PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 [160] 161 162 163
  1. Need bigger stall for highway racing M6's?
  2. Vig 3600 question
  3. Difference in TH400 mount and 4l60e mount
  4. How would a SY3500 feel with a 3.15 rear
  5. How many people here have broken TH-350's/400's?
  6. 4L60E to T56 swap info for you who need it.
  7. b&m converters
  8. Flexplate for TH400 swap
  9. converter for H/C-N20 with th400
  10. How does the stall converter work?
  11. 4l60e buildup quote
  12. Quick A4 question
  13. no wimpy T.C. for me...
  14. Which converter H/C/I/Nitrous setup???
  15. How quick/how much power do you think the 4L60E will take?
  16. Installed my Pro 5.0!
  17. Effect of aftermarket converter on tranny?
  18. Horrid A4 shift points
  19. 4l60e a4 the same trans in 95 s10?
  20. How much does it cost to get a Torque Converter Installed?
  21. Custom programming and manually shifting an A4?
  22. Yank converters
  23. Going from a M6 to a 700R4. Need a little help.
  24. 4L60E/4.10/6200 rpms/26" tires/3rd gear
  25. Which is looser: SY3500 or ST3500.
  26. Why don't more people have PT4200s or PT 4000s?
  27. Trans Temp???
  28. Comments on the Mega Raptor 700R4
  29. Stall Convertor?? What???
  30. TH400 dilema
  31. Vig3600 to much stall!?
  32. A4 for M6 swap, anyone interested?
  33. cooler with converter? and lockup questions
  34. 382-436ci cars, what CONVERTER are you running?
  35. Has anyone tried this 4L60E mod yet? let me know what happened
  36. Yank Converter Durability???
  37. I need help picking a converter????(kinda long)
  38. T56 swap questions....from A4 to M6...within....
  39. 4L60E Troubles
  40. Vig2800~3600 restall
  41. Yank 4L70, manual valvebody, no 2nd gear
  42. Torque Converter
  43. Can u lock up a Yank?
  44. PYE3600 car converter in a truck question
  45. Worth going from Y3000 vs. ST 3500??
  46. vig 3600 restall questions????
  47. Question about Transgo shift kit
  48. Racing tips - PLEASE! - ST3500...
  49. What fluid to run with yank tp 4000
  50. Anyone wanna trade their M6 for my A4....with a twist....
  51. New FLP Level IV in, still having problems..HELP
  52. swapping stock A4 and M6 rear ends
  53. Newbie: 3.73s or 4.10s on an A4???
  54. how much to go from A4 to an M6
  55. Please help!! Converter wont downshift!!
  56. Whats up with Yanks website?
  57. Thinking about a new converter/gear combo...opinions please.
  58. Trans Go guys, I have a ?
  59. Issues w/ installing MCLEOD ADJ. MASTER CYL.
  60. 4.56s installed! - and a broken tranny :(
  61. Vig 2800 or 3200 for LS1 with 3.73's and NOS? Help please!
  62. What's the current turn-around time for a Yank converter?
  63. Vig3600 w/ 4.10's????
  64. Tranny temp???
  65. Last converter question!
  66. Vig3600 vs. YTP4400
  67. Why do thruster pros not run well....
  68. Tightness: Vig 3600 vs. PT4400
  69. where did all the vig3600 guys go
  70. What do you think about TCI converters?
  71. Convertor chatters like hell going into OD
  72. Converters....
  73. Tried to get an LS1 SFI flexplate - but BAD experience with Reactor products
  74. **Comment on SY3500 with 3.42's**
  75. What mods do I need for a big converter? or what converter for these mods??
  76. trouble launching with converter
  77. Installing 12-Bolt
  78. Converter Suggestions
  79. What converter with 273 gears???
  80. Torque Convertor for my truck???
  81. what should i get a ST3500 or YPT 4000
  82. YankSY3500 with 3.73's vs. YankTP4400 with 3.42's.
  83. What cooler for the daily driven SY4000 in Colorado weather?
  84. Do I need an install kit for gears if I'm not doing it?
  85. trans Cooler placement ...Dope VS others
  86. A4 M6 swap if I own both cars???
  87. For those looking to install a 1LE trans mount on a 2000
  88. Ok pick my next Yank
  89. idle problem after converter
  90. Vig4000????
  91. Question for people that have installed T/A Girdle
  92. Yank Tranny Trouble.
  93. gear install prices
  94. Help! Need to figure out the stall speed?!?
  95. Why High Stall Converters Rule off the Line! :)
  96. st3500... looose
  97. Anybody still runnin their 2:73s with a converter?
  98. Normal Tranny operating temp with Moroso cooler and stock verter?
  99. A4 guys: Sometimes my tires chirp & sometimes they don't from a low speed roll. Why?
  100. new 3.73's installed and..
  101. SY3500 vs. PY3600E NEED HELP!!!
  102. ARP Pressure plate/Flywheel Bolts ?
  103. TH400 leaking problems....HELP.....
  104. Need convertor webpage
  105. Advice wanted: Wuss converter
  106. Torque Converter for '01 C5???
  107. Edge Racing Converters
  108. please help:having problems with my tranny and the yank converter..explanation inside
  109. Transgo Shift Kit or B&M Shift Improver
  110. BIG problem... dealership and other reputable repair shops can't figure this out...
  111. Questions for guys running Vacum controlled 4l60e---->
  112. A4-M6 swap, questions
  113. a4 flexplate
  114. HELP NOW! Random Tech 12bolt Install
  115. ST3500 now... What the next STEP UP?!
  116. whats the best way to adapt a TH400 ?
  117. who has t400 trans? t400 or flp 4l60e?
  118. Anyone buy just the 4.10 ring and pinion and have a good shop install?
  119. Impressions of the Ultra Thruster 4600
  120. Will The Yank Stealth 2600 Torque Converter Do Much?
  121. which converter?
  122. At what MPH does A4 shift at ?
  123. Any '02 owner with converters have any problems?
  124. Will I be hurting myself much with a 3000 stall with this set-up?
  125. Typical install time for a 12-bolt?
  126. ST3500 goes in today...
  127. Does anyone have a A4 with 3.90s?
  128. Funky Idle after Converter install
  129. Question about Yank PT 4400
  130. Ultra Thruster 4600....
  131. whats the difference between the 4l60 and 4l80
  132. I found a problem with GM pressure plate....Revlok-II/Star people take note
  133. anyone have pic of randon tech torque arm installed
  134. REALLY ROUGH CONVERTOR SHUTTER
  135. ST3800 v ST3500
  136. P0300 code- Can this be from a converter please help
  137. Need Help: How to install a 01' slave in my 00' Z-28?
  138. buying and installing synchro's?
  139. would like to thank and Recommend FLP
  140. Getting 4l60e refreshed, what should I have done to it while it's under the knife?
  141. NEW CONVERTER----->On the way!!!!
  142. would it be okay to remove the "guide pins" in the flywheel upon re-installation?help
  143. 3.73 or 4.10 gears in a A4?
  144. A4-M6 swap...whats needed, anybody interested?????
  145. Who's got a ST3500?
  146. T350 vs T400 vs FLP 4L60e
  147. Built 4L60E tranny problems
  148. Stock torque converter shift extension?
  149. NEED 97 4L60E TRANS CASE
  150. M6 TRANNY COOLER
  151. Vig2800 ?
  152. Need some info on the Ultra Thruster and the Ultra Yank
  153. Front pump seal keeps failing with my Yank 3500 Converter.
  154. Ram VDS installed today---Chatter's...
  155. Discussion on Gears and A4's! (everyone give your 2 cents)
  156. YANK?????
  157. Which A4 Shift Kit?
  158. Question concerning installing 4.10 gears in A4
  159. Transaxle for mid engined installation
  160. 3.73 cruising in an a4
  161. 4L60E rebuild list for 500HP?
  162. 4l60E help
  163. Best converter for a 40 mph punch?
  164. SY3500 or SY4000
  165. Vig3200 or SY3500
  166. Tried out the converter finally
  167. LS1 Flexplate (for ls1/th400) - broke my stocker :(
  168. St3500 or Sy3500
  169. difference between PI3200 and SY3500?
  170. Have some converter questions...
  171. Trans Go install. How many washers?
  172. The elusive a4-m6 swap... alright WHO has done it!?
  173. Who's had shift solenoid problems?!?! I can only use 2 gears in my tranny
  174. What to torque Deep trans pan bolts to on a TH400?
  175. Difference in 93-97 and 98-02 torque convertor
  176. Anybody Running a ST3500 w/ 3.42 gears...
  177. What could be causing my car to fall on its face on the 2-3 shift
  178. ST3500 and transgo?
  179. Vig 2800 w/ or w/o cooler
  180. torque converter install
  181. vig 3200 power braked & moves @ 2500rpm?
  182. best converter for n20
  183. Tranny cooler location
  184. TA install on 10 bolt, need install specs:
  185. ST3500 didn't cut anytime off my et
  186. Who is running the B&M shiftkit or Transpak for '98 up 4l60e?
  187. A4 I think its done shifting, need rebuild advice
  188. ? about installing TransGo shift kit?
  189. Adding Yank ST 3500 ?
  190. 4L60E torque converter lockup switch install
  191. Raising line pressure "free mod"
  192. Need any pics of trans cooler install- trans temps are heating up
  193. ? on installing tranny temp gauge.
  194. please help- trans temp 210 with b&M cooler & ST3200
  195. wont do the 2-3 at wot in drive...
  196. Converter vibrations
  197. Converter for 200 - 250 shot?
  198. A4 starts in 3rd/ help
  199. HELP... Servo cover on A4 popping off?
  200. tranny cooler install
  201. Raising the stall of my converter?
  202. Torque Management w/ Transgo
  203. Tranny?PCM?Stall?
  204. k....where does the tranny cooler return line go?
  205. Chime in guys.... Buddy has 99 TA A4.. wants a stall
  206. Is the Vig3200 good w/ TR224?
  207. Just installed my Kirban shifter and.....
  208. Stock cam (02') with SY3500 - Keep 3.23 or get 3.73??
  209. Free Mod - Firmer shifts for A4's??? OPINIONS???
  210. A4 rear seal, I'm on my 2nd one, someone help..
  211. How much mph will a converter knock off
  212. which tranny cooler will fit if i have the SLP CAI
  213. Guys with Speed Inc 4L60Es, or any vacuum modulated 4L60E...
  214. Should A4 downshift when braking?
  215. Installing a new torque arm
  216. Tranny cooler on stock convertor?
  217. Bolting converter to the flywheel??
  218. anyone selling a flp tranny?
  219. Transgo Guys - 1, 2, or 3 washers?
  220. Race prepped 4L60E. Which one to get?
  221. It seems like there should be a way to tap into the factory tranny temp
  222. crazy vibration after shift kit install
  223. vibration after torque arm install....pinion angle or driveshaft issue?
  224. Updated-Tranny hesitates 2-3 shift at WOT.Why?
  225. Matching converter to bigger cam?
  226. Yank Y3000 users, come on in!
  227. Gears install help
  228. Best time to lock the converter?
  229. Can a stock A4 handle this?????
  230. SY3500...anybody have it?????
  231. Converter causing weird ( low ) idle?
  232. Is a 3200 Stall to big for me?
  233. ?'s about changing converter lock up mph.
  234. Converter question - effects of vehicle weight + torque
  235. I should be a drivetrain moderator with all the converter questions I have asked.
  236. 4L60e Interceptor - Same as shift kit?
  237. Dallas area SY4000/3:73 owners inside.
  238. help me set my shift points
  239. Calling all guys with a Pro-Torque Converter!!
  240. 4L60 or TH400
  241. B&M 19000 gvw supercooler...
  242. 2nd - 3rd change shifts to high in a4
  243. Is it possible to get too big a converter?
  244. CONVERTOR QUESTIONS ?????
  245. 2-3 shift hits rev limiter/ why?
  246. 4L60E tranny cant hold up , whats next?
  247. Will a A4 out of a 2001 work in a 2000?
  248. help . . . after shift kit install, tranny's gone insane
  249. FLP STAGE VI???????
  250. irratic idle after vig 3200 install
