms in 5th gear?
- Ever heard of this built 4L60E....
- Trans. cooler placement?
- Anyone is Dallas area with a VIG2800 to ride with?
- I've found a problem with the Yank TP4200...
- How much $$$ for an FLP level IV tranny???
- Probs with After-market converters on 01 ls1's?
- How much for gear install?
- Anyone know anything about Neal Racing Converters ??
- Think i blowed the A4 tanny up friday night :(
- anyone using midwest torque converters???
- Installed converter, car feels slower
- Flywheel to crank Pin? (a4->t56 conversion)
- 3200 VIG
- Anyone running an aftermarker torque converter come inside...
- M6 or A4 for bracket racing?
- Anybody Running a Vig. 3200
- ST3800----->PYE3600... Car Slows Down Big Time
- Question for those with Aftermarket torque convertors and aux. trans coolers
- Installing TP4200 this weekend - need input.
- How to install coverter lock up switch?
- Gears w/out converter swap
- Should I get the 3.73's with my converter ?
- TH-350
- TH400 question
- what to do with a4
- Bypassing radiator when installing tranny cooler?
- Comments/Inputs (Converter)
- Tranny temp guage install Qs.
- Should I have a GM dealership do the labor on a A4 to M6 swap?
- Trans-Go's
- Mike at Yank
- Nitrous on an A4 is spraing through shifts ok????
- A4 Head and Cam Cars with Stock Transmission
- TH400 and a working speedometer???
- U Joint question...on a 12 bolt install...
- ? for those with TransGo shift kit.
- help!!!
- Remember Me??? - Yank Problems...
- Vig 3600
- Stall Converters
- Vig 3200 installed!!
- Proper setup and maintenance of a built 4L60E + big converter (discussion)
- ST3500 is in, I love it
- Installation of FLP IV trans question
- HELP! Car doesnt idle right/dies after converter install!
- pump numbers on PI converters
- Transgo going in...
- Installing a line lock
- New Verter need help with shifts
- folks with 2.73's and Vig 3200. What are your shift points?
- 2-3 shift problem with 85mm MAF?
- Any Detroit, MI Ram installers?
- Stupid question, but what is a PYE3600?
- Is my Torque Converter screwed?
- ST3800 Is Out......PYE3600 Is In.....
- 4L60E problems
- Best torque converter for A4
- Pro Yank 3600 For Sale (400turbo/4L60E)
- Car cutting off after converter install
- From a 12.0 to a 12.8 with the Vigilante 3000?? Help
- If you have a TCI converter-HELP
- Converter, Tuning, Tires? WTH?
- Yank stopped making certain converters????
- Stock A4 shift points?
- Help! First day and Problems with Converter already...
- Poly Motor mounts for the LS1 installed
- Im so happy, My FLP IV trans, and VIG 3600 are:
- 4L60E Probs
- How even are your LCA's to the ground? They dont seem even after the 12 bolt install.
- Need your help (RE: FLP IV trans question)
- YANK torque thruster 3000
- Yank ST3500 vs. PY3400E
- Vigilante 3200
- Torque Converter advice needed
- SFI Flexplate?
- Has anyone ever heard of installing the 12 bolt at a 6 degree angle?
- For those of you who have a 3000 Stall Hight Precision Converter....
- Torque Converter Shutter Problems/Grinding
- FLP level IV trans, and VIG 3600 question?
- Lakewood DSL works great with FLPs and 3.5" driveshaft
- STOCK WS-6 DAILY DRIVER WHICH CONVERTER?
- Recommend me a conveter for a new setup (TH350)
- What Converter with my current mods?
- Installed T/C now car stalls
- Trans was acting up...removed vigilante converter and now seems good???
- Yank ST3800 Non Lockup - Part2 - Help
- Parts install
- VIG UPGRADE
- Installed but not tested (Poly Motor Mount)
- Filler Tube O-Ring Busted on A4, Can't keep Tranny Fluid In! Help?
- M6 or A4?
- Anyone ever try a B and M holeshot 3000 in a 4l60E???
- vig3200 vs. ST3500
- The true story of Yank's Transmissions
- Noise after 12 bolt install,need idea's
- M-6 to TH350 swap?
- Is there anyone here actually running a 700R4?
- th400 have to manually shift? better et?
- Computer ?? about A4 to TH400 swap
- Tranny Cooler ?
- my 4l60e trans went south, need new one
- Anyone have a Hughes converter?
- Just installed new verter, Car wont move!!!
- I've Had It Up To Here With My Yank - Help (Long)
- How long should a shift take A4
- PT4000 vs. SY4000
- what is up with my a4?
- trans cooler ?
- SY3500 vs. ST3500
- need 4L60E to handle 450-470 HP-H/C 99TA
- How to hookup 4L60E trans lines @ transmission???
- Please help, shift points problems
- vig or yank
- Vig3200 guys take a look
- TH400 crossmember for free
- Is a Hughes 3500 Stall any good?
- Tips for installing Pro 5.0???
- Problem after B&M Tranny Cooler Install
- Yank 3000 for LT1
- Torque Converter Lock-up Processor?
- ? for those with aftermarket trans coolers
- Help Please-->Converter flash/shift extension
- Please help --->>> why does my a4 keep blowing up
- converter ?
- Hit the limiter on the 2-3 shift (A4)
- Cracked Flywheel on an A4
- how much $$$ and details going from M6 - A4?
- A couple of questions after converter install
- ST3500 INSTALLED TODAY !!
- A4 not completing the shift correctly.
- How much fluid do you put in converter????
- Suggestions for proffessional gear install...
- Yank ST 3500 Opinions Please
- 12 bolt install...are they truely bolt in???
- getting torque converter for 2002 Z28
- Trans go shift kit, does it really promises a long and happy life for my tranny ?
- What driveshaft loop are you FLPs/3.5" driveshaft guys running?
- frag me if you will: what is a torque converter?
- Update on converter chatter in OD.
- Transmission flush
- reverse lock out solenoid removal?
- Vig 3200 gas mileage losses.....
- Buick/Pontiac style TH350-will it bolt right up?
- Who sells a 4l60 pan with drain plug?
- I'm not going to use a M6 harness for my A4 to M6 swap. (What's gonna happen?)
- Synthetic or Regular in your A4 with a YANK converter
- Help me pick a Converter!
- How hard is it to install a converter?
- Is there a bearing in the tailshaft of a 4L60E????
- Convertor Bolts
- Converters......whats what?
- Used torque converter
- 1-2 Shift Solenoid location and part number?
- Second thoughts on my converter choice
- How much should my 3.73's cost installed?
- 3.73's and what converter????? HELP!!!!
- ST 3500 Install/SLP LT's
- Stock shift points on 4l60E .
- torque converter.
- A4 trans line adapter ?
- TCI converter 1/4 results
- any body have a clue what's wrong with my tranny? A4?
- ST 3500 Install
- installed my Lakewood driveshaft loop today
- 3.42 In a TH350
- Finding gears and install for a good price?
- Anyone here of problems with torque converters and 2001 cars?
- An install document for gears?
- (NEWS) 4L60E Transmission shields should be available by end of year
- Please tell me I don't have to pull the rear axles to install longer studs!!
- New Vig 3600 installed
- BMR K member installation.. came with no directions
- Rebuilding a 4L60-E
- TH400 questions please help.
- SES after Vig 3600 install, whats the problem?
- vig 3200 and tranny oil, help
- Anyone ever hear of Torco Converters?
- NEED help, thinking about installing gears ASAP
- Tranny cooler? In series or seperate from stock cooler?
- Vig unlocking... HELP
- Installed a TCI torque converter.sad&happy
- Question about auto tranny fluid......
- RAM 980 Installed!
- how is na performance of st3500 vs pt3800e?
- Vig 2800 vs ST3500
- Bad vibration after Ram install.
- TH400 question
- Can someone explain the Yank adapter plate to me?
- how is the na performane of a yank 3600e
- SY3500 to YTP4000 with 3.42's?
- Trans Cooler mounting
- LS1 Flexplates
- How much will a vig3200 improve my 1/8 times?
- ?? 00' A4 swap to 98' M6 ??
- Rebuilding a 4L60E any advice?
- Radical A4 Idea
- Bad wheelhop after Y3000 install...LCA time?
- Could an engine lockup damage my A4?
- Vig 3200 or Vig 3600??
- Trans cooler pics needed
- VIG 3600, hooker LT's with true duals, underdrive pulley, lid, free mods, with 3:42's
- Question regarding stall and gearing..
- Converting car back to M6 from A4 What other parts do I need?
- 3.42 to 3.73 in an a4
- ***Converter Question***
- vig 3200 question/possible issue
- Need help installing Mcleod Adjustable master ASAP!!!
- Gear install?
- A4 Q, 2nd gear firmness
- 4l60-e servo
- NEED HELP!!! Just installed a McLeod single disk and adjustable master cylinder...
- How big a difference in normal driving with a vig3200 and a vig3600???
- Best Converter
- Need bigger stall for highway racing M6's?
- Vig 3600 question
